View Full Version : Honda Prelude
- header/exhaust problem... What to do?
- NEED ADVISES ON TO DO IT OR NOT!! PLEASE!!
- usdm oem parts on jdm h22a
- FS: H22 Head, Tranny, and Throttle Body
- chipped P28 ECU with h22a basemap
- new tires.. 205/55/16 v. 215/45/16 or 215/50/16
- what to look for in a used 5th gen prelude?
- Throttle Body
- List of cars w/ 4x114.3 lug pattern
- Making of a carbon fiber hood
- Did a compression test yesterday
- need lab control solenoid valve
- 94 prelude dohc si trans into a 2001 prelude?
- JUN III Cams in my Type SH a big upgrade over my Rocket re-grinds
- Just finished my swap need a little help
- best front bumbers ever !!
- best 4th gen rear lips
- Honda Prelude 1995 F22b spark plug wires
- Breaking in a built h22
- Intake & Vaccum Line Problem
- h22 w/ KAAZ LSD which oil to use
- All motor w/ $4000
- Car Shuts Off When I Accelerate Quickly
- Moonroof Problems
- passanger side axle
- H22 secondary actuator diaphram
- Clutch problem
- What does a bad O2 sensor look like? Running rich CEL (Pics)
- H22 Trans Question
- Diagram of EGR passage on h22a4?
- Open downpipe on turbo setup
- How To: Install Brake Stainless Steel Brake Line
- Any ideas what id be running? boost/track time
- new girl needs some help with prelude carbs and de-vaccing
- Bumper fitment/ signal light fitment
- no sparke
- p28 on a h22a1
- help me put my lude back together!!!
- access to rear suspension... speaker grille?
- Getting a pristine `96 Prelude VTEC this week
- 1997 Base problems, please help! IACV?
- 5th gen obd2p13 running/converted onto JDM p13
- 98 5th gen are they the obd2a or obd2b
- WTF is wrong with my lude?
- greddy header on type-sh
- How much paint is needed to paint a 4th gen?
- ET 35 for Honda Prelude 1995
- 1988-1989 Honda Prelude...
- Should i get mugen Fan switch, and thermostat
- My 1988 Prelude Si overheats.
- Honda Prelude 1995 BA-8 F22b ABS
- Will a M2B4 Tranny fit a 5TH gen with stock axles???
- Need to know all grounds and anything else that would cause electrical problems.
- My Boost Project
- How to remove the trunk torsion bars
- Need 4th gen. pass. side interior quarter panel!!!
- Will 16x8 wheels fit?
- i sure could use some help with my 86 carb'd prelude
- Car dieing at idle and stuff.
- 92 Honda Prelude Si /Auto H23 to H22 swap??
- last recall for 4ws. Was wondering about it?
- Do you need sleeves for high horsepower h22's?
- to lude or not
- 1992 Prelude engine cutting out
- '93 Prelude SR Jumper Plug (Cdn, H23)
- 99 Prelude keeps blowing EAT ECU fuse
- QUESTIONS ABOUT EXHAUST
- Needing new transmission. Should I go for H to B?
- Crank and wont start?
- 01 prelude having rev limite @ 5500rpm HELP PLEASE!!!!!
- H23 Manual Tensioner
- JRSC pully/belt question
- Valve adjustment question?
- jdm h22 type s
- H22a1 auto ecu
- How can i make an auto tranny withstand more power
- Someone with an 93 OEM rear bumper?????
- Timing/Distributor Problem...
- Question about 4-2-1 header gasket
- biggest turbo
- Fuel filter and fuel rail nut
- almost in the 10's
- a/c removal
- Full Braided Stainless Brake Lines
- hodata s200
- prelude question
- Any difference between obd1 h22 vc's and obd2?
- p0108 yes searched, yes i went through the flow chart. reading 30in/hg car off.
- broke old tranny...want a better one?????
- need brake light help
- Relays: Can I get a generic one from Autozone?
- 91 prelude A/C problem
- ABS Removal In 92 Prelude
- Timing help
- h22a4 cooling diagram?
- tsx wheels on my lude?>?
- H23 Turbo Manifold wont fit
- OB2 Inspection Help?
- Radiator hose compatability
- stock heat shield + top end header(RMF, hytech, SMSP)
- Pistons
- I just ordered my new lip...
- question about leather interior...
- Ticking sound still after vavle adjustment
- stock 5th gen dyno?
- type sh struts?
- h23 questions
- How to test a relay?
- friend got his oil change and...
- Where to?: Northeast H22 Rebuild!!
- Engine Build Underway. H22a
- DYNO RESULTS from intake testing + tuning graphs
- Car dies when parked over night
- wiring help
- wiring harness problem
- O2 Senor Problems
- Broken starter / pinion
- where can i find stock 93 sideskirts
- any one selling any aftermarket parts or know good places to buy?
