- Done the searching and no luck...
- h22 type question
- type-s intake in an h23, question
- All Gaskets and Parts when changing Timinig Belt
- Acura CL2.3 (F23A) Anybody know the gear ratios for this bad boy?
- Ebrake Adjustment
- base shocks bolt up 98 SH
- 5pd tranny
- recomended h22 builders
- OBD2 H22A4 motor into OBD1 H23 wiring harness.
- Battery going dead???
- crashy crashy.. need advice
- G series guys
- H22 TRANNY LEAK?
- ATTS Question
- h22
- Tail Light
- 1992 Honda Prelude SI 5 speed 1650.00
- 1988 2.0Si passenger side vibration.
- no code but a cel???
- what is the website
- !!##big problem with instrument panel and tail lights! No Illumination!##!!
- H22 auto to H23 manual timing tesioner.
- ignition timing Q's
- H23 turbo question (searched)
- engine makes this clunking noise when I'm in a low RPM 2nd or 3rd gear
- type-s cams
- which way i'm confused.
- Exhaust Rasp?
- Name brand parts on eBay...
- o2 sensor?
- how to rewire a 3 wire iac?? (searched)
- Do i reeeealllly need to do this?
- Warning to those with Balance Shift Removial Kit
- Need '85 Fuel Pressure Regulator for 1.8 Dual Carb
- Does anyone know where to get drilled/slotted rotors for 2Gen Si?
- Possible swaps for 3rd gen prelude.
- obd2 to obd1 info
- check engine light with push on gas
- Tire wheel size reading.....need some tires
- how long have u had ur turbo kit?
- SKunk 2 Stage 2
- What Internals?
- Battery in the trunk....
- Knock sensor help
- Honda Prelude SH suspension question
- whats wrong with my clutch/transmission?????????
- Returning to stock susp. Woes!
- should i go higher compression?
- Getting Oil Out Of Coolant System
- Custom Crankshaft
- What head gasket to run?
- H22 build?
- fluid spewing every where what is it DAMNIT
- What is the most cost-effective way to buy all the necessary parts for changing my timing belt?
- quick control arm question
- 3 spoke steering wheel
- adjusting clutch, brake, and gas pedal height
- Coolant plug wires all mixed up and not the right length
- Do any 3G lude parts fit on a 2G?
- H22a build NA
- wrecked my prelude
- How many miles on your ludes???
- For the Mugen lovers...
- easiest way to locate shift linkage?
- Alternator
- Leakdown Test Results: Would Like Some Feedback
- how much power can u get from a H23
- What ecu to use...
- Flywheel
- removing tranny, cant put car into reverse
- what odb?
- H series tranny
- What size injectors for my turbo h23a motor?
- Problems installing 5zigen cat-back for SH
- time for a new exhaust
- suspension cross member problems
- Front Sway bar problem
- f20b or h23vtec A
- crower stage 2 h23
- external coil question.
- quick fix for race B pistons into A block
- need advice on what to do about clutch
- lookin for 98-01 Honda Prelude Automatic Tranny
- 98 honda prelude automatic tranny problem ??
- best replacement radiator for a 4th gen si?
- ABS - incompetent garage - THEIF
- Knock sensor readings on SAFC
- Not sure what alarm system to get for my H22
- 96 prelude w/ 94 h22a running obd1, want to run obd2
- H22 Head Torque Value???????
- will 5th gen stock shocks fit perfectly on a 4th gen?
- Noob
- Anyone know if SH door panels will bolt onto a base door?
- Need some help with H/F-series piston info. *Searched*
- Tein Suspension
- Just had the Clutch/flywheel replaced
- Mystery h22 tranny help with gears
- H22 Turbo or na my block
- 1995 SE ABS problem
- wut kind of JDM or OEM Honda Steering wheels fit the 5th gen?
- 4WS question
- Dead Radio
- 93 lude won't start
- 4th Gen. Prelude / Headlights/Marker light disassembly.. help
- 1992 2.2 VTECH Front Brake Discs?
- jdm lsd gearbox
- sooo happy(not tech related though)
- Will Paypal 10$ to the guy who helps me fix my problem! Idle/running issues (95 vtec)
- DIY intake?
- Searched everywhere msd blaste 2 coil....why is it not working good?
- Based on this dyno plot what vafc2 settings?
- engine leak
- Official Prelude Video Thread
- cheap way to increase fuel flow/pressure for my turbo
- Any one with the h22a experience this?
- Did you know this about the gen 4's
- 99 prelude timing marks
- H22 A/C Delete - Which Belt
- strange idle
- Air in coolant lines? Bleeder screw?
- Need help installing ignition box and coil (already tried to search)
- Stereo / Sub / Amp wiring issues
- would a 4gen valve cover fit a 5gen ?
