PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 [179] 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Random problems: Power locks and key noise
  2. ITB + turbo?
  3. HELP! I was on my way to school when I couldn't start my 97 Prelude anymore?? HELP!
  4. Rough Idle and check engine light???
  5. just swapped a JDM h22a into my car and it has a really loud noise in the head
  6. JDM H22 in 93 Accord Clutch change out ????
  7. jdm vs usdm p13 pinouts (obdI)
  8. first time at a Track
  9. Interior trim piece above radio, whats the part number?
  10. What's the best fitment for my lude?
  11. Headers For A H22A? Choice And Expierence?
  12. TRANNY WONT SHIFT
  13. Swap on SH
  14. Free beer if you tell me how to solve my problem.
  15. 22 problems HELP!!!
  16. my type s shitbox.
  17. accord coilovers to preludes
  18. question about these rims that came off a prelude
  19. Can shifter cables/bushings only affect one gear?
  20. Thump sound from exhaust??
  21. Headlight Hell
  22. Light Bulb blew..where to get a light bulb for 1 piece headlights. ( just stock ones nothing fancy)
  23. Some Questions: Clutch Pedal Spring and PS Problem
  24. turn signal delay?
  25. Those running standalone, whats the optimal A/F ratio in partial throttle?
  26. Head setup for NA
  27. Trying to understand timing
  28. Bodykit bumper needs turn signals...
  29. Accord 5 speed SS swap....
  30. removing heater vents 4th gen
  31. Min oil pressure for vtec?
  32. Check eng light, VTEC no longer working
  33. Selling a Prelude turbo manifold
  34. JDM H22 need higher then 93 octane?
  35. what is the best header for my 97 prelude (non sh)
  36. full carbon fiber 5th gen lude?
  37. 5 lug swap: splash shields?
  38. polyurethane bushings for 5th generationers
  39. help on H-series lude Engine spec sheet
  40. Question about machining h22 head.
  41. good h22 mechanic in socal???.....
  42. cam gears?
  43. best h22 header
  44. what is the best ecu for a h22
  45. can you make a prelude have a higher top speed?
  46. will this fit
  47. trubo set up
  48. Compression Ratio?
  49. Prelude 97-01 Weight Distribution?
  50. SS to 5 speed question
  51. head gasket oil leak
  52. JDM H22A piston replacements? (i seriously dont know)
  53. Exhaust A pipe stay(bracket)
  54. royal purple vs castrol syntech
  55. what should happen if iacv is disconnected??
  56. can't see timing marks... confirm with these pictures
  57. car backfiring?
  58. rpms too high in h22??......
  59. Suggestions please...
  60. Just picked up my Rage/Prospeed Header...
  61. Another crank bolt thread
  62. 96 SI, warm idle trouble?
  63. help on CAI insatall
  64. Question on Red Stitched Shift knob and boot???
  65. i have my h22 build for turbo. i want to make 500-600whp
  66. tail light not working?
  67. to bay area luders (pref. san jose area)-- need some junkyard names
  68. 5th Gen. Stuff for sale
  69. Auto to Manual swap on a 3rd gen lude
  70. VSS Code Help
  71. will it fit?
  72. Please Help... Error code on stock radio..
  73. howto install accord lip on lude
  74. Switches near the clutch pedal on 5th gen
  75. What can I do about a P1300 CEL?
  76. clutch trouble...
  77. 20HP Speed Chip???
  78. cel pop up, how to run it
  79. SRS removal...posting for a friend...searched
  80. vtec problem
  81. Sloppy feeling in 1 3 5
  82. H motor identification??
  83. Help! Red Wire for TPS too short!
  84. VSS wire on 5th Gen?
  85. Turn Signals Don't Return
  86. please help identify this wire!!! pics too!
  87. relocating clutch fluid resevoir
  88. h23 tranny in h22
  89. wheel size
  90. H22 Throwin Codes Need Help!
  91. can i be losing power by my header?...
  92. auto tensioner re oil
  93. camshafts what are the best for turboing a h22
  94. motor mount
  95. dont get mad....h23vtec or h22
  96. Fuel Rail Upgrade Needed??
  97. PRELUDE TYPE-S (H22A JDM) how to identify?
  98. spark plug check on H22a
  99. alternator corrosion???
  100. Head Flow Test Results
  101. Passing Smog Check after 5spd->auto swap, using OBD2 auto ECU...
  102. weird fuel gauge problem (searched)
  103. WTF happend? help needed plz
  104. question on h22 tranny serial
  105. H23 tranny swap on a 5th Gen
  106. Question about FACV
  107. Battery tie down..(sorry n00bie question)
  108. Suspension question
  109. removing rear seats and bars behind the rear seats. will it affect handling?
  110. How to tell what year (or obd version) a motor is?
  111. adjusting my timing--confirmiration
  112. looping powersteering lines (yes i have searched)
  113. stock pistons, scat forged rods
  114. Need assistance with intercooler piping on ebay...
  115. Does anyone prefer GM synchromesh AFTER using Royal P or Redline?
  116. NEED HELP PLEASE
  117. Think i have a BIG electrical problem!
  118. need help installing koyo rad in 5th gen
  119. is it worth it?
  120. Tuning success story: VAFC II = +13.4whp on Mustang Dyno
  121. wow radiators are expensive
  122. 95 Prelude VTec...H22A1
  123. --Proper positioning of the 3/8" tubing for the AEM V2--
  124. mounts auto to 5speed ??? are they the same mounts on the tranny side
  125. h22 alternator
  126. Scheduled Maintenence for 97 Prelude, Base Model
  127. which valvetrain?
