PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 [256] 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. What does R/S ratio actually mean?
  2. MSD Ignition... Help Please...
  3. So what's the deal with the Prelude SH? and early 5th gen versus later 5th gen.
  4. just hit 70,000 miles
  5. 5th gen JDM door sills?
  6. clutchmaster stage 3/4?
  7. Moonroof opening at a rate of hours
  8. I found a parts car, who needs parts?
  9. Crazy Honda
  10. trip to the strip
  11. crank senser
  12. Does short ram install require resetting the ECU?
  13. Anyone who's changed t-belt w/ aftermarket cams
  14. need a manifold
  15. JRSC 2000 prelude (Help with the belts?)
  16. Might buy a Lude what are your thoughts???
  17. camber kit question
  18. help on rear suspension plz
  19. Switching back to concentional oil?
  20. Basic things to keep it running right
  21. WOW - someone lucky is gonna get this - '93 VTEC w/ 29K miles...
  22. trying to find main fuel line
  23. turbo h23 people what are you s-afc settings?
  24. vafc, where to set the vtec...
  25. ****Spoon Strut Bar Install???? HELP Please****
  26. Where to find paint colors
  27. Need Pinout diagram for P14 ECU
  28. need help fast - fuel tap in
  29. h22 problem
  30. How to get LCA bolt back in?
  31. Need help with suspension torques
  32. need help with head swap
  33. New steering wheel, where did you put your cruise control at?
  34. so what else could it be?
  35. Aftermarket steering wheel.
  36. Spec Motors
  37. Question about prelude big brakes i'm selling
  38. tps
  39. mph speedometer readings
  40. turbo h22s look here please
  41. Black Smoke
  42. H22+H23?
  43. BAD FUEL PUMP???
  44. Who wants to play suspension ID?
  45. Car is feeling sluggish
  46. Replacing Ball Joints & Rubber Boots in Suspension.....where to buy???
  47. throttle position sensor- voltage output wire
  48. o2 wire p13
  49. Installing Tach on 92 Prelude
  50. need shop name in the states or in canada to build me h22 turbo
  51. horsepower winner
  52. 1990 lude
  53. Prospeed header dyno results for H22a (Link inside)
  54. Rebuilding an H Series block!! Where to buy oversized bearings??
  55. H22 balencer shaft
  56. Finally
  57. Finally snapped a few pics of the Gi-normous holes I blew in my block...
  58. Ball Joints
  59. BADBAD NOISE
  60. MPG??
  61. Graffiti
  62. Prelude engine needed...question
  63. clutch (pedal) help -92 si-
  64. Need Advice on going Turbo or N/A+NX route...
  65. ...::Prelude Pictures::...
  66. *****Removing rear panels: Help Please*****
  67. Cf Hood Questions Please Help
  68. atl/commerce/nopi meet this weekend
  69. time for the timing belt... Wgat about the water pump?
  70. does anyone know of a wrecked 4th gen lude for sale?
  71. URGENT help: Koni shock compatibility
  72. 99 SH Inatke manifold on 94 Prelude Vtec????????
  73. Mugen vs Smsp
  74. Does anyone know of a good place (so cal) where they can perform the scheduled maintenance?
  75. Aftermarket Sunroofs?
  76. 93-96 jdm prelude headlights
  77. Do you need aftermarket ecu to boost?
  78. EGR cleaning procedures
  79. h22a1 in a 1992 Prelude SI what is needed
  80. Someone Bent this by jacking my car. Fixable?
  81. Jdm H22 vrs USDM h22
  82. ringlands
  83. Swapping sun roof for moon roof... (searched)
  84. guys with hids
  85. Everything i need for H22a swap?
  86. I need help with h23 vaccum? asap
  87. Prelude Power Windows 4thgen. Seems as thought the windows are BOGING.
  88. KYB AGX SHOCKS FOR SALE!!!!
  89. Prelude JDM H22a Injectors FS
  90. any skunk2 stage 2 people...
  91. need help BADLY... no haynes manual
  92. H22a JDM Vtec SOLENOID. USDM vs. JDM seals
  93. Sleeves: Darton or Manley?
  94. Clutch problem and question - 5th gen w/ 4th gen tranny
  95. Question about TB
  96. cam gears
  97. Vortech centrifugal supercharger
  98. anyone know how to remove front door windows on a 5 gen
  99. Aftermarket ECU's
  100. (4th gen) Wings West spoilers ?
  101. 4th gen + Thermal exhaust questions
  102. who has lowered there 92-96 ?
  103. '92 v-tec install help! wut axles?
  104. R&D Dyno H22 Cylinder Head
  105. Intermediate shaft on sh
  106. getting rid of atts unit
  107. Front Bumper Absorber
  108. S-AFC questions!
  109. quick lude purchasing inquiry
  110. Home compression tester kit.
  111. my lude post
  112. 5th gen PRELUDE stock rear lower lip
  113. SpeedTrialUSA @ GingerMan Raceway October 11
  114. After market lighting info please.
  115. whats the 1/4 mile time for a 95 lude non v tec with i/h/e
  116. Possibility of exhaust blockage?
  117. V-AFC is Dead need help!
  118. Body work in Savannah? and other conundrums.....
  119. Legend caliper upgrade for the 3rd gen!
  120. Power steering and a/c removal??
  121. Apexi VAFC Help
  122. Anyone with Tein SS on their Preludes?
  123. NEED HELP what FPR should i use for my H22
  124. Need H23 Head!!!
  125. Winter Tires For Sale (Fit Prelude 97-02)
  126. dumb question
  127. what would happen if you shaved 0.056" off the deck of an H23 :P
  128. HELP!!!!!!!! Which gasket to use????
  129. boosted 92 si..... R.I.P.
