PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Removing stock '94 Honda prelude radio
  2. problems with the digital gauges...
  3. oil light!
  4. shakes in neutral
  5. h22 type s pistons with stock usdm head gasket"
  6. Please help, F22a1 head to F22a4 VTEC Mini-me. LOTS O QUESTIONS!
  7. 4WS question
  8. over heating trouble
  9. lost all the bolts for my auto to manual swap
  10. Anyone else having this problem ?
  11. Oil on plug threads
  12. Do I need a camber kit? General alignment related.
  13. Help with internal ignition coil
  14. Need ECU for 00 Prelude Base Auto
  15. Input Shaft Bearing: $475 to replace????
  16. jdm H22 help
  17. 5th gen pictures of 3 local Ohio preludes
  18. 98 prelude sh t-belt problem
  19. Bump stops for my prelude
  20. Changing my dash color!!!!!!need some advice
  21. h23 motor/ h22 trans
  22. Where Does This Bracket Go?!
  23. Help regarding my exhaust system.
  24. KYB AGX and Tein S-Tech
  25. h22 swap, harness issues!
  26. H23 oil burn, good leak down, new head
  27. H23A OR H23A3!!!
  28. stock base wheels
  29. Does the inside of a 97 H22 atts tranny fit in a 97 F23 tranny casing?
  30. valve lash problem..
  31. A way past crank sensor on BB6?
  32. how much would u pay for my lude....
  33. Voltmeter Readings
  34. IACV? vacuum? need help please.
  35. Timing Belt Tension?
  36. New radiator Weird fittings?
  37. Help with CEL code 12 - EGR
  38. 2001 prelude cel issues
  39. JDM H22A Timing Belt/Water Pump
  40. Brake lights stay on continuously?!?!
  41. check my oil clearances - h22
  42. H23 stalls after 3500 rpm and won't go any higher but can drive around 2500rpm
  43. Brake, Brake Lamp, and ABS Lights are lit up (92 Prelude SI)
  44. differances in coolant temp sensors
  45. How much do yu think this damage will cost?
  46. umm trial user again?
  47. How do i fix the leaking vtec solenoid on my 98 prelude sh?
  48. identifying h22
  49. rd. generation prelude appreciation thread. post dem pics!
  50. Moog adjustable upper ball joints... Anyone used these?
  51. Texas Luders?
  52. 2.2L 2.3L Radiator Differences?
  53. tsb 00-090
  54. map sensor problem
  55. HAHA
  56. prelude shaking while in neutral, please help
  57. h22 turbo
  58. fuel running rich on my pprelude
  59. how do you paint calipers
  60. question about f22 wiring harness with h22 engine
  61. Ecu
  62. brake lamp light and srs
  63. civic steering wheel?
  64. h22 balance shaft timing issue
  65. Oil Light
  66. 92-96 & 97-01 header compatability
  67. H23 <--> H22 Rear engine mount bracket compatible??
  68. A/C question
  69. Car won't start after engine is cut off when warm.
  70. do i need new fuel pump with h22 swap??
  71. I'd like to know which is the correct way for Head gasket install?
  72. just got my first cb7 with H22 prelude engine
  73. Mechanic has changed timing belt twice in 2 weeks and cant fix problem
  74. H22a Crankshaft Pulley Bolt
  75. h22a4 dizzy?
  76. help with ecu pinouts obd1
  77. would a H22a4 SH tranny fit on h22a1?
  78. H22 Tranny to F22 Tranny
  79. 4G Models worldwide
  80. Oil Pump Seal leak problems h23a obd2
  81. overheating issue
  82. 97-01 ex manafold fit to a 4th gen
  83. oil light!!
  84. What engine is this oil pump from
  85. Good site for JDM Honda specs
  86. Pink Key
  87. 4th Gen non-USDM Helms Manual link
  88. Honda Regional / Area Codes
  89. My clutch is gone......
  90. Questions about hids on my prelude
  91. 93 prelude swap questions h23 dohc to f22 sohc!
  92. Windshield wipers not moving
  93. Vtec solenoid installation
  94. 91 si question
  95. bb6 exhaust question
  96. Type sh block
  97. Still can't fix suspension issue
  98. MAJOR oil leak
  99. enigine advice please:)
  100. need a b21a engine for my 90 lude si
  101. jdm side markers
  102. Bouncy
  103. Mystery intake manifold
  104. Idle Fluctuating problem; 1996 Prelude
  105. Fuel Problem!! Help please!
  106. Need help finding a downpipe
  107. H22a1 Piston In An H22a4?
  108. O2 sensor wire color?
  109. VTEC Exhaust Shield - removing bottom bolt
  110. Anyone have EuroR/Type-S/Sir-S swap?
  111. Noob question about my rotors...
  112. Oil Control Orifice
  113. volt gauge hook up
  114. air/fuel guage reading?????
  115. Chassis Tech Adjustable Upper Control Arms....anyone use them yet ?
  116. mant to build h22, Help
  117. engine trobles
  118. H22A valve adjustment problem
  119. 5g JDM ecu pin-out
  120. Car Not Getting Fuel, Crazy problem.
  121. still having issues with wheel hop
  122. h23 tranny on a H22
  123. Power Steering problemo
  124. throttle body blues
  125. Fuel Pressure Regulator question
  126. Cooling problem, possible water pump?
  127. Sold the Prelude
  128. how do you remove front speakers
  129. engine going richer during track session h22a/p72
  130. Car wont start! fuel problem!
  131. Best place to buy front and rear upper control arms
  132. help me.
