PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 [224] 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. 94-97 Accord F-Series Automatic trannny being replace with H-Series tranny...
  2. Do 1998 automatic Preludes have overdrive?
  3. To h22 owners with with auto tensioners
  4. I Think You Should Check This Out (Ram Air on Prelude)
  5. Secondary O2 Sensor
  6. vtec problem
  7. h22a4 into a 92 sr prelude
  8. AEM fuel rail question
  9. turbo head gasket
  10. need some help with my 96 srv shell if not... accepting offers for it if you guys need one?
  11. are the new 2003-2002 cl type s motor stamp with a vin number ?
  12. HELP: Came out to car this morning, clutch floppy, won't engage, completely out of fluid, filled sti
  13. JDM H22 swap - Knock Sensor
  14. I need a cmaber kit
  15. tanabe coilover experience
  16. 6 feet under with Hondata...
  17. attn: Mike Nester
  18. BUBBLE IN TIRE
  19. anyone know how to get the orange color out of 92-96 taillights?
  20. wheel offsets
  21. 95 special edition. type s or not?
  22. Making Oil Cooler out of P/S Cooler???
  23. Brake light quick question
  24. overtensioned timing belt?
  25. TURBO OR NOS
  26. timing question
  27. how many qts of tranny oil for 5th gen?
  28. rattle sound just installed headers,high flow cat, and cat back
  29. short ram intake
  30. Tranny problem i believe?!?!
  31. where to get oil pump gear fo my 94 h22 lude?
  32. p73?
  33. grinding in 3rd question??
  34. H22a, JRSC & 440 injectors, I/E/H, Hondata S200, AEM Rail & FPR....What fuel pressure????
  35. Just got my second prelude!!
  36. I need a 98 prelude auto tip tronic tranny asap
  37. $0.11 Oil Catch Can
  38. SP2
  39. cams Qs
  40. Searched: ACT flywheel clutch... whats up with "225mm (220 stock)"?
  41. Just Bought HKB Hub and Momo Monte Carlo Steering wheel, help me identify which belongs to which
  42. Crankshaft swap
  43. Replacing Stock steering wheel in 97 prelude SH
  44. witch tranny has better gears ?
  45. oxygen sensor?
  46. HELP ME!!!!!!!
  47. help withfog lights
  48. Gen 3 1988 Prelude-S Come help with my project (project story)
  49. Markings on Prelude Type S Cams
  50. cut off?
  51. Pistons Q.s.
  52. Problem starting my car
  53. MAin Relay and O2 sensor
  54. Super Stripped Bolt in Fuel Filter
  55. Odd noise, possibly transmission.
  56. 96 OBD II h23 to 92-95 OBD I jdm h22
  57. 2003 Accord motor fit in 99 lude?
  58. Camshafts
  59. Ignition.
  60. h22a1 swap and extra stuff give me some input please.
  61. OBD2 to OBD1: Why should I do this?
  62. HELP! My cigarette lighter isn't working
  63. CF hood damage *pics are big*
  64. exaust
  65. Are the stock injectors on a JDM Type-S Lude same size as on our 5th gen's???
  66. pulleys
  67. prospeed headers
  68. need pics of h22 turbo catch can
  69. No flexpipe?
  70. Mallory 685 ignition problem
  71. all motor type sh
  72. Taillight ?
  73. Could this be bearings ???
  74. turbo h22
  75. Buying an H22 for 92 Si
  76. AC evaporator removal ????
  77. oxygen sensor wiring help
  78. engine problem
  79. would a JRSC for 97-01 h22a fit on a 92-95 H22a?
  80. HELP...problem with the clutch
  81. how much hp and tq with a hondata ecu give me
  82. Different Length Wheel Studs Normal?!
  83. type sh LSD vs a quaife LSD
  84. turbo for 88 Lude
  85. I need some help with my mod decisions
  86. h22a jdm...$2500 complete conversion sound like a good price? or not?
  87. in the middle of my h23 to h22 swap and i have ?s
  88. obd2 work around, obd1 p13 ecu
  89. help me decide...
  90. Finished adjusting my valves
  91. IGNITION?
  92. help cant get half shaft into new automatic transmission 3rd gen prelude
  93. Top speed on h23 gearing...
  94. got a 96 srv (obd II ) ... looking for an H22A complete conversion... PLEASE HELP... :O)
  95. 97+ Charge Pipe Question..
  96. best tranny for street racing on a fith gen h22 prelude
  97. what is the lug pattern for both the 2000 prelude and a 2001 accord?
  98. How to: Clutch replacement
  99. Autotensioner died, Honda of Hollywood sucks, and Diamond Bar Honda rocks.
  100. Radio aerial wiring info please?
  101. Buying springs/shocks soon...where to buy?
  102. merge or not to merge
  103. intake manifold?
  104. need help choosing rims for 4th gen vtec
  105. Tuning, need adice plz
  106. !~)* need some advice for my 92 lude *(~!
  107. Towing a waverunner with my lude?
  108. What is everyones timing set at on H22a swaps
  109. CAM GEARS, ARE THEY WORTH IT???
  110. Another gauge cluster question
  111. Need help with the cat converter
  112. H22 ITB's
  113. H22A engine for sale: Testing water
  114. Cam gears
  115. IAB vacuum problem. need help
  116. integra with h22 axles. please help
  117. Turbo F22 Help
  118. Big-o and alignment: ripoffs?
  119. h22a where is the best price
  120. Where to find a stock crank pulley and timing belt cover
  121. Turbo?
  122. Anyone know if the spark plugs (and gap) & fuel injectors are same on USDM H22a as the JDM Type-S H2
  123. final drive question
  124. where to buy an f22b
  125. choosing Cam gears?
