View Full Version : Honda Prelude
- 4th gen owner, i need a measurement
- 97+ lude timing chain?
- H22 specs question
- H22A Low Idle/Brake related?
- free oil from mobil
- IAB's vs. No IAB's (Answers and Dynos)
- Prelude JDM H22A auto to manual conversion
- car price salvage title
- cant rev past 6000 on 94 w/h22
- Gauge Probelms
- 92 prelude electric problem.
- ?H22 question?
- Broken Axle?
- 92 si engine
- Performance question
- Prelude SI with H22 motor, what cat to use?
- 97 Honda Prelude Automatic Transmission (sports-shift) when parked and switching gears engine almost
- Prelude 97-01 struts/shocks/springs?? Front is lower then the back? Need some lowering expertise..?
- no spark - need help quick
- 94 prelude vtec running really slow
- Hondata s200 == smooth vtec not much kick and pulls much harder before vtec
- Forged bottom End
- Help. Clutch went out?
- Zex dry nitrous kit...bought it off ebay..
- Emissions results- FAILED- need some help translating what it all means.
- prelude ball joint? searched?
- knock sensor
- ***MSD wiring problem***
- Are these good coilovers JIC
- Need a h22a in Ontario/Quebec ... can anyone point me to a good vendor?
- Shaky Steering Wheel....sometimes ??
- 604whp H22 Powered Accord
- JE rings in FRM sleeve
- One of HID lights is giving up on me (want to know why)
- What year was the prelude manufactored in US or canada the first year
- B20 Performance Suggestions?
- 92 prelude SI...VS Del Sol Vtec / Integra GSR
- Suspension - stock spring rates?
- IM technical question
- My auto-x results (aka wrx killer) Did I break an engine mount???
- 5th Gen Headlight Removal
- valve cover torque spec?
- Wing West don't make lips for 5th gen preludes?
- Q on factory prelude cd player
- My bolt for my crank pulley broke. Please help!!
- Does anybody know if...
- problems taking knock sensor off!
- obd1 h22
- Performance help
- When did your stock clutch go out? Guaging budget for the summer
- Price of a Prelude.
- vafc2 settings
- 93 Idling problem...
- Spring Rates on Stock Suspension
- Holy moly..no boot on axle
- OBX LSD : Buyer beware
- Noticed something weird will suspension look
- Cam Gear Fitment
- Exhaust manifold bolts?????
- h22 swap done - but no power from 1k-3k rpms! HELPPP
- PROPER hose routing for H22 "oil catch can/breather" needed! I have searched...
- Pics of my retrofit
- Missing ARP washers for headstuds, What can I do?
- Need some identification help.
- Oil Pan Install>?
- OBX Intake Manifold Install Q?s
- adjusting valve clearance..180 turn @ each cyclinder?
- A/C slider wont slide all the way to cool end
- what oil should i use??
- tie rod/alignment problem
- my air doesnt blow cold at a stop...
- Prelude 97-02 Koni yellows on Prelude 95
- integra projectors in jdm 1 pieces
- coilover options for bb6???
- Greddy Tbelt backorderd
- H23...H22 TPS
- JDM H22A Type S or Skunk 2 Manifold?
- will a h23 water pipe fit a h22
- check engine problem!!!!!
- Speedometer gear on the differential...
- Wanted various parts for 97 lude
- H22A1 and H23A1 Confusion
- Tensioner Question
- Grounding system really work?
- Fuse Box Diagram (under the steering wheel)?
- for you h22 owners. (intake manifold)
- Can some1 post a pic of door internals
- Euro-R Intake Manifold on H23 non-VTEC?
- Primary Heated Oxygen Circuit
- '92 Prelude Si speedometer not working
- 1986 twin carb prelude
- 2001 Accord 'Euro R' Manifold Modification & installation pics
- weird noise help plz
- who's got a CAI, and hydrolock
- Possible Water in CAI. Service light on.
- Bolts Stuck In Bushings!!!!!
- prelude battery relocation
- h22 bogging problam.
- clutch prob
- type s pistons and cams
- What happened to my car, and how can I make sure it doesn't happen again?
- Driving on the spare..........
- Code 23 knock sensor... but why?
- tranny trippin
- how thick is an oem sway bar?
- Quick tensioner help
- texas shops
- At what point (ATTS question)
- H22A fuel pressure...
- JDM H22 throwing CEL 23 knock sensor
- Please Help H22 in to H23 1995 prelude
- Prelude problem
- Loss of power on h22...
- Checking Vtec head oil pressure
- koni yellow install
- flex pipe leaking, broken motor mounts?
- Yes i know this is the Prelude forum.....
- Slave cylinder dead, replacement and causes?
- Friends accord with H22 having problems
- Need wiring connector help...
- axles
- what a bitch ass site....
- Sway bar question. Searched.
- Camber Kits for BB6??
- a/c compressor help! Its freakin hot!
