View Full Version : Honda Prelude
- back in the game!
- For those with the 5th gen shop manual
- Pricing on Prelude....Opinions Please!
- whos lude
- prelude price- quick question
- best clutch value/performance?
- Oil filter block adaptor
- retarding ignition
- getting gas!
- Trying to figure out why I can't post in the trial forums sections
- what kind of honda engine is this?
- talked to JG at nopi
- shitty synchros. need better
- piston help
- rsr exmag exhaust
- Reviews or feedbacks on Tein FLEX for 5th get SH
- Feedback on RS*R header...
- anyone with zex experience
- Volk Racing GT-7 Question
- valve lash specs for skunk stage 2's???
- How Does it cost to a Tranny swap from AUTO to Manual on a 99 Prelude Type S
- I'll be frickin suprised if anyone can help me with this...
- jackson racing supercharger for 4th gen?
- reviews or feed backs on Tein FLEX for 5th gen SH
- antenna
- where to buy h1/h4 bulbs & wire harness
- H22 P30
- Free Carfax until 10/09/03
- finally able to post dyno chart of jun built h22a/ better picture of dyno
- dyno chart
- Dyno with HyperGround Wires.....
- post dyno
- 5th Gen. w/ Type R 5-lugs?
- Whats the story with these things??? ECU?
- Flapping noise under acceleration....timing belt?
- Need specification, helms at home.... -deck height=?, OEM headgasket thickness=?-
- Fog light bulbs? what kind and where to buy?
- So..oem foglights are illegal?
- where can I get JDM Prelude parts (last gen)
- H22 VTEC Black OEM VTEC Valve Cover
- rear strut help......
- searched.... Whats thebest head gasket??
- need help with e-brake on 2nd gen
- jdm climate control in usdm
- rigging nitrous nozzle - need advice
- generic camber kit on ebay. GOOD OR BAD?
- Post your EG/EK JDMH22 time slips here, along with all modifications.
- anyone ever boosted 94 SI?
- Balance Shaft Belt Installation Question
- hydraulic tranny conversion?
- Clutchnet clutch bad after 15k?
- h23 crank pulley?
- Mirror problem
- dyno
- how much do you think this is worth?
- power steering cooler
- ACL bearings
- VTEC wont switch on (sometimes?)
- speeding ticket
- New to tuning, need help
- do I need to get new headgasket?
- Thoughts on Engergy Suspension motor mounts?
- lean problem?
- What are some modding complications on 97-01 SH's?
- jdm header not compatible with accord downpipe
- Skunk mega power
- Headers?
- system in prelude
- Weight reduction on 5th gen
- h22 parts
- will these wheels fit my car????
- falken azenis?
- h23 swap done,now problems when driving it?
- NEED HELP setting for jdm h22 5th gen timing
- would a intake mainfold from a H22a fit on a 2,0 prelude ? (92-96)
- Possible solution to "not running on all four"
- WHERE IS THE TRANSMISSION FLUID PLUG?
- What I've been up to...
- Pro Drive Final gear
- lip for 5th gen prelude
- AC messes with the Idle
- Radiator
- 4th Gen Foglight Switch Picture Request
- 92 Si and S radiator the same???
- Helping a friend any thoughts? (car wont start has spark and pump primes)
- lowering springs and upper strutbar....91 lude si
- jdm 2.2 DOHC non vtec?
- CEL, code 7 or 70?
- need help with tranny swap
- need to contact Koni(HELP)
- h22a cam gear setting
- How to clean 4th gen JDM headlights
- help reading spark plugs - nitrous
- gauge conversion from new to old in 4th gen..will it work?
- clicking noise from engine
- h23 compression numbers.
- Where to take car to get Camber done
- Not Hitting VTEC, Please help!
- 11.5 compression system requirments for an h23...
- checking timing
- Zex n2o problem..?
- valve adjustment
- oil burn?
- Installing a 1998 H22 in a 1992 Prelude Si
- 93-95 jdm h22 into a 93 accord
- jdm milage
- wanted: 96 prelude VTEC ecu.
- Nitto Neogens?
- trial user question
- axel back exhaust
- Too rich on idle...
- Funnest Way to blow motor?
- 92 prelude si.... can anyone tell me the specs....
- what is the correct thread size for 5th gen prelude for lug nuts
- question about shocks
- H23 to H22 transmission difference?
- What belt size?
- where is the 4ws fuse located in a 1994 prelude?
- Difference of obd1 & obd2 injector clips?
- Anyone have Eyebrows on your 97+ Prelude?
- which spark plugs wires for jdm h22a? USDM didn't fit!
- 4th gen with 5 lug conversion
- H22 engine noise - PLEASE HELP
- precision valve adjustment.
