View Full Version : Honda Prelude
- Need help choosing radiator application
- Hotshots header
- I NEED HELP… QUICK…
- What is necessary to switch from a 93 e-brake and console to a 94?
- Blue Dash Lights Conversion 4th gen
- Blue Conversion 4th gen: Led's vs Film?
- distributor ticking
- CEL: Code 9(nine) thread Pt. 2
- ATTS codes?
- Reverse glow gauges
- 3rd gen H22A swap?
- any shops in kansas city or missouri or the mid west for a H22A swap
- Who purchased my OEM axle back exhaust a few months ago?
- 11 second 4thgen prelude
- installed skunk2 intake manifold and now have idle problems, part2
- Just did a compression test... i think its a lil high?
- motor / exterior
- Just bought a 98 prelude SH, clutch problems
- MSD plug wires...need help.
- H22a4 ignition timing questions..
- rear shock collar size in MM(metric)..
- Engine mount ques. *don't laugh*
- Anyone know this tranny code
- spring Creak Which BUSHINGS?
- injector harness?
- 99 prelude abs indicator
- 5th gen fuel pump relay
- putting back together my JDM H22A
- h23 Vtec pleae help
- 5 lug conversion for a 92-96 prelude
- lsd oil?
- prelude weights 4th vs 5th.... big deal?
- Header and pulley problem
- K20 swap
- skunk2 im and idle? turbo!
- Ohms setting
- SMSP Header Question
- I NEED HELP! 3rd gen engine blew, want to swap H22
- Buddy Club Pro Spec :Review:
- CEL codes, car bucking and jumpy idle ....
- Attention Prelude Experts
- 1990 camber adjustable?
- Thread Lock
- h22a head
- 92-96 yellow Neuspeed wires
- Exhaust leak at flexpipe?
- cel 12 help
- Buying a car: Can't decide between 5th gen. Preludes/ GSR/ or 99-00 SI
- White smoke!
- buyin prelude.
- Rims: will 16 X 7.5 fit?
- Rebuild of '91 Prelude SR, power additions?
- sdkracer, satan_srv question.
- More o2 Sensor help needed.
- short ram intake question
- Several problems with my '97 Prelude?
- Problem? Distributor?
- accord control arm.
- Specific Oil Pump install question
- axle back gasket
- prelude engine code
- valve adjustment for h22a4
- Prelude wont roll
- exhaust question
- H23 swap to-----H22
- Location of Clutch master cylinder
- emissions?? will a JDM pass..?
- DISTRIBUTOR PROBLEMS?
- What flywheel to buy?
- Do sparco sliders/brackets fit Bride Seats?
- TUNNING MY NEW BUILT BLOCK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!
- Passwordjdm.com????
- which offset to choose????
- Which DC header to H22A8
- Engine management fake?
- Anyone install a skunk manifold yet?
- H22a oil pump gear question
- H22A4 Open Deck / Ring Problems?
- Best engine mods for N/A h22 ??
- 1992 4wsi starting problem
- eibach prokit springs on bilstien shocks...
- 1986 honda prelude si swaps
- site headlights
- H22 Silicone Hoses
- Stock H23 w/ 40K miles. How much power can stock bottom end make on boost?
- gen4 lude speedo problem
- wtf throwin a code 43 (fuel supply system) help......
- sensors....
- ever hear of this brand?
- clutches
- Timing
- wondering what this little rattleing sound is...
- Post your setups!!
- Sunroof deletion question
- desiding between apexi n1 or greddy evo
- Prelude Accord Compatability
- good cat for 5th gen to buy
- h22a swap problems!!
- cv boots wheel side 86 prelude
- H22 Idle problem and lights dim
- offset/wheel size/tire size relations
- is crower stage 1 cams good upgrade ?
- Need Help With H23 JG Cams
- gauge cluster
- replacing msd blaster coil 2 with stock external coil?
- knock sensor
- burnin radiator fluid!
- Fuelrail question.
- ATTS problems?
- 5G Axle Differences
- engine weight
- Need help w/ ignition switch ASAP
- ...G23 VTEC...(56K...Definitely Beware)
- 92-96 console
- 92 JDM H22A (Si / Si 4WS) Compression Questions
- V-acf vs. Hondata...which one?????????????????????
- Bad Rear Hub?
- JDM H22A Valve Lash - What are the values?
- JDM H22 ... What Spark Plug do i use????
- running in of engine
- bb1 engine code
- stripped ball joint
- h22 with sc60 good choice???
- engine overhaulin'!
- JDM folding mirror install site???
