H22A Vtec engagement... already searched.
Old Oct 22, 2003 | 04:16 PM
ozzyman's Avatar
Default H22A Vtec engagement... already searched.
Whats the Vtec engagement point on a OBD1 JDM H22A. Already searched so dont flame.
Old Oct 22, 2003 | 04:20 PM
Honda Sport's Avatar
well mine's engage around 5200rpm. Really depends on the ECU you use.
Old Oct 22, 2003 | 04:37 PM
accordhybrid's Avatar
Default Re: (Honda Sport)
I believe all P13's engauge at 5200
Old Oct 22, 2003 | 04:46 PM
satan_srv's Avatar
Default Re: (accordhybrid)
Okay for the last time it's 4900 I'm looking right the damn helms. It may look like 5000 on your tach but it's 4900.
5th gen preludes engage at 5200 though.
You can see right here on my stock dyno VTEC has engaged before 5000 rpms.
Old Oct 22, 2003 | 06:56 PM
Eddiebx's Avatar
the JDM p13s as well as the usdm obd1 p13s all engage at 4900, and fuel cut at 7600. Not sure about the 5th gen ludes though.
Old Oct 22, 2003 | 07:21 PM
see_our_vtec's Avatar
Default Re: (Eddiebx)
satan is pretty much right on the ball. but it's actually more between 4900 and 5000 on your dyno chart. more or less 4950ish. but still 4900/5000 is typical. and for the last time. fuel cut is not 7600rpms.
Old Oct 22, 2003 | 07:28 PM
Default Re: (jspecbb2)
mine engages at 4,967 ...........well when it was stock it did......now it's at 4600
Old Oct 22, 2003 | 11:34 PM
ozzyman's Avatar
Default Re: (JDMlude92)
LOL, this gives me like 4 different answers. I think mine engages around 5200, not sure about fuel cut off. I took it up to about 7800 and no fuel cut off, so I'm not sure. Anyone has any hard proof? Besides the dyno chart??
Old Oct 22, 2003 | 11:39 PM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlude92 &raquo;</TD></TR><TR><TD CLASS="quote">satan is pretty much right on the ball. but it's actually more between 4900 and 5000 on your dyno chart. more or less 4950ish. but still 4900/5000 is typical. and for the last time. fuel cut is not 7600rpms.</TD></TR></TABLE>
and how did you verify that? cuz on the few stock USDM and JDM ECUs I tried out, it all cut of at about 76xx rpms according to my datalogs
Old Oct 23, 2003 | 12:09 AM
according to my data logs.(both usdm and jdm p13's) i got around 7850. and once somehow i got 7,9xx. next time if i have a camera i'll take a pic.
Old Oct 23, 2003 | 12:26 PM
ozzyman's Avatar
Yeah, I agree. I got around 7,800 and had no fuel cut off.... I dont wanna try to rev up that high but I might have to
This is OT, but has anyone tried running chipped P28s or P72s?? If so.. how did they feel?? Just wondering cause I have an idling problem with the JDM P13.. but when I plugged in my friends P28 w/ Mugen chip.. idled perfect.
Old Oct 23, 2003 | 03:04 PM
Default Re: (ozzyman)
ot: thats weird that you say that. cuz i had the same problem. and so did a guy i know. and so did the guy i sold my jdm p13 to. weird.
Old Oct 23, 2003 | 04:42 PM
SKDRCR's Avatar
yes but isn't the tachometer actually off about 400 rpm,
say your at 7900-8000rpm, aren't you actually @ 7600 or so
Old Oct 23, 2003 | 04:51 PM
KW2000's Avatar
Default Re: (SKDRCR)
4900 RPM for stock 4th gen ...dunno where i heard this but isnt 4900 the best engage point for stock cam gears and cams...? thats what ive heard whats the benifits of lowering the vtec engage point to 4600 other than the cool sound
Old Oct 23, 2003 | 05:06 PM
criddy. actual datalogging. not my stock tach. my actual engine rpms.
Old Oct 24, 2003 | 10:30 PM
Eddiebx's Avatar
actually sorry, I would like to correct myself, the stock revlimiter is at 7700rpm. I finally took the time out to look in my manual, I always assumed when I logged like 76xx rpms, that meant 7600,
And yeah the stock vtec point is 4900, if you have a vafc or something you can probably benifit by lowering it to about 4600-4700, thats the spot that I find good on the dyno. I picked up about damn near 25hp at the vtec switch point by lowering it a bit and playing with the fuel.
And finally that wierd idle with the p13s has something to do with the EGR mess. I remember we had this problem on my boys hybrid too, and we swapped out to a p72 and it was golden.
Old Oct 24, 2003 | 11:02 PM
fizzbob7's Avatar
i'm 100% positive that my JDM p13 from a 1995 model lude had the vtec x over at exactly 5200rpm at WOT......112mph speed limiter too, whereas some are 117mph and supposedly some are 110mph......now with my chipped p28, it's at 4900 but is still a bit too high.....
Old Oct 24, 2003 | 11:08 PM
Default Re: (fizzbob7)
p13 ecu's xover at 4900 rpm's. speedlimited(jdm) at 112(actual mph). now what you guys must realize is that stock tachs and stock speedo's are off. not by the same amounts allways. one person's car might cut out at 118. one might cutout at 115. but the ecu cutoff points are the exact same(in actual mph)
Old Oct 25, 2003 | 01:51 AM
ozzyman's Avatar
JDMlude92, Thanks for the all info. I just want to make sure that the idling problem is normal I dont need to do any major diagnosing. Also doesnt H22's have secondaries? I havent heard anyone mention about them or when they open up. Would my secondaries work if I used a P72??
Old Oct 25, 2003 | 03:49 AM
Que_Lude's Avatar
Default Re: (satan_srv)
Do you have the stock a/f ratio's on base dyno runs for the USDM & JDM engines? (Sorry this is a little off topic)
Old Oct 25, 2003 | 06:43 AM
NirVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlude92 &raquo;</TD></TR><TR><TD CLASS="quote"> and for the last time. fuel cut is not 7600rpms.</TD></TR></TABLE>
When is it then??? 7700? It looks like 7800ish on the tach.
Modified by NirVTECn2o at 4:01 PM 10/25/2003
Old Oct 25, 2003 | 02:57 PM
Default Re: (NirVTECn2o)
you've got me. i've smacked revlimiter at 7,786 and i've smacked it at 7,956 who knows.
Old Oct 25, 2003 | 07:52 PM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NirVTECn2o &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by NirVTECn2o at 4:01 PM 10/25/2003</TD></TR></TABLE>
7700 , if you don't believe me its in the manual
Old Oct 25, 2003 | 11:23 PM
next time i'll take pictures for you guys. i'll try and get another 7,9xx for you guys. maybe my ecu is just weird(doubt it though). when i shift. it's normally right at 8k on the stock tach. which usually nets around 7,750ish datalogged. but every now and then i'll be able to sneak a 78xx or a79xx in there.
Old Oct 26, 2003 | 01:48 AM
EK22Tim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlude92 &raquo;</TD></TR><TR><TD CLASS="quote">ot: thats weird that you say that. cuz i had the same problem. and so did a guy i know. and so did the guy i sold my jdm p13 to. weird. </TD></TR></TABLE>
Seriously?? Me too? What kind of issue?
