PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 [200] 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. any superchargers for the 4th gen prelude?
  2. 1994 Prelude VTEC
  3. need parts for shocks
  4. 1991 prelude 4ws si 2.0
  5. diffrence between type s cams and skunk2 stage 1 cams
  6. Mysterious smoke.....
  7. I just bought 97 lude, but :((
  8. best wheels?
  9. any body have dynoes for kteller header?
  10. h22a swap in my 1996 prelude need help!!!
  11. H22 flywheel
  12. Throttle Body Sensor
  13. Rubber exhaust hangers
  14. tein ss springs
  15. anyone on H&R race springs?
  16. tire size question and drag radials
  17. Dynoed the Obx cams, prospeed header,and skunk2 intake manifold.
  18. I STILL HAVE A THERMOSTAT PROBLEM!!!!
  19. JDM Spark Plug Wires
  20. Hondata clutch switch
  21. My last o2 sensor question for my 2000 'lude.
  22. 5th gen conversion
  23. where can i take my h22to get it sleeved in pa wv md help and how much will it cost
  24. How to take the sunroof of a 92 si?
  25. Mahle Motorsports Pistons
  26. HELP!!!!Anybody have a prelude intermediate shaft
  27. h22 half size radiatior?
  28. Crower stage 2's?????
  29. 5th gen exhaust pipe lengths (SH vs. base) Help!
  30. I threw a cel :(
  31. done a few bits
  32. Cost of bottom end rebuild?
  33. Prelude Colors; Silver / White
  34. H22 Port/Polish Question & Concern
  35. Ebay HID Xenon Bulb review
  36. Taking out stock gauge setting
  37. I need help with choosing an ecu...
  38. Prelude header question (not like the rest...i promise)
  39. Growling intake noise/CEL code 17
  40. Bogging/hesitation
  41. Where is good to buy tires?
  42. How to protect carbon fiber??
  43. 97 Prelude Immob ECU question
  44. cv joints- popping sound when making hard left turns only
  45. skunk 2 Im install.....
  46. prelude brakes
  47. Clutch Problem... I hate clutch problems..
  48. Oil sender instalation
  49. H23 HELP
  50. just received my gcs today... what are these?
  51. Gauges
  52. H22 and H23 Oil pan
  53. What are these wheels?
  54. Header Wrap on Intake
  55. BIG Vibrations when Accelerating.
  56. question about 98 prelude
  57. can u put a h22 head on a h23 block help
  58. Heating Problems
  59. winter steelie size help
  60. HID HELP
  61. NO AC or power steering
  62. Buying a new clutch/flywheel
  63. what pistons should i get 8to 9 to 1 for a h22 turbo
  64. Clutch/Transmission Fluid
  65. can u put a h23 tranny on a h22 block help does any one have any parts for the h22 block for sale
  66. Pulleys
  67. Has anybody heard of Hazidous Racing in California?
  68. 300bhp NA from a JDM Vtec Lude. Possible?
  69. Gsr ecu on
  70. What you guys thinking about this deal
  71. Opinions on intake manifolds ?
  72. Help! Camber kit problems
  73. spark plugs for turbo (searched)
  74. Sometimes I get no vtec and fuel cuts off at 6.5k, what's up with that?
  75. spoon rad cap
  76. Vaccuum Leak.. ??
  77. HID problems
  78. wtb 5speed swap parts, no tranny needed
  79. On/Off Switchable PS Pump
  80. Thinking about upgrading brakes, suggestions?
  81. car doesnt start sometimes
  82. Clutch
  83. help with muffler!!!!
  84. stock heat range
  85. for those who have seat warmer?
  86. any H series guys using an oil sandwich?
  87. Tranny Fluid
  88. 2W vs 4W on Jdm p13 - What does it mean
  89. h23 to h22 swap completed - HELP -
  90. TURBO PICS NEEDED
  91. H22 Turbo Kit on H23 motor....possible?
  92. Turbo the H22A1
  93. Camshaft tech
  94. Check Engine, Seatbelt, Low Fuel Light Don't come on!!!???
  95. 5hp gain from 98 to 99...
  96. Decent price?
  97. Help with axel dilemma, did a h22 swap into h23 94 lude...
  98. Where to buy complete gasket set for h22?
  99. how much boost can it take a h22 on stock parts vs how much a Build motor what the best turbo an
  100. Brake Light on dash when its cold
  101. can use h23 stuff on a h22 like ALTERNATOR starter Distributor crank rod ?
  102. rim offset question
  103. h22a4 questions
  104. Want to install keyless entry + alarm
  105. key locked in ignition
  106. need help on egr switch wires for h22a jdm in a cd-5 obd1 1994 accord lx
  107. 91 prelude motor
  108. quality parts for h22
  109. wierd temp problem the car gets colder at acceleration ?
  110. h22 clutch line question???
  111. Help pls Electrical
  112. Heat Problems:
  113. will h23 and h23 vtec turbo fit each other?
