PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 [58] 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. 1998 Prelude stalling???
  2. 4th gen speakers
  3. H23 > than H22, or vice versa?
  4. Distortion on speakerwires?
  5. Just when I thought it was over......Help
  6. 4th gen question. 92-96 prelude owners. making all bumper lights on?
  7. stick shift conversion
  8. 97-01 prelude fog lights relay sensors?
  9. Help me and my 98 Prelude.
  10. eclipse injectors
  11. Obx lsd install into M2A4 problems
  12. H2B?
  13. 97 SS with 112k....change or not to change the tranny oil?
  14. h23a1 problem and question.
  15. clutch bleeding issues
  16. headers/exhaust setup for 5th gen n/a prelude
  17. My Project BB6, Turbo DD (Engine build)
  18. Rubbing bad in my new 5th gen...pics inside...maybe lack of bumpstop causing it?
  19. Loud CLUNK noise when engaging 1st/ Reverse?
  20. compression
  21. how do u hook up aftermarket rear speakers
  22. Proper way to Install Cam Oil Seals?
  23. Is this manifold AC compatible?
  24. 96 prelude climate control
  25. help! intake!
  26. Apex'I WS2 - 5th Gen
  27. Code 17 -already searched
  28. can you slip timing if you miss a shift while racing?>
  29. welded diff
  30. egr valve
  31. camshaft
  32. bb side markers
  33. new, motor questions?
  34. clutch and tranny problems NEED HELP!!!!!!!
  35. car wont start
  36. 97 lower control arms
  37. Heater control unit not working! Help!
  38. 88 prelude headlightslights
  39. 2 timing belt related questions (balance shaft and auto tensioner related)
  40. 97 prelude ecu?
  41. 01 H22A4 OBD2 > JDM H22A1 OBDI
  42. 01 H22A4 OBD2 > JDM H22A1 OBDI
  43. Lude door lock interchangeable on both sides?
  44. rear wheel drive prelude-
  45. burning oil and whinning timing belt sound...
  46. vtec problems and vss problems
  47. Skunk2 or Apex'i N1
  48. 4th gen. prelude header question
  49. Exhaust Review: Apex'i GT Spec Exhaust System
  50. Paint...
  51. 97 prelude sh help!!!!!!!!!!!!!!!!
  52. prelude base or SH !!?
  53. Transmissions
  54. F22b1 vtec wont start
  55. DIY: how to fix your cloudy plastic headlights
  56. 88 prelude air conditioning
  57. loud zinging noise from motor>?????????
  58. Foglights=death
  59. 88 prelude power
  60. over heating
  61. which Oil Pressure sensor ? .. 2 different designs for the H-series.
  62. 01 prelude stall problem
  63. Loud VTEC... weak power????
  64. Oil Leak - Head Gasket or Warped Head?
  65. 88 prelude
  66. About to Order an Exhaust, Quick Question...
  67. where can you boost the idle of a 88 prelude with the air conditioning on?
  68. h22 swap wiring/sensors/vacuum hoses
  69. Intake Manifold Bolt Specs
  70. prelude transmission
  71. car turns on then dies after a couple minutes...
  72. Timken Oil Seals Behind Timing Gear Sprockets Too Small?
  73. Half Radiators in 4th Gens
  74. no vtec
  75. Trunk leaks in 2001 Prelude
  76. 95 H23 balancer shafts. Is it safe to run motor without them?
  77. a/c problem with coolent issues
  78. oil coolers
  79. b20?????
  80. tuning options..
  81. h22a with bad misfire
  82. help me locate a member guys
  83. So... I'm about to join the Prelude family..
  84. h22 resleeving with Darton on Close or open heck
  85. For anyone struggling to remove crank pulley bolt come inside...cheap solution
  86. Mani swap issue.
  87. Crunching/Knocking Noise???
  88. Back in the game h22 ferio rebuild
  89. 92 Prelude..no dash lights, blinkers, clock, windows
  90. 4ws problems
  91. 92 just started
  92. loosing coolant??
  93. Just got a 97 SS...with 112k....got plenty of ???
  94. bar in trunk hits speaker magnets
  95. Identify h22 cams
  96. Coolant Reservoir
  97. question and a problem. I need help with both
  98. Loose Shifter
  99. Throwing OBD1 code 12
  100. eld code 20?? 4ws not working?? throttle cable getting hot! help please
  101. H22a throttle cable different from a H22a4???
  102. ABS light came on! Help please!
  103. rich fuel
  104. Hey how often do 97+ Preludes get stolen??
  105. 97 prelude bogging down, Please help!!!
  106. Car wont start :cry: (plz help tried many things)
  107. How do you sleep the headlights of a 91 Prelude?
  108. ordering RMF custom header
  109. question...
  110. head work
  111. Vacuum Line ?- and yes i searched
  112. Power Mirrors?
  113. Distributor cap spring
  114. Whats up guys still trying to figure out whats up with the 4ws steering
  115. Pic request of VAFC in 4th gen ashtray location...
  116. Questions on 5th gen, JRSC and Hondata S300
  117. 2001 prelude oil puddle under car ???
  118. h22 head gasket and timing
  119. No audio sound
  120. can i please get a pic of the underbody prelude SPECIFICLY 97-2001
  121. clutch help
  122. 3inch exhaust setups
  123. CEL
  124. question x2
  125. Anyone ever use the carnu-b wax?
  126. 4th gen interior colors
  127. tranny swap need info
  128. need new cams - any input?
