View Full Version : Honda Prelude
- skunk2 stage 2 camshafts
- Need Some Truth: 5th Gen Pass. Airbag
- 4th Gen under the hood fuse diagram plz
- got the check engine codes
- Crank Pulley
- will cutting carbon-fiber cause the weave to slowly unravel or damage or anything?
- Have a question for an 92-95 JDM H22A belt..
- Car rolls forward while parked in gear.
- Anyone dyno tested after completely removing IAB plate?
- is there difference between h22a4 and h22 valve covers
- prelude alternator question.. read me
- Oil leak
- WHOAAAH another new cf 92-96 front lip? for 400+
- prelude ecu question
- stripped rotor screws!?
- Mechanical O2 Sensor Simulator with PICS
- oem lip
- Gobble Gobble
- Coilover comparision
- 4th Gen. Lowering Springs
- How much power can you make out with JRSC without built motor?
- main pulley came lose...help
- KMS valve guides
- quaife lsd?
- trans removed, how can i make sure its bad without opening?
- 5th Gen Test Pipe
- Powder Coating Wheels
- oil light on. should I be worried?
- Where to find codes...
- 98 prelude non sh high flow cat/ throwing code / 02 bypass???????
- h22 intake manifold plz
- camber kits?
- I NEED HELP TONIGHT!!!! wont shift into 5th or reverse
- CEL Issues
- Jumpy tach? Huh
- What rear lip is this?
- fuel filter washer & bolts... quick question
- buying a 99 prelude
- S2000 Steering wheel in a prelude? Fitment question
- Auto to manual Where to cut for the shifter cables ??
- High Output Alternator!
- About h22 headers
- starting problem 99 SH engine turns 3-5 seconds after key is turned
- Some Rolling shots of the lude
- 5th gen hid
- PLEASE HELP ME........
- adjusting agx shocks???
- h23a1 intake manifold vacuum lines
- sigh* worn crankshaft
- h23 vtec swap or full on h22 swap
- Spark Plug Question
- Prelude TCU Qustions, 2 Transmissions blown TECH HELP NEEDED
- hey i need this asap
- Need Help Quick!! Power Steering
- Timing Belt Replacement Parts (New or Reuse?)
- JDM h23 vs h22 collector shape/size
- Idle Screw Question on my 98 lude
- Rear strut bar trouble: HELP NEEDED!
- Tuning and keeping ATTS
- went to willow springs on 11/12
- changed timing belt, now car wont start.
- are all f22a f22b2 and b1 block internally the same?
- Thinking about stronger engine for Kimini
- HELP!! Vtec Solenoid/Spool Valve
- Kimini on track
- looking for a right sided door
- Jdm H22 v.s. CA Smog Regulations
- problem shifting above 3500 rpm
- aligning rear balance shaft
- Euro R intake Manifold ....
- dizzy question
- need info on part
- Tuning with Velocity/BPI Stack on prelude Question...Need Advise!!!
- IACV *TRY THIS ON FOR SIZE*
- v6 in a 92 prelude? anyone know?
- pulling my engine *searched*
- Turbo Tech Question
- Selling B20A5 head from 91 prelude, how much?
- Ignition Column problem
- What could my problem be?
- 92 lude cross member (cross beam)
- Fast idle due to advanced timing?
- 93 lude performance upgrade.
- Radio code
- ECU?
- Headlights?
- Alright, narrowed it down to 2 exhaust, which one will I like more??
- Places to grease
- Looking at a car
- "4gen prelude foglight wiring"???????????????????
- Throw out bearing(clutch) - Knowing if its good or bad
- Getting out rusted cat bolts
- changing timing belt - having trouble setting timing
- Tire size ?
- 92 Lude Coilover kit help.
- snapped 2 wheel studs
- H22 Idle Problem
- Cloudy Carbon Fiber Hood
- what could my problem by **video clip**
- 18" sokudo wheels
- turbo+prelude vtec+?
- I need some help! i need to drop and drain the gas tank...
- Stock Exhaust?
- all kinda problems
- what gas mileage can I expect from a '91 Si?
- Need Help On Decision
- Idle problem
- Check Engine + Atts Signal
- 5th gen caliper question
- Help, Ignition problem ?
- HELP!!!! type-S
- San Diego Locals
- Intresting problem with Prelude
- clutch, master cylinder, slave cylinder? what is it?
- how do i remove the backseats from a 4th gen?
- anyone have a writup for install. of rear brakes(pads and rotors)?
- transmission not wanting to go into 1st or reverse
- h22a intake question
- 95 prelude shifter cables in 97+ Lude
- rear lower control arm
- The truth about ebaydms (the one piece headlights were curious about)
- 92 prelude to 91 civic engine swap
- Need help with stock/aftermarket foglight hybrid.
