PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 [280] 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. 70mm STR Throttle body for sale
  2. Reputable dealer / Good prices (Crower Rods)
  3. I need a Prelude!!!!
  4. Problems w/ Type S throttle body
  5. want to chip computer wich to go with?
  6. wtb: NX Shark Nozzle for the wet kit for the prelude
  7. Clutch
  8. O2 Sensor
  9. get a life
  10. Clear Sidelamps Activated by Indicators HELP PLEASE
  11. Difference between base prelude and sh?
  12. WTB:LSD or Phantom grip for a 98 SH?
  13. WTB: turbo kit (new or used H22A)
  14. Does h22 have pilot bearing?
  15. Base Prelude Rim Width?
  16. jdm h22a
  17. Reverse Problems----Manual, Reverse
  18. 94+ gauge conversion
  19. APEX parts for H22 only...
  20. 4th gen Lude interior question.
  21. Trouble with my 88 Si
  22. I'm taking my head off, help!
  23. Timing question, help ASAP
  24. Track times with Nitrous
  25. Neuspeed sport springs
  26. Selling off some stuff from my 4th gen... airbags, wheels, bumpers, back seats etc.
  27. apexi n1
  28. Brake Caliper Removal?
  29. Web Sites for preludes?
  30. H23a on the bottle
  31. 4WS throwing Code 20. Can anyone tell me what this is?
  32. base vs sh exhaust question
  33. which camber kit for front end?
  34. Where to hoist H22a????
  35. Question for you turbo people
  36. hondata
  37. tire question ...
  38. Pics of Luda on C-twizzoss
  39. middle counsel question
  40. climate controls
  41. vtec?
  42. 20 over?
  43. Changing rotors and brake pads
  44. changing 96 prelude to vtec?
  45. Transmission help
  46. Any drawbacks to block guard?
  47. external internal coil
  48. Newbie question about sh exhaust
  49. Yet another Check engine light problem.
  50. Where can I get a 5th. gen oem kit??
  51. apexi rev speed meter
  52. Kuhmo tires
  53. Need better suspension on my 4th gen...
  54. How to make your 88 Si Lude faster/handle better
  55. Aem bypass valve
  56. What fuel rail for h22?
  57. Thinking of parting out my prelude, should i??
  58. Few questions on engine aftermarket parts
  59. JDM foglights
  60. head light question about 3rd gen. lude
  61. Prelude meet TODAY...Jacksonville, FL
  62. U.S. General Aluminum floor jacks and ebay transmission adapters compatible?
  63. ot : help passenger seat wont slide fwd!!!
  64. m2b4 true lsd!!! i dorve w/1 axel!!!!
  65. WTB: 01 Prelude Rear Bumper
  66. supercharger?
  67. parking lights
  68. Dyno - i/h/e/vafc
  69. Dyno places
  70. How much boost for the h22a?
  71. what should i do if the online store send me wrong parts?
  72. clutch pedal quickly diminishing....
  73. Hard start and rough idle
  74. OT: Preludes and The VAFC
  75. What should i do?
  76. Need opinions... HOW BAD IS THIS?? LSD pic inside
  77. Learning 2 drive a 5pd...
  78. brand new OEM timing belt(H23)
  79. traction bars
  80. H22 valve clearance specs ??
  81. my rims are on ebay!
  82. reverse stopped working =[
  83. just a question about h22a swap
  84. how to check CE code for h23 running hondata w/p72(integra ecu)
  85. 92 prelude si ignition problem
  86. H23 vtec?!
  87. VAFC Settings Try at your own risk
  88. NSX Callipers
  89. rear lip?!?!?
  90. DIY For Indiglo Gauges?
  91. Anybody tuned a Stock H22A with VAFC?
  92. organic vs. semi-metallic
  93. Working with a Stock cluch
  94. Im new, i need some help
  95. Leaking heater core
  96. cruise control not working
  97. I think I found out the problem for my idle rattling
  98. Attn: TN, GA, AL, and FL Luders
  99. replica of the factory 5th gen kit...
  100. Have a few aem pulley ???'s
  101. I still Need help with srs reset
  102. lower tie bar?
  103. A newbied question.....but seriously
  104. Spark Plugs
  105. curious: Sound Deadening
  106. hydro lock
  107. Sweet a 2nd Gen!
  108. suspension
  109. wrong clutch!!! jdm h22a vs usdm?
  110. need help with jammed sunroof...
  111. jdm lsd transmissions
  112. ??? '93 Prelude Engine ???
  113. Will these rims fit on a 4th Gen lude? If so what size tires should I go with?
  114. how low should my lude be?
  115. JDM 10.6:1 H22A pistons
  116. NEEDED! = h22 tps sensor!
  117. need a clutch
  118. ABS Problem
  119. 4WS Problem/Questions
  120. wtb: anyone have a stock 4th gen 92-96 trunk for sale?
  121. 99 v6 accord vs. 00 prelude
  122. APEXi USA Factory Garage Sale : March 8th & 9th (giveaways - vafc, civic turbo kit, n1 muff, etc.)
  123. Will '97+ prelude side skirts fit on a 2000 civic coupe?
  124. VIS CF Hood groupbuy
  125. Are there any major problems with Sportshifts I should be aware of?
  126. What is redline on h23a1
  127. Balancer shafts.?
  128. 4-1 header?