- new clutch/flywheel going in advice?
- HELP! How do I obtain my true mileage?
- Need Help on H22A Turbo Setup
- Turbochargers and Superchargers
- Need Help Figurin Exhaust Length!
- Accord Aftermarket Springs on a Lude?
- who's got best prices on sleeves,rods,and pistons
- 5th gen prelude axle question..seeking professional advice
- getting new wheels, need help
- Apexi n1 troubles
- Differential fluid change
- h22 h23 flywheel?
- New Luder!
- what vtec head on a b20?
- Where can i find headlights?
- vtec engagement
- jdm h22, with good, i/im/h/e + hondata
- KKK K27 on a H22A, is it to big ? =)
- Quick Q about srings and retainers for crower stage 2
- sparkplug wire order?
- o2 sensor witch one will work?
- Crower Stg 2 cams, any reviews?
- knock sensor on a built engine
- Auto parts stores rape you on prices, need help
- Short Shifter???
- 90 prelude carbs...
- ALMOST NEW KONIG PROPHETS 18"
- Relocating battery
- H22 short block weight
- Are all H22 pistons/rods interchangable?
- H22, can't hone the cylinder walls...
- Phantom Grip vs Quaife
- interchangable pistons???
- 4bidden short throw shifter
- Advantages to using Hondata/p28 or Hondata/p72?
- 4th gen preludes rare?
- EGR block off plate
- Anyone have any ideas for flush mounted headlights for third gen?
- Lighting search for 5th gen
- high flow cat?
- J&S safeguard v2
- spark plug gap
- Am I wrong?
- driving with no muffler?
- mods for 84 prelude
- Back from the Dyno...
- Battery Light on
- 84 prelude ?
- aem cia installation problem
- WHERE TO FIND ECU CODE JUMPER?
- 5th Gen Prelude Front Lip
- bad halfshaft
- dyno results from nopi
- Rolling arches
- ***Installing Tanabe F&R lower bars???***
- who makes those Roller Rocker kits for the H22?
- '93 Si stock headunit
- Goodridge brake hose kit for 5th gen Prelude?!?
- 86 Prelude ECU location
- rust
- short shifter
- Help, Tire Rubbing
- anyone know where to get a HELMS manual for cheap on 5th gen prelude
- need info about the AEM cold air.
- High Amp Alternator H22A Prelude
- 92-95 H22 vtec, and 2000 H22 vtec DC headers are they the same size.
- ground-controls
- URGENT: need combustion chamber CC for the H23A and F22B1
- Need a prelude expert
- power mirror please look
- h23/h22 header the same?
- H22 flywheel weight
- help!! h22 chokes as rpms climb then dies...
- suspension what type of sway bars/a-arms would ppl suggest for a 2000 lude
- Brake Rotor question, Brands
- Exedy OEM replacement clutch
- Need camber expert's help!
- Is 200whp posible....?
- Question about JDM p13 ECU
- 4th Gen Help -Gauge and SRS Light
- ECU question
- Hid Kit Questions
- Difference between auto tranny ecu and manual ecu??
- 4th gen vs 5th gen
- what would you do about rims selection?
- Ok so 5th gens suck for boost. But what about 4th gen H22's?
- Brake Setup
- Best tires for handling and drag?
- HELP ME
- Jdm Prelude Cup Holder How 2 Install??
- why is the engine so bad?
- Clicking noise when I release first gear and second.
- Questions about 4th GEN Prelude "Si-VTEC"
- Ported IM or aftermarket
- exhaust note
- radiator for 92-96 prelude
- pinging noise!!!
- Pistons?
- Question regarding synthedic oil
- NITROUS bottle placement pics please
- my 95 non vtec for a 92 h22?????
- Whats wrong with my clutch?
- Help! Took dizzy off and can't put it back on because...
- bout to shoot nitrous - anything else i should do 1st?
- "performance" "resistor" "ecu piggy back" "IAT mods" chips... opinions please.
- HELP!! Sketched bout my new engine :o/ Really need some help/advice
- rattling when open sunroof - 4th gen
- anyone got a helms or can answer a easy question?
- Apexi World Sport
- type s lip?
- Any H22's using the RPM Service throttle bodies?
- JR Supercharger Install
- need help ......higher compressin piston????
- hey, what is that on his headlights?...... --->
- An H22 pic like this one?
- Clutch Issues (bad master cylincer?)
- check engine went off and so is atts
- New here, turbo prelude, need tires
- loud clutch squeak
- Tail light issue
- h22 (Type S) in a 4th gen question?
- OK to use used type s cams???
- i got to drive an H22 for my first time!!!
- Crower cam question
- 99 Prelude SH problems
- Upgrade vavle train for FI?