- question about 97+ prelude Interior
- brake help(part2): how to get pressure to brake pedal
- Blow-by testing on cold H22A engine. Questions!
- H22A Power Steering Pump Leak
- vtec solenoid question
- might have a fix to the jdm h22a idle issue.
- DTC 79 ATTS Control Inhibition?? What does that mean?
- help..H22 Laggin
- 450cc injectors?
- a little help with 89 or 90 prelude
- HOURSE FOR THE LUDE
- Read this
- DC Sports Sucks
- Any Ideas on this O2 problem?
- Houston Area Help!! ECU problems. '92 Prelude, OBD 1, P28.
- suspension make little squeak when going over little bumps!!!
- prelude conversion
- brake help: how to remove rotor with messed up screw head
- lneed wheels
- p1457 code Manfac. Control Auxiliary Emission Controls
- shift linkage
- 4 gen heated seats?
- 93 Prelude Issues
- Please Help O2 sensor/ pipe question
- H23a1?
- Can you fix a ECT sensor plug???Anyone have one?
- WHAT SORT OF POWER
- 5th genration lude engine????
- a.f.c. controller
- Neuspeed header, any good?
- f22b dohc the motor that dont exist
- greddy evo v1 worth 320 bucks?
- want to buy a lude 98+, just a few questions, can you guys help me?
- Bad oil smell / white smoke burning off valve cover
- How does a 3 cylinders runs?
- loose timing belt H22A
- A/C belt installation on 96 Civic
- anyone with a 94-97 cat for sale ??
- 93 Prelude H23 to H22a swap
- New jdm fog bulbs not working???
- S2000 RIMS
- NGK Iridium IV's
- whats wrong with my baby
- Cylinder #1 down??
- h23 rods and h22 oil squirters question
- How do you remove the H emblem?
- lucas injectors
- Links for everyone!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Anyone have any problems with retainer failure or coil bind with their aftermarket valvetrain parts?
- Whoa NO GOVERNER! IS THERE SUPPOSED TO BE 1!??
- Carbon Fiber Hood Question concerning online retailers...
- Prelude Stock Weight! Does neone KNOW?
- Anyone running a Buddy Club Prospec on their 5th gen.??
- '90-'97 accord suspension fit prelude?
- Uprating Auotmatic gearbox (H22a)?
- Hi Low converter on 5th Gen
- ecu help
- h23 valve train
- Brake Question?
- Nsx Lip?
- Wondering If the 94-95 Accord Prelude Dc Header Will Fit 92 Prelude S F22a1
- Baffled Oil Pan
- 92-96 bb4 digital climate control.
- What is the jdm ecu specs 4th gen
- ACT prolite or streetlite flywheel
- Shifter with the shortest throw.
- head gasket
- Torn between two cars
- engine oil burning FAst part 2!!!!!!!!
- throwing o2 code
- venom fuel rail install
- Is there a way to rest the check engine light?
- Torque specs. for a H22 header????
- prelude engine question
- Clutch help!!!
- header question
- oil leak!!!
- What happened to my clutch!?
- oil
- 92-95 prelude shifter?
- SMSP, Prospeed, Mugen, and imagine engineering headers compared.
- Prelude 01 Valve Adjustment
- i need help!
- swap help
- Some sort of electrical problem..
- fuel pump not getting power...any ideas....?
- anyone know where i could get obx turbo kit for h22?
- Wheels
- springs cambers question
- Lowering springs
- question about spoiler??
- multiple throwout bearings goin bad.
- Prelude pricing question...
- VACUUM GAUGE INSTALL
- 5th Gen Catback Best Gains or Best all around
- VERRY LOUD STARTING PROBLEM
- is it a good idea to turbo my h22
- probably a repeat question but can you put a h22 head on a h23 safely?
- suspension problem
- Is it necessary to Gap spark plugz?
- engine help
- Harness
- My Lude Won't Start, someone please help
- 92 prelude speaker install, please help!!!!
- Need H22a vtec
- accord suspension
- prospeed header questions
- Some questions for you guys about various mods.
- hesitation when cold
- Vafc? ? ?
- What Rear Sway bar and tie bars are a good set up for 92 prelude.
- Hollowing cat
- h22a
- ITB's
- question about tires
- Just Installed Drag III on 97 prelude need help.
- Timing Adjustment urgent help..
- Headlight Motors
- knocking sound coming from head.!!!!!?
- Questions about axles
- 92 prelude ACT extream clutch
- power window doesn' t go up need help
- Are OBD1 and OBD2 Dizzy's swapable ?
- odd check engine light
- engine swap