- New Buddy Club exhaust for 5th gens+
- how many turbo guys are running stock head gasket
- Front Sub Frame
- Trying to bleed slave cylinder
- Greddy Evo 2 Exhaust
- sources to get 4th gen lude urethane kits plZ!!!
- Hazard Fuse
- Mugen Steering Wheel
- Turbo Gasket
- I am thinking about getting a 5th gen lude got some questions?
- HELP!!! 5th gen owners
- Lack of info on the type s piston is really pissing me off...
- h22 sleeves
- Need help with tranny swap in a 5th gen
- seibon lip install tips?
- looks like my antenna took a crap on me
- Front Suspension on BB4
- 4th gen. el gauge swap???
- Can I skip the AC Pulley
- Hondata IM Gasket/Euro-R
- h23 block with h22 head
- stupid question dont know what to search for !
- OEM Wheels - Blades (5 star curved). Good condition with tires. $275.00 pick up in San Diego.
- OEM Hood - Black - 97-01 Prelude - $100 pick up in San Diego
- 5th gen h22A4 engine removal and installation
- HELP: installing autometer tach/ where do i hook the wires up to
- Headgasket??? what else could it be
- auto tensioner question..buying new one?
- air filter?
- Need rear upper control arms for 98 prelude base
- head gasket H23vtec....
- h22a4 belt question
- 5th gen prelude race car and some new parts for U.
- WS2 vs. SMH
- OBD gurus: JDM OBD2B ECU + JDM OBD2B Motor + USDM OBD2A 5th Gen Shell = ...?
- h23 to h22a4 swap issue
- 98 running very rich, slow and burning oil
- h22a4 noise & funny idle
- customIZED?
- 4th Gen Knuckle Question
- crower stage 2 camshaft with stock idle vtec lobes?
- I have a '93 H23/Vtec I bought a year ago
- My cousin's eclipse GS intake sounds so much deeper..
- Stereo CD player problems on 99'
- Learned (the hard way) a couple of things about 2gen trans...kinda long.
- Prelude compatability INJECTORS, DISTRIBUTOR, ECU's
- drive pulleys
- Question about replacing distributor for jdm h22 swap...
- car not cranking over need help
- Fog Lights on a 4th gen
- Intake Control Solenoid Valve?
- 2 questions....
- can you put the newer prelude gauge cluster in a 92prelude?? or can u put a type r in a prelude
- V-tec Engagement
- 4th gen axle problem
- bad ecu? knock sensor issues
- apexi dunk exhaust...
- problems and more problems.....
- what causes bad knock sensor?
- muffler for 97 lude
- h23a head problems
- jackson racing supercharger
- Exhaust Silencing
- Check out my new H22!
- Tires
- Need '85 Honda Prelude Air Cleaner Base with Main Jet Solenoid
- RSX seats in a fifth-gen Prelude
- 1990-91 prelude parting out whole car!also 1992 prelude parts
- headers
- Some noise i'm hearing - pissing me off.......
- Performance question
- 90 Prelude ATF question
- O2 sensor keeps failing
- Front bumper resonator removal = bad MPG
- Camber kit problems
- the sickest manifold ever!
- Eibach Sportline on a 4th gen fits a 5th gen?
- Anyone got Installed Nitrous pics?
- MSD blaster ss coil.....?
- 4 gen cluster conversion question
- alternative Please
- Question about BASE prelude 5th gen
- what the best way to break in a new motor
- how do you install a pro drive oil pump gear
- who makes a good clutch for a prelude for 450-550whp
- how do you install a lsd in the tranny
- Add a passenger airbag
- Vtec conversion time?
- Iac block off?
- switching the vtec head?
- 260whp h22 do u think i can do it
- window doesnt work
- suggestions for a 94 lude buildup
- ok to run 205/65R15 studded snows?
- idle gets stuck at 2k after driving for a while
- correct install of ebay coilovers
- Low Compression h22 9:5:1 with a Fat Turbo
- Is my engine salvageable?
- all season tire choice 5th gen.
- Prelude engine
- 1999 Prelude..Help...Want to achive 350 FWHP...Making part list need opinions
- Best lightweight wheels
- 87 lude tranny prob
- I Accidently Popped the Rear-View Mirror Out: now what?
- JDM Headlight Confusion
- question about 94-96 console
- Basic Newer Model Prelude Question
- What springs to go with Bilstein sport shocks for 2001 Prelude?
- Need help removing indiglo gauges
- F22b Vtec Head
- A couple of issues...
- Car stereo choice
- New Antenna Motor
- Cheap parts????
- 92 W/H22a swap NEED HELP!!! wont fire
- balence shaft
- Euro-R IM/FI
- The Best Car Covers? Suggestions?
- Rear disc brake piston problem for H22
- vtec problem
- F22 crank final verdict
- OBD II Code P0118 Help
- head swap as simple as it sounds?
- lightened flywheel
- noob
- headlights stuck
