Top Speed 4g vs 5g?!?!
Old Oct 21, 2003 | 03:46 PM
NirVTEC's Avatar
Default Top Speed 4g vs 5g?!?!
Does the Final Drive have to do with this? I just noticed that the 4g VTEC uses a 4.27 FD and the 5g uses a 4.26FD.
Is that how 5g'ers get that extra 5mph up top?
The lower the number the higher the top speed?
Old Oct 21, 2003 | 04:12 PM
LudeyKrus's Avatar
yep, that's it; i've never actually sat down and looked at the drive ratios on the lude's tranny, the bigger the final drive, the lower the top speed, but faster the accelleration.
Old Oct 21, 2003 | 04:20 PM
NirVTEC's Avatar
Default Re: (LudeyKrus)
I guess it would make sense to me to use a big FD then. Are there companies out there that rebuild Honda trans' with different FDs?
Old Oct 21, 2003 | 04:30 PM
skunk2lude01's Avatar
my friend cant get his 95 h23 manual past 135. But of course thats not vtec
Old Oct 21, 2003 | 06:48 PM
satan_srv's Avatar
Default Re: (skunk2lude01)
the FDs are the same, 4.266 your one source is rounding when the other isn't.
Given equal final drive, the lower 5th gear number has a higher top speed.
5th gen = .812
4th gen = .870
5th gen has a higher top speed.
Old Oct 21, 2003 | 06:49 PM
user 9782082308's Avatar
Ummm, no. The top speed is limited by the ecu.
Old Oct 21, 2003 | 06:52 PM
LudeyKrus's Avatar
Default Re: (racerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerx &raquo;</TD></TR><TR><TD CLASS="quote">Ummm, no. The top speed is limited by the ecu.</TD></TR></TABLE>
SUPPOSEDLY! But it isn't for most US cars, but it is for the JDM's.
Anyways, we were talkin about the gear ratios, not the ecu's limitations
Old Oct 21, 2003 | 06:55 PM
satan_srv's Avatar
Limited by the rev limter only. There is no speed limit on USDM preludes.
Old Oct 22, 2003 | 09:15 AM
NirVTEC's Avatar
Default Re: (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">
Limited by the rev limter only. There is no speed limit on USDM preludes.</TD></TR></TABLE>
And people say JDM is soooo dope. JDM H22s top off at 120ish?!
Even the B16 is limited here. Not sure about the B18.
I still remember the look on my friends face when I tore past his modded DelSolVtec at 125ish like he hit his brakes......Silly speed limiters!!!
Old Oct 22, 2003 | 09:40 AM
Nick M's Avatar
Default Re: (NirVTECn2o)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NirVTECn2o &raquo;</TD></TR><TR><TD CLASS="quote">
I still remember the look on my friends face when I tore past his modded DelSolVtec at 125ish like he hit his brakes......Silly speed limiters!!!</TD></TR></TABLE>
who cares about speed limiters unless its a track car?
Old Oct 22, 2003 | 09:44 AM
explosive's Avatar
Yeah, from what I have heard, there is a speed limiter on the JDM H22 at 115...all it takes though is a little modifying to the ECU to get rid of it though. I heard that there is even a VTEC controller out there now that you can buy and once you plug it in, the speed limiter is gone.
My chipped ECU gets the job done though.
Old Oct 22, 2003 | 11:02 AM
Old_Nocturnal's Avatar
Default Re: Top Speed 4g vs 5g?!?! (NirVTECn2o)
I just put a 4th gen tranny in my 5th gen...
Old transmission (5th gen) 4000rpm@80mph
New transmission (4th gen) 4000rpm@72mph
Old transmission (5th gen) 5000rpm@100mph
New transmission (4th gen) 5000rpm@93mph
From that, you can kinda see the difference between the two and what it will be at top end...
Old Oct 22, 2003 | 11:14 AM
NirVTEC's Avatar
Default Re: Top Speed 4g vs 5g?!?! (Nocturnal)
Damn....thats a big difference.....
It also explains why I walked my friends 5g through the top of 3rd and all through 4th.....Then he slowly started gaining on me before we shut down!
