View Full Version : Honda Prelude
- Camber problems on stock suspension...
- Alarm ????
- h22 tranny/clutch problems
- 5 gen wheels offset????
- idle problems
- ???throttle body and axle questions???
- STR Adjustable Cam Gears Two Thumbs Up! Not Slipping
- suspension questin?
- carsound cat
- Ghetto turbo f22
- hydrolock.... i just sucked up water in my intake :(
- gas??
- non stable prelude hesitation?
- 02 sensor issues
- Found rust on my tein HAs.. now what?
- price of modifying a header and info?
- Continuous engine fan troubles
- oil recommendations for 5th gen H22a
- HELP removing H22 oil pan!! Searched-still cant get it off.
- 88 prelude car quits
- Manual swap/turbo h22a4 application
- question about falken azenis sports...
- Somebody help me, need JDM headlight help!
- sea foam
- What Octane should/could I use in my Prelude?
- installing jdm fog lights on 5th gen
- 2000 Prelude sh question?
- Drivers Low Beam Headlight Won't Turn on Please Help
- Is the 95 H22 crankshaft same as a 97 H22a4?
- Remote start?
- help - h22 staggering going into vtec
- new gauge cluster
- Questions about Prelude Type-S
- Possible to lower 98 lude on 19''s?
- how to wire a alpine dvd in-dash player
- an h23 w/200+ftlbs of torque n/a... is it possibile
- Last Gen Prelude
- 3rd gear trouble
- speed limiter bypass???
- Took my new 89 SI Lude to the track tonight (Stock Times)
- do rear brakes work as much as front
- new clutch, now car wont start
- SPARK PLUGS SPACING
- Manual Trans question for a 92 Si 2WS
- Garrett M24 a/r .60 turbo on an H23a
- Valve cover trouble...
- h22 transmission
- can some1 tell me wat type of bulbs are used in park lights for 1994 prelude si??
- Brake ratio's for 92 Si
- surging idle
- Car dies while driving
- throttle body problems in my h22 hatchback swap
- H22 vs K20 , truth , Hype ,BS
- how much hp do cam gears put out?
- Sound from front driver side
- i spun a rod bearing....is it possible to fix
- Headgasket blown????
- 90-91 foglights
- H22 making weird squeal sound when I....
- What extractors and exhaust???
- Turbo Sam, Where are you?
- prelude motor trouble
- Bore and Compression Q's - H22A Piston Selection
- Cheapest OBD2 ECU I Can use for H22A (Smog Testing Only)
- VAFC Instead of P13 for H22 Swap?
- mugen coilovers
- why is there power steering lines on the tranny?
- Apex'i VAFC Vtec Point
- I hydrolocked my car, replacing short block...questions.
- Spoon bar bolt size
- vaccuum canister
- Installing New Struts and Coilovers
- Type S, SH, Si - whats the difference?
- P72 safe?
- 4th gen front end on a 5th gen.
- What would you launch at?
- Tranny oil seal
- Electronic flasher location help
- Code 23... knock sensor... any advice??
- CarSound cat
- Tranny Problems
- So Cal Job Offer (install my ES MM inserts)
- Oil Pressure switch...Gauge/Light
- prelude and accord tranny are they intercheangeable?
- Ebay front Strut Bar
- ran at the track
- Massive Weight Reduc. Plans
- what motor do i have?
- School me on the Auto tranny for the 97 up lude.
- overheated new Kumho's?
- Grounding points for 4th gen
- Torqueless Motor
- Alternator Pulley
- TIMING!!! plust short ver. horror story heh
- best catch can for h22 turbo
- Changing Engine Mount bushings on 89 Prelude? Need Help.
- EGR block off plate
- Got a CEL 14
- Main relay fuse blows intermittently
- what is the good shop and bad shop to get stuuf done in san diego?
- built head HP increase?
- ac dont work.. please help me fix it
- M2K4 Transmission?
- Superchargers?
- JRSC on 9psi and a 75 shot?
- Prelude aftermarket parts?
- ABS and 4ws warnings lights.
- UK imports who has??
- Looking to buy a prelude, need some insight: TypeSH or reg 5spd? need ur opinion
- lowering springs?
- Rear Caliper
- need interior work
- F22 auto tranny infos needed
- H23 TURBO
- how much trouble to weld a 5th gen cat back to a 4th gen
- has anyone have special tach(autometer monster tach)
- Will a honda accord tranny fit in a Prelude h23 non vtech?
- Manual
- when does your vtech kicks in on everyone prelude?
- H22
- 4th or 5th gen prelude?
- Horses at the flywheel
- abs unit leaking.have a new one but need help with installation????
- 3rd gear problem
- Bad motor/ engine swap
- h22a arp head bolt torque spec
- what is this part on the throttle body, part #13 in the picture.
- nitroused sh
- Code 36, possible Bypass????
