View Full Version : Honda Prelude
- help with megan silencer
- auto tranny going
- Having a Problem and Out of Ideas
- Consumer review: Radiator from www.partstrain.com
- Oil or Driveshaft grease leak? (pics, apx 700kb)
- Torque Converters
- 2001 engine swap
- H22a4 versus h23a1 block differences
- I finally found something to clean my 5th gen. headlights with!
- skunk2 throttle bodies
- no vacumm
- 5th Gens with Wings West Wide Mouth Kit
- Cleaning EGR metering ports
- H22A turbo - how many PSI on stock internals SAFELY?
- grinding noise from front end???
- what would cause this ?
- *CODES 45, 71 and 72*
- where can i find a set of type s cams?
- Neuspeed "L" bracket question.
- preoblem with e-brake, help needed
- Would generic be as quiet as the real thing?
- oil light comes on but oil level is fine?????????
- My 3rd Gen H22A Swap Project - PROGRESS - 56k NO WAY
- Alternator problem.. 13.5-13.7 volts?
- car wont start need help
- Which is worse (for exhaust)? Bottleneck or overall smaller diameter?
- h22 STR cam gears...
- Engine wireharness
- Shuttering on acceleration?
- Trunk Lid light
- Overheating and Dying
- What type of fluid?
- 1st gear grinding?
- 85 Prelude Brake Woes
- Big drop...which Camber kit? (plain and simple)
- What size Optima Red Top will fit in a 5th gen Prelude?
- *searched* Air conditioner problems
- Problems with JDM H22
- 90 Prelude AC problem
- auto tensioner
- h22 head on to f22 block qusetion?
- HOW TO: Remove Power Steering and Loop the lines
- 205/50/15
- Need help with my jdm h22 on my 93 civic hatch"""
- anyone know what size this is?
- p13 an crome????
- What you do you think is better for 11.5:1 compression NA H22a4? Skunk2 ProSeries stage 1 or 2?
- Anyone know the springrates on the H&R Race springs?
- Shifter Bushings
- 00 prelude will crank but won't start help anyone?
- real quick question
- uneven braking
- prelude not starting - vid included
- Getting brake caliper piston back in
- JDM parts interchange-ability
- 1983 prelude idle issue
- What oil should i run?
- TDC help
- E55 projectors retrofitted on my 5th gen prelude
- 93 Si brake bleeding question
- KAIZENSPEED Balance Shaft Eliminator kit
- super charger
- Head Problem, loud metal sound
- hissing sound. searched but didn't really help
- how many ft lbs do i torque my oil pan on 93 h22 ...please help!!!!!!!!
- How to recharge A/C after motor swap
- Air Conditioning gets warm at higher RPM's
- h22 swap problems with hoses that go 2 the intake
- Prelude won't crank
- Question ab out headlight
- Keyless Entry Question
- So confused about my 1988 Prelude...
- h23a1 non-vtec pinouts?
- h22a4 block with f23 crank
- E-brake feels different, help please!
- 97 prelude dignostic plug?
- Older STR cam gears good?
- Problem with new brake pads
- oil on spark plug threads - engine cranks but wont start
- Fan runs after car is cut off until motor is completely cool...
- Help on heated seats
- intake manifold
- boosting my usdm h22a4 soon, need some suggestion
- injen intake + k&n filter?
- Sloppy steering?
- aquiring a prelude for free....inx
- valve guides?
- Question on turbo cam and idle
- How to clean AEM cai?
- JDM '95 H22 swap into a 97' base 5 spd Lude
- D4 Light
- Caliper Bolt Help
- Changing a wheel bearing...
- Obd2 to Obd1 distributor wiring need help! (searched)
- Help needed - removing front bumper (fender) 4th Gen
- El Gauge conversion problem, turn signal indicator won't work. HELP!
- 95 prelude vtec vacum hose diagram
- TPS reading in reverse? help me out
- Distributor king rotor replacement
- i need advise on what exhaust
- is this the waterpump?
- Different in JDM and USDM H22 Head
- jun header
- does the megan racing header for si have any problems?
- interchangable external coils F22a1
- Clutch for turbo
- RPM Raising, and then dropping?
- H22 bog at WOT. Most likely a fuel issue.
- Mad T-Belt issues! Ideas needed
- h22a CUTS at 5500 rpm's . . . . .
- How fast
- Putting in a ZEX Wet Kit, 75 shot, which MSD Ignition do i need
- does this pose a threat???
- what do you think of this as an OEM replacement clutch?
- tuning the timing on a jdm h22
- OBDII P5M ECU on JDM H22A giving misfire codes - know how to resolve?
- Tach question
- Is this header giving substandard performance?
- How hard is it to modify an exhaust not intended for your car?
- f20b ecu conversion (link)
- Fluorescent Dyes transmission leaks
- Do I need a camber kit?
