View Full Version : Honda Prelude
- over reseaching, conflicting infor, lost
- POTM Nominations - January 2014
- Jumpy idle, and ocassional stalling
- Loss in Power
- headlights messed up? low beams dont work high beams do?
- F20B, H23a, or H22a
- 99 Prelude SH - rebuild or part out?
- O2 sensor question
- Issue with ignition getting stuck
- H22A4 Turbo Build
- 2001 Honda Prelude Immobilizer question.
- H22 Block
- F22A1 Rear Motor Mount Bracket Fitment.
- Tensioner fluttering noise
- K series shifter box on 4th gen prelude ???????
- ARP rod bolts for h23a1?
- what sensors and componets to the vaccuum system can be deleted?
- Honda vs. Synthetic Auto Trans fluid
- h23a1 non vtec to h23a vtec swap help!!
- control arm
- 50 Amp fuse blow in my Prelude 5th Gen
- Something smells ROTTEN!!
- h23a1 help 9.8:1 needs reduced to 9.0:1 to comply with track rules.
- H22A with 6-speed K transmission?
- Cold starts
- My bb6 build thread!!!!
- Third high mount brake light not working
- H23A, Non-sleeved and forged Pistons/rods
- h23a blue top build help?
- 94 prelude h22, starts then dies within 2 seconds
- prelude wont start help!
- Jdm H22a main caps: are dowel pins same as usdm h22?
- My First Car... Help!!!!
- Failed Smog for High NO on 4th gen
- Thanks Everyone
- Jdm P5m works without issue on Us BB6 Preludes
- 98 Prelude SH, cold start RPM Idle bouncing
- mystery leak.
- What OEM steering wheels fit in the 4th gen
- What would be the best upgrade?
- exedy clutch question
- 80 amp alternator good?
- What to do first,looking for some opinions
- wires from seat 1990
- H23A Crankshaft pulley woble
- NOOB Prelude Misfire and Egr Issue
- T2T4 in a 94 prelude cv axle question
- Is this a Motor Swap?
- Prelude Build(suggestions)
- My car will barlely start when cold,
- I am SOOOO proud of my little Prelude!
- H22 skunk2 manifold coating
- Anyone running 2.75" exhaust?
- best oil for built turbo prelude
- Clutch Issue!!
- Can't Seem to find the right throttle body 96 si w/sensor on top
- Story of my Prelude, Loss in power.
- Need Info/Help on purchasing correct H22a1 Rings/bearings
- Cooling System Issue with F22A1
- old engine rebuild ?
- Engine apart(h22a1) Should i buy type S pistons?
- 4th gen auto stuck in park
- Engine loping at idle followed by odd symptoms and coolant boiling
- dis-assembly under crank (h22)
- what do I need to turbo an h22a
- How to replace an altrernator on a 4th gen Lude?
- clutch Squeal
- 94 prelude build/project
- OBD2 scanner no connection
- What drivers mount for H23A VTEC into 92 SOHC??
- 2000 Prelude wont start
- oil pump replacement
- Crazy Dashboard - Alternator?
- Mystery cables, squeaking noises, oil leaks and more!PLZ HELP!
- Broke motor
- 87 2.0 si prelude 2nd gen wierd problems
- H23A OBDI problem
- Do i need a new radiator?
- Bottom of radiator is leaking from 3 different spots. Bare with me on this one plz.
- Stumped.. Hot start intermitten problems
- Why you should not neglect a rip in a CV Boot.
- What transmission?
- engine light that is on without throwing a code?:S
- Need help for my 5th gen lude guys
- Easiest way to remove h22 IM nuts?
- JDM H22A build questions
- fuel problems on a 5th gen prelude
- Water pump weep hole
- New rims / tires - rear rubbing.
- prelude tranny swap problem
- 5TH Prelude delete
- prelude wire harness question
- Personal Opinions? Sunroof Visor/ Bug Deflector or Rear windshield Visor?
- Would it be a good idea to jb weld a crack in my CAI?
- 98 lude Sh rear ball-joints
- 98 Crank Pulley Wobble [PICS]
- Trouble starting after running (20 mins later)
- Need some expert opinions
- throwout bearing
- 1990 2.0 S unknown problem.
- Manual Conversion or.....
- Suspension Questions.
- NEW ECU BLUES.........
- JDM H22A Head Help!
- what model b20 is this ?
- Alternator belt shiny and sticky?
- Smog check help - 93 Prelude H23
- Turning Causes Engine to struggle when at low rpms/parking
- 95 Prelude Si H23A1 - Crank Pulley Broke twice
- spark plug wires
- 97 prelude idle at 5k rpm
- 1992 Honda Prelude Crank
- H22a with chiped p28 ecu runs like crap!! help.
- 92 Prelude S Limp mode, ECU throwing Injector Code
- OEM H22 clutch HP limit?
