PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 [131] 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. WTB: a/c compressor and ds front brake caliper 92 Prelude Si
  2. Another h22 swap: things i should look for?
  3. WTB : DS front brake caliper and A/C compressor - 92 prelude Si
  4. nitrous ?
  5. Is this a good buy?
  6. Can i swap my P11 ECU for any other Prelude 92 - 96 ECU?
  7. SWAPPING IN A H22
  8. OT:Whats the diff between oem lip kit and sh
  9. Boosting H23a1
  10. 95 Air/Fuel Ques.
  11. overheating - bottom hose stays cold, do i need a new thermostat or just to bleed the lines
  12. Sun visor
  13. Mugen Header on Ebay, for CHEAP
  14. opinions on h22 throttle body spacers
  15. t-belt slack
  16. Timing belt damage (Pic attached), cause?
  17. Balljoints + Tie-rod ends: Does OEM matter?
  18. JDM P13 OBD I pinout
  19. opinions on ecu chips that disenable sensors
  20. Will a OBD1 accord vtec ecu work with 93 JDM H22A OBD1?
  21. What ecu?
  22. Pulleys
  23. Oil pressure
  24. 5th gens with coilovers please post
  25. Balancer shafts ... to keep or to loose ?
  26. How do I replace bent valves ? (post tensioner fail)
  27. Tps voltage a little off and jumpy idle.
  28. diagnostics port
  29. were to get my motor sleved
  30. Hunting for idle
  31. Prelude won't Idle
  32. polishing H22 IM myself. any instructions?
  33. Refresh / respray paint?
  34. Looking for a Wiring Diagram
  35. Will A OBD2 ECU work on a OBD1 motor?
  36. CEL code 36
  37. b20a firing order
  38. Headlight Housing
  39. battery
  40. Q about front lip
  41. supr noob IDEA? :D
  42. Need help ASAP!!!!
  43. question for 2point6, does the euro r im use the egr.
  44. P0G 0BD1 ECU???
  45. A/C problem – need HELP!!!! :(
  46. AC Problem
  47. Wings West kit
  48. ATTS question
  49. Exedy stage 1 clutch
  50. Harmonic balancer Fell off, HELP!!!!?????
  51. Help CEL # 9
  52. need a spring compressor?
  53. h22a closed deck headgasket
  54. Question for turbo luders
  55. 92 lude h22a swap
  56. aftermarket suspension parts???
  57. chu77's "Headgasket Change Adventure" Thread
  58. alternator
  59. 92 prleude tranny rebuild
  60. Tranny/Clutch Problem - happend last night
  61. used brake pads for 1-2 weeks can be reused?
  62. 4th gen fog light screw replacements?
  63. h22 high compression gasket
  64. FOG LIGHT RE-Wire
  65. Has anyone ever done the Aerospeed FPR install?
  66. VTEC KILLER CAMS for H22!! already exists? custom maybe ? need info!!
  67. Quick Brake Rotor Question
  68. quick question torque specs!
  69. ABS on a 4ws
  70. throttle sticking
  71. wanted a 4th gen wings west front lip
  72. 97 + preludes
  73. suspension question
  74. Cel Code 90.
  75. H22 rebuild?
  76. manual trany fluid???
  77. powerslot rotor upgrade
  78. Plz help, switched ignition coil and now problems
  79. strange 4ws code
  80. Nitrous Users...
  81. DC2 ITR wheel fit on 4 gen?
  82. n00b needs help with clutch ?'s
  83. Carbon fiber fenders
  84. flanges/gaskets for A'PEXi world sport exhaust
  85. Help with my GF's Prelude
  86. F22 Hydro Lock... yet again
  87. End Link Problem?? I Think.
  88. Prelude h22a4 head
  89. BASICS TO TURBOCHARGING THE 5TH GEN. PRELUDE
  90. swap done everything works but idle bounces
  91. H22 thermostat help!!
  92. JDM Type-S emblem
  93. Map sensor and EGR plates
  94. Installing Type S cams in JDM H22a?
  95. Prelude techs, does this sound ignition related???
  96. JDM P13 Ecu specs
  97. 5th Gen Engine Bay shave
  98. vaccum hose diagram #12 tube, where does it go?
  99. Smoke in engine bay
  100. Koni and H&R Setup noise
  101. Saw a stock 05 TL with huge brakes that said Acura on them - Fit a bb6?
  102. autometer gauge hook up
  103. h22 swap ?'s
  104. Car consumes wicked amounts of oil yet no drips or smoke while driving
  105. ecu code reader??
  106. Parts for sale!!!
  107. 92 SI wants to shift into high gear quick
  108. 92 Prelude, Surging Idle??
  109. Quaife LSD on a 99 Accord F23a Tranny
  110. Installing a Header not sure
  111. Speedometer needle light out
  112. ES tuning?
  113. 5th gen jdm fog light switch holder anyone????
  114. 4th Gen, dash light problem
  115. $750......ADVAN RIMS.......!!!!!!!
  116. NEED JDM fog light Instructions!!
  117. euro r intake manifold questions, tried searching
  118. Belt Size with no AC in 5th Gen SH
  119. Getting a 94 lude....
  120. H23/H22 Head Swap Questions HELP!
  121. tranny
  122. noobish ?'s
  123. Darton Sleeves
  124. h22 Water neck
  125. side question
  126. Sputtering through all gears (randomly...)
  127. Will car start if balance shaft are misaligned?
  128. 4th gen ? on coil
  129. Will the RS*R exmag pass smog?????
  130. torn cv boot.
