View Full Version : Honda Prelude
- my car keeps over heating at night and long idle?
- Carbon Fiber
- JG 1001 h22 cams?????
- prelude blues
- Nitrous/Turbo
- Adjusting rear toe
- Best Price On JDM Fogs?
- need to totally revamp my fuel system
- prelude plus rear diffuser...is it really worth it?
- 4th gen prelude front lips?! options?!
- H22 limitations
- mystery solenoid...
- 550cc RC Injectors for H23 turbo wrong/right setup
- H23 turbo engine OverHeat
- Who sells H22 bare block?
- CF intake manifold h22a
- Need help, 4th gen trunk measurements
- What should I do with my Intake Manifold??
- Coilovers and shocks
- What Performance Radiator for 92-96 Prelude
- help with an H23 to a vtec conversion
- Help Install Missing Link to an H23 turbo kit
- JUN piston cr?
- Tranny? Clutch cable? Pleae help
- Prelude, H22, injector sizes
- 89 Lude, Am I stupid?
- Low Beam Bulb Type?
- How to know if transmision gears are from M2Y4 or not
- Intakes
- Gasket set
- 01 h22 v2 00 h22
- prelude jump video
- H22 Header
- 14.3 in a 2000 Prelude with 3 bolt ons, is this true???
- What prelude motors have vtec
- need some quick help
- Map Sensor trouble
- Oil coloration and application
- temp. problem
- Jg im vs str im
- over heating problems.
- Dumbest thing about the 5gen prelude IMO.
- Greddy SP CatBack for 92-96 SRV , putting on SI, whats different?
- supercharger 5th gen?
- How much is this car worth? Thinking of getting it, need advice!
- puttering narrowed down
- Radio setup (screen)????
- pros and cons of a 94' Lude...help??
- Boring out the H22/H23 block: Benefits??
- lowering 86 prelude si
- Fuse Question
- by-pass control solenoid valve
- where can i find a block!?!?!
- I had a nice ride today....NOT
- Is it bad?
- AUtomatic Tranny and Turbos/Superchargers!!!!
- I need some stock wheels with tires from 97-01
- Spring Install Question
- Cause of backfires(rich), and clouds of smoke
- every crank the car w/o tranny?
- Prelude power dissapointment
- 16 inch wheels and comfort. Is this possible?
- TURBO HELP!
- camber<question>
- where can i find oem header and ecu (obd1) for 95 Prelude Vtec
- a/c lines for 4th gen vtec
- Help! Ive got a huge alternator/electrical problem
- Help
- Turbo AUTO transmission HELP!!!!
- i wanna see what an example of 1992-1996 lude with wings west rs lip kit
- Turbo'd Prelude Transmission
- 1994 Honda Prelude S Suggestions/Help
- 98 lude oil consumption
- 'middle' of stock water temp gauge = ??? degrees?
- Are Preludes less stolen than Integras/Civics?
- Light weigth Gel Cell battery
- Brakes
- Body Work - rust removeal from wheel wells.
- WANTEDPrelude body and stuff
- Anyone know the url for B20A n/a build up?
- OBD1 vs. OBD2 Question
- clearer install instructions for a/f gauge
- Powerchip???
- Anyone know where i can get carbon fiber door mirrors for my 5gen??
- nitrous setups
- where did you tap in your water temp gauge?
- torque spec for h22A4
- Power loss
- prelude/accord cat converter
- Spark Plug wires
- auto stick transmision #
- help
- WTB: Stock 5lug prelude wheels !
- Early fuel cutoff??
- VRD racing wheels
- Part Number Help
- Need a clutch alignment tool ASAP
- whats your single favorite mod?
- H22a distributor
- o2 sensors
- quick q
- OT: Man Supras are tough (56k warning)
- JDM Type-S Pistons For Sale - Mod Approved
- verdict on my car
- Stock Fuel Pressure
- What size injectors to get for my JDM H22
- 97 Prelude ECU OBD2 to P72 OBD2
- Does DC short shift adapter hurts tranny?
- how to test your igniter?
- 99 Prelude VTEC, which ECU/Conversion Harness to use?
- Stupid Question....
- do i need a new flywheel if i get an act xtss?
- HAPPY NEW YEAR!!! From Australia
- Anyone with the Drag 2 Gen. Kit, Please Answer this.
- Car takes longer to start, do you guys think it's something serious?
- Prelude Videos???
- h23 pistons
- Axle Replacement
- Fluctuating Idle problem, possible answers??? -- already searched --
- recall
- Brake Rotor Size
- installing 4th gen rear speakers
- Engine swap/h23 vtec/engine block questions
- RSX seats into a 5th gen lude
- Where can i get a es Oval muffler?
- H series or B series parts valued more on market?
- used h22a turbo?
- Preluds Never win
- any different between jdm stock kit or usdm stock kit
- jdm h22a turbo
- What clutch are all the other turbo ludes (5th Gen) using?
