View Full Version : Honda Prelude
- A/C dosent work right?
- 92 prelude
- Gen 5 interior
- Goofy-a$$ brake pedal fade (searched)
- obd2 obd1 injectors
- will double din dvd fit wit my 99 prelude???
- which oil pump am i suppose to be using????
- h22 lower crank gear
- Help! iacv?
- guages
- EVAP CANISTER REMOVED OBD2
- f23 vs h22 clutch disc
- No compression in number 1 cylinder... need your input.
- Valve springs and retainers for a h23
- Cooling System leaks
- Leakdown
- Prelude stolen
- cat. converter?
- 5th gen oil pan on 4th gen
- h22 losing coolant?
- Can I ship a motor like this?........
- h22 non v tech
- How to Sell my Prelude
- have a couple questions
- s2k or prelude?
- Clicking in the vents
- Check Engine Light comes on randomly?
- INFO ON THE MEGAN M-OE MUFFLER??!!
- H22a swaps
- RSX-S Seats in a Fifth Gen
- BRAKE QUESTION......Please help
- Well a compression test......
- I was hoping if members could compile a list of Oil Leaks and typical locations for them
- h22 tranny issued---fixed update
- Where can I buy steelies from?
- Damn Flapping Noise Coming From Engine...
- whats a good thing to get
- Dash Electrical nightmare
- H22 finished but now done again?
- Anyone running the Professional Products 65 or 68mm Throttle Body on their H22?
- Thinking of buying a 5th-Gen SH
- Driver Seat Broken
- To those with Fidanza 8lb flywheel installed
- how would this rims look on my 4th gen?????
- 4th gen- prelude front bumper cut as lip?
- '93 Si, knocking/tapping, pictures and videos.
- H23 main cap torque sequence
- My car sucked up water through intake!!
- injectors no pulse
- US OEM TB on a Euro-R manifold advice?
- ecu questions (type s or not)
- car hesitate to give power.
- Roll-on paint job
- 4Gen thermostat switch
- Revs bouncing around
- EGR Insufficient Flow Code!!!
- i just got the 01 lude the vin motor don't match the car.... got it from hella shady guy...
- what would you pay????
- jdmh22a how can i tell if it is type s
- My Tubro H23A1 build
- Help no spark! (H22A1 JDM BB4 1995)
- wierd knocking noise... plz help
- Injectors
- Just Installed a Mishimoto radiator check it out
- 92 Prelude SI Auto - intermittant shudder under load
- i searched it and got nothing. vtec kicking..
- Quick Q: Heater Core, bottom / top, which one goes where?
- 4th gen headlight covers (not mugen)
- Drop in gas mileage recently h23a1
- Oil leak from passenger side 4th gen h23
- question about adjustable cam gears
- In I had a worn or spun rod bearing, would the knocking fade away if I rev the engine
- PSPEC making a new short shifter
- Lugs, wheel locks? What are they called?
- 94 prelude SI heater not working
- alarm systems.
- supercharger question?
- need 84 prelude dual carb gas tank, lines, carbs. rust rebuild
- What width/backspace for 15" rim, 225/50/15 tire, that will clear fenders?
- hardware question re: engine swap
- prelude suspension question
- noise when engaging clutch
- question about type S pistons on H22A1 rods??
- can anyone help
- Engine stalls/dies when warm.
- 1997 Prelude 2.0 SI - HELP!
- Motor questions
- Black oil within throttle body??
- does the 2000 year model prelude.........
- spring rates
- Constant Squeaking
- What part would of had to break?
- new to forum...
- intermediate shaft question
- Interest in 2,3,4pt strut bars for 3rd,4th, and 5th gens
- need help with rotor on distributer
- were can i get the h22 iron sleeve liners from?
- still have p13 problems
- Quick ? about Hmotorsonline
- 92 honda prelude with all wheel steering ?'s
- 4th gen front crossmember
- For those that have done piston work ...... costs???
- Maintenance light question. Very quick question
- 92 prelude no start problem, help please
- DON'T DRINK & DRIVE
- Build for home made intake pipe
- Question about an oil leak
- does the under hood fuse box plug in and out?
- is there a differences between p5m and p13 head gasket?
- Bad Idea
- Bolt sizes for mounting an H22a4 to an engine stand?
- I have a prelude question
- please help ht
- final drives
- Source/Cause of my Oil Leak
- Clutch master cylinder rebuild kit?
- Prelude SH Shocks (which aftermarkets are ok)
- exaust sounds
- H23a1 connecting rods
- H23A Engine
- fujitsubo header does not give any power
- Adaptive One Pads
- Block heater on 5th gen SH
- 5th gen license plate location
- stupid front bumper cover question
- CEL=bad gas mileage
- where can i get...
- intermittent rattling
- Opinions on these 5th gen projectors (non-retrofit)
- HID Problem. Please help.
