PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 [92] 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Removing Distributor
  2. replacing steering wheel
  3. Quick question about the which f22 will work????
  4. Help? cant find short shifter for 5th gen. prelude
  5. Got a noise...
  6. EGR vacuum disconnected at valve- a/f
  7. Luber Finer fuel filter? Does it suck?
  8. looking for an h23a1.
  9. cel and atts light just came on need help plz
  10. H22A Hesitaes from 2000 rpm to 3000 rpm need HELP!
  11. ===Ecu resting procedure===
  12. Dc rear lower tie bar install help
  13. H22a1 n2o help
  14. help in ny please?
  15. bad smelling...
  16. stock tach not working.
  17. H22 Rev limit
  18. H22A stock fuel pressure?
  19. just bolt on and made 200whp how?-
  20. 1997 Honda Prelude Rear Bumper Cover
  21. cooling the lude down
  22. nitrous (searched, just need opinions)
  23. fully built turbo h22.How much power should i make??????????plz reply
  24. Changing Pads and Rotors on a 5th Gen Prelude
  25. can any1 help? please!
  26. Indicaters of a slipping clutch???
  27. 92 Honda Prelude AC not working - help needed
  28. Removing my engine
  29. replacing main bearings, any suggestions while i'm down there?
  30. Caz's Supercharged 4th Gen Prelude
  31. Seibon 5th gen front lip
  32. Need Help Deciding spring rate Preference (GC/Koni Yellows owners)
  33. v-tech oil pressure switch
  34. HElp fast On Rod bearin H23 vtec
  35. Need to understand about this internal to external stuff
  36. new jack
  37. Anyone tried the NRG Type-R seats yet?
  38. Ready for turbo?
  39. found h22
  40. OK To Run Car Without A/C Compressor But Everything Else In???
  41. H22A1 vtec leak
  42. Altenator belts loose
  43. H22 turbo
  44. No more 3k hesitation, Better Gas Milage, Smoother partial thottle response.
  45. Why No Turbo For SH Prelude???
  46. cams
  47. Honda Factory performance rims
  48. Whos had an alignment? I got a Q..
  49. engine swap ?
  50. Timing problem!
  51. no spark 4th gen
  52. VTEC PROBLEM HELP!!!!
  53. AIR/FUEL RATIO GAUGE
  54. HF1-HF2
  55. Ground Control and AGX Help please!
  56. does anyone know where the IAT senor is in 4th
  57. h22 ecu
  58. CELICA SEATS in a PRELUDE?!
  59. Shreded bearing
  60. Turbo 5th gen converted to obd1+no emissions
  61. will 2005 Audi TT projectors fit in the 5th gen for retrofitting?
  62. racing seats
  63. Speedo works sometimes
  64. Would these wheels fit?
  65. How To Get Clear Turn Signal Lenses
  66. Bent Rods? Blow Head Gasket?
  67. Is obd0 prelude injectors 310 or 290cc
  68. Autometer Tachometer Installation
  69. Idle Air bypass valve?
  70. What should i do to my prelude?
  71. Teg or Prelude
  72. power seems to taper off a good bit
  73. My F20Z1 boosted Prelude
  74. does anyone have a cluster diagram?
  75. JDM H22A Distributors Can i use the 2000 Cvic si cap n rotor?
  76. PROBLEM WITH 2000 PRELUDE. HELP???
  77. blue dash light
  78. Air conditioning A/C lines always cold, a/c clutch relay or connector?
  79. Type S pistons
  80. Timing problems
  81. RUNNING really rich after hard launch
  82. Car pulls to right
  83. Great Engine/bay cleaning product
  84. p75 tuning?
  85. Prelude sunroof
  86. Race car Brake Judder
  87. NEED ADVICE!!!! on my h22a1 prelude
  88. Duraflex (polyurathane) Mugen Replica Kit
  89. tire rubbing!!!! used 97 prelude
  90. problem?
  91. BAD DAY FOR MY LUDE =(
  92. Quick Qestion.
  93. Prelude Transmission Problem
  94. need some help with my stereo wiring harness
  95. stock tail lights
  96. H22A Swap error codes 41, 12 cant get rid of it!!! HELP!
  97. what exactly is chipping an ECU?
  98. wtb complete h22a head
  99. Prelude on s2k rims?? any pix?? need an image.
  100. 5th gen headlights
  101. 89 lude service connector
  102. Anyone has any videos of their preludes post it here!
  103. HOOKING UP MSD WINDOW SWITCH FOR NITROUS?
  104. removing cat
  105. converting auto to manual......
  106. Motor works!! I got one last question...
  107. Which Brake Pads?
  108. stock lip spoiler (black plastic things)
  109. Clutch Question
  110. snapped bolt on valve cover !!!! please read
  111. jdm headlight bulbs
  112. catch can
  113. Low Low compression, Car won't start .....
  114. New Engine help - newbie question
  115. H22 Questions needing answers asap.
  116. Cat on OBD II
  117. sad day for the lude
  118. Hit curb can't get rid of caster... help!!!
  119. 11:1 CR...need bigger injectors or fuel rail?
  120. 92-95 Tranny Bracket same as 97-01?
  121. premium fuel..h22.
  122. interior gutting
  123. problem w/ my exhaust
  124. lambo doors
  125. 1 or 2 o2 sensors?
