PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. What size turbo to run on stock bottom end?
  2. Before and After pics fixed and custom powdercoated Volk TE37's and painted exhaust
  3. problem at low rpms
  4. Question on the "seals" that go in the intake manifold for the injectors *pic*
  5. '04 Civic Si seats into '92 Prelude
  6. H22 Cylinder no.4 low compression fix? common problem?
  7. s2k throttle body questions
  8. REFILLING A/C R134A 70PSI HELP?
  9. Coilovers
  10. Are these bolt supposed to be sticking out or flush?
  11. Turbo H23 Vtec idle issue and stalls Help?
  12. H23A1 Distributor to H22A1 motor
  13. Alternator Pulley, help please!!
  14. confused on what to do?
  15. VTEC not working during normal oper. temp.
  16. f22 harness on h22a
  17. metal rattling
  18. 92' Prelude Clutch?
  19. What can it be?
  20. 4th gen tranny Swap help
  21. JRSC upgrade pulleys for 2000 Prelude
  22. Diagnostic Code?
  23. help 4ws problem
  24. Love Fab Mini-me EQ Results on H22
  25. Bent Header, Loss of Power?
  26. need opinion.rod knock? spun bearing?vid and pics
  27. 94 black honda prelude won't start
  28. how to remove oem air intake
  29. b18 cam caps on h22
  30. WHat kinda gas?
  31. what cams do i have?
  32. hood latch cable
  33. A/C condensor fan wiring...?? (4th gen)
  34. PROBLEMS WITH 4WS ON MY MARK 5 PRELUDE HELP
  35. About to clean EGR ports, but they are welded.
  36. dizzy rotor problems...
  37. Prelude jerks at steady speed????
  38. strange sound from engine
  39. Help locating Intake Control Diaphragm
  40. swapping a motor
  41. Passenger Side Mirror
  42. nos or h22
  43. atts code 43- ecm communication line
  44. h22 engine
  45. fuel pump or wires???
  46. damage block
  47. jdm h22 ek
  48. Oil leak
  49. CEL help
  50. Denso Spark Plug wires?
  51. Extra Plug On Wire Harness
  52. VTEC only works 80% of the time
  53. rear bumper
  54. F22B JDM engine timing procedure.
  55. Lude Problems
  56. Pics of your din/double din video in a 5G?
  57. how to properly clean out injectors?
  58. Rotrex h22a
  59. vtec controller
  60. How much do 1996 Preludes SI (Vtec) run for?
  61. quick h22a coil questions
  62. clocks
  63. Soft Spongy Brake Pedal
  64. cluster removal
  65. 1999 prelude
  66. ac issues
  67. Driver Side Axle dilemma
  68. HELP!
  69. Transmission problem
  70. should my ABS light come on when i turn my key
  71. Please help: Radiator/Cooling fan issue
  72. what is this and where does it go please help
  73. help with dizzy
  74. Just got a lude...
  75. HELP: One Step Colder Spark Plugs
  76. Please help,starts right up but wont move
  77. there's a new ebay 5g front lip
  78. 01 prelude timing belt install
  79. spark plug (colder)
  80. Still winning awards!
  81. Honda Prelude
  82. Supercharged Prelude ET's?
  83. H22 H23 Lower timing gears
  84. radiator leak...
  85. Kudos Philip Ngo "99 BB6 July issue Honda Tuning
  86. 92 prelude si question
  87. Thicker head gasket for F20B-Turbo.
  88. Adding s300 to JRSC Prelude
  89. Changing an oil pan, help.
  90. Overheating problem
  91. Car worth keeping
  92. 4ws Tie Rod End question
  93. gas/temp guage blinking and resetting!?!?
  94. Horn doesn't Work...
  95. what intake is best ofr 90 si?
  96. jumping radiator fans
  97. compression test #'s, NEED HELP!!!!!!
  98. NEED HELP!!!! compression test #s
  99. What's a reputable place online to buy a jdm engine from?
  100. i need help identifying a transmission
  101. SRS removal
  102. vtec help
  103. Which Wheels and Exhaust are these?
  104. heat wrap?
  105. 750cc's too much?
  106. I'm selling a STOCK 2001 Prelude Type SH
  107. Skunk2 Intake Manifold or Other?
  108. 5th Gen manual steering rack conversion question
  109. Driver and passenger side windows loose?
  110. throwing 3 CEL's
  111. Removcing the shock tower cover
  112. starting issues
  113. super low budget front lip for 92-96 prelude
  114. Window Regulator and Motor Question.
  115. Would honda civic relay fit on my lude
  116. Indicator Light Question
  117. RDX injectors
  118. Wont start
  119. Camshafts won't stay aligned?
  120. new to ludes
  121. Car doesn't want to roll
  122. H23A issues..
  123. classic or not
  124. Technical Service Bulletins (TSBs)
  125. Wobbly crankshaft pulley
  126. For Sale Skunk2 S2 Tuner H22a
  127. reverse glow gauges
  128. Minor Rust Issue
  129. function and form type 1
  130. Cam holders
  131. relocating 4ws computer
  132. h22 turbo
  133. Help with rear view mirror
  134. 4TH Gen EL-Cluster
  135. Need info on compatibility
  136. h22 transmission
  137. need help!