- Obx camshafts in an h22?
- What front lip is this? 4th gen.
- Automatic is Shot :( Need help assembling 5spd swap
- Koyo Radiator+Cooling Fan=Problems
- Valve cover gasket change...should I adj. valves too?
- Help on new Clutch set up
- G23 turbo build in progress......what pistons?
- f22a1
- Brand new oem clutch replacement, now problems.
- Please help me understand.......ecu question(s)
- Broken Cam Bearing Housing! Help!
- gearing on p2t4
- h22 tiptronic block vs manual block difference? Help!
- Gasket, Timing, Compression
- Tuning Apexi VAFCII vs Greddy Ultimate E-Manage 2001 prelude
- EGR Bypass
- Ebay turbo kit
- DH racing springs and retainers.....
- Intermitent smoke from engine bay
- H23 external coil wire harness/JDM H22 internal coil - Please Help
- Do 07-08 TL Type s Rims fit on 5g ludes?
- h22 header? rmf, vibrant, esp, hytech, prosspeed, smsp, camp 1320..which header
- are the sways the same?
- ? about cams (searched)
- back seat removal
- looking for an old thread...
- HAsport have developed Kseries into BB1- 92-96 prelude chassis mount kits!
- Weight and dimensions of H22......
- poping out of 1st grinding in 5th
- Need to ship my H22, NEED HELP
- sagging
- part fell off while driving... battery light and brake light... no power steering
- Bleeding coolant...
- GC/Koni on 5th gen
- What hose am I missing?
- Forged Piston/Mahle Golds .......FRM sleeves
- Diagnostic Help - 1987 2.0 si
- Need some help guys My 98 SH will not start
- ====H23a1 swap to H22 Questions====
- Pinning noise from tranny
- Valve adjustment and some other maintenance questions
- OEM lip kit 5th gen
- ecu layout is this one good?
- Headliner Removal
- 98 prelude noise problem coming from engine bay
- How do you change the parking light bulb? Grr...
- swaps
- 15 inch wheels on lowered 5th gen..advantages/problems
- name of gauge
- Installing Stechs on Koni which way.
- Turbo Kit for daily driver
- Nokya lights
- noise commin for rear of car, sway bar links?
- Ordering last parts tomorrow, last minute concerns
- has anyone installed rsx seats in a 92-96 prelude
- Wires to hookup jdm foglights for 5th gen help
- for sale 92 prelude SI 5 speed 109k miles cold A/C phoenix-tempe area
- strange problem at highway speeds
- Controlling A/F
- Water Leak!
- drives fine other than at wot
- Need Help!
- Compression Ratio
- Prelude Videos Thread
- Official 1st-3rd Gen Prelude Picture Thread - No Comments/Replies/Flaming
- Official Prelude EXHAUST Picture Thread (All models)
- lsd tranny (searched)
- Max size tires on stock wheels
- ECI
- Cluster, Stereo, Performance Electrical issues?!
- my new daily
- Few questions (pics)
- Grinding in gear
- HELP "98 prelude" NO VTEC !!!
- my heater stoped working in my 92 prelude
- Light weight 97+ preludes
- Yet again
- H22a **NO VTEC** HELP!!
- 4th gen gauges
- best drivetrain import company'a
- Biggest headache ever!! READ THIS
- Interchangeable rack and pinion
- Need Major Prelude help, concerning swap..
- removing factory alarm
- question about H22 Tranny
- H23/H22 Alternator
- Wiring diagram
- ►►►►►►►►►FAQ FAQ FAQ - 99% of your ANSWERS are HERE◄◄◄◄◄◄◄◄◄
- looking for h22 turbo log manifold dyno numbers
- Accord clutch master cylinder compatibility?
- engine swap help?
- Brake warning lamp error?? HELP!
- Need pin out asap!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- can i use civic/integra/accord fuel pump 92 si
- please help with tach problem (ive searched and havent gotten any where)
- 5g aftermarket wheel install write up? (searched)
- Headers for H23A1
- 1988 honda prelude
- Review: My Custom 2.5" Exhaust
- when my car warms up the rpm revs up and down
- Idle
- tranny noise
- Prelude gen4 injector wave form - fuel flow meter project
- alarming
- speed sensor problem.. help please
- HELP!!!!!!!
- Well hello there Mr Hole!......my latest discovery!
- Power to Manual steering conversion 5th Gen
- Pinging at low load between 3k and 4k
- h22 build
- idle issue ive searched and have a question
- brake fluid lines
- h22 and h23 blocks the same
- did some searching and i'm still a little confused f22b to h22
- rough starts NOT in cold weather
- Clutch relase
- Are sparkplug covers important?
- Question about head swap??????
- Clutch disc Interchageable?
- carbon fiber hood adjustment
