PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. will a 2002 h32 engine fit a 93 prelude?
  2. ITBs or Skunk2 IM
  3. Working Cat to pass inspection
  4. Where is there a good shop in Central Florida for hondas'?
  5. Possible rebuild thread :p Should I bring her back to life?
  6. Prelude / H22 Dry Sump System
  7. idle air problems???
  8. 1993 prelude instrument lights don't work??
  9. Brake problems
  10. Pics of my 2000 lude outside and inside
  11. h22 header ?
  12. Need help. Placing Mainshaft&Countersaft from TYPE-S into my tranny (non ATTS)
  13. anyone have an updated "removing cruise control" instruction
  14. 94 prelude electrical problem help plz.
  15. 2000prelude wiring problems
  16. What sensor is this?
  17. Snapped Timing Belt on H23 VTEC , The Results Are In...
  18. looking for 97-01 prelude tail light
  19. can i swap vtec into my 1997 crv?
  20. ABS code
  21. Prelude Wont Start!! HELP!!!
  22. Prelude Wont Start!! HELP!
  23. Best way to get a hold of a jspec?
  24. Vtec pressure switch
  25. Sleeper nitrous install ideas...
  26. OBD-II to OBD-I conversion.
  27. piratemcfred email is maste4269@yahoo.com
  28. g23 build finished today. feels weak and slow as hell
  29. H23 turbo. Alternator in way with log mani
  30. JDM Side Markers
  31. big trouble need help fast
  32. OBD1 H22a swap into '98 SH
  33. Starting issue, i have gone over everything i could think of, help!
  34. will this gasket set fit my jdm h22a?
  35. How to install s100??
  36. bleeding all fluids
  37. h22a swap problems! please help
  38. Rear mount
  39. 97 h22 swap into accord HELP
  40. Euro-R IM install result...
  41. looking to get a hold of pirate mcfred for adapter plate
  42. 2.2 si VTEC Problems
  43. 215-50-16
  44. diamond white pearl // premium white pearl comparisons
  45. My 95 vtec with slight mods is slower than my stock 96?
  46. v-tech / rev. limiter problems plz help
  47. Fuel Rail Service Port Thread Size?
  48. help me troubleshoot steering problem
  49. Axle compatibility...
  50. Sunroof question?
  51. idle air control valve question
  52. questions about sh model h22a4 and h2b kit?
  53. 1997 jdm h22a distributor part number?
  54. 4th gen quarter window trim removal
  55. mugen header problem
  56. H23 turbo
  57. what are you running for 450-500 HP axles?
  58. Replacing the connecting pipe (thermostat to water pump)
  59. Any One Ever Seen This? Transmission Issue & Vtec
  60. DIY interior refresh......check it
  61. Help me on prelude
  62. Skunk2 cam gear timing
  63. PLEASE HELP
  64. This breaker bar is *sick*
  65. crank sensor issue?
  66. muffler deminsions
  67. RHD conversion?!
  68. axle backs, some help is needed
  69. May Sell my 98 Lude
  70. Power Steering Rack / Tie Rod Problems
  71. OEM replacemnt motor mount
  72. H22a1 93' Running Issues - Not sure could be misfire/bogging and cuts out.
  73. f22a1 performence parts
  74. h22 smoking after rebuild?
  75. Front end creaking
  76. timing belt tensioner noise??
  77. Adjusting JDM headlights
  78. What pad/rotor setup are you guys running?
  79. SSR Header owners please post.
  80. all 4th genners who plan 5 lug swap, read this first (sorry was all in caps- everyone needs to know
  81. Turbo Prelude..
  82. OBD2 JDM H22 into a USDM 5g, crank sensor question
  83. A/F Ratio gauge on p13
  84. how do i stop the bolt on the bottom of the spindle to stop moving
  85. Does any one know how to do an aftermarket quik release wheel on BB4?
  86. Removing balance shaft belt
  87. looking for h22 lsd tranny
  88. 1988 Accord 5spd into 90 Prelude?
  89. 97 Prelude SH wont start
  90. Random Technology Cats
  91. 99 Lude type SH, What are some good ideas with this thing?
  92. spring and shock setup
  93. convert f22?
  94. prelude ecu swap
  95. Clutch is now flat! Drops straight to the floor..Nothing works :(
  96. ABS light Help!!
  97. Drag wheel/ tire combo
  98. High idle + aftermarket VTEC controller
  99. need help with my sh model h22?
  100. TB SIZE
  101. WTB: CAI for 4th gen
  102. running like crap, codes p0170, 0172
  103. Has anyone purchased one of the fiberglass lips from ebay?
  104. Cleaned my engine bay.....
  105. Has anyone ran Momo Racer wheels? (pic request/question)
  106. Trade/Sell 2001 Silver Prelude for Civic Hybrid 4-door? yay or nay...?
  107. turn signal question
  108. 97 prelude
  109. 17x7.5 front and 17x8.5 back??? would this fit a 4th gen prelude????
  110. camber kits
  111. cruise control??
  112. Anyone order a large part from Majestic Honda?
  113. Clutch Problems
  114. Can you swap out 4th gen sunroof to 5th gen??
  115. Anyone Parting Out H22 Head?? Need Parts!
  116. real question h23a1 head on f22 block
  117. low rpm hp
  118. Puttering noise at idle HELP!@ H22A
  119. shock setting?