  130. couple q's for h23 vtec w crower stage 2 cams
  131. Hello problems with jdm climate control
  132. type s cams
  133. ass load of compression
  134. whp question?
  135. 95 Prelude VSS problems. Did search, only found info on Civics.
  136. Help! smoke!?!
  137. NOVA prelude meet...anyone interested?
  138. Weird front suspension noise..
  139. will someone explain "resleeving" your block?
  140. How do you tell what cams these are?
  141. prelude rebuild
  142. best mods for an H22
  143. h22 stroker kit?
  144. WANTED: AEM CAI and V2 5speed dyno comparisons
  145. Center console
  146. Problem: Burning smell from exhaust and poor gas mileage
  147. to anyone who uses aftermarket cams
  148. WTB 2000 prelude parts
  149. 1991 Prelude Engine Swaps??
  150. 4th gen and 5th gen h22 exhaust maniold/header the same??
  151. Compression ?
  152. EGR code on Prelude hybrid....
  153. where to buy stock valves
  154. Autotensioner Help
  155. Golden Eagle Electric Water Pump
  156. need help with my head......
  157. help me troubleshoot this problem.
  158. EMS users
  159. Alignment on a lowered car
  160. Axles for prelude where can i get some?
  161. how much would it cost to rebuild a h22a?
  162. What to think of skunk2 stage 1 camshafts and str cam gears?
  163. H22a type S question?
  164. transmission assembly
  165. H22A Question...
  166. resleeving block
  167. cams??
  168. EVO prices
  169. can u buy just 1 shock?
  170. Parts required
  171. mishap today fellas...need guidence
  172. Diagnosing Code 8 (Top Dead Sensor)
  173. What to do for a build-up?
  174. got my kit on!
  175. search no good!!88-89 foglight light bulbs????!!!?!?!?!
  176. Red Dog Motorsports?
  177. wheres the spot to fill up trans axels at on a f22 tranny?
  178. any ideas
  179. Need some advice on a 1991 Prelude.
  180. :::::Gainesville Prelude Meet::::: pictures
  181. Prelude Type S bottom end.
  182. anybody know how to fix a main engine seal?
  183. 5th Gen Helms
  184. Should i buy or not
  185. 4th gen. how do you adjust stock headlights?
  186. Shifter bushings for 5th gen??
  187. headers and exhuast bolting up...
  188. Loud screetch when starting car
  189. Brakes squeeking...
  190. fuel maps h23
  191. Car Won't Start, Any Suggestions?
  192. Prelude Airbox Question
  193. JDM Type-S owners
  194. I think this is relevant to the luders.... Probably not in my state of mind, but I DID have lude pi
  195. DIY: H22A VALVE ADJUSTMENT
  196. ultimate JDM part
  197. Wiseco Pistons & not sleeving block.
  198. 5th Gen Offset??
  199. OEM Kit
  200. 5th Gen tranny problem
  201. Got a problem ? what do u think?
  202. HP of stock 97'prelude typeSH?
  203. H22a Problem
  204. Should I buy it?
  205. Prelude seat rails: repair? replace? WTB...
  206. ITR Helical LSD on H22?!?!
  207. Re-sleeving a block. Any Pics of the process??
  208. turn signals
  209. 01 Prelude Vs. 03 RSX-S
  210. Bad E-Brake?
  211. 270 whp H22???
  212. 11.0.1 cr JE pistons for h23
  213. h23 info
  214. For those H22 owners with C/F hood...
  215. Prelude/Accord on the same platform?
  216. fellow prelude owners i need help chooseing what mods to get
  217. What Oil Filter do you use?
  218. HELP. KONI question
  219. H22 VTEC Oil Problem!!!!
  220. Help, Need Advice on Timing Belt
  221. Starting Problem
  222. slows down w/vtec
  223. Exhaust suggestion for Big H22 setup?!?!
  224. Heavy idling while AC is on?
  225. act clutch not fitting flush with flywheel? is this normal?
  226. Prelude 4th Gen Gauges in Ashtray. Wanting to do this, what all is needed?
  227. who makes h23 intake mani
  228. Prelude Pricing
  229. Crank Pulley and a gasket questions
  230. Exhaust Question
  231. looking for more specs on H23AVTEC accord wagon motor
  232. ...::|Prelude Forum Guidelines & FAQ LINKS|::... *Read Before Posting*
  233. Prelude type S handling issue
  234. vafc install
  235. slim radiator fans?
  236. What are the best prelude sites?
  237. airbag replacement
  238. JDM h22 swap
  239. Windsheild replacement
  240. Info needed on Honda Prelude...thinking about purchasing one!!
  241. anyone with a clutch master cylinder for sale?
  242. Euro-R serious issues.... Please read.
  243. How hard is a HG replacement on a 86 Lude?
  244. Oil Pressure Gauge Problem!
  245. Vtec guys I need your helms..I mean help (h22&h23 valve dimension comparison)
  246. are motegi mr7's hub concentric with a 5th gen prelude?
  247. Has anyone had the engine flush done from the dealership??
  248. Timing Belt
  249. How can I test EGR?
  250. In need of referal...
