PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 [89] 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Adding gear oil...where?
  2. Clutch Bleeding
  3. 215/50/15 4th gen
  4. Clutch for an uncommon setup.
  5. WTB: h22 or h23 bare block with main caps
  6. i have a 1996 h23 obd2 being swaped 4 jdm h22 obd1
  7. QUESTION ABOUT STEERING WHEEL!
  8. Ecu Cel code
  9. 3" Apex-i N1 Muffler - Sound?
  10. ELECTRICAL ISSUES HELP(LOOK) - can someone help need advice
  11. ecu fuse keep blowing
  12. Battery problem posing as alternator?
  13. bb4...
  14. trouble shoot problem
  15. which ecu comes with the euro-R??
  16. prelude stereo problem..
  17. Running improperly until check engine light.
  18. Reasonable price to replace head gasket
  19. H23 Manual Tensioner
  20. Question about shift boots.
  21. accord k-member
  22. stock bore on a h23
  23. Shops for auto to manual conversion in SF or bay area???
  24. head gasket blown, put new one on, now wont start
  25. h22a4 cylinder head torque specs
  26. Any of you 97 lude owners experience these problems?
  27. No idle
  28. dont know much about brakes, little help.
  29. noises coming from rear end
  30. left turn signal wont work.
  31. Strut bushing and shock mount bushing??
  32. replacing heater core - joy
  33. switched ecu to p13...car hates me
  34. help pls. im picking up a TENZO R seat. installation?
  35. stock p28 run a h22 ok?
  36. help plz with vafc2
  37. trouble codes P1259, P0132, and P0420
  38. Pic Request:
  39. Injen CAI Bypass Valve???????
  40. type-s h22a
  41. What part's are needed to fix this issue? :Searched:
  42. h22 Dist problem, help
  43. SH-AWD???
  44. is it ok to do this this?
  45. Want to change fluids on new buy????
  46. Pic request. 4th gen w/ 215/40/17's
  47. lsd
  48. crankshafts question
  49. ecu pinouts
  50. 5th gen springs on 4th?
  51. Need help on Type SH shock absorber.
  52. ecu location
  53. H22 Belt w/no AC?
  54. how much should i expect to pay
  55. h22 throttle problem...
  56. atts power disable
  57. Intercooler Dimension
  58. 1, 2, 3 gears are going in soft
  59. help! h22a throttling issues!
  60. 1990 2.0 12v prelude forsale
  61. 5th gen help needed, shocks springs etc
  62. Did i get the wrong ECU?
  63. Widebody 5th gens
  64. Rims Help
  65. h22a4 block?
  66. H-series trans on F23A1
  67. Dyno Results Today
  68. h23 problem!!!!!
  69. Hello, new guy, need your help plz.
  70. check engine light
  71. so confused please help!!!!
  72. Possible Broken Crankshaft Rod?? Replace or Repair??
  73. headgasket for h22a
  74. NOS Question???????
  75. What should be changed when doing a main seal replacement?
  76. H22 gasket differences?
  77. prelude dash light problem, please help
  78. Saturday morning sex-change for my lude
  79. car wont stay in 1st 3rd or 5th. wtf
  80. Deciding between two exhaust brands. Your opinions please.
  81. Intake manifold question
  82. m2b4 lsd Tranny Question
  83. As requested.. my JDM BB4 SI VTEC
  84. Exhaust, O2 or Knock sensor?
  85. BA8 to H22A
  86. wiring hell.
  87. Anyone running the APEXi N1 catback?
  88. mileage
  89. Need help on Type SH shock absorber.
  90. best parts to go for N/A
  91. 89 prelude engine swap
  92. 6 speed lude?
  93. Is the EGR Port Plug replacement in the Helms?
  94. oil drain plug
  95. Clutch Question - 1999 Prelude SH
  96. rebuild or replace h22?
  97. Prelude 5th Gen Rear Caliper Question.
  98. 5th gen parts and turbo!!!
  99. 96 h23 block Open or Closed?
  100. rewire obd2 distributor to obd1 harness
  101. HELP PLEASE! I HAVE ENGINE PROBLEM!
  102. Accord Strut Bars
  103. coolant leaking
  104. 1993 Prelude H22A Wiring Help
  105. Torqing down front swaybar?? to what spec?
  106. Rear swaybar repair question.
  107. 4th rear lips!!!!
  108. is it a sh or a base?
  109. bb6 prelude running problem
  110. 4th gen suspension setup HELP
  111. Bad Alt or bad ground?
  112. Changing a Head
  113. high emissions 96 honda civic ex(help!)
  114. Cage for prelude.
  115. Bent rear axle(s)? Need serious help
  116. VAFC
  117. Confirmed. H23 with H22a4 head. Owner. kinda pointless. Can you wire me some Vtec?
  118. f20b or h23 vtec?
  119. what lip
  120. (Searched) CEL Codes 6 & 22, h22a, vtec not hitting.