- where can i get these also tech questions
- DIY glow gauges
- Some odd electrical problems with ATTS
- Foglights Problem!!!!!!
- Installed new clutch think i have a problem
- 5th gens without ABS ?
- Prelude Flare nuts
- Request Prelude Drawing Please.
- coilovers for a 01 prelude?
- will sh parts work on a base prelude?
- WideBand 02
- 1988 Prelude 2.0 Si strange ECU code
- quick question
- black rota slipstream on bb6
- should i get this prelude?
- Ecu Problems
- just finished my swap... is it supposed to do this?
- How rare are 3rd gen preludes in america?
- JDM fuel rail on usdm car(searched) Need help asap!
- starter problem... I think?
- Ball Joint Help...please
- Help on built engines?
- Denatured Alcohol
- need a drag and autox suspension setup.
- Best internals for the H22A
- 1989 Prelude Ignition Control Module (ICM) location
- My car rolls in park position....
- 91 honda prelude cooling system problem
- new old car, 88 lude si, and the worse air filter in history.
- Pressure Plate Bolts, are they universal?
- s2000 wheels?????
- nate daniel
- what would you do?
- H22 Trans fluid amount
- Review: the BEST eBay Header - cheap and well made.
- JDM H22A W/ Spun BEARING?!?!
- possible engine temperature problem?
- Am I Screwed??????????????
- H22A4 TO A H22A PROBLEMS! HELP
- Popping sound?
- jdm
- jdm h22a into a 98 prelude sh
- Coilovers for a 5th Gen
- VERY LOUD, WEAK VTEC...searched
- how many ludes do you guys see around
- air filter
- Dead tail lights, dash after swap
- WTB USDM 96 OBDII p13 ECU
- What size hex to adjust IACV H22a4?
- hey looking for a wireing diagram
- Clutch / Tani problem?
- HID kits?
- updated info on the 95 srv h22a1 prelude im ight buy
- Persistent CEL 3 MAP Sensor and Falling Idle
- Pic Request: Honda Tuning Magazine
- New Lude, New Problems.
- Passenger Vent Blows Warm Air with A/C on Cold
- Hondata S300 Compatibility
- Should I Sell My Car?
- HELP! 98 Prelude Immobilizer
- Help Installing lowering springs
- any one need stock parts?
- best h22a4 header?
- Help with kyb shocks install
- if i buy this prelude..
- H22a Crank Position Sensor
- tune up advice
- timing a 01 honda prelude
- which prelude should i buy from these.
- broken water pump ? 88 lude si
- any superchargers for the 4th gen h22a1 ludes?
- Slicks and Axles
- Alternator Problem
- 96 JDM H22a -- Open or Closed Deck?
- motor swap
- exhaust rattle
- JDM H23 FROM 2000 ACCORD EURO R PARTS QUESTIONS
- TURBO PRELUDE
- 97-99 difrences?
- Idle speed
- Snapped Timing belt
- questions about 5th gen prelude
- 88 lude ATF change, where to fill?
- Car stutters when going up hills
- Integra front lip on 4th gen
- H/F series differential cases the same?
- Synthetic Oil: Is It Really Worth It?
- *help* cant jump ecu code
- My momo hub wont fit on my 5th gen?
- All Generations Post Your Pics!!!!
- H22 Won't Start
- Oil pump install
- ATTN: White 92-96 JDM'ed lude. Your car is stolen.
- typcial valve train noise, would you feel it in the corresponding spark plug?
- 4WS Conversion
- CRANKS SPARKS BUT NO START ?
- h22a connecting rod.
- how low to go, BB6
- cleaning egr ports, or taking off manifold
- Is a p13 manual Ecu compatible with the greddy blue box?
- Problem with clutch engagement "self adjusting"
- coolant leak.....help!!
- Bolt stretch guage
- 1992 Prelude main relay location
- main relay ok....now what?
- For sale
- h22/h23 parts required
- cams installed...is this normal?
- Temp gauge not working.
- How many of you have spun a bearing? H22's
- Honda-Challenge race at Mid-Ohio, in car vid!!!
- euro-r vs type-s
- Injector resistor box??
- Integra with Racing hart c5 rims
- Problem to wire the EGR on 2gen h22 swap
- Pic request: intercooler
- H23 vtec conversion?
- Does anyone know how to flush...
- Removing plate on oil pump
- Replace main bolts
- Help diagnosing which rear bearing is bad
- JDM F22a1...is there such thing?
- accord rear lip...what mud flaps to use?
- h23 vs jdm h22 rods...
- smoke from exhaust
- Need help finding my CEL service connector..
- Questions about an OBD1 JDM H22A into a 98 Prelude SH
- 92 prelude si stutters when starting
- need help with knocking noise...need help plz
- 97 Auto to manual wiring faq
- Fans Stay Running?
