Wide Band o2 sensor
Old Oct 24, 2003 | 08:14 AM
raser5050's Avatar
Default Wide Band o2 sensor
http://www.takakaira.com/asp/t...njqMl
this will suit for regulation S-AFC?
Old Oct 24, 2003 | 09:28 AM
spoolinlude's Avatar
I live under a rock
Default Re: Wide Band o2 sensor (raser5050)
Not with an AFC..... sicne it modifies the factory ECU's fuel map...... you'll need two O2 sensors.... one for the factory, and the one for the wideband readout...... its actually a pretty common thing to do now
Old Oct 24, 2003 | 10:19 AM
raser5050's Avatar
Default Re: Wide Band o2 sensor (spoolinlude)
I can use this as Wide Band o2 sensor ,and with its help adgust AFC,or me needed motec?
Old Oct 24, 2003 | 11:09 AM
577HondaPrelude's Avatar
Or you could get one of these set ups:
http://www.plxdevices.com/onlinestore.htm
it has both wide band output and narrow band outputs for your stock ECU.
Old Oct 24, 2003 | 03:20 PM
BoostedH23a1's Avatar
Default Re: Wide Band o2 sensor (57STS)
hmmm
airesivt
Jun 16, 2014 09:33 AM
DC2R96
Feb 11, 2011 02:17 PM
ChaosUnbound
Aug 25, 2004 08:12 AM
opto_isolator
Mar 27, 2004 05:37 PM
fastestdriver
Jan 19, 2002 08:04 PM