  129. Location of Srs plug in a 4th gen
  130. ABS light
  131. Prelude tach
  132. h23 NEW timeing belts..
  133. Shorter 4th & 5th geras on my 1998 ITR , cheap cheap
  134. ideling problems on my ITR
  135. Flywheel installation
  136. downpipe/collector....
  137. 4th gen guages
  138. 4WS almost killed me
  139. Belts make car sound like its supercharged???
  140. 4WS people - any problems
  141. Odd question... F22A1, F22B1, H23A1 head? Which one came from where? Help... please?
  142. WTB: h22 vtec solenoid, throttle body, etc..
  143. Any tips on removing/installing header?
  144. majestic turbo manifold?????
  145. Biggest turbo on drag manifold
  146. F*&K!!!! I can't get my clutch slave cylinder off!!
  147. JE 11.5:1 cr pistons...
  148. 5th gen light question....
  149. c/f trunk lids?
  150. anyone know who's lude this is??
  151. f/s skunk2 parts for h22a plus miscellaneous parts
  152. My trunk won't open!?!?!?
  153. Hard time getting into first gear??!??! Why?!?!?
  154. Finally decided to dyno today
  155. 5th gen ECU question
  156. Compression numbers and suggestions
  157. New stock clutch or ACT HDSS setup?
  158. Prelude SI off set for wheels
  159. Fuel Injectors size??
  160. Sensor on vacuum line between fuel pressure regulator and intake manifold????
  161. suspension
  162. My new Valve cover
  163. SRS System
  164. Leather Seats In 4th Gen
  165. engine back in the car (PICS)
  166. i need an engine!! help
  167. 3 gears in the 1/4?
  168. fs tanabe suspension 4g
  169. Can I ask a question?
  170. D.I.Y. intake box mod?
  171. installing pulleys
  172. prelude gauges....... question...
  173. Electro luminescent gauges for 98 Lude
  174. Kicker 6X9 Subwoofer
  175. Any word on the new 4-2-1 SMSP header...
  176. 2.5" collector with a 2 1/4" test pipe
  177. Is my car stronger than normal?
  178. hi flow cat question
  179. can someone post or email me a 97+ prelude wiring diagram?
  180. What ECU does my friend have?? H23 ECU
  181. NEED an EGR valve for an H22a4!!!!
  182. 4th gen stuff for sale!
  183. Timing Question
  184. Screaching Noise
  185. will a 5th gen base 5 speed instrument cluster work on an SH???
  186. Domestic Turbo
  187. which front bumper cover
  188. prelude block girdle
  189. Intake
  190. ARP Main Studs. Was it worth it?
  191. By adding these parts, what will I get
  192. Octance booster?
  193. H22 head on an h23
  194. skunk 2 camshaft
  195. Coilover problems Exp. Please 4th GEN
  196. WTB: black 5th gen located in south east
  197. H22 tq-spec
  198. H&R springs opinions please
  199. WTB: AEM tru power pullies
  200. is it possible to do a targa conversion for a 5th gen prelude?
  201. Intake dual runner bypass control question
  202. I lost 36 hp!!!
  203. Crankshaft issues
  204. Highest rev with stock valvetrain?
  205. Do my rims fit
  206. quick question for boosted ludes
  207. FS: tokico Shocks with coilovers
  208. help!!! 5th gen JDM valve cover install
  209. what do you guys thinK?
  210. VAFC in 5th gen
  211. has neone used a v-afc??
  212. more balencer shaft questions but for an h23...
  213. need a 5th gen pic
  214. Went draggin today ;)
  215. Intake question?
  216. jdm h22a tranny?
  217. What sides and rear would look good with octane front??
  218. Do you suggest buy Bypass Valve .........
  219. Some Track Footage . . .
  220. WTB: H23a
  221. Koyo Radiator ?
  222. when to change plug wires?
  223. H23 Build......where do I find pistons, rods, rings?
  224. Need an Opinion...........
  225. i NEED to clear this up....?
  226. Is there anything that can be done without $$
  227. WTB used header
  228. Prelude with dual runner intake manifold????
  229. Prelude for sale, opinions needed,
  230. Instead of an intake, is it safe to.....
  231. 99 Accord H23a Vtec
  232. Injector Resistor Box HELP
  233. Where is service connector to read codes?
  234. pistons
  235. compression ratio theory
  236. Wooohoo. I might be getting head!!!
  237. exhaust
  238. 4th Gen Preludes / Accords: H22A Auto.... Times, Numbers, Etc.
  239. slim fan
  240. I've got a question about installing Pedals
  241. weber carbs
  242. whats the fastest youve gone in your prelude?
  243. Can't get caliper bolt off?
  244. Head Gasket Material
  245. H22/h23 head gaskets the same??
  246. H22/H23
  247. changing fluid in clutch master cylinder HELP!!
  248. Cleaning air filter
  249. Making my car lighter.....
  250. CE light caused my distributor?