- 93 Prelude - Fuel Pump Stays On
- dont read
- H22 random misfire code need help
- 90 honda prelude all coil wires were cut what goes were
- Couple Questions - 97 Prelude OBDI
- Dumb question but a good one
- Ready my H22A4 for a turbo kit
- Car revs when braking
- engine build
- 92 Prelude Si 4WS
- F22A2 misterious engine.. Revealed!
- Slow Cranking, No Longer Starts
- Prelude 5th gen auto to manual transmission issues & problems
- h22a castings
- Best head gasket for nitrous?
- valve adjustment please help!!
- 5th gen prelude cat back on 4thgen
- Prelude cooling fans.
- Dumping Fuel
- 1997 Prelude Transmission
- Misfire at idle
- what are my options, or am I just screwed, no start
- Help!!! i have P0301,p0303,p0304, p0302, p0300 codes. And a pending p1399
- 94 Prelude S will not start. Wife's car...please help.
- intermittent wiper doesn't work.
- h22a block bore size?
- Acura Integra Suspension for Prelude???
- Buy another prelude or fix my old one?
- Another dumb question
- Stupid transmission m2b4 please help!!!
- Help removing engine harness from 97 prelude?
- 94 Honda Prelude Audio System
- Just Curious.
- Bad battery/Alternator? High Voltage?
- 4th gen questions
- Odd Vibrating/Noise Tranny or Axle?
- BB1 Prelude Overheat
- hi guys what is the best engine fit my prelude 1988?
- You guys think I need a valve adjustment?
- 98 prelude auto tranny issues
- [HELP] VAFC Install - Cut @ 6500 - Low RPM no power
- Exhuast rattle?
- Throwout bearing? or some bad gears?
- 1998 honda prelude misfiring bad
- Dread P0171 Cel... Tried everything
- 99' Prelude issues
- rebuilt h22a ticking soon after rebuild.
- Valves or a belt?
- H22 Wossner pistons, FRM compatible?
- 1993 honda prelude
- h23a1tranny swap
- Cooling fan problems '94 Prelude
- Is my h22a obd1 or 2?
- 3rd gen egle crank problem
- Has this motor been swapped??
- suspention
- 5th gen prelude problem
- How does this engine look? Jdm h22a
- Whats model of engine
- h22a4 cold start idle?
- *Official* H22A Euro-r Injector Size
- 1994 prelude t2t4 4th or 5th gen mounts?
- Replacment UCArms?
- Mechanic used RED key we now have no start condition
- h22a4 swapped EG Which injectors?
- 1999 prelude v2 intake
- Valuation Help?
- 96 prelude NEW nonpower steering rack
- Difficult to get into 1st gear
- 93 h22
- 98 prelude ATTS light on?
- can a 88 prelude driver window fit in a 87? URGENT ITS RAINING
- Can anyone help me identify this?
- NKG BCP7ES-11 good for H22a
- 5th Gen Pic thread or Squad???
- h22a4 swapped EG
- vss & power steering looping question
- I need to fix my headlight harness.
- 1993 Prelude S Harmonic Balancer Broken after belt replacement or coincidence?
- Exhaust Choices
- Megan Lowering springs??
- 5th gen prelude immobilizer bypass not working!
- H22 88x95 some questions about my setup
- Honda prelude massive oil burning
- 1987 prelude front crank seal HELP PLEASE
- bb6 k swap
- gauge cluster bulbs need to change to LED help please
- H23A1 inner mods recommendation
- 1993 Prelude tail lights not working
- 98 lude No Injector trigger Pulse
- Prelude BB6 Build and Questions
- h22 type s pistons?
- Mild Exhaust
- 5th gen prelude limp mode help
- Timing Belt Noise
- we're to find h22 billet main caps?
- h22a4 rebuild not worth it?
- 97 Prelude - H22A4 pricing...
- 99 Prelude and turbo
- Charging problems
- Cold air intake question
- Best engine oil for H22a
- Need H23A1 vacuum line help
- prelude S model proportining valve
- 4th Gen Prelude question
- Wiring VTEC.
- 95 SI
- building h22A4 an 99 prelude
- aftermarket headers/wstock downpipe
- Digital Cluster Help.
- Question regarding rim / tire / suspension.
- H22a won't stay running
- Got a ticket for no lisence plate lights.
- 1989 honda prelude, SOHC, smokes and dies a lot.
- Rebuilt H23a1 smoking.
- 4 Distributors and still same problem.
- 95 plelude si 2.3l temp gauge
- Radio and Power outlet problem
- Wiring issue
- 88 prelude trans. swap
- Help Plz, time sensitive question?
- Accord SiR (H22A) possible vtec/engine problems
- Broken bolt hole in block where water pump mounts - need suggestions!
- speed sensor wire location for 1997 honda prelude sh
- F22A4 in a 1994 prelude?
- Sad. Probably fuel pump problem o what? F22A
- why crazy wheel hop after lsd tranny and traction bar install
- 1992 h23 prelude problem
- Converting my prelude from Turbo to NA
- Clutch help
- 98 SH everything blinking
