PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. will OEM P13 exhaust manifold bolt up to DC Sports downpipe ?
  2. gas light is tripping out
  3. wtb
  4. 2001 honda prelude wont get spark tried everything!!
  5. h23a vtec swap question
  6. fuel gauge not working 91 Prelude Si
  7. Want new muffler or catback
  8. Cylinder 1 Misfire
  9. idle problems twin carbs
  10. No Caster, need help
  11. Carbon fiber fenders?
  12. Looking for some decent sites
  13. 99 prelude
  14. no tensioner, belt, etc..??
  15. Need help Bent valves!!!!
  16. Craigslist add in Georgia
  17. Problem with skunk2 H22 basekit?
  18. My First Car :)
  19. h22a help
  20. Main Relay Question
  21. what belt size do i need
  22. h22 prelude swap accelleration prob
  23. 4th Gen Prelude JDM Climate Control Questions??
  24. what weights more; sunroofs
  25. 2001 w/ H22A Engine Turning but not starting...Help
  26. 91 Prelude (import) dash warning light problem
  27. Hondata for H22a
  28. 95 Prelude VTEC (H22A1) Tracking down some oil leaks (pictures)
  29. AEM standalone. drivable with base map? any info appreciated.
  30. h22 arp flywheel bolt part #
  31. For Sale ! 1998 Honda Prelude SH (15k Miles)
  32. I need help with a part?
  33. Knock sensors? Quick and easy question.
  34. H22A1 Spool Valve Stuck on the head
  35. odb1 connector?? 93 prelude si
  36. '93 Prelude with '90 Accord tranny
  37. need pcf ecu for 5 speed
  38. is honing a must for rering?
  39. Replacing a clutch
  40. Vibration after timing belt service?
  41. carvox cx 999 engine start helpp!!!!
  42. F22b timing setup?
  43. BDL Throttle Body on a H22 Prelude
  44. h23 wiring problems 2 crank sensors
  45. No front right turn signal radiator fan doesn't turn on and horn buzzes.
  46. Is this a good deal? 90' prelude for...
  47. h22a timing belt loseser when engine is cold then hot ??
  48. h22a timing belt loseser when engine is cold then hot ??
  49. Anyone know what is up with this short block?
  50. Please help me find this part! h22a integra swap!
  51. AFBS? Do i really need to bypass it?
  52. jdm ecu vs usdm ecu
  53. A ECU Question
  54. 4th Gen EL dials
  55. H22A1 VTEC Oil Leak from behind lower timing belt cover, need some guidance
  56. Which crank pulley for my H22?
  57. Using the F22B DOHC dizzy in place of H22A distributor?
  58. steering wobble while cruising, new rack and tie rods
  59. Just bought my first prelude, 1991 Prelude Si 4ws. Little help?
  60. 4th gen posible earth fault???
  61. Longer stroke..pls look at pics..do I NEED a hone?
  62. h22a4 swap into 4th gen lude
  63. no starting, smoking in cabin
  64. help!
  65. Front bumper?
  66. GETTING ILL car Starts then dies!!!!
  67. Anyone Swap there SH to a base?
  68. Power Steering "Guru" needed to trouble shoot problem
  69. Bouncing - Erratic - Jumping - Hunting idle fix
  70. Burning oil
  71. Want a new header? Here are some reasons not to go for the cheapest one you can find!
  72. H22 type-s M2u4 gears into M2a4?
  73. P5M piston question
  74. OEM Front Bumper Price??
  75. type r swap??????
  76. Prelude Barbie's Dad needs help
  77. Power Steering problem
  78. STANCEEEE MY PRELUDE! :)
  79. ITR lip on 97 prelude
  80. h23 bluetop sh5g swap
  81. g23 n/a break down needed!!! using h22a head and f23a4 block
  82. 2001 honda prelude electronic issues ?
  83. Another 01 Prelude No Start Issue
  84. Will DC2 or EK9 MUGEN TWIN LOOP fit on a 4th gen lude?
  85. Body shop around rochester ny?
  86. power restoration
  87. 2000 Prelude Key Issues
  88. h22a head decking and compression ratio
  89. 97 Prelude Problem HELP PLZ..
  90. I'm just baffled.
  91. Need help with shift plz!!!!
  92. H22A swap ecu connector question
  93. HELPPPP!!!! engine is rev itself to 6000 rpm
  94. GOT ONE!!!
  95. serious problem need help
  96. prelude v-tech in an accord... help!
  97. full exhaust system
  98. H22 back to an F22B? 1997 Prelude
  99. Prelude seller not sure H22A is sleeved. How can I know?
  100. Anyone Knows What Theses Are 2
  101. Anyone Knows What Theses Are 2
  102. type s piston need help asap!
  103. Heating Issues/Heater Core/Clog/Bad Pump?
  104. S3 light flashing, speedo quits, check engine = Computer?
  105. h22a1 raw fuel smell poor idle
  106. HELP with F20B swap into 5th Gen, Surging IDLE
  107. Windshield Wiper Reservoir
  108. 00' lude with h23a?
  109. H22 base axles to SH axles
  110. jumping idle?!?!?!?!?!
  111. help me out
  112. Slow process, H22A rebuild
  113. Replacing Engine Variable Timing Solenoid Gasket
  114. H22a4 TDC Sensor Issues
  115. my honda prelude
  116. Stock h22 p2v?? All stock..surely someone knows this
  117. Compression
  118. h22a1 injector confirmation? [PICS]
  119. p28 or p72 or p13
  120. ignition timing
  121. Advice Please - Leaking Transmission from drive shaft
  122. What throttle body size? RBC manifold on H22, plan to boost later on.
  123. imported H22a, WHAT ECU do i need
  124. Man. Trans
  125. Discussion: How would you build an H22a1 block/head?
  126. 97 Prelude(auto) wont start, dashboard lights turn on. all electrical works..help?
