PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. - Another H22a Swap Aftermath, Thoughts, Things learned – Extensive
  2. HELP! F20B into 97 prelude
  3. strange question.
  4. H22 Accord Euro-R Tranny Parts
  5. H23 wont start/replaced head gasket? Help
  6. Hydrolocked motor, need help with head removal.
  7. FIRE under the dash!!! which harnesses will work?
  8. JDM BA4 BA5 INX Prelude 88-91 Digital Climate Control
  9. car oil temp gauge goes up in traffic---
  10. Passenger Side Suspension:HELP!!!
  11. Koni yellow question
  12. whats the casting # for the front prelude 5 lug
  13. Shifter Cables
  14. Back end is jumpy
  15. Another DIY- double stack intake manifold
  16. Brembo Corss-Drilled or so they say
  17. How to remove air filter resonator?
  18. 2000 Prelude burning oil??
  19. Can you identify this?
  20. Warmup Issue
  21. 1988 - 1991 - Common Issues?
  22. Bad Auto tensioner?
  23. JDM swap durability
  24. h22a with h23 tranny will it work?
  25. High Compression
  26. Strange fast idle problem when moving only.
  27. Any Charlotte,NC members here, need help ASAP
  28. fuel pump question
  29. IAB Vacuum hookup with broken nipple
  30. i love my prelude
  31. idle screw help me
  32. b-series tranny on to H motor?
  33. Help me and my 97 prelude!
  34. 5th gen loss of power & very loud engine
  35. help put head bak on
  36. F22 Ecu problems
  37. Will ABS removal affect 4WS
  38. Tire rubbing?
  39. h23vtec header
  40. 5th Gen Alternator in 4th Gen... any benifit?
  41. Factory air intake
  42. H23 Rebuild, need some advice.
  43. whats moving? (oil squirters)
  44. accord rear lip help
  45. Can't decide on coilovers
  46. need help with a timing belt for a h23head and f23 block
  47. Help ignition bad?
  48. I need some parts
  49. Whats the best racing header?
  50. Hood help?
  51. grinding noise at low rpm
  52. Replacement Quarter Panels
  53. HELP! clutch slave cylinder
  54. H/F spool solenoids
  55. d16 alternator on my h22a
  56. SRS system Removal
  57. 5th Gen Airbag
  58. 1993 prelude h22 for sale
  59. quick question on routing clutch line w/o clutch damper
  60. What aftermarket intake manifolds fit a egh22??
  61. h22a sluggish/hesitation when cold
  62. H22a turbo build or h23a1 vtec turbo build?
  63. Power steering belt coming off...
  64. M2F4 vs M2B4
  65. H22 wont start
  66. check engine ligt, gas cap?
  67. Hypothetical prelude swap
  68. acl stock bearings bigger than stock
  69. How do you make both fans run at the same time
  70. .::Unofficial 3rd Gen Picture thread::.
  71. h22 head f22 bottom end questions
  72. H22A4 Fail.
  73. will a golden eagle h22a1 headgasket work on a h22a4?
  74. Were can i find ECu
  75. Clutch Slippage on 97 Prelude
  76. want to buy!
  77. New second gen
  78. Problems with 91 Prelude
  79. Used springs? Okay?
  80. car stalls when warm... helppp
  81. DRL relay... again
  82. high idle
  83. Coolant Loss+Constant White Smoke Exhaust
  84. Oil leaking from the Back of my 95 DOHC Vtec
  85. timing issue/confusion
  86. cluster problems
  87. H22 4-1 RMF Replica in a 4th gen, Is it possible??
  88. p13 ecu
  89. aPexi vafcII install?
  90. shiftlink problems
  91. I searched but could not find Please Help
  92. Upper control arm Question
  93. help93 prelude 2.3 litre
  94. Rebuilding H23A1
  95. USDM Engines
  96. Oil pressure gauge
  97. Modding my H22 Prelude...5th Gen 2001
  98. 2.2 vtec injectors
  99. ECU upgrade for JDM Spec Prelude Type S.
  100. Adapter for using H22 Style intakes on H23 Heads...Ive seen it before...
  101. Quick Question: 4th gen Prelude Hood Jet Washer removal
  102. weird noise
  103. Bleeding the clutch?
  104. 5th gen springs help!!!!!
  105. Help with ABS
  106. 96 prelude passenger side airbag delete???
  107. Newer style LMA's. To shim or not?
  108. h22a cc size
  109. fuse box for 88
  110. `94 Prelude Si - Keeps cranking
  111. Dumb Question - Does Napa really carry genuine parts?
  112. 92 h23 BAD oil leak
  113. pistons/rod combo
  114. 94 Prelude
  115. Can someone help me please!!
  116. car kind of shakey when accelerating..searched!!!
  117. Removing the windshield trim?
  118. Is this reasonable?
  119. tune up questions
  120. nasty fluctuating idle
  121. obd2 idle adjusting. searched!
  122. jdm h22a tranny
  123. help please: H22 Swap will not rev past 4K
  124. Valve cover gasket possible leak - Replace with Genuine or Aftermarket
  125. Recomendations for a quality Machine Shop in Raleigh area
  126. A Little tranny help!
  127. H22a1 rebuild
  128. Any experience with ABS Code 1?
  129. manual trans grind..