- Searched...Need write up for friend on JDM lights in a 95SI
- my jdm headlights
- Aftermarket spoiler
- I just test drove a 97 Prelude and a PROBLEM..............TECH GUY'S PLEASE LOOK
- 5th gen lude oem cd player
- what is the torque spec. on oil block adapter bolt?
- Comptech ICE box
- what yr lude motor is this and type?
- Where to buy fiberglass OEM 4th gen front fenders? (searched)
- where to buy jdm engines?
- Advan wheels, 17 X 7.5
- JDM P13 replaced with JDM P72.
- 85 Base Dual Carb 1.8L is stalling after starting since it got cold..
- need help/opinion on why turbo not making power above 5k
- Whistling tranny
- clutches 98 lude
- 1992 prelude struts
- HELP. Flashing green s light on dash
- WTB 5th gen parts
- reinstalled stock flywheel
- Prelude injectors
- Yeahh!!!!Putting my turbo kit tomorrow. I'm new into turbo help please.
- MSD question: 6a or SCI
- new to preludes looking at getting one, few questions
- Lude rear ended... need some help choosen new parts.
- hey guys, problem after shop changed timing belt
- 92 Prelude Fender Removal... Help!
- 4th gen rear wheel bearing
- Found a copy of a 1993 C&D magazine with the Prelude VTEC in it!!!
- 93 speaker install
- Door locks stopped working, Whats the problem?
- 5th Gen Stock Stereo
- spring ?
- Rev Hard tubular manifold Question *Mod Approved*
- need to get some wires through....
- what should i set my cam gears for with this set-up?
- Help, my car won't start and there's gas on spark plug
- 1990 Prelude A/C Problem
- Where can I get mugen bumper for a 97-00 prelude?
- Weird 92 Prelude S Problem...
- My friend wants to put a turbo on his lude. Whats kit do you recommend.
- upgraded motormounts inserts/replacement.
- Anyone know the redline/fuelcut for the JDM H23A and/or F22B
- prelude fuel filter
- Shifting through the gears is not smooth. What could be wrong??
- link to short shifter write up?
- Best Place to Get Ground Controls?
- Clutch still acting funny
- prelude injectors
- h23 direct port?
- Pic Request.... Flywheel
- Prelude guys, Please help me out!!
- Mod Approved: 1997 - up combination switch...NEEDED
- skunk 2 or type s?
- C's Driving Position Short Shifter
- How to get 6x9 out of 94 Lude
- hack & puttering
- Thinking about a turbo
- Mugen M-5's
- motor into 2nd lude
- My spring Project
- Colder Plugs with rebiult H22 head
- modify h22 header to fit h23, possible?
- Will my stock 4th gen rims fit a 92-95 Civic Hatch?
- How to adjust black 1-piece JDMs?
- Lights on Warning
- Greddy SP2 Exhaust?
- Are 92-96 Preludes prewired for fog lights??
- Will a skunk2 obd2 to obd1 harness from a 96 integra work on 96 prelude?
- h23a1 p13
- Carbon fiber moon roof filler?
- quick question about bulb sizes
- h23 how much is it worth???
- Aftermarket Oil pans & instalation
- Which fogs are these?
- N/A H22 blocks and heads...
- p72 to run like an h22??
- timing question
- well isnt this nice...
- egr port cover and T/C bracket for ATR IM
- changing to fuel injection
- JDM hiro front lip?
- anyone using vafc hack on their boosted lude?
- Driving around with a bad knock sensor.
- bolt in oil pan?
- door panel speakers and rear speakers
- Sounds like valve tapping...
- Vafc II Probs. HELP!!!!
- type s cam specs??
- Fuel Line Q:
- Is any one using the MaxRev turbo Manifold?
- v-tec harness
- exhuast flanges
- looking for timing belt links
- vafc + field harness? is it possible?
- Low beams, clock, trip odometer, 1 high beam not working
- Prelude Antenna
- what ecu for my h22?
- difference between prelude SH and normal coupe
- 3 Bar Map Wiring?
- oil leaks
- Best Head Gasket for JDM H22a? -searched-
- 92 Prelude corner lights????
- Car grinding after starting and going in gear.
- DC sports rear upper strut brace (5th gen), cheap!
- 5th gen smells badly of raw fuel.
- JDM bottom block?
- want to swap into a 88 prelude
- Greddy type S bov question
- Any Advice? Im goin turbo!!
- h22 turbo throttle body recomendations
- h23 header to a h22??
- WTB: 5th gen prelude 98+ tranny, and stock cat
- stock rod weight?
- anyone willing to outcall a timingbelt /tensioner install?
- suspention Systems
- h22a1 vs h22a4 bottom end
- which gear to dyno prelude?
- buying a 96' prelude with a so, so head swap?