  138. gstrudler's 2.3L stroked h22 SH 87x97 build
  139. horn wire please help
  140. About take another Smog check, just changed Cat..
  141. Shaking steering wheel from 40-60
  142. CEL after test pipe!? help
  143. KYB Shock ride height question after install
  144. b21A1
  145. alcohol/methane injection?
  146. what happens if this oil sensor is broken?
  147. my prelude has a hard time shifting outta first
  148. ABS troubles
  149. Camshaft and rocker shafts?
  150. hello all
  151. What should be my next mod ?
  152. How to a install a tranny cooler?
  153. H23A1 Crank Position Sensor
  154. taking a trip and need some help
  155. Need ideas for 2x broken lower rear sway bar mount
  156. Tune after trans swap?
  157. Hopped a curb.
  158. 1986 honda prelude manuals
  159. 1989 Prelude starting problem.
  160. 95 SRV tranny problems?
  161. TPS reads .03v and WOT 3.0v??
  162. Knock Sensors Identical???
  163. What should I look for??
  164. diy paint job
  165. Blown Motor-Need Help!
  166. S2K cluster in Prelude...has it been done?
  167. JDM Fog Light Dimensions...
  168. How To: H23 Valve Adjustment
  169. T-Belt Jumped, How to Re-Align Camshafts?
  170. 98 Prelude - Engine shut off while driving?!
  171. Vtec pressure valve help
  172. Viper Alarm/remote start Install Help
  173. taking off a/c . needs info
  174. engine swap
  175. h22a engine...no shit
  176. Boosting an 89 Prelude SI (Non 4WS)
  177. 93 H23 intermittent starting
  178. AC problem/ climate control
  179. 92 Prelude SI H23 Timing Help... & Vacuum Noise??
  180. starting problems please help!!
  181. Idling problem after camshaft install
  182. 1999 Prelude Automatic trans delayed shifts. Anyone?
  183. front and rear sway bar for a 97 prelude
  184. Honda Prelude Rear Tie Rods 92-01
  185. Disecting Smoking Prelude.
  186. vtec brake and rotor sizing
  187. about 5-6 miss shifts, now trans is toast.
  188. Honda Prelude Problem
  189. H23A Vtec Blue Top into 97 Prelude wowes... Help?
  190. My Borg Warner S362 prelude: Tell me what else I need
  191. oil light!
  192. H22A What is this and where does it go? Help...
  193. Honda Prelude 97 TypeS
  194. Engine Dies at startup unless I hold the gas
  195. Need Help with H22A engine
  196. Interchangable?? H22A / H22A4 Trannys?
  197. PS pump bolt issue
  198. final drive gear
  199. Thank you everyone!
  200. blowin ecu fuses
  201. Clutch noise
  202. Power steering out?
  203. Starter mount cracked
  204. Spun out and went into a ditch... Look if radiator supports need replacing?
  205. Need Help Removing Passenger Seat
  206. H-tech or Swift springs?
  207. Could someone get me a pic of their wires?
  208. 1999 Honda Prelude
  209. Help on removing Fail-safe Relay On a 5th gen
  210. FS: 5th gen. Carbon Fiber Oem Style Hood
  211. jdm H22 swap not sparking
  212. H22 engine parts
  213. Please help Car starts but wont rev
  214. Solid CEL! NEED HELP!
  215. 86-89 accord/91 prelude
  216. anyone have a pic of the dizzy harness plug?
  217. I need help.
  218. Bleeding ABS Pump Manually
  219. oil pans
  220. looking for radio code
  221. Bubbles coming from power steering resevior?
  222. 97-10 Replacement Seat Foam?
  223. Help...Overheating at Idle!
  224. need help for h22a tranny>>>
  225. Help/input on new suspension setup.
  226. 92 prelude si dies out help
  227. JDM h22 swap not starting
  228. Is it worth it? Need answers quick!
  229. F20b, blued top H23vtec or jdm H22?
  230. What do you think about these rims on my prelude?
  231. Name that sensor? H22 JDM CAT
  232. Check Engine Light
  233. Wheels for Prelude
  234. GSR or K20A2 swap into prelude
  235. Tach Not Working after car sat, EL Gauge
  236. H23 con rods
  237. Oil light and idle problems.
  238. help with jdm abs problem
  239. How do I add fluid to differential/axel?
  240. F20b question!
  241. Prelude SH shock/spring install
  242. f20b vs h22a
  243. Car not turning on, + no power at all
  244. brake set-up
  245. Clutch Pedal Dead
  246. Spark plug wire?
  247. 5th gen::does anyone know how to make the turn signals stay on constantly?
  248. Need Help ABS light on
  249. Prelude failed a smog test; results posted
  250. Caliper Piston Spinning But Not Compressing
