oil leak after reassembly
Old Oct 22, 2003 | 07:38 AM
mhgleitz's Avatar
Default oil leak after reassembly
just got my motor back from GE. put it back together in a couple days. when i crank the engine i get a leak from the oil cooler. for those of you who don't know where it is, it's where you screw in your oil filter. anyway, it's leaking between the cooler and the engine block. i went and bought a new oring from honda, and it's still leaking. any ideas?
Old Oct 22, 2003 | 10:24 AM
19924ws's Avatar
You have to torque the **** out of that thing. I check the service manuel at Honda and I couldn't find a spec. I made it as tight as I could with a 1/2" drive. Make sure that the surfaces are flat. Make sure the cooler doesn't spin while you're tightening it or the O-ring will rip and you're back to square 1.
Old Oct 22, 2003 | 10:45 AM
mhgleitz's Avatar
Default Re: (19924ws)
so i assume that since i got such a quick response, that this is a regular problem with rebuilding? any idea how much torque you put on it. i may remove the intake manifold again to get better leverage on it next time.
Old Oct 23, 2003 | 06:41 AM
mhgleitz's Avatar
Default Re: (mhgleitz)
has anyone else ran into this problem?
Old Oct 23, 2003 | 12:27 PM
19924ws's Avatar
Nope didn't ever have that happen. Like I said there is no spec for that bolt thing in the service manuel that I used when I worked at a Honda dealer. Did you find what the prob is?
Sprockets
Jul 13, 2018 03:18 PM
fastrider213
Feb 12, 2009 04:28 PM
asleepz
Jan 12, 2006 02:46 PM
JDM-EJ1
Oct 2, 2004 02:32 PM
People_Mover
May 19, 2003 01:05 PM