  133. Carbon fiber vinyl
  134. H22 injector size?
  135. obd1 ecu now car wont start
  136. 5th gen front shocks base/SH?
  137. dumb h22 question
  138. Timing belt shredded
  139. fuse questi0n
  140. rywire sub harness question
  141. oil filter
  142. Altenator belt squeaky
  143. Tunning Question
  144. crank pulley help
  145. ticking noise on left side wheel
  146. Suspension problem?? Help
  147. 99 Prelude transmission problem
  148. 97-01 prelude suspension
  149. To Resurface or Not...
  150. h22 and h23 throttle body size
  151. still have overheating problem. Advice Please
  152. Changed the breaks... no more four wheel steering and abs came on
  153. TB Issue
  154. 5th GEN Vanishing OIL help
  155. h22 keeps on bogging
  156. h23 dohc swap to f22 sohc vtec not working !!!!!!!!!
  157. Problem with Hydro Clutch
  158. oem interior replacement
  159. Can Manifold Work?
  160. 92-96 OEM Exhaust/Muffler Question
  161. i have a motor swap question can anyone help me?
  162. Any info on Fujitsobu H22 header
  163. Car dies when I stop, could it be my 8lb flywheel?
  164. Turbocharged RWD H22
  165. Power locks and keyless entry not working
  166. 5th gen stock, engine Q
  167. Need prelude tow hook pattern
  168. help! my h22 cuts out at high revs
  169. 1996 Prelude - Idles up and down [Advice/Help]
  170. 4th Gen 5-Bolt conversion: Parts? (Searched)
  171. Help me fill in the gaps, 5G models worldwide
  172. 1999 Prelude SportShift 1-2 shift flare problem...
  173. Water PUMP not sure??HELP
  174. What should i get first????!!
  175. Hytech Replica and O2 Sensor CHAOS
  176. main relay problem or is it?
  177. Coolant temp sensor / temperature sender problems
  178. still no vtec.
  179. External coil conversion
  180. whining noise after complete tb change
  181. Gas and Temp Gauge Dim away when turning on head lights
  182. header advice
  183. 94 honda prelude front headlight
  184. Oil Leak Help
  185. pro/cons of closed deck(h22a/1)Vs.Open deck(h22a4)
  186. CYP sensor gone bad.
  187. Balance shaft re-install
  188. axle stud size????
  189. Crank pulley mess
  190. INTERNAL OR EXTERNAL COIL HELP
  191. I need your opinion: OEM or after market crank pulley
  192. Removed FITV but idle still increaes when cold?
  193. what are you guys running?(swaybar)
  194. desoldering knock sensor circuit
  195. how many people have trouble with 4ws
  196. stock prelude 1/4 mile
  197. Problems starting sometimes...
  198. P.S. Pump not working!
  199. No brakes, already bled them, help please!
  200. Misfire or is something else happening?
  201. What Kit is this?
  202. B21a1 exhaust mani bolt pattern
  203. H22a and Skunk2 Cams
  204. manual knob onto auto 5th gen
  205. F20B into 97-91 prelude
  206. Oxygen sensor question
  207. 1990 Prelude AC problem
  208. oil squirters h23a
  209. D4 light blinks no error code tossed.
  210. h22a1 question
  211. coilover fitment
  212. Prelude Question
  213. Replacement Radiator
  214. H22A4 what plug is this? (97-01) not starting
  215. pos
  216. INJECTOR CC's QUESTION
  217. Clutch vibrates, won't disengage, help!
  218. is this statement true?
  219. getting a prelude need some info please
  220. My bumper is still turning black
  221. jerking through gears
  222. will this engine an tranny work?
  223. 10,5-12:1 pistons
  224. enkie rpf1's 17x9 on 01 lude
  225. h22a too slow!! v6!!!!
  226. Oil pump gasket?
  227. Unknown clutch issue...
  228. Wtb Prelude Body Panels
  229. Car stalling.....rough idle
  230. 99 Prelude not starting after motor swap.
  231. jdm h23a vtec won't start
  232. code 9--- cyp.. @@@help please@@@
  233. Watery-oil in the chamber, blown head gasket or not....
  234. h23 broken rods
  235. Aftermarket Prelude Motor Mounts?
  236. S2000 throttle body idle
  237. boost stock prelude
  238. Just hit 200k on my lude (video)
  239. 92 si Lude injector problems
  240. fans on all the time, wire damaged help
  241. 1992 prelude radio code
  242. looking for advice(pads and rotors)
  243. GC Qustions
  244. 5th Gen Prelude Spare Tire Cover/Cardboard
  245. Prelude 97-01 Type SH with 11.5.1 compression-Question?
  246. just did a valve adjustment
  247. MSD Digital 6 on 01 Prelude
  248. 4th gen camber kit question?
  249. vacuum hose placement?
  250. Minor Misfire...HELP!