- Power Windows Sticking
- cam drawings
- TBS sensor
- Different question abut seats (already searched)
- Random OBDII DTC Codes, Help
- swap parts
- did a compression test on my usdm h22a4 today, is this number ok?
- Odd vibration/npise @ 1500 and 3100 rpm on 5th Gen after complete tune-up. HELP??
- Recommendations on brake system
- EGR valve question
- Identifying Type S cams
- Turbo kit for a 1990 Honda Prelude Si MT
- PowerSlot Rotors or Rotora Rotors
- 4th Gen. Shock Opinions
- Prelude dash lighting problem
- valves h23
- shaking problem
- cam settings h23
- JDM H22 A1 swap into a 1998 BB6
- JDM Fog/Pole Button
- changing oil of an automatic transmission
- 4ws suspensions
- how do i tell if its an SH???
- Steering wheel vibrations at highway speed... -> tie rods?
- H23 External Distributor Work with H22A?
- Diff between 97+ SH and non SH pistons?
- Why don't ya take out the passenger seat?
- Rebuilding tranny?
- I need h22 (5sp) tranny...
- F22A Crank Pulley on a H22A (searched)
- Busted Clips In BB6 Driver Side Mirror
- camshaft seals h22a
- blown clutch at track
- clutch squeeking
- 2point6 on "Pinks"
- 5g seats into 4g or Vice versa
- Link for DIY black housing headlights
- belt size without a/c*searched*
- quick question with tranny swap
- grinding 5th gear
- Power steering speed sensor
- has obx fixed their lsd problem
- How many quarts of engine oil?
- Overheating
- Leakdown numbers?
- H22A with a problem...need help
- why does my emergency brake light stay on
- ethanol
- help please...i really need help with this....
- manifold shot what to do >?
- Rebuilding Clutch Pressure!!
- building my head...
- H22A auto in 96 Accord no power
- Strongest sleeves maid
- VTEC SOLINOID GASKET/screen
- 1st race event for my prelude this year.
- Crower Stage 1 or 2 Cams?
- 2000 prelude CEL code 9 CYP sensor
- Prelude replacement antenna or antenna plug
- installing rear shocks & can't get ball joint off, help!!!
- Accord H22/H23 swap question Tried searching
- jdm headlight turn signal wiring question?
- Anyone Running 235 tires or higher? (5th gen)
- cabin filters on 5th gen
- help instauling 92-96 prelude front bumper
- Replacing the h22 oil seperator with a catch can? Advice needed
- Disabling EGR on a h22a?
- caps for balancer belt removable?
- CEL code 14 - Idle Control System Malfunction
- Question bout my 98 Honda Prelude Tail Lights!
- Grease inside my fuel gauge sending unit??wtf
- where is the ecu jump connector to check codes on 95 prelude vtec?
- No vtec in first gear only
- removing front engine mount
- h22 crank..how much?
- 6 speed trany!!???
- engine light / faulty speedo / power loss
- Any companies stock a CF hood?
- Engine Coolant Temp Sensor?
- h23 header on an h22...
- experience with a p72
- Mr Gasket Fuel rail
- help...oil pan torque spec.
- All Prelude Links
- Best Wheels/Tires for 5th Gen
- sound like a bad ECU or not?
- 4th Gen SUnroof Removal?
- prelude halo headlights
- 97 type SH idle problem
- 92 4th gen> JDM H22a engine swap. Looking for pre-swap tech.
- New 92 Lude Owner - Question about 1 and 43 Codes
- What to look for in a used prelude?
- TROUBLE SHOOTING CEL PROBLEM 4th GEN LUDE w/ h22a4 swap
- got a question about black sut build up on rear bumper
- prelude all motor, or turbo?
- Rattling inside my sunroof. Sounds like someone put a marble in there
- crank pulley noise
- OEM Lip Kit Paint
- 1988 Prelude
- M2J5 vss?
- finally got my whole exhaust system intalled!!
- Tires/Wheel Width
- H22A....need help on this engine swap
- Don't buy cheap bodykits, no matter what...
- 93 prelude si~~~~NEED HELP!!
- cylinder head rebuilders
- High flow cat problems
- transaxle switches
- vtec problems h22 accord
- Changin ATF in 95 Prelude
- high compression turbo idleing promblem
- How much Manual Transmission Fluid for 96 Prelude S (F22a1)
- Is it worth it to swap my cams(crower 2's) out for stage 3's?
- energy suspension hyper-flex kit?
- need help on some bracket on the bottom of the 5th gen
- Auto tranny, help!
- HELP ABS and Clutch
- windshield wiper trouble.
- 4th generation prelude fog lens same as the integra ones - lens not brackets
- 93 prelude sir.... What does the sir mean?
- h22 h23
- ...I have a 93 prelude H23a...
- 99 Prelude smoking??
- Check engine light problem
- Question concerning CEL code 22.
- 5th Gen Fuel filter
- prelude,we need to replace the passengers belt,but there are so many different belts andseatbelts on
- how to wire fog relay to turn on without lights
