PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 [240] 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Type s pistons (oversized??)
  2. Help on USDM 4th gen headlights...
  3. Injector purchasing
  4. Finally got around to dynoing again & dragstrip complaining
  5. Turbo
  6. need help on ignition and fuel for h22 @ 15psi...
  7. HELP cant pass emissions
  8. how much juice does it take?
  9. back from the 1/8 mile track
  10. replacing a head gasket
  11. firing on 3 cylinders
  12. These pistons good addition for my setup?
  13. jdm h22 in a 4th gen has a real bad miss when vtec comes on and runs lean after
  14. is there a Difference in f22 fuel pressure regulator from h22
  15. Can a 97 SH motor be pulled from the top?
  16. Putting the lude back together help
  17. b20a6?
  18. BOTTOM END CRANKSHAFT QUESTION ???
  19. Exhaust fumes
  20. Auto Tensioner
  21. little help dont know much
  22. CarSound 2.5" High Flow Cat=CEL???
  23. 225/50-15 too big?
  24. violent shudder in my friends 93 Lude ( Help Please )
  25. My GC coilovers are seized up What could i do so i can raise my car up?
  26. Rattling noise when letting off the gas..pls help!!
  27. 4 wire o2 sensor help!!!!!!!!!!!!!!!
  28. JDM PowerBand Problems
  29. Vortec FMU
  30. Trip meter reseting??
  31. Does CEL for TPS sensor affect motor?
  32. Gauges and Fog lights went out!!!
  33. need some help with my new setup...
  34. Weapon R Suspension
  35. header h22a
  36. New guy need help, 86 prelude stalling
  37. strange rattle noise
  38. Precision H23A and his boosted prelude
  39. Wheel Hopping?
  40. grounding Systems
  41. '97 ecu in a '00
  42. Intercooler Question
  43. Had to wash motor now battery light comes on!
  44. gst manifold and turbo on h23?
  45. PLEASE HELP ME SOMEONE
  46. forged pistons in h22a1
  47. Prelude Specs (general)
  48. 5th gen seats
  49. plug gap and torque spec?
  50. I need a new suspension kit
  51. how to? driver and passanger windows auto up and down?
  52. cold start-up crazy idle help
  53. custom exhaust question differences
  54. 4WS light is on, what should i do?
  55. Does 92 Preludes have the "glow" gauges?
  56. Wntd: generation 2 parts
  57. "Hidden" nos setup
  58. Vtec engagement point
  59. Stroking an H22
  60. wtb prelude drag gen 4 intercooler
  61. h23 n/a - compression levels on stock pistons 'n rods?
  62. Apex-i V-AFC fuel settings???????????????????????
  63. Transmission Problems
  64. Helms Manual
  65. Headlight Question
  66. VECT changeover point –MPH converter?
  67. 650 streetable whp out of h22..
  68. Who was going to sell me their IM a few weeks ago?
  69. Little V-tec Vtec problem
  70. Gas Mileage
  71. 1992 Prelude with the 2.3L
  72. Motor Mount Insetrts for 5th Gen 97-01?
  73. H23 rebuild
  74. spring manufacture question
  75. 97 prelude: TURBO on a 90k miles h22?
  76. Ok to Red-Line?
  77. Bedding new rotors and pads
  78. h22a injector problem
  79. Which prelude years are interchangable
  80. Tranny/ Clutch problem
  81. How much should swap cost
  82. How do I check to see if my tranny came with the car??
  83. Bolt patten?
  84. prelude problems :(
  85. weird problem.....
  86. The best springs for 5th gen?
  87. typeS tranny on 94h22?
  88. 92 prelude throttle screw..
  89. 94 jdm vtec lude 129000kms. To nitrous or not to nitrous??
  90. how much for an obd2 head?
  91. Crank Pulley News :Stock H22 vrs Euro R.
  92. what is it?
  93. Fifth Gear Grinds... and Hard to get into REVERSE...
  94. Front ST sway bar install
  95. Body shop quick questions...pricing?
  96. coner lenses
  97. 88 Lude S
  98. 97-01 obd2b prelude ecu pinouts
  99. pistons pistons pistons
  100. Ground Wire Kit
  101. another camber question!
  102. h23 to h22a all motor
  103. Vision
  104. 5th Gen CAI problems?
  105. H22 egr probelm
  106. what other cars have same luge patter as a 4gen lude?
  107. Is there an easier way?
  108. prelude ecu # 2
  109. Turbo or supercharger???
  110. Bent Valves then replaced them. Still having idle troubles any thoughts on what it might be?
  111. 5 geb dash into 4 gen?
  112. What size drag radials
  113. Cracking noise coming from under car
  114. will 92-93 lude front seats fit in my 94-EX 2dr...
  115. My 88 Lude S
  116. AEM CAI replacement filter...where to buy?
  117. H22a1 swap and exhaust question
  118. Anyone experience Alternator problems???
  119. where to buy H23 short block?