  130. manual trans axle leak
  131. BB6 - evap system removal
  132. H22 Injector Compatability
  133. Need help! cleaning motor.
  134. 98 sh prelude tie rods.
  135. Water pump pulley
  136. JDM H22a Swap
  137. m2b4 trans, what fluid to use?
  138. What do i gotta do to make it run !!!!!!!!!!
  139. 89 fog lights
  140. H22 injector compatiblity
  141. Shredded timing belt?
  142. belt set up?
  143. crank bolt
  144. 94' prelude (F22) clutch replacement?
  145. 91 lude
  146. 91 prelude?
  147. JDM Climate Control Install
  148. Transmission oil seal replacement
  149. 92 Prelude blown engine...H23a3?
  150. 1985 prelude motor mod suggestions
  151. 4th Gen auto tranny
  152. 95 prelude with f22b1 questions?
  153. Anyone have a 96 Prelude Auto shift cable?
  154. Tail light bulb replacement
  155. Trans Question
  156. Is it the Head Gasket?
  157. Where there is placed the Tie Bar Rear Low???
  158. rattles, wiggles, and other annoying car noises!!!
  159. car wont start when its cold outside!
  160. HELP !!!!! motor swap help
  161. do i need both O2 sensors?
  162. ::The official Type SH performance thread::
  163. I Need some opinions
  164. Loud whining noise when steering wheel is turned
  165. Almost done w/ swap. Got a ? on 2 of the hoses, GOT PICS
  166. How to bypass fitv?
  167. Power steering reservoir fluid leak
  168. 304 WHP H SERIES BUILD (dyno gragh inside)
  169. Hearing a thin slightly ticking hissing sound when clutch is up
  170. type sh intermediate shaft play?
  171. Problems with Transmission or related to
  172. Very loud rattaling noise.... IDK what it is....
  173. can somebody identify h22 cams?
  174. is the stock fuel pump good enough?
  175. instruction on putting shock and springs together.
  176. Stock FPR comparison...
  177. Innovative Motor Mounts
  178. EGR port cleaning estimate....
  179. H22A4 Swap Is Done :)
  180. Advice on replacing Shift linkage for a 5g
  181. My H23vtec build gone bad!!!
  182. manual timing belt tensioner?
  183. Balance shaft belt removal
  184. Replacing AC compressor on my 4th gen, please help!
  185. Spring rate question
  186. Time for my H23vtec build
  187. Dies when i come to a stop 4th gen
  188. whole car is actin up plz help
  189. Prelude exhaust question
  190. CEL code 80?
  191. oil pan
  192. JDM H22A, No VTEC Pressure Switch?
  193. My motor should be here soon. F22A6+H22A head.
  194. Oil Pressure please!
  195. Having Major Trouble...
  196. Is it normal that my IACV open about 1mm (1/16 inch)
  197. ball joint help.
  198. Sparkplug/Head issue, need help ASAP!
  199. 4th gen hood dampers
  200. which lsd is better
  201. Head Studs
  202. shifter stuck need help asap
  203. H22A Block slightly warped!
  204. tranny woes
  205. Engine Swap
  206. been searching, picture request
  207. 5G Preludes with black roof pics?(esp silver)
  208. Front Upper Tie Bar
  209. Transmission Woes
  210. 4th gen center console conversion
  211. ?'s about tri-y header
  212. H22A Turbo Build Suggestions and Limitations
  213. Jdm h22 and Us h22
  214. Help me with rear fog lights
  215. swap out h23 to h22a4
  216. Electrical Problems. Batter/Alternator/Main Relay?
  217. NEED HELP!!! 92 Honda Prelude Si (H23A1) condensor fan not coming on
  218. Anyone selling used 5th Gen Koni shocks F+R?
  219. door trim rusting (5th gen)
  220. Engine Oil? Spark Plugs?
  221. Stupid valve adjustment question
  222. accord ecu in prelude
  223. H&R or Tein S tech springs
  224. Gt35 Coolant Lines???
  225. revving problem
  226. H23a3.....?
  227. USDM switch for JDM fogs...
  228. Overheating 94 Prelude
  229. Crank pully bolt torque
  230. about to replace a piston in my 92
  231. if you had 900 bucks...
  232. New Clutch
  233. Any problems using a CIVIC SI PT2 ECU w/ H22?
  234. P13 ecu on an 01 5th gen
  235. Exhaust
  236. Need Help!!!
  237. Throttle Body
  238. swapping 97 h22 into 92 prelude S
  239. 1999 Type SH Clutch Replacement Weekend Project
  240. electronic vtec switch
  241. H23a1 engine fit a b21a1 tranny?
  242. greddy evo2 price used?
  243. JDM h22a bucking and loss power (non-vtec related)
  244. Where is the location of the knock sensor on a 97 Honda Prelude?
  245. 97 prelude sh questions..
  246. Skunk2 1.0mm Oversized High Compression Forged Valves...Any experiences?
  247. Fuel rail and gauge??
  248. Ultimate 5th Gen suspension setup
  249. oil pressure gauge problem
  250. engine bogs in 5th gear only
