PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 [120] 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. aftermarket exaust wheight (searched)
  2. 1992 VTEC
  3. p72 ecu question
  4. vtec controller help!!
  5. tranny allignment dificulties
  6. H22a4 compression test results
  7. spring suggestion
  8. Cluster
  9. Auto to manual Kits
  10. Brake Warning Light Coming On, Why would this happen?
  11. Help with 4ws codes 70 and 29
  12. installed new suspension, weird noises?
  13. H22 Track Time! Disappointed =( After Rebuild!!
  14. dohc v tec on a f22a1
  15. HID question
  16. Cluthera of H22 trouble
  17. How much Freon?
  18. h22 tranny stuff
  19. anyone running 215/45/17 tires?
  20. motor oil!!!!!!
  21. 1991 Prelude si ...what is a good swap
  22. H22A distributor
  23. Idle Problem
  24. HELP!! I installed the p13 now problems
  25. Brakes - squishy feel
  26. New prelude specific ebay lip!
  27. HELP: clutch pedal pressure problem
  28. LSD needed for turbo?
  29. 97 Prelude won't start
  30. the trails with my auto
  31. Fuel Rail needed???
  32. stupid CF hood problem
  33. What will last longer?
  34. My h22 is stuck in limp mode
  35. 2.5" header for 97 and up preludes?
  36. Need serious help before taking car to shop, already searched.
  37. h23 head gasket question
  38. '97 SH Check Engine and ATTS
  39. Legend/NSX brakes
  40. Honda ECU pins - help me please!!
  41. H22a1 Coil + Mount vs. H22a4 Coil + Mount
  42. 92-96 cold air intake the same as 97-01?
  43. little to no voltage on icm green wire.. solutions?
  44. can anyone verify this?
  45. 5th gen with leather
  46. Door Visor, look what I found!!!
  47. exhaust gasket problem PLEASE HELP
  48. Cam gear slipped.... what now??
  49. How much do u think i could get for my car
  50. Swapping distributors.... h22a on a f22a4?
  51. Name this exhaust:
  52. wiring diagram needed
  53. H22 vtec sputtering
  54. Clutch torque specs..
  55. Headlight wiring question (searched)
  56. PLay in the shift fork ----VVVV
  57. Good 205/45/17 tires?
  58. Timing Belt Broke (Question)
  59. You guys helped make this possible
  60. Camgears on ype-S Motor worthit?
  61. Jerky Transmission- Is transmission crapping out??
  62. .6" drop and stock shocks
  63. small or large mains ????
  64. friend's prelude overheated, now it won't start.
  65. Stubborn head bolts
  66. cel code 15. help!!!!!!
  67. 5th generation floormats
  68. Paint code
  69. Hows the H23 Tranny compared to the H22 tranny when turbo (n00b question)
  70. quick question!is prelude 4x100?
  71. Quick questions about SH preludes.
  72. Is not having a lower timing belt plastic cover going to lead to bad things?
  73. HELP: clutch pedal pressure and idle problem
  74. Shifter Arm leakage? what to do?
  75. 2k idel from vacum? & e-fans stay on.
  76. compression test,is it too low?
  77. TPS
  78. Gear Ratio of H23 tranny? Did search already!
  79. 97-01 prelude motor mounts
  80. 92-96 4th Gen. Prelude CLUTCH question:
  81. cant put castle nut on?
  82. ECU question related to transmission
  83. Where on a 5th gen are the best places to put Dynamat for maximum noise reduction?
  84. 4th Gen Fog light Question..????
  85. Automatic H22 longblock VS. Manual H22 longblock. whats the difference? *searched*
  86. Universal FPR
  87. JDM Foglight install 5th Gen
  88. need h22 ecu wiring diagrams??
  89. Volts dropping to 5-6 on crank, no start.. ideas?
  90. P13 chip
  91. skunk tuned p28
  92. what cc is the h22 injectors??
  93. Idle rpm's etc
  94. Name these rims!
  95. techone HID install *pics*
  96. jus swapped h22 into my Si, but car wont start...not sure what to check
  97. super rainstorm in chicago = car wont start
  98. green 99 ek pixx
  99. H23 ARP's on F22a1
  100. high flow cat : inlet/outlet 2.5 for my 93 vtec?
  101. cf oem style spoiler
  102. Wings West Retailer
  103. turn signals on98
  104. EGR gasket and plug differences
  105. 98 Honda Prelude Alternator Question.
  106. Auto switch for windows
  107. new lude need exhaust
  108. Braking problem?
  109. Prelude Exhaust
  110. hard shifting into gear
  111. to those with jdm headlights
  112. Post up ur foglights
  113. need exhaust tips(searched)
  114. Flat Screw on throttle body for idle. Help.
  115. back window shattered today
  116. Need to repaint metal strip under side windows. Suggestions?
  117. EGR ????
  118. Post your setup here
  119. obd2 3 wire idle air control sensor converting to obd1 2 wire sensor????
  120. new rear calipers needed?