  126. what you think 98 prelude
  127. 4th gen 95 vtec lude
  128. i need help , h22a4 w/ ss tranny in a 94 accord
  129. Basic suggestions?
  130. Help WTF????????
  131. what rims are these?
  132. Shifter cables or syncro?
  133. plastic cover beneath engine?
  134. converting base tranny to SH tranny...
  135. whats the dif between h cam gears and B cam gears?
  136. JDM DOHC F22B
  137. egr reinstallation
  138. Advice on 01 Prelude purchase....
  139. 1997 turbo prelude
  140. how do you turn down a turbos psi?
  141. engine hesitation
  142. Anyone here running a 7" Ground Control Spring with their yellows?
  143. 4th gen suspension
  144. question on h23 vtec
  145. 1993 h23 swapped to a h22a1?
  146. need help getting my car tuned
  147. Hilltop Honda and Acura really fast and really friendly
  148. Removing TPS sensor
  149. NOS Hook-up
  150. 5pt harness
  151. Started signal wire.
  152. hood scoops
  153. 5Gen brake caliper piston diameters
  154. replace Oxygen sensor 2000 prelude
  155. for stock interal true jdm 2.3L vtec, does it only have 160 hp? 153ft-lb torque???
  156. JDM h22a
  157. Does a jdm 92-96 prelude automatic tranny fit on a 97-01 prelude?
  158. Stuck Gas Cap..
  159. no mil w/ vtec unplugged--no change in fuel % during vtec--HELP!
  160. engine problem? maybe?
  161. fuel system help please
  162. KYB agx is made in japan?!
  163. H22a4 Burning Oil...
  164. intake mainfold?
  165. H22 Engine and internals
  166. Prelude PHOTOSHOP REQUEST
  167. error code with 4 quick blinks?
  168. 2000 Prelude keyless entry help
  169. ___Honda prelude emblem____
  170. 1991 Honda Prelude stalls when gas gets low
  171. Buying a 98 lude
  172. f20b head on f22b block 11.0 compression?
  173. clutches
  174. condensation in Jdm headlights
  175. my spun bearing
  176. JDM H22 Swap
  177. turbo - supercharger
  178. Just got 18x7.5 on 00 Lude and kinda scrapes
  179. ANYBODY KNOW HOW TO DO A VTEC CONVERSION!!!!?????
  180. 5th gen Mugen Twin Look+Type SH= Compatable?
  181. h22a4 lsd question
  182. s2k vs prelude
  183. need help with removal of crankshaft pulley on h23
  184. Just Bought a 92 Prelude
  185. 2000 Prelude OBD II to OBD I Conversion.. How do I pass emissions? noob here.
  186. passenger window, sunroof, squeaking noises
  187. Brake Problems galore :(
  188. My 93 Prelude..
  189. 4th gen vs 3rd gen gas mileage?
  190. Just bought a 93 Prelude
  191. will this downpipe work with the drag mani and t3/t4 turbo
  192. Motor needed
  193. Oil Temperature Sensor
  194. tranny problems on 99 prelude
  195. Cooling fan doesn't work
  196. need new crankshaft bridge/main caps???
  197. Need help with tilt lever on steering wheel.
  198. Main shaft bearing ?
  199. Engine Cleaning......Need advise from experiences
  200. Tightening E-Brake
  201. Help me get my alternator off.
  202. can a 95 accord EX Dizzy work on a 92 h22????????????
  203. Lower ball joint 93 prelude
  204. WANTED F22 INJECTORS
  205. CEL #43, Running rich?
  206. illumina kit help on a 01 SH
  207. Knock Sensor Question
  208. Okay, JDM harness to UDSM harness question..
  209. I need a H22 LSD transmission bad!! Where can I get one??
  210. custom axle back cost?
  211. Show of your third gen prelude here
  212. Intermittent 4ws light
  213. Failed a WOF (Springs)
  214. d4 light flashing
  215. OREGON PRELUDE MEET
  216. Difference of H22a1 vs H22a4
  217. Distributorless Ignition system.
  218. Prelude h22a1 automatic at the track
  219. Kinda messed up my clutch fluid change.. lil help?
  220. Radius Rod or Stab Bar!?!?!?
  221. ABS light
  222. cigarette lighter
  223. msd spark plug wire for h22
  224. HID Pic Request (Non-Retrofit)
  225. HELP....Crank Shaft Sensor????
  226. WTF:are these h22 vtec injectors????
  227. need engine mounts....help!!!!!!!!!
  228. Removing the intake manifold/throttle body question
  229. Proud New Prelude Owner
  230. Cooling fan switch
  231. Battery?
  232. Skunk 2 cam help
  233. Where Good Place To buy! online!
  234. air\fuel wiring
  235. C-Pillar Bar
  236. prelude ECU problem....
  237. timing cover
  238. Body Rust
  239. Tan RSX seats?
  240. My H22A Accord Dyno Results
  241. timing going crazy!
  242. HELP! No vtec . . Rev limiter @ 5k h22a . .
  243. look what i found on ebay
  244. help with front bumper...
  245. does the 4th gen shift boot fit the 5th?
  246. how to remove 5th gen fenders?
  247. Auto 5th gens.
  248. Cat diameter
  249. motor?
  250. Whats the difference in 97-98 and the 99-01 h22a4?
