PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 [143] 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. rear motor mount.. what a b****
  2. pic organization thread
  3. h22 manual tensioner conversion
  4. Power Steering Pump?? Replacement?
  5. headers f20b
  6. H22 Head Question about Detonation
  7. h22 oil pan differences?
  8. What's the best 5speed Tranny fluid?
  9. Front Bumper
  10. Gas Mileage for h23 users
  11. lighten the front end of a 5th gen?
  12. climate control lights... can i change them?
  13. help what are these sensors named h22
  14. Please help ...... is my engine TOAST?
  15. help "spark plug"
  16. No one to tune my car
  17. more help needed
  18. 4TH OR 5TH GEN????
  19. are agx's same as gr-2
  20. broken lude costed me $900 to fix!!
  21. Accessory Socket= ?
  22. Idle ?
  23. Hondata & P28 chip
  24. Axle issues...acceleration vibrations...need some help.
  25. anyone else with shock knock help?
  26. low idle
  27. h23 trans
  28. drive-shafts?
  29. How much oil for h22.
  30. Cooling fan problem
  31. 12" Fan fit on stock 4th gen radiator?
  32. 91 Prelude reving high?
  33. V-TEC question 2
  34. UK prelude ECU swap out for JDM prelude ECU? P13
  35. Intake Manifolds, are they different?
  36. Power Steering Gone, Please help
  37. chassis codes
  38. helicoiled???
  39. rotora vs. powerslot vs. brembo
  40. sorry to those I offended and intructions to people that are absent minded
  41. Trick it out right now 4th gen
  42. need help with jdm h23a swap on 92 prelude si
  43. Pspec install and review
  44. Manley or Supertech valves & valvetrain
  45. h22a cap
  46. 92 prelude DISTRIBUTOR firing order
  47. s2k antenna on tha lude??
  48. interesting hid idea
  49. Loud rattle from the timing belt side...something bad to happen? PLEASE READ
  50. SH clutch fluid
  51. How do you remove the rotor off of the distributor?
  52. need help plz
  53. Leather shift knob with red stitching?
  54. Lights Comin on all the time
  55. hid ignitor(mitsubishi electric)Acura TL 05 connector
  56. 82 prelude question
  57. carbon creations
  58. WTB Good Prelude Body lacking drivtrain with title.
  59. h22a4 need parts!!!!
  60. H22a exhuast?
  61. CAM
  62. EXHUST SYSTEM
  63. Anyone install energy suspension bushing kit??
  64. V-tech question
  65. Air Bag Sensor
  66. JDM Prelude 4th gen front side lights question
  67. lost low-end power?
  68. what size tire to use on these rims
  69. LED interior light coversion
  70. Short Shifter for 5th Gen Lude
  71. 1994 Full folding rear seats project.
  72. PGFI sensor code?????
  73. top fuel zero 1000 exhaust?
  74. ATTS When does it work?
  75. Something bad happened to my engine
  76. 95 prelude - oil leak from back of block. Oil temp unit?? help me..
  77. Electrical/Electronic System
  78. double clutching/shifting techniques
  79. Question about super chargers
  80. injector clips order
  81. Bushing Replacement
  82. what would be the best clutch combo for 600+whp set up
  83. How long does it take to change the water pump on a h22 prelude?
  84. boost vacuum write ups?
  85. cruise control problem
  86. Wow, no h23 swap in the FAQ section?
  87. OK so I am back, Very blown
  88. P5M, what pistons are these?
  89. how to remove rear bumper
  90. WTB: Camshaft, Camgears, Flywheel, short shifter for 4th gen
  91. help
  92. help I just hit a curb!!!!!!!!
  93. Help! I have a short
  94. DIY idle adj.
  95. Shaving Emblems
  96. ecu
  97. removing 4thgen bumper help
  98. Aftermarket seats
  99. 5th gen fuel pump on a 4th gen
  100. ATTS Codes 42 , 43
  101. need help asap
  102. Simple Question
  103. HEY SUP FOLKS FROM NORCAL CAR MEET THIS SAT.
  104. touch-up paint
  105. Hi Flo or not
  106. clutch pressure plate flywheel
  107. Dirty oil
  108. 3rd gen 3g Prelude 4WS manual rack conversion
  109. vortech supercharger on h22???
  110. 205/55/16
  111. Clearing Codes
  112. auto to manual swap
  113. Need pics of air bypass filter
  114. Markings of Euro-R cams?
  115. eBay seats...
  116. Hood dampers for Carbon Fiber hoods for the 4th Gen
  117. questions about jdm h22a
  118. Who is the FASTEST?!?! Can we get an update?!
  119. My Weapon R Secret Weapon Intake install
  120. Difference between the Type-S and Euro-R manifold
  121. projector retrofit for a 5th gen honda prelude
  122. King Motorsports modification to Mugen H22A header?
  123. Oil inlarge amounts the Intake! PCV works fine
  124. Turn signal problem (short ?)
  125. 5th gen seats compatible w/ 4th gen?
  126. Prelude Power Steering Rack Rebuild
  127. Need help on Koni Suspension and 4WS....
  128. need help on electrical issue
  129. Is the skunk2 IM really that bad ????????????
  130. tb problem..... need help!