  121. f22b timing
  122. disabled the knock sensor
  123. 92 Prelude axle nut size
  124. Important Distributor question.. please help asap
  125. Binding Brakes on 91 Prelude Si
  126. What to do with foggy headlights
  127. urgent help* thanks... RIM FITMENT issue
  128. new keys
  129. clutch squeek
  130. help with megan header / blown gasket
  131. tranny rebuild
  132. EGR Blockoff is Worthless
  133. Header Wrap
  134. what timing belt to use
  135. 5th gen bb6 custom radiator shroud??
  136. h22 transmission bolts
  137. How much money are u guys spending MAINTAINING your prelude
  138. Could this happen?
  139. hydrolic clutch bleeding. my first time.
  140. 4th gen AC lines and hoses
  141. 5th Gen Headlights
  142. 1986preludepgm-fi lighton
  143. Whats the best route to take with my prelude?
  144. How much are 5th gen passenger side airbags going for?
  145. Map Sensort Bracket HELP!!
  146. h22a motor mounts
  147. Lowering springs question
  148. Dust seal allow brake fluid to leak?
  149. How to: Install universal fogs on a 5th gen + Bonus RSX seats installed!
  150. valve stem seals
  151. wheel question
  152. Installing headlights
  153. What is going on? Won't start...
  154. need help on v-tech
  155. Pershing Bumper Covers
  156. Bad rings what caused this? Pics
  157. Check engine/ ATTS
  158. my hood is raised..should I worry abour rain/water?
  159. ECU Question
  160. exaust picks
  161. 2 things: New rims and A/F ratio question.
  162. How many prelude have you owned?
  163. driver's side brake pad stuck
  164. h23 crower cams on f22b dohc
  165. Got spark and fuel- won't start
  166. Ecu question
  167. weird idling issue
  168. suspension help
  169. the right pistons
  170. Belt squeal upon startup.
  171. Pulsating sound coming from car, possibly brakes. Pads always squeak as well.
  172. Turbo Prelude Black Smoke
  173. Driving hard
  174. CEL, im so lost.
  175. BS? www.horsepowerchip.com
  176. Check engine light wont turn off after mods
  177. 5th Gen ACT 11.9lb Flywheel
  178. I NEED HELP ON F22 DOHC
  179. alternator belt
  180. JDM Climate Control Vacuum hoses. (Already Searched)
  181. Weird whinning noise @ belt area
  182. help with a window
  183. Hell of a time with Koni Yellows
  184. F20b head gasket
  185. JDM F22B boltons?
  186. Prelude Professionals!
  187. Acceleration problems. Can it be the clutch slipping?
  188. Another quick question
  189. 92 Prelude S - F22 Manual Speed Sensor
  190. coil overs for 4g
  191. Hesitation
  192. H22A4 TBelt and ManTensioner install squeal?
  193. littel help
  194. where are the main ground wires on a 98 Honda Prelude located?
  195. el gauges VS 92-93
  196. mugen 4th gen spoiler
  197. increasing displacement on H22/H23?
  198. bleeding my clutch
  199. exhuated installed...engine light
  200. Exterior and Interior Light question.
  201. Whats a clutch replacment job cost?
  202. Rpms drop during idle
  203. HEELP MEEEE
  204. 1985 drivability problem
  205. The thunder from down under. The yellow thunder, that is. JUN prelude. Your thoughts?
  206. Sprung or Unsprung clutch?
  207. What bulbs to use in the corner lights?
  208. what to do next? for low/mid range power
  209. Flywheel Bolts: Removal
  210. RPM meter. help
  211. Driving without power steering belt is like wrestling a bear. Not a koala, an effing panda.
  212. 89 prelude h22 swap??
  213. post if you have an aftermarket steering wheel
  214. fuel pump
  215. EGR Issue Fixed
  216. Cam gear install?
  217. H22A > F22B2 or B18C1?
  218. H23-Turbo
  219. H22a is it worth it
  220. engine burp
  221. valve cover quick question
  222. header question
  223. 5th Gen low idle/putt noise/rattling
  224. Turbo Prelude Smoke Problem
  225. bad rear mount cause vibration throughout the car?
  226. prelude type-s cams wtih H22A cam gears
  227. High Idle after H23A swap into EF, tried everything, need knowledgable help
  228. 5th Gen Bumper Gap/Sag?
  229. Forbidden short shifter installation and parts question
  230. Fuel Pump Fuse
  231. constant stuttering
  232. vortech supercharger on 5th gen
  233. Help!! Check Engine/ATTS light... problem with cornering
  234. Modifying stock bumper into a lip!, I swear there's a pic of this here!
  235. fuel and temp doesnt light up.....?
  236. cel code 1 and 43
  237. Changing Tranny Fluid help
  238. shifting problems
  239. h22a ecm
  240. engine torque damper?
  241. Piston ring gap???spacing??
  242. car takes forever to start after clutch/flywheel install
  243. ...Tuning Question...
  244. Pulley Kits
  245. Smoke
  246. Clutch Issues: Possible Bad Cylinder?
  247. Exhaust question
  248. Mushimoto Civic 96-00 Radiator in my 4th Gen Lude - DIY How To
  249. knock sensor problem!
  250. Some installs We did...