- Check engine light on JDM H22A... please help!!
- will these mods go bad?
- Rear Seat Removal
- What motor came in a 93 prelude si?
- venom 400
- Darton sleeves. Can they work for my engine?
- Good CT shops
- H22A 2.2 Si Vtec Lockwood White Dials, anyone?
- Lude's steering/alignment is funky
- Electrical Board/AC issues
- b20 si with b16 vtec head????
- turbo specs?
- WHAT USDM HEADER 4-1.. 4-2-1 ONE PEICE FITS MY JDM 96? ....
- I HAVE A 4-1 HEADER FOR PRELUDE $300 CANADIAN DOESNT FIT MY CAR
- H22 Performance problem
- KYB AGX install help needed. Those who did it themselves, please read
- whats h22 & h23
- H22A 2.2 Si Vtec Secondary o2 Sensor help!
- Interest in custom H23 rods by Scat?
- S2K wheels on 5th gen Lude
- skunk2 accord springs on prelude?
- converting S to SI
- Built H22 ECU Questions.
- 4th gen seats
- greddy evo 2 exhaust good, sound, power?
- h23 alternator on jdm h22 engine?
- HELPPPPPPPP! Crank Pulley problem
- 5th gen mods and HP questions
- Oil catch tank help with vtec burning oil?
- New JRSC M62?
- Shop did not put on my shock dust covers on
- prelude t shirts????
- anyone have problems with sri's on your ludes?
- for those of you looking for a euro r tranny
- bodykitsNW CF hood
- good exhaust for 5th gen
- RHD conversion
- How big mileage has your clutch survived? Problem, please help.
- Throw Out Bearing???
- which turbo kit for 5th gen?
- Thinking about buying a '96 Prelude *Need some Advice*
- Carbon fiber trunk?
- Best Turbo H22 Intake Manifold
- Need a Q answered ASAP!!
- autotensioner
- flywheel is grinding against tranny case!
- Air conditioning problem
- The day my Prelude comitted Suicide....
- what kinda power should i expect?
- Interchangeable A/C Compressor with other cars????
- Got my Prelude Back! :Temperature Sensor Problem
- Hey guys, i have a few questions about preludes.
- Suspension alignment for street performance 4th Gen. Ludes
- DSM E/x Manifold + turbo + o2 housing
- any good new jersey shops to go to?
- OK so I think the h23 vtec is gonna have to be pulled apart again!
- How Many Miles to the Gallon...
- Extreme Dimensions Carbon Fiber Spoiler
- After Market Radiator? what kind and where at?
- Dash light question
- h22 turbos...stock cams...vs...crower 2t intake and stock exhaust cam
- Why you should get a catch can for your H22A4
- high rpm shiftin my exhuast shoots a 3 inch flame.
- are accessory mounts different between 4th & 5th gen?
- How much power should I expect?
- external battery kill switch question...
- Labor: Reassembling H23 Tranny?
- Piston question
- Prelude question??
- Intake Manifold and throttle body for H22?
- ? on the turboxs manual boost controller
- Anyone Have an EBAY Clutch?
- clutch
- New Honda Owner
- Are all Honda knock sensor's the same?
- prelude --> saturated injectors
- Ported JDM intake manifold
- J's Racing Intake...
- 1992-1996 Greddy Stainless Steel Header...
- Accord SE-i rear disks same as Prelude?
- cam gears worth it...?
- Lowering spring from a 92-96 lude fit a 99
- individual t/b opinions
- 5th Gen Tire Poll/Question
- shaking on braking. Suspension related?
- Head gasket thickness
- H22A build up how much power?
- Questions on Top Speed eaders
- H22a question...
- Cincinnati, anyone near?
- Data Link Connector (1992 BB2 H23A)
- Tranny
- 5th gen accord SRI on 98-01 prelude?
- What header for h23
- Exhaust pipe routing the same?
- 95 front lip
- Whats the largest tire that will fit on a lude?
- better for racing all motor h22 or h23 tranny ?
- Where can I get ABS codes? I dont have a helm manual.
- headlight question
- where to purchase apexi world sport?
- CF Hood - need opinion
- Timing Belt HELP
- question bout h23 to h22
- Thinking about a new car
- 94 vtec digital speedo issue
- removing bumber supports.....read....
- 4th gen: How do I take out the driver's side rear seat??
- greddy evo cat back
- H22A vs. H23A vs. H23A DOHC VTEC Prelude Crankshaft
- Backfiring problem
- Weapon R H22 header Any good???
- JDM P13 governor
- 89 Prelude 2 si
- H22 video of all my problems please help
- 1988 Prelude Power Antenna
- HELP HELP 97 auto to standard
- Installation of Tein Coilovers in Northern VA?
- 94 Prelude H23 to vtech
- ARP head studs for H23A torque procedures??
- BB1 verse BB4 - whats the friggen difference!
