View Full Version : Honda Prelude
- quick quesion
- can u put b series vtec head on old 88 prelude
- Type S intake what kind of power gains and what range of RPM?
- AEM brig break upgrade.
- Where can i get mugen parts?>
- Anyone have 25K they want to spend? :p
- Checking CEL codes at the ECU?
- Looking fo a h22 engine gasket set
- quick lude question
- Come on guys
- S2000 seats in a fourth gen...
- Troubles, troubles-engine dies- help
- 4th Gen One Piece Headlights
- A little help with my hoo-ride
- H22 ECU Codes
- need sunroof HELP!!!
- I need 97-01 wheels
- Exhaust comparison, noise, performance, price
- track trouble
- Straight Pipe
- anyone know an estimate of a shopping changing a head gasket? 92 prelude
- Carbon fiber or Brushed alum
- Rim&Tire combos
- port and polish??
- Project Rsx seats
- VAFC settings
- i really need a 4th gen pipe that hooks to the headers and goes to the cat
- front upper strut bars: skunk2 vs. neuspeed etc..
- help with clutch
- DIY wideband controller
- VAFC with spoon, mugen, jun, etc ecu chips????
- spring help
- Gathering Interest in CARBON FIBER TRUNK lid for 4th GEN's 92-96
- how do you install hood pins? (did a search)
- H22 Pistons/ H23 Compression change
- Miami area Honda Dealer recommendations?????
- preliminary list of Acuras & Hondas in GT4
- help with h22a firing order...asap.!!!
- H22A intake manifold
- H23 ECU on H22 engine?
- comparing 3rd and 4th gens underbodies
- Annoying Rattle, Trying to track it down
- Tire Question
- walbro pump with stock fuel system
- What is the most power I can get out of a H22a1 without turbo, super or nitrous?
- 97-99 vs 00-01 ECU (GReddy Turbo Kit)
- what happen when thrust berning go out?
- H23 throttle body
- n00b here! (of course with a question)
- Will these wheels fit?
- 5th gen JDM fog lights???
- JDM H22 Cams and Throttle Body
- je piston compression
- how do i tell if i have a stock tranny or another one?
- Will This SAFC Work?
- put a rebuilt head on my h23 and now im getting a lil water in the exhaust pipe
- 4th gen lude parts
- 97' Type SH prelude FS with mod...
- h22a and h23a tranny use same Diff?
- rings or seals?
- Help
- What do i need to do to my engine to give a 75-100 shot of nitrous
- wat shock should i use with ground control? (searched)
- Upgrading cooling system....
- tsudo muffler for 95 prelude
- installing headers
- a new turbo manifold for H22, or have I been living under a rock.
- would it be difficult to make an H22 intake manifold fit an H23?
- Turbo Kit purchase question...
- inner fender plastic linings
- Who makes throttle bodies for H22A?
- yokahama avs 100?
- RIP turbo prelude
- h22 into a 93 prelude
- 94 LuDe FoR SaLe
- Reset the ECU?
- 4G coolant flow questions
- NEED!!! EXTREMELY Important! and very urgent H22a prelude related!
- HELP!!! 4th gen Camber ??'s
- Motor swap question
- Ripped Piston Boot on Brakes!
- Changing to Synthetic oil... kinda worried?
- How much do you pay for insurance??
- Phantom Grip LSD
- h22a2 turbo
- erebuni style 179....
- performance tranny rebuild kit
- Distributor shaft seal
- Surging Idle, PLEASE HELP!!!
- f@#k up my motor need help!!!!!!!!!!!!!!!!!!
- 152,000 Miles on a 1993 JDM Vtec engine?????
- what all is needed for 5spd swap in 4th gen?!?!
- Who wanted the Power Enterprise Blue Superstrong timing belt?
- Turbo Help (Blown Motor)
- Recommended injector size for turbo H22's...?
- hey prelude guys!! need help h22 turbo
- Manual conversion
- how hard to fix ac compress. clutch? (3rd gen but any gen will do)
- Who has a JDM digital climate control in their 4th gen?
- Anyone Know where the wire harness is for the Fog Lights on a 1991 3rd gen Prelude
- transmission stuck....no reverse. PLEASE HELP!!!
- Replace Brake Rotors?
- rice rice baby
- What kind of damage could the balancing shafts being off a couple teeth cause?
- Real Dilemma with the Lude
- anyone with a JRSC wanna trade for a GReddy turbo??
- vafc dyno plot
- 5th Gen Suspension Stuff?
- 5th Gen Prelude Items for Sale
- well, it's for sale now, 93 Prelude Si
- haSpoon Front Lip
- Prelude Speed Sensor
- 5th gen Cusco Oil Catch Can
- h22 type s cams
- Timing OBD1 H22a- Don't have this helms- need advice
- Are these headers & strut bars ok...
- H22a spark plug wire question (boot lenght) from end to end.. 5 inches ????
- Pistons with 11.5:1 compresion for JDM H22A 1992 engine.
- turbo guys, i think i sparked an idea
- Strut Bars
- 93 accord AEM short Ram intake
- Now how much am I lookin at spending?