  126. Skyline taillight conversion
  127. headers and power boost
  128. JDM H22 pistons...another a or b question
  129. 2nd gen vtec?
  130. 4th Gen IACV Location
  131. Idle Issues with JDM H22
  132. Intermittent Knocking under Acceleration. Non Directional Related.
  133. JDM black housing headlights question
  134. 2001 stock oem prelude springs?
  135. Opinions.... ATTS or 4ws?
  136. Wanted/Needed to buy: 4th Gen STOCK! Headlight(s).
  137. best clutch for 5th gen
  138. Violent noise at 7000 to 7500.
  139. Performance shops that love ludes in toronto?
  140. CEL and CA smog check
  141. turbo upgrade
  142. timing question
  143. cold air intake and rain?
  144. need engine help
  145. Muffler Question
  146. Engine Swap Problem
  147. How to: Cruise control removal
  148. How to empty gas tank....?
  149. Exedy clutch questions
  150. torque specs on the LSD for a jdm
  151. what strut tower bars and tie bars are good.
  152. squeaking and knocking in 2001 lude suspension.
  153. H22 Series JDM Valve Cover Scam
  154. retro-fitting projectors in 5th gen lights
  155. 99 Prelude Cd player Error message
  156. Rear Swaybar for 89 Prelude
  157. skunk2 stage 1 cams
  158. Skunk2 Valvetrain + Headwork Setup
  159. Tire size on Rota Slipstreams
  160. dont know why some peeps say they dont make a skunk 2 intake manifold for our car
  161. Where to buy Koni Yellows
  162. NGK Spark Plug ( Help A.S.A.P.)
  163. How much would you pay?
  164. Engine Questions
  165. Help for a V-tech Con. install
  166. Headlight not working!!!!
  167. LUK clutches
  168. turbo prelude SH ???
  169. CF Hood Question
  170. 5G Cylinder Head Swap Questions
  171. where to find these parts
  172. Knock Sensor/Hesitation
  173. LUDE UNDER ATTACK
  174. MSD Blaster 2 installation/Wiring
  175. Auto Tensioner to manual (h22)
  176. got new clutch/flywheel in!
  177. difference between 1,2,3... generation
  178. basic tuneup questions
  179. Gurus Needed! Several problems: Intermittent CEL, No cruise, and how do you adjust ignition timing?
  180. starting problem
  181. h23 pistons?
  182. Prelude h22 transmissions?
  183. Radiator in 92 Si
  184. Best Rear Sway Bar 5th gen lude
  185. gen 5 heated .. and power seats.. will they fit in a 96 ( gen 4) .... and work properly :P
  186. Jdm h22a QUICK QUESTION!!!! Short Question
  187. H22 vs Prelude ?
  188. 16 or 18 inch rims on the track
  189. Garage to get valves adjusted
  190. h22a in 92si wireing question
  191. 5th Gen Master Cylinder Brace
  192. lowering coils or coilovers?
  193. Got back from dyno with Euro R motor with JDMSHIT chip and K Garage map(lol)
  194. Whats a good lightweight wheel???
  195. 94 interior
  196. Got back from the Dyno with Euro R motor with JDMSHIT map and K Garage tuning(lol)
  197. Weapon R header
  198. 5th gen: sh oem exhaust onto base model?
  199. Sensor?
  200. greddy header to cat, conversion required?
  201. Weird Clonking noise when turning the wheel
  202. Need help wiring techmeter???
  203. 4th Gen Prelude Suspension Recommendations
  204. v-afc I or v-afc II?
  205. 5 speed conversion parts list
  206. does gasoline conduct like water?
  207. Prospeed header (pics inside)
  208. Silly question.. jdm folding mirrors
  209. F22 to H22. $3000 price qoute. any good?
  210. how should i build my bottom end for turbo
  211. speed "alarm"
  212. 89 prelude si FINAL PLEA
  213. which turbo for stock head/built bottom end h22???
  214. 4th gen prelude
  215. Some wires got CUT and now i have no AC?
  216. fan to battery and interior switch?
  217. Daytime Running lights
  218. Picture Request - 4th gen Radius Rods
  219. JDM powerfolding Mirrors
  220. first impressions: KYB AGX + Eibach Sportlines
  221. m3 mirror install
  222. Engine Identification?
  223. 4th gen vent replacement?
  224. I NEED A MOTOR FOR MY '92 PRELUDE!
  225. need 3 wire plug for my idle air control valve
  226. anyone know where i can find a banged up 96+ lude?.. (without the blood and human flesh in the glass
  227. skunk2 stage 1 cams
  228. front hub
  229. Running very rich
  230. New Tires
  231. skunk 2 intake manifold
  232. 98 prelude auto-tiptronic tranny acting up...
  233. JUMP POWER TO FANS FROM BATTERY?
  234. ABS light on in gen 4 lude
  235. 5th gen Susp in 4th?
  236. new distributor, now rattling noise from start up
  237. Wanted: 5th Gen OEM Exhaust
  238. anyone know what you need to go from auto to manual.. mod wise..
  239. all prelude website
  240. h22 deck plates?
  241. how much does a 92 si honda preldue weights
  242. Which tranny: H22A LSD, US H22 or H23 tranny?
  243. lude headlights
  244. Another afc question
  245. ngine rebuilding?
  246. 96 with obdI inspection
  247. Found something really weird in my car...
  248. Read Me
  249. Need help ASAP: Removing dash harness in a 4th gen Prelude
  250. Ring End gaps