  120. anyone rock 2 inch drop skunk 2 lowering springs on 17s?
  121. Just got back from the track...
  122. Can I remove aftermarket 2 piece headers as one piece
  123. is there aftermarket for this?
  124. obd1 h22a goin into a 5th gen prelude se model need help...
  125. IM spacer/gasket
  126. jdm dizzy?
  127. How can you tell if you have a base model or an SH?
  128. Running lean but only when warm
  129. power steering again
  130. lightweight drag rims/slicks
  131. type s head swap
  132. Ricer question: Anyone seen a CF roof skin?
  133. A/T Shift Release - please help!
  134. Searching for ideas on h23 missfire
  135. h22 problems
  136. HELP!!! A/C compressor
  137. Does any one have part numbers for the oem optional kits?
  138. OBD2 test connector where ?
  139. pro kit, h tech, or coilovers? w/illuminas
  140. 5th gen SH header question.
  141. h23a starting issue
  142. Manual Boost Controller
  143. Ecu and Harness
  144. 4th Gen Harness Bar?? Should I????
  145. turboed h23 with a problem
  146. ZER0 oil pressure. and no voltage to plugs?
  147. 5th gen fog light replicas
  148. hey i need help with my tranny
  149. 4th gen power steering question
  150. Balancer Belt??????????
  151. bogging...WOW help!
  152. Rasping noise in engine
  153. Wings West Big Mouth Body Kit
  154. Tranny Question
  155. speedometer is off
  156. Rare Tire? Need one OHTSU
  157. header
  158. half shaft failure 96 si (right side)
  159. price opinion
  160. -Oil Seals, Hondabond or not?--
  161. Wheel Brand
  162. Can someone advise me? (about m7 wheels)
  163. Steering wheel and SRS??
  164. Wheel diameter Vs Offset Vs Lowered 5th Gen
  165. want to know how to relocate battery to trunk thanks
  166. almost done with my jdm h22 swap.. soooo?
  167. it cost this much to fill up my tank
  168. Pressure reading on the VAFC at WOT
  169. USDM h23a FPR Vs. JDM h22a FPR?
  170. baffled sumps
  171. Header question please help...??
  172. Lower Ball Joint Will not seat right
  173. Car stays running with the key off
  174. Intermediate Shaft question
  175. quiq quistion ????
  176. question for my lude
  177. H23 HELP
  178. p28 with s200 help please
  179. ARP Head Studs
  180. 5th gen seats in 4th gen
  181. supercharger
  182. timing belt
  183. balance shaft
  184. will t3/t4 turbo manifold/turbo get in the way of AC and PS
  185. Questions about a turbo setup for those with experience
  186. SRS Light?
  187. can someone confirm for me?
  188. Cool and Heat lever
  189. crankshaft pulley bolt
  190. 5zigen offset
  191. BRAKES
  192. Oil light on, '93 Si with jdm h22a.
  193. 97 Prelude Won't rev past 3500 rpm...acting like a rev limiter
  194. 225 45 17 to wide?
  195. Low profile seats?
  196. Is this a good deal?
  197. need saenz h22 gear set
  198. Skunk2 camshafts on JDM Prelude BB4
  199. greddy turbo kits
  200. What sensor is this?
  201. car dieing due to turning on accessories
  202. 1st gen anyone?
  203. 4th gen, low offset wheels
  204. 1992 Honda prelude 4ws light
  205. hi-flow cat
  206. Help programming factory remote for 1998 prelude
  207. JDM h22a swap fuel pressure questions
  208. 2008 Honda Tech Bay Area JDM Meet
  209. Official 5th Gen Prelude picture thread?
  210. question about moog upper ball joints...
  211. water pump question
  212. 1998 honda preldue MOMO steering hub?
  213. Prelude head removal
  214. cant tell if its a rod knock im lost...
  215. h22a... a-what?
  216. car running too rich?
  217. I am a new user..
  218. what to look for when buying a used transmission????
  219. question about compressor (turbo)
  220. What the heck, Won't start!!!
  221. Oops.. need help
  222. Transmission help
  223. 2001 honda prelude
  224. Brake Master Cylinder
  225. i figured you guys would like to see this...
  226. how to bleed power steering system?
  227. Problem with my power steering help me please!
  228. b18a to b20 swap ?'s
  229. how to take off front bumper
  230. Buddy Club Pro Spec Exhaust
  231. pics request
  232. H22A removal
  233. 01 Prelude Emblem
  234. Apexi N1 vs Greddy
  235. Turbo vs. Supercharger h22a
  236. B18 Swap Into 99 Prelude
  237. Removing Flywheel with No Clutch Tool
  238. TPS technical specifications
  239. Really weird question(s)
  240. 2000 SH values
  241. Please Someone help me, with JDM H22 wiring problem Thanks.
  242. Water Pump Replacement
  243. Interlock Control Assembly
  244. 5th gen mugen bumper
  245. Driver window not working on '93 Si.
  246. how much is to rebuilt a h22A4?
  247. My LED Tails
  248. Rotor Off?
  249. Concerning best ECU for Turbo application on my H23
  250. H22 or Rebuild H23?
