View Full Version : Honda Prelude
- equation for better launching ?
- question about fog lights for a 92 Prelude
- dc sports collector mod
- H22A Internal "Breather Cover" Question
- BOOSTED H23a
- '91 Si 2.1 Revving Issue
- h22 head on a f22b
- Searched..H23 non-v IM vs. H22 IM
- which IM for turbo h series
- "Port n Polish" Results from the flow bench......
- Removing bumper from 4th Gen
- DIY rustproofing?
- Power steering problem...
- type SH automatic?
- Missing the fuse to my fuel pump... Problems???!
- Summer is coming, help me fix my power windows!!
- H22 in a 96 civic with a H22 tranny Help! Speedo
- spoofing the vtec pressure signal
- square or round knock sensor plug need help!
- Timing Question!!
- WTB Auto Shift Cable 4th Gen
- Clutch problems
- Type-S cams
- How did u hold ur HID bulbs in????
- Running Rich??
- how to confirm what tranny i have
- 75 shot in JDM H22A?
- Ultimate swap guide
- Base vs. SH drive shafts (cv axles)??
- Hear that removing the EGR provides power gains..
- oxygen sensors
- Flexpipe Leak + Code 12
- building motor for jrsc
- h23 valves adjustment specs
- h22 valve timing questions...
- Turbo H22 lastin?
- 1987 Prelude Si *How do you take the steering wheel off?*
- Prelude engine and ATTS lights went on.....need advice
- Need wiring diagram for 97-01 Prelude Cluster
- 97 lude immobilizer
- car wont start after sitting for a week
- 87 Si-4WS Wont Start
- thought you guys might like a heads up (mugen bumper on ebay)
- the clutch clicking... idle dropping... solutions?
- "trusted" mechanic on timing belt...
- H22 and H23 Throttle body
- prelude gagues conversion
- Steering wheel is a bit left, I go straight.. and other wierd stuff
- JDM 92-96 Prelude Climate Control Vent & Sensors Sy "i need info on wiring"!!plz
- coilovers or lowering springs?
- tire size..
- prelude thermostat
- gears feel notchy and 5th gear grind
- what shocks work with the SH model?
- Carbon fouled spark plugs
- Using oil like crazy!
- differance between OBD 1 and OBD 2 IM?
- Weighed some parts, thought I'd share 4th Gen
- Antenna Wiring Question
- Does anyone have mugen headers???
- crower cams with stock bottom end
- Need advice on h22a7 and h23a(JDM SiR wagon dohc vtec motor) blocks and also final drive ratios.
- Tire Sizes on Stock ride height, 17x7 wheels?
- headlight problem
- performing 5gen auto to manual swap starter question
- '01 OEM White front bumper
- check engine and ATTS light came on
- DC ceramic vs SS . opinions any1
- I NEED HELP! PLEASE....overheating..
- mugen
- Prelude USDM si cluster ... question
- Who has rebuilt their own tranny (DIY)
- Loss of POWER? due to distributor and cap change?
- good setup for 07+ prelude
- H23 DC Header part #
- question about 91 'lude si 2.0
- What's the best way to secure my vehicle?
- top of manafold
- short shifter
- FINAL WORD on CAI vs SRI (stop asking about it so much!)
- 97 OB2 P5M - running with a JDM OBD1 H22 - NO VTEC?????
- slim fans on Koyo Rad for 97'
- need part number for a spark plug(h23 boosted and 1 step colder)
- Hesitation/jumping tach(searched)
- STR 68MM throttle body - ebay
- OBX LSD
- TDC for a Specific Cylinder - How do you know?
- good tuning shop
- Need help asap
- Turbo h22 Prelude Tuners in South Florida
- Cold Air or Ram Air? Best results
- Turbo Install 96 SR-V
- whats the Diff between JDM and AUD P13 ECU ?
- Removing intake resonator looses low end power ??
- B18b into an 84 prelude?
- Lug Pattern
- prelude turbo ?
- CEL-->23, Knock sensor.
- Rev Limiter Problem
- Obd1 or Obd2 H22a
- A/C problem......need help ASAP
- Cai-short ram-type s intake...which is best?
- timing belt was coming off so I pulled the cover and the tensioner bolt was broke???
- What springs offer the lowest drop? ('02 prelude)
- would these fit a 4th gen prelude?
- 97-01 w/no mods What is the whpand torque?
- 1985 Honda Prelude Tuning.
- On h23 flywheel, the white line or the white plus sign is tdc?
- Not getting fuel!!!
- CKP and TDC sensors
- is there a washer on the outside of the camshaft gear?
- fuel filter
- CD player randomly out? does it have power? which fuse?
- Throwing codes
- Need help removing Console!!
- simple ecu question
- 5th Gen Exhaust Recommendations
- Is this a 96 p13?
- retard ignition timing
- Gas milage (tell me I'm not crazy)
- Cylinder bore+hone and line hone pricing?
- 2.2L sohc vtec?
- wrong readings on my speedo need help!
- Spring install trouble **Free Laugh**
- Gone through a set of brake pads in 3x months, need advice...