- sequential turbocharging
- Engine noise at 65+ MPH
- Remove stock intake and box, any gains?
- Motor mount bracket for my accord
- 98 h22a4 minor mods love jdm p13 ecu. why?
- Uh Oooh, an mystery prelude problem I have...please help
- Done with h22a swap and manual conversion
- exhaust questions
- Valve clatter until car warms up, then none
- 98 Prelude shifting difficulties - help diagnose
- is this the alarm brain?
- 17mm Starter bolt problem
- Stock fuel pressure regulator 4th gen h23
- help installing autometer air fuel gauge 5th gen
- type s pistons os or not
- how to use a timing gun on h22a
- lambo doors help
- help: JDM H22a into 92 Accord EX with auto tranny but no spark
- whats the name this h22 part
- 92 lude stops after a while
- 1998 prelude headunit install help
- belt length to bypass ac compressor??
- What size exhaust to get?
- vtec died... HELP
- Type S Intake pipe size?
- optima red top?
- 2nd gen si tranny questions
- Need Help Tried Everything!!
- h22a1 lots of black smoke @ v-tec rev.. normal?
- broke my knock sensor installing hondata gasket...should this effect my idle?
- Help: Idle Woes
- Im about to remove the head but have some questions.
- 5 gen Tein S-Tech springs need camber kit?
- JR Prelude EMS Users, Hows Reliability?
- Rod Knock, need help please!!
- did you guys ever see this before?
- Strange Noise (Vid Included)
- Clutch Issues
- Vafc 2 install
- 5th gen Polyurethane engine mounts?
- Confirm wiper motor?
- Need help on speeding ticket.
- THE OFFICIAL compression height and center to center calculations thread
- Vecco Turbo kits
- Can someone help me?
- Car shuts off while driving!
- THE OFFICIAL Offset Grind thread (offset grinding H/F crankshafts explained)
- need help finding writeup for installing LCD screen in fourth gen
- 91 2.0si dies
- what are these plugs?
- Need Help Please Help!! JDM H22A
- Idle problem
- car won't start after replacing TPS and radiator. HELP please
- problem with tachmeter at dash.
- 5th Gen SH Transmission Problems
- Ok any ideas?
- 1st gen hondamatic tune up
- 98 Lude - Shifter Problem?
- borla exhaust
- suspension
- WHeres a good reliable place to buy Remanufactured transmissions?
- Will a 1997 H22a Base 5 speed transmission bolt to a 95 H23 non-vtec?
- Turbo Kits for 5th Gen
- Does anyone know how to adjust climate control cable..5th gen
- SS Autochrome
- Squealing brakes
- brake lights out on both sides HELP
- ECU Cycle?
- where do you get JDM foglight covers for a 5th gen mugen kit.
- Idle Bounces - When using Lights / Heater / Radio
- h22 or all motor h23 or h23 vtec
- 92-96 prelude owners.....
- just instaled a oil can but dont know what this spare part is
- Whats this number mean?
- 97 - 2001 prelude parts for sale and other randoms things
- Nitrous jet sizes for direct port
- 89 Prelude Upgrade Internals
- ABS removal question
- S2K seats into 98 Prelude
- Type S Pistonfor AAAA block
- Where to add lucas transmission fix?
- B20A jdm Swap Help!
- mahle h22 11.3 valve relief question
- Need help.... lude was stolen in Cali i know its still around... DONT DELETE PLEASE !
- what color rims on a black 5th gen prelude
- different engine in a 5th gen prelude
- built h22
- Electrical Help
- Intake manifold spacers...
- CHECK ENGINE LIGHT
- ground control AND koni yellows
- Starter not engaging new flywheel? Starter checks out ok.
- need to know what theis hoses are on a type sh lude
- H22a & H22a1 intake manifolds... any differences???
- parts
- Maha Dyno?!
- anybody polished/paint theres?
- NEPTuned h22 380whp/320tq!!
- Skunk 2 dyno ..Before and after
- Clutch slipping in 2nd gear
- H23A (jdm motor, not hybrid) questions
- cars not starting in hot/warm weather??? help please
- H22 ring lands? Is this a common problem?....
- 1992 Prelude SI Electrical Problem: Interior Lights
- OEM 4th Gen downpipe and DC sports header?
- Intake Header and Exhaust...What's next?
- motor mount repair
- ITB's or Turbo the H22
- sh header
- Warranty...using oil
- Need Help with Oil pump removal
- Installing OEM spoiler
- 5th Gen Electrical Problems, please help
- POwer antenna works but not in my car. Help please
- Problem with stalling, need some input
- For those of you with jdm h22's
- quick KS question about size
- Factory LSD Tranny
- When i buy an h22a will i have to...
- O2 Sensor Location
- Help please: What is this "rod" next to the axle?
- hytech headers
- crank removal.. help plz...
- 4th gen suspension help. SKUNK2
- what could bust a crackin your trans case? :a snychro letting loose and breaking?