  131. Changing oil, ran into problems.
  132. 2000 Honda Prelude SH - dealership repair questions
  133. my 91 prelude
  134. any advantage to h23 over h22a?
  135. 2001 Prelude colors??
  136. 4th Gen CarbonFiber Trunk
  137. everytime I take out the battery is my ECU reset?
  138. My Prelude will not start?
  139. vaccum hose diagram help with By-Pass control solenoid valve
  140. help v-tc aint workin!!1
  141. Does this sound like a transmission problen or a computer problem?
  142. jdm steering wheel fitment
  143. Idle Problem
  144. resonator (i think)
  145. Tranny problem
  146. Need help w/ choosing Koyo Radiator....
  147. prelude wont start, dash lights dead, battery/fuses ok
  148. looking for other with t3/t4 turbo i need to see some setups
  149. Do not install Type-S camshafts in a USDM h22 head!! Clearance issue w/ valve guide.
  150. wierd starting up problem
  151. Problem with AC vents...
  152. brake dust covers - yes or no?
  153. Shift knob, which weight?
  154. Need Motor Help
  155. 98 prelude base interior part missing
  156. pic request of a 5th gen prelude with black rota slipstreams
  157. Condensation buildup
  158. anyone had any success using the erl mf2 for turbo h22??????????
  159. Its all been settled...
  160. H23 Turns over, but will not ignite
  161. ***searched*** bleeding coolant
  162. loss of power through 5th gear at about 120 mph
  163. 1987 Prelude high idle, timing off, failing emissions test.
  164. VAFC installed along with nitrous... Vtec is jumpy... Possibly need to take and get tuned!!!!
  165. Fuel Filter Removal
  166. Tein Suspension
  167. Lowered 1997 Honda Prelude VTEC and snow.
  168. Coolant leak/overheating issue...
  169. Tein SS Install on 97 prelude base
  170. Koni Yellows + H+R Sports Q
  171. 91 Prelude Si 4WS Suspension Question! searched
  172. HELP JDM H22a Fuel rail question
  173. Heat wrapping exhaust manifold?
  174. f22b1 vtec solenoid fit h22a1
  175. 92 Prelude Si, Hesistating/backfiring.
  176. 92-01 Coilover Springs
  177. now thinking about goin vafc
  178. quckie question...fog relay buzzin'
  179. Broken axle stuck in tranny (pics attached)
  180. High Idle!!
  181. A few problems I encountered, that no one knows how to fix...
  182. 2001 Prelude Maintenance Schedule
  183. does anyone have a picture of a 5th gen with different carbon fiber hoods
  184. I need help
  185. stroking 2.2 to 2.5 opinions and advice welcome
  186. electrical problem HELP 4th Gen H22a
  187. h22 type-s?
  188. HID legal without projectors ?
  189. any suggestion
  190. idle problem when a/c is on --- SEARCHED!!
  191. will these fit ok? 17x7.5 42mm offset. pics please
  192. advice on which block to use for boosted H22?
  193. Headunit / Speaker problem
  194. Problem with AC switching on
  195. Help ek with JDM H22
  196. just ordered my H23 from Hmotorsonline.com
  197. Hondata and PLX
  198. BOSCH universial o2 sensor HELP!! 96 accord chasis with 93 jdm h22a
  199. What do you guys use to vacuum your Lude?
  200. 5th gear trouble
  201. should i buy this h22?
  202. Mystery H22 Valve Spring - Part # in post.
  203. Problem with my air condition!! help!
  204. Billions VFC
  205. Brake booster?
  206. parts needed for 5lug swap on 4th gen??
  207. Third Gear Grind
  208. H22A fuel injector issues
  209. Brake question.
  210. should i boost my H22A4
  211. Compare between H22A4 and H22A?? Cons - Pros?
  212. H series questions
  213. question about drive shaft and axles for 97 prelude auto to manual swap.
  214. Quick questions about odb I h22a Swap?
  215. Prelude factory sideskirts and rear trim
  216. Loud knocking noise after a mis-shift
  217. what could it be?
  218. obx lsd users post up
  219. any 5th genners rocking 15's?
  220. help
  221. greddy header ID
  222. My engine is makeing this noise.
  223. top end loss
  224. JDM Type-S Motor with a USDM Type-SH ECU
  225. 4th gen vtec
  226. H22A ecu question
  227. fuell problem
  228. Top Speed???
  229. Fixed back style corbeau racing seats...
  230. ? f22b1 v.s f22b2
  231. Running lean?
  232. need help with installing trunk spring
  233. Engine cuts out at high revs! Plz help
  234. Hard to get into gear
  235. where can i get fog light relay for 93 prelude vtec bb1?
  236. jdm fog lights .... parts i will need????? HELP
  237. 92-95 ecu on fifth gen
  238. 92-96 Cup Holder
  239. GReddy EVOTT pics? sound on turbo car??
  240. lsd vs no lsd?
  241. trying to find a lip for a friend
  242. A new dyno but still work to be done
  243. will type s oversized pistons fit directly on a h22a1?
  244. Prelude Si
  245. sh h22a4 block
  246. valve spring and retainer install
  247. Can this cause future problems???
  248. Converting ac to r134
  249. Megan Header Gasket Burnt?
  250. can't pull codes?