  127. WANTED TO BUY ONLY :: NO TRIAL USERS, NO PICTURES - Mar-Apr 2012
  128. FOR SALE ONLY ::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - Mar- Apr 2012
  129. Piston expansion and P2W with stock cast pistons?
  130. Prelude fuel pump ?????!????
  131. Can anyone confirm this?
  132. lude transmission help
  133. Need consistant info on h22 valve lash adjustment
  134. crank pulley..
  135. Vibrant Header is Best Header
  136. Where does this electrical plug go?
  137. H22A Oil Pump Changing Questions
  138. anyone know wha theses are (H22A4)
  139. Oil drain bolt - how many washers?
  140. i need to buy...
  141. HELPPP!!!!!! F22 with H22 Pistons
  142. 92 Lude Si4WS Fuel Mileage
  143. prelude auto 2 accord manual?
  144. turbo header choices
  145. !skunked h22a eg nukka!
  146. rear upper ball joint
  147. Prelude idle and crankshaft pulley grinding Please help!
  148. 01 Prelude: Help Build
  149. 5G Auto; Rev Limiter at 6.5; No CELs; VTEC Works
  150. Need HELP! H22 Build, NASA-style!!
  151. 11.5 High compression questions, Turbo?
  152. 92 prelude si chip
  153. If anyone's thinking about selling their Lude, let me know!
  154. **BEWARE: IDEAL HONDA in Mississauga, Ontario** YES OR NO?? H23A DOHC VTEC
  155. 97 lude power window help
  156. New tranny??
  157. prelude 99 knock sensor
  158. massive oil leak
  159. 00sh help
  160. 5Th Gen Transmissions
  161. 95 Lude - h23-f22b swap
  162. Sooo... my...
  163. injector help!!!
  164. Fuel is comin out
  165. 97 prelude doesnt crank. stuck gear selector
  166. VAFC II install from Whitfield Racing AKA "Rage Performance" gone wrong?
  167. Clutch Bleeding
  168. help?
  169. New 97 Lude
  170. y 4 to1 header?
  171. MAF sensor or equivalent?
  172. Rotor hotspots; still good to use?
  173. New Owner
  174. 1995 prelude SRS
  175. need a little help with piston choice
  176. f22a1 Sohc Build what bearings should i use
  177. 1996 Prelude interchangeability
  178. 97 h22a1 auto
  179. prelude core damage. bent pass. frame rail need help fixing
  180. #2 injector clicking when ign is on..
  181. New to the tuner world.
  182. 92 prelude si h23a idle problem
  183. hit curb, bent rear, replaced bent rear cross bar, better...what's next to check?
  184. 89 lude
  185. koni and ground control. Do I need a camber kit?
  186. H/F Transmission Gear Compatability
  187. 4th gen - steering rack PAS valve thread sizes
  188. someone please HELP me. h22 tranny
  189. Interior make over
  190. h22a na engine built help asap
  191. heater question
  192. Front coversion
  193. 94 honda prelude si h23 wont start
  194. broken cv joint spindle inside tranny, has anybody dealt with this befire?
  195. 97 lude no start helppp
  196. Dead Prelude Help!
  197. H22 prelude P1655 code
  198. Window won't stay clamped onto bracket!
  199. Fuel system specifications, model specific H23
  200. Sh H22a change over
  201. Header options
  202. oil completely empty. wtf
  203. 2000sh
  204. f22 head work
  205. Thread size for coolant bypass nipple
  206. H23 headache. Need help please
  207. 93 prelude engine replacement
  208. How much should I pay?
  209. Prelude GT-R
  210. Can't get rear arm locking bolt out, any suggestions
  211. Styling difference between USDM or EDM Prelude- what parts people need.
  212. OH YEAH BB6
  213. Thermal intake gasket leak
  214. differences between H series motors
  215. What size are the bolts for the transmission??
  216. 4th Gen SI alternator replacement
  217. JDM OBDI into 5th gen.
  218. WANTED TO BUY ONLY :: NO TRIAL USERS, NO PICTURES - Jan-Feb 2012
  219. FOR SALE ONLY ::.. NO TRIAL USERS, NO COMMENTS, NO PICTURES - Jan-Feb 2012
  220. Multiple Plenum spacers
  221. new!
  222. New prelude owner need some help!
  223. HELP!!!! LOST MASTER KEY TO 5TH GEN. TYPE SH
  224. Flywheel for 89 Prelude?
  225. Codes 1 & 12 Both Are New. ?MAP Sensor or ECU?
  226. 1999 Prelude immobilizer question
  227. 00 atts help
  228. h22a timing belt tensioner????
  229. h22 tranny help!!!
  230. F23A4? HELP PLEASE
  231. New to the scene New to Honda
  232. Vibrating issue NEED HELP ASAP!!
  233. 89 Si 4ws, engine issues
  234. kilometer gauge cluster help
  235. H23a vtec swap vacuum hoses problem
  236. Front clip conversion
  237. I have an H22
  238. P2U5 on 96' Prelude H22A1?
  239. 96 Si h22a4 swap, help please!
  240. Suggestions on suspension
  241. looking for a shift linkage for 97-01 h22a4!!
  242. Stolen - 93 Prelude Si
  243. relocating e-brake
  244. how much of a drop in power
  245. Timing gear stuck on crank
  246. v-tech solenoid
  247. Car wont start No spark
  248. bent rear wheel, can i just realign it
  249. '91 Honda Prelude (Where to start?)
  250. H23a1 in a 96 ex pleazzze hhhhelppp
