View Full Version : Honda Prelude
- Engine swap
- EGR ports
- FUEL ISSUES ON MY H22 HATCH. HELP PLEASE.
- no speedo
- My Audio Player stopped working. It says, "CODE"
- Quick clutch/flywheel fitment question.
- Anyone running an eBoost2? I have a few questions...
- Kuruma Motoring on ebay, Good or Bad?
- how loud are Tanabe Racing Medallion exhausts?
- Can you help me locate these parts?
- clutch fluid problem
- whats your gas mileage with your h22 prelude (1999)mines
- Swapping Steering wheels
- VTEC wont engage after tranny swap
- H22a in a auto prelude what ecu to use
- best oil filter under $20?
- Whats the diiference if any between a H22a1 and H22a4 Head?
- what type of bulb do JDM foglights take for the 97-01 prelude?
- Where the Squeaks at??!!?
- Base Map's for Ludes.
- gasoline!
- help with 88si tie rod bolt snapped
- Gears, water pump, timing tdc, crank gear etc.
- 3rd gen ETC Sensor location?
- skunk2 throttle body
- precat O2 sensor....which plug in?
- 4th Gen Prelude Newb!
- what year did the el version gauges come out???
- Automatic Transmission Problems
- ecu chip question
- Brian Crower Stroker Kit
- changing the dash light color
- Rim Repair?
- Question about the bolt pattern
- How much would it cost to swap the engine?
- 1996 prelude troubles.
- Transmission issues. Trouble shifting.
- new2site
- EGR/check engine light
- 89 prelude help pleaze?....
- Racing Team.
- Shipping dropped motor- need advice on damage
- what do you know about Hawk Performance HP Plus brake pads? Any recommendations?
- automatic vss the same as the manual?
- header question??
- extremely touchy steering after lowering
- Need Bumper and Headlights for 1992-1996 Prelude
- interior question
- I need help finding a 99 honda prelude ecu for my motor
- whats the best wheel size for 5th gen prelude? (i searched)
- Brake light on guage instrument light is always on... what the?
- anyone using a plx wideband in 5th gen?
- Engine squeaks....
- Caliper Bracket Pin Removal
- Stuck wheel
- remote engine start on stock honda keyless entry remote?
- 1991 Prelude - Gremlins in the cooling fan motor
- auto to manual swap in 93 prelude.
- Need new radiator, do i take the mechanic's advice? help
- ===Engine oil cooler, Please help
- Need help!! Prelude questions...
- engine close to driver side
- Car shuts off at stops
- f22a non-vtec vs. h22 vs. h23 head flow
- Car starting, then cuts off right away.
- prelude sh tranny and atts questions
- Will an Accord A/C compressor work with an H22?
- H23a1 engine build up any crazy ideas?
- Immobilizer/ecu
- not hitting vtec.. oil problem?
- Prelude 1997 (4 wheel steer)
- Need Help On New Color
- measurements for valve lash type s cams
- USDM car to Canada?
- Car Shuts down, Need Help!
- Lets talk Wire Harnesses
- Problem with my A/C
- center arm rest with cup holder ??????
- water pump?
- h22 alternator question...yes i searched...
- coolant drain on block on h23?
- A couple of h23 tensioner conversion Questions
- CEL problem
- heavy vibration and a squeaking noise coming from the front end.
- 3rd Gen Prelude
- tranny problem
- Removing Crank Pulley
- Car doesn't start right away?
- skunk2 throttle body gasket???
- H22a build
- H23 Transmission Install
- somebody tell me how this works (immobilizer)
- Fog light install with jdm switch?
- Greddy Header Install
- 2001 stock h22a4: what type of gas does it need?
- 5th gen front end repair
- a couple of questions related with change of timing belt and swap of engine !!!!!!
- 4th gen lude overheats at idle but fans work?
- Possible Clutch Problem!! HELP!!
- NSX calipers...........
- 1992 Prelude S F22a Auto - Needs Engine
- RWD prelude
- will a 97-01 shift cable/linkage work in a 92-96 lude
- Motor issues..need help asap
- Parts Identification on H22a Alot of time spent to make this post please help
- new head gasket question
- Q. about rear motor mount
- Prelude Owners! Please help me with this purchase. I am going to buy a prelude. {pictures}
- Radiator hose
- OBD 1 Engine, OBD 2 parts.
- Motor mount stud question
- another question............
- belt?
- VSS help
- 5th gen tow hook?
- Problem reinstalling alternator belt
- 1997-2001 Honda Prelude Foglights?
- my brothers plugs are growing fuzz
- why?
- el gauge conversion problem
- b20a cam sensor, timing, valve adjustment
- THERMOSTAT Problems...
- compression test
- accord lip questions...
- Question about axle seal leak?
- Kteller Header on All motor build?