- Advice 97+ jdm h22a into a 96 usdm prelude
- Brembo OEM replacement Rotors
- H23a1 oil pan fit h22a jdm motor? (search but no luck, help please)
- Quick question on valve terrain
- First area to look at when car idles rough?
- usdm f22b sohc vtec into 93 prelude Si
- Vtec controller problem
- EGR Valve - Did search need more info...
- JDM Honda Prelude 99-00 Dealer Brochure
- SRI vs. CAI
- Are extensive repairs good or bad when looking for a used prelude?
- can somebody post the duration and lift of the skunk2 cams stage 2 and obx stage 2
- Cable or Hydraulic?
- rod bearing color order from smallest to largest, 97 h22a4 ????
- Question about hytech/an-r/prospeed/smsp-type headers
- Wheel Spacer question
- Turbo project underway
- 87 prelude si a/c removal
- h22a4 balancer belt marks
- How long should I idle my engine?
- first CEL of ownership..need some help
- quick question - VAFC + leaner settings = better fuel economy?
- Gauge install: running through the firewall questions?
- adjusted valves, now car smokes
- OEM 97-01 Front Bumper
- question on pricing (hid retro)
- Possibly the fastest Non-Vtec H23 Lude
- Going JRSC, What are must-have's?
- IACV for 92 prelude
- Swapping H23 out of Automatic Si.........need a lil info
- center radio pouches
- Quick question about springs/shocks
- Official Body Parts Weight ??
- ECU pins and wiring
- hondata h23 gasket
- Timing Belt ?
- AEM cold Intake Questions
- jdm h22 95 accord
- Noob needs help with suspension
- Polyurethane bushing for 1997+ preludes??
- Suspension dropped on the front right side...Diagnosis?
- Oil usage
- speedometer not working
- H22 with no VTEC?? Need Help
- 5G steering wheel hub ?
- How much should I mill the head?
- took it to the track. ran it twice
- 88 prelude si performance?
- weird shaking??
- Open Block vs. Closed Deck
- which valve springs?
- Need help!! URGENT!
- Got a code 4 chk engine light now WTF
- V2 Intake question?
- Acoustic Feed Back Question
- ANYONE HAVE ONE>>>> H22 PISTON and ROD **HELP**
- What stage is this exedy clutch disc?
- Need help from my fellow H22 owners,concerns dyno run...
- jdm h22 swaps for 92-96
- need wiring and vacuum diagrams please
- Hyd. timing belt tensioner question
- So my block and pistons are fubar'd...
- JDM H22A in 3 gen Prelude!
- aight getting my h22 put in next weekend
- not even at 3,000 miles and oil is lowww
- Best Way to Recondition Seals
- car dies when starting
- has anyone personally installed a diff?
- aftermarket lca's for prelude?
- idle out of wack..
- Hondata w/I.H.E
- 97 h22 crank into 92 h23??
- Can't Diagnose Problem...CEL intermittant HELP?
- Broke sensor!!!! OH NO!!
- A-pillar / roof rail cross section (pic)
- Need to run a OBD1 H22 with a OBD2 ECU
- Question about coilovers
- will a 92-96 automatic prelude tranny work in a 97-00 automatic prelude ?
- Need wiring diagram for JDM Prelude cluster
- jdm f22b + h23a1
- Which Sports header
- skunk2 pro
- OMG!!! My Lude won't go into gear and clutch messed up. NEED HELP PLEASE!!!!
- should i keep my fmu?
- Cat Convertor suggestions
- kteller header/crossmember
- HELP!!! i need help with a nick name for my lude please help
- h+k hybrid?
- How much oil and trans fluid?
- h23 clutch fit a f22?
- new rims and tire question
- Wierd Electrical problem 5Th Gen Prelude
- Replacing ignition switch help?
- Good Price for an H22 Swap
- Passenger air bag (4th gen)
- 1997 honda prelude dohc vtec
- Distributor
- good header
- 95 jdm h22 lsd tranny on 01 type sh long block
- stock jdm header
- Turbo Prelude Owner? **Please Read**
- Engine Management questions
- ECU question - hondata
- h22 and boost, What are you guys doing for a good Breather Setup
- Spoiler question?
- headers
- ARP rod bolts?
- Prelude w/ high mileage DSM Project 1 gen turbo
- test pipe
- Oil Cooler Question...
- best oil pan for drag racing with forced induction
- Code 4 On h22 ekcivic coupe Please Help!!
- Switched from 205-45-17 to 215-40-17's.....Harsher ride but better control..:)
- i need helpppp
- Tein Coilovers.....Difference Between Flex and SS...??...Is it more than the mounts and EDFC?
- Anyone a pro at putting the timing belt on?? Got a couple Q's
- Help with CEL code!!!
- What's the avg. 1/4 times for prelude 96-00 turboed?
- Electric Shock Closing Door
- Direct port Nitrous on h22
- bad rotors? help me diagnose the problem!!
- 2000 Crv Radiator into a 4th gen?
- WTB : Honda Prelude ECU P13/JDM for H22a MT
- can someone help me with info for a install...
- Swapping A H23 with a H22, Is this Engine Suitable ?