  131. Type S cams the Same as F20B cams?
  132. K-1 Attack Roadster w/ H22 motor
  133. what would the benefits be with a chipped p28 on 94 prelude h22a1?
  134. help. power steering problem?
  135. need help with door hinges
  136. camber kit needed???(searched)
  137. Engine Main and Rod Bearings????????
  138. Check engine light
  139. car won't start after swap
  140. New Hood
  141. anyone know what this problem is?
  142. jdm integra white 4 lug rims
  143. F22 Turbo Kit
  144. Help make my Prelude pretty...
  145. custom airbox
  146. h22a map sensor quetion?????
  147. Engine preparations for possible JRSC?
  148. complete h23
  149. Wheel damaged by pot hole can i get the city to pay for it?
  150. can someone tell me what peice would go here
  151. Rear Wheel Bearing on 2000 SH @ 73k miles?
  152. PLEASE someone tell me what this is. . .
  153. cel code 43 on 93 lude vtec (wiring?)
  154. compression test
  155. Tire Rotation Question
  156. Engine Problems Relating To The Clutch
  157. product reviews.
  158. Insurance on a '01 Prelude SH?
  159. h22 alternator tensioner bolt
  160. Changed Front and rear brakes and rotors to cross drilled and slotted but.....
  161. Motor Mount Insert Question for H23 vs. H22A4
  162. Wondering does the H22A dyno about 10-15 more hp on a dyno
  163. SRS light on after auto to manual conversion
  164. F20B or H22A swap
  165. Getting to the Balljoint
  166. koni yellows up front and tokico blues in back? is this bad?
  167. Short Shift Kit-SEARCHED
  168. cam/air/fuel question
  169. Serious opinions on kteller header
  170. F20B swap questions
  171. Im in a delemma... Help....
  172. HELP: Code 9
  173. which intake
  174. Fidanza Halfshaft Review
  175. 98lude, chipped p13 odb1 ecu, chrome and boost *question*
  176. sleeve choice????
  177. need help
  178. f22B vtec
  179. 4 sale EF's parts-3rd gen lude,Teg
  180. battery light on
  181. F22B question
  182. Installing Volt Gauge on 4th Gen.
  183. cams
  184. h23 block w/ h22 head..swap in 5th gen lude...possible?
  185. Should I also replace the tensioners? (91k miles)
  186. Tachometer Trouble
  187. Good Idea? Bad Idea?
  188. wheel hop like MADD crazy??!?!??!
  189. Stock ECU codes.
  190. 92 prelude idle problem
  191. PLEASE HELP
  192. F22A6 into a 89 prelude si?
  193. What size washer do i need to get for my 94 Si oil drain bolt?
  194. 1990 prelude need help
  195. Power steering ...
  196. Any picture of front braking system?
  197. What is the Velocity stack intake??? Need help locating.
  198. what should I know about installing a 4th gen vtec tranny into my 5th gen
  199. taching out a jdm h22a
  200. if u car is turbo is safe not to use the Balancers shifts
  201. My car is slow!!!!!!Help
  202. oem size tires on 5th????
  203. bb4 Side Marker Help (searched)
  204. 2 quick questions...
  205. Wow Ebay has some nice looking black housing headlights (gota see this)
  206. can u chip a usdm p13?
  207. the best timing for a h22??
  208. taking off a abs computer
  209. h22 revs by itself at idle???
  210. Tranny Reassemble
  211. drilled out cat... prolly shouldnt have
  212. Overheating problems!!! Please HELP
  213. Cam gears cause cel?
  214. Can I go boost??
  215. Vafc2 in a SH
  216. Type-S piston help!
  217. Type R seats in a 2001 prelude
  218. msd sci
  219. Using Honda MTF with LSD Tranny
  220. BOOM!!! (HOUSTON WE HAVE A PROBLEM) turbo techs please read
  221. HANGOUT SPOTS IN ORLANDO
  222. h22 pistons..?
  223. Magnaflow Exhaust installed
  224. not starting, egg smell
  225. DYNO...JUN,DTR,etc...P1 auto
  226. What springs fit 4th gen ludes?
  227. OBDII HELP
  228. shift cable
  229. VAFC 2 help
  230. F22 Turbo Question
  231. H22 starter installation HELP!!
  232. WTB P13 ECU
  233. cooling fan fuse keeps blowin
  234. p13 ecu
  235. bumper lenses
  236. how much as parts car?
  237. car jumped timing help
  238. Honda O2 Sensor or Denso (eBay)?
  239. Wanted- '91 Prelude Headlight Covers
  240. Catback piping to muffler on H23a
  241. Brakes quastion ...
  242. Question about camber kits..
  243. FS: OEM Springs, Struts & Shocks Prelude 5th Gen.
  244. JDM motor replacing H22A4
  245. Help in making my h22a4 a racing car
  246. JDM rain guard
  247. The work and time required for installing a Flywheel?
  248. ignition thoughts
  249. magnaflow high flow catalytic converter?
  250. Check Engine Light - Cat Converter