- whats best spark plugs/wires h23a1
- car's still heating up?....
- H22 turbo help?
- Emergency release button?
- ATTN 5th gen guys, I found a dope site today full of japanese catalog scans
- FITV and its operation. If car only idles at around 1400 upon cold start should I be...
- 1989 Pelude 2.0S Check Engine Light...Help
- Code 41 and 43 question
- 93 h22a intake mani and back side daigram of vaccum lines??????
- Trans filler hole?
- engine rotation direction... question
- will 97-01 automatic tranny bolt on to 92-96 body
- 5th Gen Skunk2 exhaust not lining up, need advice
- Question about balance shafts
- Strange grind/whirl noise in first gear.
- nopi by aem?
- Spark Plug Cover
- 1996 Honda Prelude SI Antenna/Radio
- Vtec Issues in 95 Prelude SRV
- Intake Install - Extra Hose
- 1999 prelude SH
- Slipping gears and Dirty transmission fluid Help
- Car Dash Display Problem
- Maybe finally a cheap JDM like headlight thats non "ricey"? Ebay link
- Dent removal businesses
- Out-of-round tires(!).
- Performance chip
- question about CF hood
- Engine shuts down, when it wants to, driving me crazy!! help!!
- ID help plz.
- Might be a stupid question, but, what do you think?
- Possible burning oil??Help
- dropping the steering column
- Valve cover
- SH knowledge needed: '97-'99, '00, '01 Difference?
- question..
- smoked peice of plastic temp.gas cluster/tv inside dash
- obd1>obd2 and obd2>obd1 dizzy adapter harness
- test pipe or high flow cat
- axle question
- slave unit
- my hood won't open
- Megan Headers not for JDM?
- Small oil problem
- Valve cover ?
- prelude blues...
- Anybody ever remove this part? Rear deck area
- hi i got a 94 prelude vtec h22 A1
- looking for some people with auto SS >> 5spd 5th gen swap in portland area
- bb6 ac removal. What shorter belt number ?
- Location of thermostat ground?
- 96 prelude si bad crankshaft
- 97-01 Type S Shift knob. with Red Stitching Question.
- apexi world sport vs n1?
- Crank at TDC but flywheel isn't
- oil on spark plugs
- Vehicle shaking on acceleration 75+ mph
- Clutch masters flywheel question??? please
- HELP!!! It still will not start??
- Question about a 4th gen TSB.
- Engine Builders
- Oil pan question
- fast question..
- H4 and 9006 headlight bulb difference.
- How many of you have installed hondata IM gasket without leaks?
- Looking for a Prelude!!
- Wiring O2 sensor on Downpipe
- Has anyone taken their lip kit off because of scraping?
- Reverse threaded screws on header???
- Heater Core???
- Big problems with VTEC H22A2
- ex type s cam
- car revs up up up up until I kill it.
- M2B4 transmission rebuild
- what brand of springs will give me the lowest drop? (bb6)
- Accidental down shift =\
- Car sputtering and dieing
- FRM honing required for new rings?
- Question for 4th gen. 4WS owners
- Dented header. How much power loss?
- Can I use an H23 distributer on a H22?
- Im thinkin of buying a prelude but dont know if its mielage is too high....
- timing retard for nos
- How do I replace the Front motor mount in my 92SI lude with h22?
- 96' H22A1 w/ p28: TDC CEL, misfire, rough start, and no VTEC
- Electrical problem - No Dash lights, power windows, etc
- Idle Question
- h22 stock head with dual valve springs?
- sorry if i posted it in the wrong place. well here it is. is this a good price?
- Ac Removal
- using a m2u4 ATTS tranny on a jdm h22a
- Best hondata base map for turbo prelude
- Euro R injectors/manifold on obd1 harness
- Transmission Problem, First startup
- Heating Problem
- Brake upgrade...
- Prelude ECU/ECM Immobilizer
- Japan Engine Sites
- funny smell when in vtec, searched..
- Squeaky Clutch
- tps and fuel pressure regulator??
- Bad PCM information
- H23A vtec conversion or H22vtec?
- Md23vtec ran 10.61 today!
- Shock, help.
- will accord rear and front lip fit?
- Evap question
- 98 Honda prelude OBD2a doesn thave obda2 pins? CKFp, CKFM mssing!!
- Lookin for a Good Shop
- Need a USDM OBD1 H22a...Can be bad...
- H22 head building?
- dyno results
- Crankshaft
- what r da best pistions
- Prelude Lifespan
- Clutch/timing belt, pull engine?
- Welding Together A 2-Piece Header??? Part 2?
- just a few questions on performance.
- H22 Swap Into Prelude? Few Questions...
- Hard to start in the mornings....
- Inputs to pcm for starting ?
- Good Place To Start... 5th Gen
- H23 Valve cover
- how do you remove the airbag/steering wheel