  128. Buying Questions
  129. Condenser Fan Housing Loose
  130. supercharger...
  131. lil knock ok???
  132. Fuel pressure??.......Intake, exhaust, and a little 116 octane
  133. NEED HELD! Sounds bad, h22 engine chatter
  134. Most comfortable 4th gen seats?
  135. what type of gas do you put in your prelude?
  136. CAT
  137. How much gas does a 4th gen's tank hold?
  138. SH RIMS
  139. South Carolina Cookout/Grand Opening
  140. i got some questions about camshafts.what are the best for turboing a h22
  141. Tach and speedo not working!
  142. jdm h22 wiring harness
  143. Weird noise coming from engine bay
  144. telescopic tool
  145. Suggestion for tight timing belt issue on the h22 manual tensioner mod
  146. Last stuff for sale - moderator approved
  147. Help with spoiler on 4th gen (measurements needed)
  148. sub box?
  149. Cylindrical Thing Bewtween Power Steering Fluid and Dipstick
  150. Cold Air Intake decreases mpg?
  151. Does anyone have experience with Bosch Oxygen Sensor?
  152. *Searched* H22 Closed deck design?
  153. idling rough, still quiet exhaust... help
  154. JDM GENUINE TANABE H22 PRELUDE STAINLESS HEADER
  155. 6 speed converson on my prelude
  156. Throttle Body Gasket ?
  157. Could someone do me a favor with a 4th Gen with a spoiler?
  158. What exactly needs to be modified on my cat for my exhaust?
  159. cold motor bog
  160. Exhaust or not?
  161. f20a sohc turbo manifold
  162. How to remove side mirror? (searched)
  163. 0 compression, 1 cylinder
  164. Rotors for Vtec and non-vtec 91(2)-96
  165. A/C Compressor Pulley replacement Question
  166. stock rims
  167. syncros
  168. How hard is it to replace a distributor on a h23a?
  169. Auto transmission problem??? Maybe??
  170. CAT??? CHECK engine LIGHT!!?!
  171. where is map senson on h22a4
  172. Ive heard the p72 gsr in the 97-01 prelude works and well???
  173. Tein SS damper on 5th Gen non-sh
  174. h22 or h22a
  175. valve knocking?
  176. Where does my fuel pump gauge mount to?
  177. LSD
  178. S-AFC knock reading?
  179. Low oil pressure woes
  180. wiring diagram
  181. idle surges and ticking can someone help fast
  182. 97SH issue
  183. Approx. how much to have my R12 AC system checked for leaks/refilled??
  184. Anyone know of any good junkyards in the CO area that have 4th gens?
  185. how big is the euro r tb
  186. my turn signals/hazards dont work!!!
  187. prelude won't start
  188. dissy cap
  189. PLEASE HELP!!!! 93 lude h23 is dieing!
  190. exhaust piping underneath axel?
  191. muffler shop cat?
  192. Need Uprated clutch (searched)
  193. Should I get my valves adjusted?
  194. is it worth fixing up my h23 motor?
  195. i got a h22a4 do think i should get this for the motor the motor is build for Turbo?
  196. Engine internals, should i buy these?
  197. buying parts
  198. 93 si lude keeps dieing?????
  199. H22a H22 Dyno Intake, Header, Exhaust, EuroR, Street Tuned 197.7whp Baseline
  200. jdm f22b dual cam 2.2 looking to vtec it ..would h22 parts work ?
  201. Stock 4gen intake mani question.
  202. steering
  203. Need help to configure A/C problem.
  204. Need some help guys...
  205. i'm getting only 15 mpg..?
  206. Help with separating drive axle from mid shaft
  207. Could this be ECU related?
  208. need help with bigger throttle body
  209. Gosh..! which mark on flywheel for timing light?
  210. need help on my motor swap
  211. Looking for LSD's for h22 transmission??
  212. snapped axle.........
  213. H22a4 in 4th gen
  214. WTB... H22 balanceshaft elimination kit
  215. What AFR with 50hp shot ?
  216. Which ECU???
  217. Mugen or Skunk?
  218. H23 Turbo / or H22 Vtec Swap Prices
  219. How do I install a trunk spring?
  220. Is the ABS on 5th Gens good? If so, can it be installed on 4th gen?
  221. does anyone have a h22 lower timing belt gear for sale? how do u post a pic
  222. What octane of gas do you guys reccommend for '93 Preludes?
  223. wiring into ecu harness
  224. ok to spray carb cleaner around eacv
  225. Radiator Question
  226. turbo prelude what ecu for uberdata????
  227. Do I need these Vacuum parts to have my car runnign right?
  228. 5th gen base prelude rims
  229. H23 vtec swap, tach not working. PLEASE HELP por favor.
  230. accord skirt trim for the prelude
  231. H22 JDM Wiring
  232. Where to buy 5G OEM headlights
  233. Replacing the lower window trim
  234. How Do i Correctly install my tps?
  235. jdm h22 iacv.......
  236. I want to increase my compression. What are my options
  237. bb6 vtir aus spec - really that fast?
  238. 4g jdm climate control
  239. 320mm/12.6inch steering wheel too small for 4th Gen?
  240. PLZ Help! (HID)
  241. throttle body sizes...
  242. can you use any of these H23 parts on H22
  243. h22 oil COOLER questions help
  244. what size speakers in my 96 vtec?
  245. OBX Valve Cover
  246. Spoon Head Gasket
  247. Lets play - "Whats Missing from My Engine Bay"
  248. How do I find the correct brake master cylinder - 88 Si JDM
  249. do the fit shocks and spring 95 to 97 prelude?????????????/
  250. 4g prelude>rear brakes.....same size as all or Vtec is biggeR?
