Dyno Results - 200+
Old Oct 23, 2003 | 12:55 PM
ranta18's Avatar
Default Dyno Results - 200+
Just got back from the dyno and I'm very happy with the results
Setup:
1995 JDM Prelude VTEC H22A Engine & 5spd Transmission w/ LSD
Golden Eagle Godzilla Sleeves
87.25mm Prelude Type-S Pistons
Head Milled 0.020"
Modified Intake Manfiold
Crower Stage 2 Camshafts
Imagine Engineering 4-2-1 Header
Imagine Engineering 3" Race Intake
STR Cam Gears
STR 70mm Throttle Body
AEM High Flow Fuel Rail
AEM Adjustable Fuel Pressure Regulator
APEXi V-AFC
Thermal Classic Exhaust
NGK Spark Plug Wires & Platinum Plugs
No P&P on the head yet!
This is in a 2000 lb 94 Civic hatch. Going to the track Saturday
Old Oct 23, 2003 | 12:56 PM
ranta18's Avatar
Default Re: Dyno Results - 200+ (ranta18)
Motor:
Old Oct 23, 2003 | 01:09 PM
HotWheelz's Avatar
did you balance the bottom ?
how about the pistons ?
runnign balance shafts ?
running crank pulley ?
running flywheel ?
stock head with stock vavles ?
what taper is the tb ? entry to exit ?
with exaust on or open header ?
alt power steering pulley ?
what fuel pump ?
*no ps* from picture (that's a given 6)
sorry but i'll be dynoing mine fairly soon. and wanna know what to expect from our difference.
*smooth graph!*
Old Oct 23, 2003 | 01:13 PM
ranta18's Avatar
Default Re: Dyno Results - 200+ (HotWheelz)
Factory Crank
Type-S Pistons
NO Balance Shafts
Factory Crank Pulley
Factory Flywheel
STR 70mm TB, No Taper
Thermal Exhaust
Factory Alternator Pulley
Walbro 190lph Fuel Pump
Old Oct 23, 2003 | 01:29 PM
Que_Lude's Avatar
Very nice numbers and setup
Old Oct 23, 2003 | 01:38 PM
@ries's Avatar
Very nice Congrats.
Old Oct 23, 2003 | 01:43 PM
satan_srv's Avatar
Default Re: Dyno Results - 200+ (emoBB1)
can I see some SAE numbers?
Nice results though.
Old Oct 23, 2003 | 01:47 PM
junbb1's Avatar
good numbers. you should be very happy. now get that header to fit in the ludes.
Old Oct 23, 2003 | 01:49 PM
Daboi630's Avatar
whats the main difference with STD and SAE?
what's the point of even dynoing with STD, when people will ask for SAE numbers?
my dyno was ran with SAE. i dont believe they ran with STD.
Old Oct 23, 2003 | 01:51 PM
ranta18's Avatar
Default Re: (Daboi630)
Thanks guys.
Its just how the dyno was setup. Changing it to SAE only drops it like 3hp
Old Oct 23, 2003 | 01:55 PM
Daboi630's Avatar
Default Re: (ranta18)
where you the same person who dyno'd less with cams?
if it was, glad you got the problem solved.
if it wasn't, nice numbers!
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daboi630 &raquo;</TD></TR><TR><TD CLASS="quote">whats the main difference with STD and SAE?
my dyno was ran with SAE. i dont believe they ran with STD. </TD></TR></TABLE>
SAE is a normalization factor that takes into accout temperatue and barometric pressure, as these factors play a moajor role in power output during a run. SAE numbers are used so people can compare apples to apples. Well at least more accurate.
Like is a huge difference in numers if I dyno at 68 with no humidity and I dyno at 95 with a ton of humidity. It's merely for comparison purposes.
