N2o or boost on sleeved block
Old Oct 21, 2003 | 07:05 PM
c1civic's Avatar
Default N2o or boost on sleeved block
just oreder a darton sleeved block and i can t decide what i want to do. i already have eagle rods, now its time to get pistons. first i need to decide boost or nitrous (150 shot or so) .. please give me some pros or cons of both and help me make this decision. thanks
Old Oct 21, 2003 | 07:09 PM
c1civic's Avatar
oh and its in a 92 civic cx
Old Oct 21, 2003 | 07:10 PM
SKDRCR's Avatar
Default Re: N2o or boost on sleeved block (c1civic)
depends on your budget and how often you want
to be hauling ballz, if you got the cheeze,
i would turbo it
Old Oct 21, 2003 | 07:14 PM
c1civic's Avatar
im leaning more towards nitrous, jsut do to the cost factor
Old Oct 21, 2003 | 07:20 PM
satan_srv's Avatar
Default Re: (c1civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c1civic &raquo;</TD></TR><TR><TD CLASS="quote">im leaning more towards nitrous, jsut do to the cost factor</TD></TR></TABLE>
Why don't you just get 10:1 compression, you could boost or spray both. If the block is strong just spray more n2o for the compression you're missing
Old Oct 21, 2003 | 07:22 PM
SKDRCR's Avatar
if you go with just nitrous, what compression pistons
are you gonna be running, because with a big shot
you don't want to have too high of compression, but then
again if you get too low of comp. pistons then your
car won't have as much power when your not boosting......
Old Oct 21, 2003 | 07:32 PM
c1civic's Avatar
damn this is a big decision, i want to use the blcok to it possibilites cause i spent the moeny for it, isnt 10:1 compression a little high for like 15psi or so
Old Oct 21, 2003 | 07:37 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c1civic &raquo;</TD></TR><TR><TD CLASS="quote">damn this is a big decision, i want to use the blcok to it possibilites cause i spent the moeny for it, isnt 10:1 compression a little high for like 15psi or so</TD></TR></TABLE>maybe not if you run some high octane when you
boost, that is if you're still leaning towards n2o
Old Oct 21, 2003 | 08:13 PM
NXLude's Avatar
you can run a 125-150 with 10:1 no problem....just make sure you gear the car up for the nitrous......If i were you Id do 100 shot and 11:1......give you real good street performance and 300+whp on the juice......
Old Oct 21, 2003 | 11:30 PM
TwoRedEGgs's Avatar
Default Re: (NXLude)
Make sure you set your car up for Nitrous if your gonna run it ! get some good tuning equipment like Hondata, that way you can switch from boost mode to N/a mode. Get somecolder plugs,purge valve, bottle presure guage etc, so you can monitor the system!
And look into getting a wet system ! The good thing with Nitrous is that you only use it when you want and it isn't that hard to install.
I would also start off with a smaller shot to be sure you have the system working right, then move up into somethign higher!
And that 10.1 compression is fine for Nitrous, you can go a llittle higher is you really wanted, but I wouldn't go past 11.1 for a street car on pump Gas !
Old Oct 21, 2003 | 11:54 PM
flip1199's Avatar
Default Re: (TwoRedEGgs)
ok i guess i'll the odd ball and say go turbo. The only thing i don't like about nitrous is the bottle refills. Let's say u go to the track. People have been know to get up to 15 runs in two day events. Now how many bottle is that on a 150shot?? If your on the freeway and need to pass a line of semi's goin up hill you won't have to worry bout having a filled bottle. All u have to do is just press on the gas and the power is there.
Old Oct 22, 2003 | 01:23 AM
oOPreludeBoyOo's Avatar
I say just go Turbo and NOS, if you got the money.
Old Oct 22, 2003 | 03:29 AM
c1civic's Avatar
how much does it cost to refill abottle
Old Oct 22, 2003 | 08:54 AM
c1civic's Avatar
any more inputs, i was think in that 10:1 was a little high, im willing to get hondata, i actually want it. i live in cincinnati ohio and i dont e even know of anyone who has expereince with it
Old Oct 22, 2003 | 10:49 AM
laughinxxx's Avatar
New User
I like nitrous simply for the fact that I have the reliability of NA when I'm not racing. Also I like driving NA cars more than turbo'd cars, but I'm the vocal minority in that aspect. You'll be dropping about $2k for a full nitrous setup(controller, direct port, heater, purge, etc.) so I wouldn't go for nitrous just because of the cost factor. In reality you don't save much at all.
Old Oct 22, 2003 | 10:56 AM
2kflamedlude's Avatar
We will have to run one day man
Old Oct 22, 2003 | 11:18 AM
MugenPoweredLude's Avatar
the way i see it is youre building the motor....why not slap on a turbo kit and standalone and make that car a beast
SiTR
May 17, 2007 10:24 PM
B18C_EJ8
17
Oct 9, 2003 10:09 PM
simplestyles
Feb 25, 2003 11:45 PM
delslow94
Jan 29, 2003 10:05 AM
BumpinVTEC
Jan 12, 2003 09:31 PM