- battery shock=power locks don't work
- egr cleaning clearification
- I got stacked! Bpi + K&N
- passwordjdm for headlights
- jrsc and my 4th gen
- Help building a 3" exhaust for a 4th gen
- head light ?????
- spoiler rubbing
- Bogs down at 1500 rpm after not being driven from two weeks
- Tein Basic Coilovers for BB6......On a Budget.
- Timing ?
- Battery Relocation Summit
- Stripped Valve Cover Nut?
- At Low idle h22 stalls
- Crankshaft pulley nightmare - advice needed!
- How would one go about replacing rear quarter panels?
- sign of bad axle?
- problem with gauge cluster please help
- H22 Cam shafts
- Issue with the H23 Vtec swap
- H22 build gone bad
- firing order correct? h23a1
- obd1 or obd2 distributors
- Tap stuck in crank
- h22a wont start just did a compression test
- h22 turbo help???
- 2000 prelude sh timing belt service help
- Realistic Expectations From My Wip
- 1994-96 fog light switch question. *searched*
- 5th gen sway bar end links
- spark plug, rotor and cap disconnect?
- H22 Transmission problem need help
- Official Md23vtec vs Oaksracing thread
- H22A motor w/ a B18 valve cover?
- Car Running Rich!! Will a FPR Work??
- Thermostat Housing
- 4th gen auto transmission will fit 5th gen, right?
- WTF!! Crank pulley came off the crank!!
- Questions about High-Flow Cat.
- Edmonton Prelude Club Website
- got a question on automatic adjuster and timing belt, need to replace then every 2 to 3 weeks
- HELP!!!!!!!!
- 00 wrecked prelude need help (searched)
- Look what the mail man brought today...
- how much does rear bumper support weight?
- how can you tell what year your head and block r??
- i got one them kms blockguard do u use stock head gasket?
- with 92 prelude do u have 2 get a wiring harness from a h22
- aiming JDM headlights? searched
- Car Wont Start! Broken Crank! =(
- H22 Cranks...Are they all the same?
- Where can I buy a new OEM carpet for my BB6 prelude?
- Rear main seal Replacement. Help.
- Valve Stem Seal Replacement, Valve Lapping Compound
- Timing marks on aftermarket flywheel
- cut OEM springs?
- anyone wrinkle paint their calipers?
- power steering pump
- Engine has a strange problem. Could use some feedback
- HELP ME ...........
- 99 prelude for sale
- RWD 5th Gen.
- e where's my CEL plug
- Would this cause me to leak alot of oil
- 4th gen to 5th gen lug swap
- rebuilding bottom end questions
- hydro locked?
- Apexi Oil Pressure Gauge install.
- Is anyone able to get in contact MadCityLude/Ludefinatic? NO FLAMMING!!!
- H22 Transmission Won't Go Into Reverse
- H22A Fuel Consumption
- EG Foglights On 4th Gen Prelude?
- Were can i get a oem h22a4 spark plug cover?
- .:VTEC Killer Cams:.
- head rebuild kit?
- 4th gen Prelude or 5th gen Accords?
- what's wrong? when I have to come to a fast stop the brakes feel like it's pumping.
- h22
- Vafc 2, is it enough? Please help asap
- re: supra lip???
- clutch chatter question
- crank shaft problem
- 97 auto tranny problem
- used (real) mugen wing for slae
- h22a1 vs h22a4
- Re-grounding, what gauge wire?
- h23a vavlesprings fitting f22a1 head
- 5th gen mobiilizer help plz
- Code diagnostics help
- For 4th gen owners looking for a nice front lip...
- USDM VS JDM H22A Vtec Rod Bearing Quick Help
- how to remove sideskirt from the 5gen
- Clutch fluid slow leak. inherent in hondas?
- meets in washington
- Installing my clutch this weekend!!
- usengine.us - good? bad?
- 4th Gen Fog Light Problem...
- Civic radiator into 5th gen prelude?
- headlight adjuster switch?
- h23 to h22
- Check Engine Light...O2 Sensor
- l;l;
- 5th gen: Do city lights stay on with the headlights?
- Car Won't Start / Code 43
- 5th gen V2 or cold air ?
- 91 prelude tranny problems
- Hesitation
- Tire options
- water leak - specifics needed *pics*
- What makes RMf Headers so good?
- NEED HELP- Valve cover Bolts snapped!
- Radiator fan keeps tuning on after car is off
- 92 prelude si
- 250ish mpg is that right ?
- pic request: open and closed deck h22
- Need to make room, good bye battery
- What Brand, Model of smaller battery should I buy? Odyssey/Buddy CLub/Spoon?HELP!
- VERY squeaky when turning
- jdm h22a obdII ecu help
- p28 help
- question about ecu...............
- Rear anti-roll bar links
- Do I need to replace oil pump for NA build?
- Play in steering wheel after manual rack conversion
- code 43 problem
- NEED HELP!! BLOW GEARBOX