Old Oct 23, 2003 | 01:57 PM
Daboi630's Avatar
so in short
SAE = real world numbers
and STD = what it *could/should* make
Old Oct 23, 2003 | 02:02 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daboi630 &raquo;</TD></TR><TR><TD CLASS="quote">so in short
and STD = what it *could/should* make</TD></TR></TABLE>
no
SAE = normalized numbers to standard test point (77 degrees and some pressure factor)
STD = Actual test conditions numbers aka real numbers that day
Old Oct 23, 2003 | 02:12 PM
DLB1994's Avatar
Default Re: (satan_srv)
what did you do to the intake manifold
Old Oct 23, 2003 | 02:32 PM
Mike95lude's Avatar
That Thermal exhaust must be killing power if its just the standard one with only 2.25'' piping.
Old Oct 23, 2003 | 02:44 PM
Joon525's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ranta18 &raquo;</TD></TR><TR><TD CLASS="quote">This is in a 2000 lb 94 Civic hatch. Going to the track Saturday </TD></TR></TABLE>
I don't give a crap about drag racing but DAMN your car must be fast.
&lt;- curious to see your times.
Old Oct 23, 2003 | 05:10 PM
Daboi630's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">
no
STD = Actual test conditions numbers aka real numbers that day</TD></TR></TABLE>
on me.
thanks for putting it into simple terms
Old Oct 23, 2003 | 06:26 PM
Mikeyslude's Avatar
those are some really nice numbers! how's it feel?
Old Oct 23, 2003 | 06:57 PM
junbb1's Avatar
Default Re: (DLB1994)
how can you say sae is 3 hp when it changes from day to day. granite those are good #s but but sae does make a diffference. and what mods did you do to the intake.
Old Oct 23, 2003 | 07:32 PM
satan_srv's Avatar
Default Re: (junbb1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junbb1 &raquo;</TD></TR><TR><TD CLASS="quote">how can you say sae is 3 hp when it changes from day to day. granite those are good #s but but sae does make a diffference. and what mods did you do to the intake. </TD></TR></TABLE>
I believe in another post he said he basically did the same thing you did joing the 8 runners to 4. So based on your results we could say it may be hurting his midrange. But if he's drag racing who cares right?
Old Oct 23, 2003 | 07:38 PM
junbb1's Avatar
yes, but the minimal gains i made on very high end would not help drag racing. hell, that mod wont help **** unless you are F/I, and maybe that.
Old Oct 23, 2003 | 09:17 PM
ranta18's Avatar
Yes, it was me who had problems last week. My cam gears were off a tooth. Stupid mistake on my part, but I'm glad it wasn't something more serious.
Yes, I'm running the Classic Thermal exhaust system. I might look into a bigger system, but I love how this one sounds.
I'll post up the SAE numbers for you guys tomorrow.
I made the 8 runners into 4 large runners,eliminated the butterfly plate, and port matched it for the 70mm throttle body. I know this has shown to loose midrange power and gain little up top, but has anyone tested this on a higher compression motor with the mods I have? My theory is that with the larger cams, tb, and higher compression, the larger and shorter runners will help. 157 ft/lbs @ 5600 seems pretty good.
This is the difference between the setup I had before the cams and now adding just the pistons and removing the balnacer shafts:
TONS of midrange gains.
The car feels great and I can't wait to see how it does at the track. I ran consistant 13.8's at 185 whp and 2200 lbs on street tires earlier this year. Now I have some suspension mods, traction bar, 200 lb lighter car, 20 more hp, and slicks.
Old Oct 23, 2003 | 09:21 PM
satan_srv's Avatar
I'm going to hazard a uess to say the balancer shafts gave you most of the torque gains, you can see it straight across the board, the pistons wouldn't make a huge difference at that rpms. I'll be doing a balancer shaft test sometime soon.
Old Oct 24, 2003 | 08:33 AM
kb58's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ranta18 &raquo;</TD></TR><TR><TD CLASS="quote">... My theory is that with the larger cams, tb, and higher compression, the larger and shorter runners will help...
I agree with the comments except for the "higher compression" part. What difference would CR make regarding intake modes? (not dis'ing you, I really want to know.) Higher compression simply means the air is squashed more, it doesn't matter how the air got in there. I mean, it's not like it's pulling in more air *because* of the higher CR, right? The only change is happening after the intake valves close, so any changes upsteam of that wouldn't matter.