- h22 1/4(repost)
- Turbo my H23? Or drop an H22
- would AEM warranty this?
- Throttle body sensor bad
- Big Desicion H23a block & H22a Head or all H22a
- need help installing Type S cams
- timing belt
- Reliability after engine build?
- prelude 1988 h22 aem skunk2 dc greddy drag turbo
- again all im asking is......
- koni yellow question
- looking for a 5 speed
- automatic bad or good?
- h22a problems???
- 1986 Honda Prelude information?!?!?!
- Clutch squeaking solved- unexpected cost incoming :(
- does any body make t4 turbo manifold 92 si h23 non vtec
- Axle hub bearing installation?
- Anyone have tranny problems while racing???
- tire size question (after doing a search)
- 97-01 base??tpye sh??? whats the diffrenes?
- Any of you SH 'Luder been asked...
- Best Master Cylinder Price???
- The Offset, Wheel, and Tire thread
- What Bodykit is this?
- Hello. I am new here.
- fog lights?
- If i get tein coilvers, do i have to get a camber kit? If so, which one?
- Prelude Rotors
- Type-S STB
- If I get 17x9.5 rims for my 98 lude...
- EVERYONE needs to read this.....
- Anyone looking for type S parts
- Help! Uneven ride height
- help!! blew a headlight fuse?? and need to drive in the dark tomorrow
- take out ac???
- OEM H22 LSD, how much? where to buy?
- Wish list.. thoughts, advice, recommendations?
- HIN last night
- H23 Exhaust System Setup...sound good?
- Attn. 3g's:Best place to buy JDM B20a?
- Spinning a main bearing. Causes??
- a/c question in 92 s
- Anyone have any idea what a stock F22A makes Hp wise?
- idle control
- engine rebuild turbo style
- cv boot repair
- Need Help!!!!
- h22 1/4 times
- oem kit
- AEM/UR pulley kits...
- Another victim of the SS transmission
- Removing OEM Steering Wheel
- JUN internals in a H22A or H23A block?
- Does the 98 factory head unit have sub woofer outputs?
- will i pass cali emissions with I/H/E?
- 94 civic w/ h22a everyone please help
- Got my i/h/e equipped 3rd gen dynoed for those intereted..
- Symptoms of a bad fuel pump
- cam next maybe??
- AEM cai....how much?
- insurance for a prelude??
- Best ECU for the H22
- what's a good price for a 5speed swap? 4gen lude?what all do I need?
- 4th Gen Owners... Where did you get your exhaust from?
- thermal r&d, need some help
- new short block
- Prelude Turbo Aplications
- Where to get prebent hoses??
- intergrated window antenna
- HELP AC is not working?!!!!
- Torque specs for installing upper STB? (I searched!)
- Best 4th gen wheels...
- ATTN!!!!! 4thgen revhard mani owners!!!!!
- need secondary on 15 pounds? h23
- Ground Control coilovers uneven in back
- Almost complete 92 Si w/H22A1
- euro-r or stock intake manifold?
- best clutch, flywheel and lsd?
- People who have taken out their AC system
- vafc help
- turbo timer for a 4th gen?
- Who has the most powerful h22a
- Instead of the Prelude
- sick looking wheels on a 4th gen.... check it out.......
- H&R 5th gen springs fit 4th gen springs?
- what happed when trust berning go out ?
- jdm fog install (4th gen)
- 5 LUG $$$$$$$$$$
- need help 2 install indiglo gauges on 5th gen prelude
- Who makes a high stength timing belt for an h23
- Cheap as$ CV-Boots
- mil code problem please help
- Clutch went out...
- What's up with the price on these wheels?
- vafc dyno results
- Front & Rear Control Arm Suspension ?
- trading 93ls teg for 93 vtec prelude
- Just put tokiko iluminas and eibach pro-kits on.....
- GC Gurus....
- JRSC SMOG TEST???????????
- 5th Gen Auto to Manual swap, driving impressions, swap info, Shop info, etc
- need help with oil pressure sensor..
- max power handling of H22 tranny
- I'm going to sell my turbo lude need advice
- Anyone instal lsd in 3rd gen ie h23, or other honda lsd
- ecu problem...help
- Some More Changes For The SMSP H22 Production Header
- need some help plz!
- check out this 4th gen.
- Mugen Body kit...
- 94+ vtec cluster
- Building up my JDM H22A head.
- Does this sound like a good deal on my 1st lude?
- f22 with a h23 head?
- help with cel problem in 4th gen vtec!
- Problem with front wheels almost touching the front fender under boost..
- 3rd gen engine swap
- can a 4th gen use 5th gen hubs?
- What are the differences between the 95 JDM H22 and the U.S. H22's thanks
- DOT Hoosiers on 17x7?
- any use a custom p28 or p72 with h22 spec's ?
- wrecked my lude
- JIC Coilovers for Preludes
- Help, what is the valve clearance for a 92 JDM H22 VTECH.
- 95 jdm h22a. Need help
- Who here has upgraded valvetrain and its effects?!?
- How many people here...