  114. hot in here
  115. How do i get the timing belt drive pulley off?
  116. Trouble Codes??
  117. Vacuum line sizing
  118. h22a head
  119. cam gear question
  120. im new what are some easy ways to get more power
  121. GT28RS Disco Potato for H22A4
  122. shift knobs
  123. Squishy Spring Seats
  124. Still have NO VTEC HELP!!
  125. do all preludes have bad axels
  126. Idle is too HIGH
  127. floating wrist pins install???Help
  128. oil pressure gauge install
  129. 60k on jdm h22 coming up
  130. Torque specs
  131. h22a4 for a jdm h22a
  132. shifting trouble
  133. Tranny swap
  134. Crank pully nut
  135. From the Lehigh Valley area? Want your car featured in Pulse Weekly?
  136. ITB Q's
  137. AEM CAI vs AEM V2
  138. Type S cams with stock springs and retainers?
  139. Neuspeed Sway Bars and 4WS ?
  140. 1995 Prelude H23A2 engine
  141. trying to convert my JDM JDM H22A -> ODB 2
  142. stock overbored pistons. Tried searching couldn't find what I need.
  143. have to get it
  144. 3bar map sensor
  145. anybody with an endyn catch can on a h22a?
  146. Does anyone have a dyno plot for h22a all motor type s
  147. will new stereo fit?
  148. H22A, no v-tec 6k rev limit
  149. Problem need opinions
  150. max tire size with 4ws
  151. PLease tell if anyone knows... About Stock ECM
  152. Wierd temperature problem. I need info please!
  153. skunk2 stage 1's on factory valve train
  154. how to convert to internal coil distributor using h23 si harness?
  155. Turbo?
  156. clutch slippage
  157. Falken Azenis St115 or Toyo Proxes 4
  158. boot light on
  159. platium sparks or normal
  160. Rear View Mirror
  161. Prelude repair question - Sorry, another newb
  162. Prelude OEM Car cover
  163. E-brake light
  164. 95 VTEC with Euro-R motor: Need Advice
  165. WTB: 92-96 Honda Prelude part's
  166. s2000 seats in gen4 lude?
  167. Prelude Wanted....what should I look for?
  168. Radiator Cap 13 or 16lbs?
  169. 99 prelude 5spd transmision
  170. Buying new Transmission >/< Rebuilding Current Transmission
  171. power steering belt
  172. prelude fuse panel
  173. SH Ecu on a 4th gen?
  174. best place to buy parts?
  175. suspension install instructions for 4th gen lude
  176. What wrong with my tranny? Shifting funny
  177. 5th Gen Transmission
  178. Cat. Flange difference on S, Si, & VTEC.....
  179. Where can i take my H22A Motor in NOVA Virgina
  180. springs/retainers
  181. gauge mounting
  182. 5th gen factory sevice manual
  183. balance shaft misalignment / help sought
  184. act unsprung 6buck with xtreme pressure plate
  185. Greddy Header In Stock
  186. heater valve?
  187. How much power does an automatic trans. H22 have?
  188. broken headlight mount..... first time JB weld ever failed me
  189. Prelude 87-91, 92-96, and 97-01, Fuel Injectors Sizes?????
  190. car is running shitty
  191. Question about motor???
  192. obx at it again
  193. How much does an H22 weigh?
  194. CEL p1259 v-tec malfunction, fuel cut @ 6800 rpm on my h22 HELP!
  195. Haynes Manual?
  196. h22 clutch on a h23?
  197. Where Could I Find Transmission Wiring Diagrams, '89 Honda Prelude.?
  198. So it's an Accord, but hope for preludes... I hit 12's last night NA!
  199. V-afcII 4 you?
  200. H22 Crank Pulley Question
  201. Air Intake Bypass Solenoid HELP
  202. Slanted Exhaust...
  203. foglight bulbs
  204. Will Fuel and Temperature Gauges from manual JDM BB4 prelude work in Automatic
  205. A/C Removal Weight Savings
  206. Prelude Engine question
  207. which bulbs?
  208. Getting exhaust on a 98 lude
  209. Redline on JDM H22a
  210. how much would i gain???
  211. lug nuts... HELP
  212. does the leather steering wheel of 97 accords fit 4th lude?
  213. tach off
  214. car got jacked
  215. Heater problem
  216. srs module...
  217. salvage
  218. Prelude cam gear!!!!
  219. I need help!!!!!!
  220. OEM lip replica
  221. IS MY ENGINE DEAD??!?!
  222. 4th Gen Reverse lights gone mad
  223. how much is a used drag 3 turbo worth?
  224. 95 Prelude VTEC threw Engine Code - help!
  225. Buddy Club P1 Rims
  226. temp gauge
  227. vafc cel help ASAP
  228. belt tensioner location.
  229. best 5th Gen Header & Catback Combo
  230. Lowering the car (5th gen)
  231. Break In Process
  232. turbo prelude engine temp
  233. Distrubutor change with change to OBD1 ECU?
  234. Need Wheels!!!
  235. Prelude SI vs. Del Sol
  236. i'm the proud owner of a...
  237. Boys and Girls of the Prelude forum, help out my friend please
  238. Small wreck...
  239. H22 rocker arm machining
  240. test pipe
  241. Accord Lip / Rear Valance
  242. Is it just mine or are the front defrosters on 5th gen slow?
  243. Tranny wont go into gears (kinda long)
  244. Powerslot rotors a good buy?
  245. Is it worth it?
  246. Will Strut bar fit?
  247. WAstegate spring
  248. Type SH and Base comparison. Why the SH needs its own block code. *Pics Inside*
  249. h22a oil problem?
  250. clicking when I turn