  120. 4gen stationary antenna
  121. Dash light go on and off
  122. JDM ITR SRS steering wheel. Will it fit a 92 prelude?
  123. Cold Valves?
  124. Engine Swap Pics
  125. CAMSHAFT SPECS FOR F20-H22A-H23AVTEC?
  126. dash swap
  127. motor pull : day 2 - Need Help!
  128. 10-94 header
  129. h22/h23
  130. Best cam shaft for 5th Gen prelude.
  131. Ground Controls and koni yellows
  132. what could it be????
  133. J&S Safeguard & Hondata
  134. Metal Gurgle
  135. smokin vtec
  136. 92 si chip
  137. prelude ecu
  138. timing belt and valve adjustment?
  139. JDM 1 Piece Headlight
  140. do you ??
  141. 94 prelude please help
  142. Mugen Kit Q's
  143. Quick Intro & Honda Serv. ?? =)
  144. 18" Spare Tire
  145. just weighed my 93 vtec...
  146. will this work ??
  147. need old school help
  148. please help before it happens again!!!
  149. radio lights and rear speakers not working
  150. 4th Gen Dashes
  151. !! Does anyone know what prices these items go for?? !!
  152. sputter at speed
  153. Searching for true JDM exterior parts
  154. 4th gen into a 5th gen Cluster
  155. the h22a having some problems
  156. belt dressing
  157. new battery?!
  158. help on h22 swap problem
  159. Can't Post Blues
  160. Price for a 92-96 prelude
  161. Skunk2 Intake Manifold vs Stock Euro R?
  162. keeping cool
  163. Please help couple of questions.
  164. H22 tech question, H22a4 block w/ h22a1 crank
  165. whp gains w/DC Sports 421 header
  166. what are the pro's and cons of a h22a tranny in a civic?
  167. Question on Check engine light
  168. Are my shocks going bad?
  169. what next , image header, or s2s1 cams
  170. 1992 prelude SR problems :( :( :(
  171. Neuspeed Strut bar Quick question
  172. 97 H22A4 SH swap Help
  173. Timing belt question
  174. lip???
  175. Faulty speedometer
  176. fellas I sold the lude, and didnt think twice about getting another one until now.
  177. prelude help
  178. boost the shit out of f22 or get h22?
  179. h23 manual tensioner (sp) on a JDM h22
  180. How many quarts of oil in a H22A4?
  181. will a h23a1 auto tranny work with h22(92-95 jdm)?
  182. JUN H22A Cosworth Pistons
  183. wire identification and placement
  184. separating the taillight tail light
  185. wierdass vibration/noise
  186. so my timing belt broke...
  187. cam questions????
  188. Tire Fittment
  189. Ground Controls w/ KYB AGX Shocks
  190. crower cam settings
  191. H22A4 JRSC, what type of pistons should I use???
  192. CAR STOLEN!
  193. what is the biggest down pipe and exhaust for a turbo 4thgen prelude
  194. stock compression on a H22a4
  195. "infamous tranny problem"
  196. i need some help
  197. could be the battery?
  198. Whats going on with my fuel set up?
  199. vafc on Stock motor
  200. mainshaft bearing...
  201. spray or no?
  202. H22 turbo/thicker head gasket
  203. Suspension
  204. new turbo blown???
  205. OT: need a beater? 87 Lude
  206. JE pistons Compression All-Motor
  207. H22 or Turbo stock motor?
  208. turbo prelude question
  209. Spark plug change gone wrong...help!!!!
  210. Engine sometimes just dies when driving, immobilizer flashing (Euro-Prelude)
  211. squealing sound
  212. which fuel pump
  213. Intake vac line?
  214. P28 Settings?
  215. Identify this wire!
  216. MSD blaster ss coil on stock ingnition *searched*
  217. NonVtec H23 Headers
  218. Quick Brake question?
  219. Boosting your Octane. GOOD info provided.
  220. big brakes + 16" wheels?
  221. My dyno results, need advice
  222. 370cc injectors and resistor box Q !!!!searched!!!!
  223. spoiler mounting
  224. 4 gen supercharger
  225. eck, killed 4ws!
  226. Who sells trannsmissions?
  227. H23 Cam gears on H22 Cams???
  228. Is it possible to fabricate
  229. h22a wont idle down when cold?
  230. DC DTM catback... opinions?
  231. h22 header dynos!!
  232. Possible replacement for B21 motor
  233. durability: my prelude engine
  234. Paeco engine kits
  235. JDM foglight switch???
  236. Ignited Push Button Ignition...
  237. Help me spend $1200 on my h23a motor
  238. how to tell if an engine is still good?
  239. i can't post in the classifieds but need to!! HELP
  240. Bolting the turbo in... gotta problem
  241. OBD1 Question
  242. Type SH side skirt help
  243. skunk2 valve?
  244. quick question on suspension bushings
  245. h22a4 valve spring specs
  246. SRS light in '93 VTEC ($5 via PayPal if you can figure this out)
  247. Fog light question?
  248. H22a1 wiring diagram!!!!
  249. modifying greddy header for 5th gen?
  250. h22a1 sleeving in Canada