5th gen tranny on my "TO-DO List"
Old Oct 22, 2003 | 12:42 PM
satan_srv's Avatar
Why would you want slower acceleration in exchange for a higher top speed? That's ridiculous!
Old Oct 22, 2003 | 04:04 PM
NirVTEC's Avatar
Default Re: Top Speed 4g vs 5g?!?! (satan_srv)
Well, thats why I said "On my to-do list"........I think down the road I can sacrifice low end acceleration for top end.....(But do I really need to go faster than 145ish?)
I see your point though.....Why not use a crazy gear that tops out at 120ish but gets there real damn fast....
Balance is the real key though.....Like trying to mate rear-ends in my muscle car days.
Those 4.11's screamed off the line but had no top speed at all. The mid 3's were the place to be for both.
Old Oct 22, 2003 | 05:57 PM
killa_lude's Avatar
I got my past 92 si to 140....i think it was redlining though....
Old Oct 22, 2003 | 07:23 PM
Default Re: (jz)
I guess the needle bouncing off 7800rpm in 5th gear was my imagination.
Old Oct 23, 2003 | 10:04 AM
NirVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerx &raquo;</TD></TR><TR><TD CLASS="quote">I guess the needle bouncing off 7800rpm in 5th gear was my imagination.</TD></TR></TABLE>
Ahhhh......thats why I can't wait for my feather-touch!
Old Oct 23, 2003 | 10:18 AM
Puki
Guest
Posts: n/a
I checked up the specifics before, I don't know that their is it a speed limitation, however there is the fuel cut off, In my H23 the car stops at 129MPH. No more.
As far as H22 I would say no more then 135. H22 and H23 run on same tranny with same gear ratio's, correct? Thats what I believed all along.
Edit, I am talking about 4th gen's . 5th gen's me no no
Old Oct 23, 2003 | 10:19 AM
CerealKiller1117's Avatar
Default Re: (jz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jz &raquo;</TD></TR><TR><TD CLASS="quote">yeah i accidently hit the rev limiter in 5th gear once. all shes got is 140. she was still pullin hard though... oh yeah i got up there really really quick. thats why i didnt notice i was that close to hitting the rev limiter. you gotta like taking it up the high every blue moon. for me its a real big rush. if you call me stupid for doing it i dont give a ****. is there any gearing difference between jdm and usdm trannys? </TD></TR></TABLE>
hell yea it is! we do that around here theres a really long coutry road just outside the township, i top at 110 tho? i have a 92 Si, its stock, should i be making more than that? i didnt push to the end of 5th gear cuz i didnt wanna mess something up
for kicks i just recently got this car, much better then the avenger i had before
1 my prelude
good topic by the way
Old Oct 23, 2003 | 01:51 PM
satan_srv's Avatar
Default Re: (Puki)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Puki &raquo;</TD></TR><TR><TD CLASS="quote">As far as H22 I would say no more then 135. H22 and H23 run on same tranny with same gear ratio's, correct? Thats what I believed all along.
No..H23 gears are longer. 2-5 anyway. The H22a is much shorter but has more rpms.
Old Oct 23, 2003 | 02:54 PM
SKDRCR's Avatar
what would happen if you put a final drive gear
from a euro accord (h22a7 i think ) into a lude hmmm.
Old Oct 23, 2003 | 02:56 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nocturnal &raquo;</TD></TR><TR><TD CLASS="quote">I just put a 4th gen tranny in my 5th gen...
From that, you can kinda see the difference between the two and what it will be at top end...</TD></TR></TABLE>
that's wierd, my 4th gen is at 4000rpm @ 80mph and 5000 @ 100mph
Old Oct 23, 2003 | 02:59 PM
LudeyKrus's Avatar
Default Re: Top Speed 4g vs 5g?!?! (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">
that's wierd, my 4th gen is at 4000rpm @ 80mph and 5000 @ 100mph </TD></TR></TABLE>
same here
Old Oct 23, 2003 | 04:18 PM
satan_srv's Avatar
Default Re: (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">what would happen if you put a final drive gear
from a euro accord (h22a7 i think ) into a lude hmmm.</TD></TR></TABLE>
I have a euro-r tranny...the final drive is 4.266 same as all the others. H22A7 is the accord type-r motor. And it's tranny also has the same final drive.
