View Full Version : Honda Prelude
- LSD Fluid JDM M2B4
- New suspension
- 5 gen prelude stalls
- Prelude Turbo Kit and Tuning Video!!
- which ECU ?!
- H23 Crank question, resurfacing journals
- 92-96 h22 jdm 5spd trans
- h22 all motor mild tune questions
- Is there such a thing as a JDM H22A 96-98 Engine Swap OBDII - Looking for 97 Prelude Swap
- fuel injectors clogging
- will a fuel rail for 5th gen lude fit 4th gen of h22
- Just a little help
- 93 JDM H22A idle problem, Engie shuts off when parked or when fan comes on HELP!!!!
- Quick intake question
- euro-r tranny price
- 1990 Prelude engine swap
- help finding Ball joint on majestic
- 4th gen head unit question
- Please Help, I need to INSTALL TWO OF MY 02 SENSOR
- PSA. If your tranny doesn't shift as smoothly as it used to. Definitely try the new MTF
- VAFC II- INSTALL HELP NEEDED!!!
- Calling Skylude
- need help quick h22a into a 95 SE
- turbo prelude
- honda prelude parts
- Well known auto paint shops in CA
- Car is built... wont fire
- blown speaker in 5th gen need replacement help
- Painting Interior
- Will a h22a4 header fit a jdm h22a?
- new and fun oil leak!!! (maybe oil cooler o-ring/balance shaft seals??)
- Breaking lug studs
- 3rd time changing my manual tran fluid. I always have like a 1/2 a quarter left
- Wierd sounds coming to a stop
- horrible sound comming from rear suspension
- Need Advice on whether or not to buy this car (97 SH)
- Flywheel and clutch question
- Timing Belt
- brake problem need help
- Shocks
- Upholstery Help!
- my h22 has no spark please help!!!!!!!!!!!!!!!!!!!!!
- What type of paint is best suited for your rockers?
- H23 Vs H22 Header Compatable??
- Block drain plug
- Need help with FJO Injector Driver install on a H22
- Need help with engine matching.
- 5th gen suspension
- Ac problem
- cover on valve cover
- Doh, can't take off the oil filter. Ok to just leave it?
- newly built motor
- Oil Leak 93 h22
- oil leak below oil filter
- Window Trim Question...Please Help!
- Leakdown Test
- SpeedTrialUSA HPDE at GingerMan Raceway Saturday, April 14
- 3rd gen prelude 2.0ex twin carb, bolt on filter????
- H-Brace For 4th Gen Prelude
- NEED HELP vtec problems
- my ride got broken into Yesterday
- Trans rebuild kit
- Rebuilding Engine
- FS: H22 Oil Pan gasket and main a couple other seals
- Consequences of switching from H22A1 to H22A4
- s2k rims
- Shift Linkage problem
- Can't get oil pan off
- The h22 project hath commenced...
- boostin info
- Cyliners 1&2 are running 250 degrees cooler than 3&4??
- Motor mount torquing sequence?
- Car wont turn over.
- OBDII - OBD1
- Setting up EGR with Euro-R/Skunk IMs?
- downstream o2 sensor stuck
- Is it safe to drill the trunk floor above the gas tank?
- 92- PRELUDE SI ALL-WHEEL-STEERING FOR SALE!
- all motor...no boost
- what years of the prelude interchange?
- oo2 sensor
- transmission problem
- Need Help
- Oil???
- Prelude bogging. wierd problems. videos included. Please help.
- New problem has arised: Overheating 92 Lude
- Purchasing a 1997 prelude SH... what problems I should look for????????
- Prelude VTEC vs. Integra Type-R
- widest rim/tire setup with 4ws 4th gen?
- car starts then stutters and shuts off
- h23 on h22 head
- idle problem
- From Crank Trigger To Internal Coil
- lug bolt diamter
- stripped oil plug HELP
- F-1 Racing?
- stuttering and surging idle cant figure it out
- Cant find a thread that shows how to identify A skunk 2 Cam
- hks super sequ bov question, sputtering?
- Chunk missing out of my transmission :(
- I got bored today... you will like
- Need Help!!!
- choke problem, prelude twin carb
- Leak Down Test
- underdrive pulleys
- Removing AC?
- Best spot to tap for power? (Gauge related)
- valvetrain and intake manifold
- Attention with Hesitations. "Fixed"
- honda-tech is on honda tuning
- Swapin an auto trans in a 97
- 5th gen with gt3
- leeking fuel injector
- 15s on a th gen
- 95 Not Starting
- f23 intake mani question
- Found a little coolant leaking...
- Wiring Gods: SOLVE THIS! (WTF wiring) *Large pic*
- H23 vtec (Bluetop) Internals
- Temperature Gauge NOT WORKING!!!!
- H22 heads 97 > interchangeable with 97 < ??
- weight of h23 engine
- need help looking for parts
- Help finding a part
- DSM injector install writeup ?
- Quick question about corner lights...newbie!
- part number on FITV.
- Weak brake pedal after caliper install???