  121. head swap
  122. pic request: s.tech w/ AGX (or 1.5in drop) on 5th gen
  123. Looking for input on an idea for H22
  124. Installed HID's and when I turn on, one light flickers/buzzes and turns off.
  125. Reliability of 5th gen Preludes
  126. JUN parts !!!!
  127. 4th gen digital dash died help
  128. Greddy turbo or Jackon Racing Super Charger??
  129. h22a revlimit
  130. WHATS THE STOCK COMPRESSION ON AN H23?
  131. what resistor box do i use
  132. H22a Adj. Cam Gear Question, Adjustment...
  133. JUN specs Race p14 ECU OBD I
  134. JDM swap in 97 SH - Lose ATTS function?
  135. Can I use regular model shock absorber for SH Model?
  136. obd2-obd1 injector resistor box
  137. h23 f22 intake
  138. red light next to ac switch
  139. 96 honda prelude SR-V question
  140. engine turned bipolar
  141. build up my h22a1 or just go jdm
  142. 96 honda prelude h22a1
  143. Wiring Diagram for conversion to H1/H4?
  144. converting 92 console to 96 console?
  145. ABS light is on
  146. Lifetime Honda Seatbelts?
  147. K swapped Accord.. =prelude K swap?
  148. Help needed ASAP
  149. Fuel rail line
  150. Difference Between Header/Exhaust Manifold Gasket???
  151. apexi afc neo helpppppppp
  152. M2A4 tranny w/ LSD???
  153. need shop to build my h22 (tri-state)
  154. Thinking about buying a Prelude.. have a question though
  155. Replacing Door Lock cylinders.
  156. does anyone know if the jdm lsd will fit on the 4th gen m2f4 tranny?
  157. LOCATION OF KNOCK SENSOR
  158. heim joint bushings
  159. just got back from the dyno
  160. El guage
  161. Service Manuals for a 1992 prelude sr
  162. Red Honda Emblem pic request on front & rear!!!
  163. Unknown camber kit
  164. JDM Bumper pole question? Is this Honda OEM or Fake
  165. Crazy idea.. Would it work!!
  166. What does your h22a idle at??
  167. PLEASE HELP. Engine swaped from 2.3 to H22 vtec
  168. Is a 3rd Gen Worth Buying?
  169. why does my first to second shift so slow
  170. quick question reassembling main inputshaft and bearing
  171. f22b dohc parts
  172. HELP: Car Sounds Like Garbage Disposal
  173. 3" collector really worth it on a Greddy header?
  174. rebuild process .. crank is done but not sure what else
  175. 2001 SH-CEL, ATTS, mods...some questions!
  176. a/c compressor
  177. FAQ section not working
  178. Jumping tach while accelerating at high RPMs.
  179. Drilling out EGR ports..Risky?
  180. h22 Problem
  181. h22 intake manifold swap question
  182. Injector question.
  183. help with engine problem (searched)
  184. Proper bleeding...
  185. what does this do: cable-to-hydraulic conversion???
  186. 1995 Honda Prelude VTEC Upgrades
  187. can I drop in the h22 sh motor in a base model
  188. vtec qustion
  189. where can I get a good reman or jdm motor?
  190. OBD II in a 4th gen?
  191. Getting on dyno again soon / any tests you want to see?
  192. Help! Headlights are stuck in the ON position!
  193. H22 ecu
  194. H22A CALI EMISSIONS ::HELP::
  195. drop the transmission to replace clutch
  196. h22+Nos question
  197. H series trannys?
  198. harsh ride shoot me
  199. PORT AND POLISH FOR D,B,F,K,AND H SERIES MOTORS.
  200. Racing seats in 4th gen ...
  201. what sensor is this ?
  202. 92 f22a1 lude dirt car
  203. HIDs help
  204. CAN SOMEONE PLEASE HELP ME!!!!!!!!!
  205. f22a1 compressor into a h22a4?
  206. I NEED HELP ON FINDING A SHORT SHIFTER FOR MY 5TH GEN LUDE
  207. transmissions problem. PLEASE HELP!!
  208. UCA Creaking
  209. Help me Customize my 98 Lude
  210. JDM type S H22a block code P5P??
  211. Another timing question.
  212. Ported Head
  213. B20 swap...Passing smog???
  214. h22a swap into a 92
  215. from automatic to standard
  216. help finding a o2 sensor
  217. prelude stats please
  218. KNOCK SENSOR
  219. What is this wire for??
  220. 440whp H23a Preliminary Dyno
  221. How to tell if a H22 Is JDM?
  222. Brake problems :(
  223. Cup holder and antenna mast
  224. What would YOU choose?
  225. getting a used prelude
  226. HIN no 4th gen :/
  227. DC Sports Ceramic Header Wrap Question..
  228. Keyless entry?
  229. Oil question's on boosted h23
  230. bad spark plugs??
  231. Collector Mod ?'s & Custom Exhaust ?'s
  232. HELP!!!! Transmission Question
  233. Trunk light on my dash will not turn off.
  234. need help with my 1989 2.0s
  235. auto cluster on stick
  236. dropping type-SH
  237. H22A swap - Charging system problems
  238. h22: removing oil squirters
  239. frustrating. anti theft code..
  240. I just bought a 1997 Honda Prelude, has power problems.
  241. 4th gen prelude cat nut size
  242. camber kit
  243. h22 timing help! asap
  244. high compression pistons
  245. 4th gen trims??
  246. Foglights
  247. Strut Rods
  248. HELP!i think im running rich bad mpg.
  249. Hiro Lip Kit?
  250. Flexible AC lines