  129. Any paint colur for your 5th Gen...What would it be????
  130. Driving impressions balance shaft on/off??
  131. Which camber kit for 2001 Prelude SH? Suspension is NOT stock
  132. loosing power when braking and turning
  133. Lude not running right after removing msd products and installing stock dizzy & coil
  134. A/C / Heater Lights Problem
  135. Factory bumpers for a decent price?
  136. Radiator shop guys strike again
  137. Possible master/slave cylinder leak?
  138. 5th Gen - No Start
  139. H22 Rebuid (Head and Block)
  140. Tach jumping around after 4000
  141. H23 have Crower Cams 62482-2 Need to know the valve adjustment clearance
  142. Gauge Cluster
  143. 1-3k RPM bogging?
  144. Boosting Troubleshooting
  145. swapping blocks shopping list:
  146. ECU LOCKOUT?
  147. 1993 Prelude Vtec Part Out
  148. Engine tick *searched* (Video)
  149. 1992 honda prelude distributor
  150. car wont run right wen drivin help urgently
  151. Oil on my spark plug THREADS, not the electrodes
  152. automatic 1/4 mile times
  153. Will these injectors work
  154. O2 Sensor....
  155. 2 problems on '93 Si(obd-1 jdm h22a swap)
  156. can anyone help with with a h22a ?
  157. CAR REVVING 1000 RPMS SHORT
  158. Fog lights....
  159. iCoolant issue.....still
  160. Automatic to Manual 4th Gen Wont start, and wont give my key back
  161. H22 parts
  162. water damage?
  163. OBD on a 1992 prelude s
  164. Programer/chip
  165. Power loss after bolt-ons - tuning suggestions
  166. 1988 Prelude 2.0S stalling at low RPMs
  167. Where is the multiplex?
  168. JDM H22A with LSD "Leaky Halfshaft" what do I do now?
  169. Fan shroud for slim fans
  170. starter motor compatibility h23 (auto) >> f22 (auto)
  171. harmonic balancer and flywheel question
  172. Type s engine ecu
  173. 5th gen Type-SH tie rods
  174. axle question??? help!
  175. ABS Problem
  176. converting man. windows to power windows in 85 prelude dx
  177. HELP!! Clutch MasterCylinder Problem!
  178. 97 SH clutch question please help
  179. Fuel Delivery Problem?
  180. Pick up my new lude tomorrow~!
  181. Need Help Finding a Good ngine Builder
  182. head stud removal sequence
  183. h23 5 rib compressor on h22a motor
  184. 97+ prelude internal coils?
  185. another brake question
  186. Going Turbo Doing The Fit Up..
  187. Dyno Dynamics Dyno - Only 192.2 bhp from H22A ?
  188. Help I have a very strange, but big problem.
  189. H22 getting no spark
  190. Cleaning EGR Ports (brass plugs no longer available at honda?)
  191. Question for a H22a5 with ATTS BB6 Vti-s
  192. Finding TDC for cam install
  193. Widebody kits
  194. i need help if everything bolts up and if all the wiring is the same??
  195. No more idle problems!
  196. engine upgrades
  197. BIG bog problem
  198. Which Block Should I Buy To Sleeve??
  199. installing fog lights
  200. Where to go from here?
  201. just replaced clutch and now...
  202. jdm h22
  203. Wiring Help Please
  204. FUEL PUMP QUIT!
  205. Looking to buy and have a waterpump timing belt installed
  206. Honda stopped selling the Genuine Honda Antifreeze?
  207. Intake gasket directions/questions
  208. turbo help...
  209. Can't get more then 20 psi of fuel pressure. Help.
  210. Live around Me????
  211. I need your help fellow luders, I can't find the auto turbo 5th gen
  212. More tune issues on my '93 Prelude(jdm h22a)
  213. Alternator
  214. 1992 Honda Prelude wont start!!
  215. what ecu can i use for h23 turbo
  216. Honing H23 block question
  217. Who maps P72 to H22
  218. '97 clutch question very serious !!!
  219. How do I turn on the foglights?
  220. Automatic To Manual Prelude Question
  221. H22A OBD2 Long Block
  222. Basic Tune Up Question....
  223. pulling an h22 from a 95 prelude
  224. Car Starting Problem
  225. ANOTHER idle problem
  226. ok i need some major advice!
  227. jdm fog lights 5gen prelude
  228. Calling all Turbo BB6 owners with powersteering removed or looped!!!
  229. Hott air in the vents
  230. P13 automatic ECU to manual????
  231. 01 prelude sh throwing ATTS lights 79,78,43
  232. AC and idle
  233. H22a oversized pistons
  234. Sometimes speedometer doesn't work
  235. H22 turbo Fully Built Top and Bottom Price Quot......Help
  236. common vacum leaks.
  237. Tranny leak.!
  238. Best Coil-Overs for Turbo?
  239. what is the best fuel pressure psi (on fuel regulator)to my h22a
  240. Radiator motor fan/Condenser Fan/Relay/ Starter/Battery - 1999 Prelude Semi Auto Tiptronic
  241. 2007 civic si wheels on bb6?
  242. Convert a (Base) auto into (SH) manual??
  243. turbo rebuild kit
  244. broke bolt in turbo manifold, is there a way to get it out
  245. F20B OIL PAN??
  246. WHATs This
  247. power steering. safe?? no fluid.
  248. The weirdest idle problem ever..
  249. what is this?
  250. H23 spark plug #1 is yellow...