- 87 Prelude 2.0 SI
- 5th gen steering removal, quick question
- New to the 97-02 Prelude
- F22 Accord tranny fit on H series block?
- How hard to swap H23 head with H22?
- H23 Cams? What are you sporting?
- Changing piston rings? what should i do?
- needed advice "i wanna go fast!"
- exedy clutch
- what are some good slicks?
- Jdm H23a Vtec swap
- i need a lip kit and S2000 steering wheel!!
- how bad is this? (pics)
- Okay. Seriously. How damn hard can this throttle be.. wtf.
- 60mm exhaust - header - what to do? need advise asap! Thanks
- Swaping an H22a Type-s into a 1993 prelude non-vtec, how hard is it?
- running k pro coilovers?
- Wiring harness diagram for a 96 OBD2 Prelude VTEC h22
- How do I become a regular user?
- *HELP* Lowering my 4th gen. Do i need a camber kit?
- im sure this is a nub question but would adding a ram air (hoodscoop) over your intake filter improv
- Control Box 88 Prelude Si
- mfactory block/water adapters, any good??
- 5th Gen Swap Options
- Making Your own header.
- KTeller Exhaust bolt up - what muffler?
- headlights take awhile to come on...
- oh man..this prelude
- have a 96 prelude, found a 94 h22 engine and tranny.
- QUick question about those yellow ION bulbs.
- h22a euro r accord motor
- h23a j-spec
- 92 prelude si (800)
- 93 vtec alternator amperage?
- where is the jumper plug for check enigne on a 92 prelude???
- h23a/vtec start-up
- Time for a timing belt change.. anything big I need to know before I go in?
- car door handle problems
- 16 X 8 TE37
- still bogging
- complete euro R intake manifold on ebay
- brakes squeaking
- h23vtec info
- H22A Timing Belt?
- has anyone bought anything for budget he post in this section
- h22 trans shifter shaft housing leaking
- nissan vs. honda
- stuck throttle.. bad motor mounts??
- Prelude Toe/ Camber Issues
- OMG!! I just had it! help me out here!!!
- rear upper arm gave out???? chassis compatability ?
- Cam gear removal and install
- hard starts and a bit of confusion
- 5th Gen SS Auto died....Need referrals/swap
- My build idea. Okay?
- H23a accord euro r....
- jdm to us conversion
- Buying an H22
- brake cooling ducts
- 2000 type s swap
- Dimensions of the double-din radio opening in 5th gen dash bezel?
- Will DSM injectors fit H22 without a problem?
- QUICK QUESTION!!!!! 5th GEN !!!
- Engine Removal Pics - 1998 Type SH
- Type S pistons?? (been searching like crazy)
- Brake Issues - 94 VTEC
- HID Conversion
- Honda Prelude '93
- Modified Intake
- What is the diff. between a jdm throtle body and a us
- Tyre pressures for a BB4 JDM prelude with 16'' rims?
- Thermostat location
- Where is the ECU at on a prelude?
- Honda MTF, or can I use motor oil
- New aftermarket CD Player
- have a few h23 wires with out a home
- Where to Buy Parts
- JUN Cam Owners Thread: List your setup/details
- Morosso Baffled Oil Pan = POS???
- Wierd Electrical Problem
- Autocross SoCal
- Cranking the motor!
- does a traction bar harm suspension dynamics?
- h22a skunk2 stage 2cams and lma's(lost motion assemblies) to mod??...or not to mod that is the quesi
- Compression test.
- speedometer problems
- el gauge on 94 prelude vtec flutters not running correctly need help
- i am looking at building another motor need some help
- weird kinda rattley sound under load 92 si
- Cam setup with cam gears and New Valvetrain little info
- Shock nut- in trunk
- Shift linkage removal
- cel code 12 and 14
- Will an H23 bolt up to an 88 prelude 5 speed?
- Grease for shifter ??
- Clutch Decision
- Mysterious random clunk/ pop sound from front at low speeds?
- Multiple Missfire
- Brake Lights not working
- *HELP* should i bother buying these????
- went to the track today.
- Silver 5Th Gen getting pulled on 401 going into Raeford
- Will a h22a1 aftermarket header work with a h22a4?
- 98 prelude halfshaft
- low compression in cylinder 3 and 4, compression lost through oil cap????
- GREDDY TIMING BELT
- h22 problem iddle problem HELP!!!
- keeps stalling but idles and drives fine until clutching, braking or turning...HELP PLEASE!
- Wiring bumper lights (Problem)
- Brain Crower Retainer H22
- After a week and a half I still cant get my intake mani off :(
- hey guys help me pick i need help thanx!!!!!!!!!!
- Will an H23 header fit an H22?
- Installing CV axles
- h22 has spark, fuel, cranks but wont start
- All N/A 13 Second Owners
- Quick question. Searched!! 4th gen vs 5th gen suspension???
- MAP sensor
- Prelude Radio
- Help: B21A1 Auto transmission to Manual
- H23 build up!
- hey fellow luders need help!!!plz
