View Full Version : Honda Prelude
- Fidanza Flywheel ??
- Radiator Fan question
- Flowmaster On My SH
- w/c shop should take my car(bay area pips)
- vafc vtec points
- Timing Belt Job, what else should be done.
- Timing Belt Job, what else to replace?
- Replacements for stock air filter elements (Searched)
- h23vtec hybrid
- Getting 2nd Gen Lude ready for swap
- h23 v tec squirters
- Sell 98 Lude to get 2000 Integra GS-R?
- misfiring
- "performance" intake manifold gasket
- idle issue...need help
- removed a/c in 5th gen... some Q's
- 97 h22 swap problems - experts read
- prelude 5th gen throttle body on a 4th gen intake manifold?
- Help please how do I get to fuse 23?
- Nippon Racing pistons
- accord lip
- 89 prelude fan not working?
- 3rd Gen Si h22a
- B20A5
- Car Smells?
- jdm vs udsm foglights please help
- Performance Brake Pads ?
- Manual Trans. Oil Ques.
- does the 92si have a No.23 fuse 15A? Helms says yes but
- anyone try probe
- KMS springs and retainers
- what motor/car/country is this fuel rail from??
- clutch problem...???
- Anyone add 8lb Fidanza lightweight flywheel to h23 block?
- question on h23vtec build
- which gen??
- H22 one piece headlight
- Possible burning oil?
- Built H22a1 Turbo block 89mm (2.3L)- w/ many extras
- quick question on mechanically blocking of EGR ports for Euro R manifold
- 5th gen accord suspension on 5g lude?
- Knock Sensor
- 5th Gen CEL Transmission codes. What does code P0700 and P1737 mean?
- help me!!! disassembling block.
- 98 prelude head gasket replacement
- Is an upgraded final drive good for a daily driver? will it work on a type SH?
- Fixed my rear shocks...but car still make noise when driving...
- Uh...Problem.answers needed please!i!i!
- 5th Gen Front Blinker/Fog Light Conversion Question
- where does the cam seal go on my h22 head thanks
- off topic!!! need help for autobody shop
- Question
- Need help with engine squeaking noise! Please help!
- 1992 Prelude Si DOA - need help.
- N/A or turbo? that is the question
- Overheating
- dynomax dnx exhaust good or bad
- only if you guys are bored, pretty interesting history of the honda prelude
- clock removal
- Should I go H22A v-tec with high compression or H23 for more torque
- Confused help me out!
- CEL 17. Speed Sensor error. Change the speed sensor and it still has code 17
- 5th gen-Location of ECU
- What is this Part Called??
- 5th gen, front sway bar size
- Rain won't dry off my car.
- Strut brace bars
- Bolt pattern
- o2 sensor light staying on`
- A/F ratio
- Automatic to Manual swap 92 H23
- proper way to tension balance shaft belt
- Did a little 're-wiring' over the break---
- 5.2 FD for h22a tanny.
- Shaking Problem
- help!
- quick question!!!!(searched)
- ss clutch line to slave cyliner
- Sleeve question
- 2 1/16 gauges
- aligning rear balance shaft
- Strut bar 5th gen with 4th gen??
- are h23 headers same as h22
- Should I plug this ?
- prelude swap!
- help, tach bouncing and ecu cuts engine out!
- Knife edging crankshaft and where to get it stress relieved, and post balanced at??
- abs light
- good header for under $400?
- Wheel/tire fitment guide
- strange noise
- help with possible abs system problem (no cel)
- Help me spend $500 the right way
- titanium retainers
- another s2k wheel question *SEARCHED*
- Slave cylinder removal
- h22a type-s valvecover color
- newb question. will autozone scan OBD1 on a 92si for free
- Koni Yellow Adjustment
- Stock Prelude fuel rail & regulator
- Anyone got the guide to removing the head off a H22 *searched*
- a couple questions...
- Clear taillights
- 4th GEN HID question.
- bad shifter cables or tranny?
- Clutch problem
- I forgot...
- 93 Lude, Where to check CEL?
- 13 inch rim on a 4gen prelude with Si rotors?
- CEL code help
- Another question about 5th gen turbo and supercharger
- quick question
- 5th gen prelude question
- MSD install question
- Forbidden Short Shifter Update for 5th gen ??????
- jdm f22
- H22a swap and 4ws
- 5th gen & 4th gen alternator interchange?
- Slave cyl question and collector mod pic.
- import builders rods
- Installing Koni's today, hardware question.
- noob post
- Anyone w/ 7" width rim and +38mm offset?
- ITB VS. Single Large TB - Differences?
- Door locking and unlocking question
- cheap intake and exhaust for 97 sh
- Aftermarket rocker arms
- radiator fan ?
- Crank pully problems! belts came off, pully is half way off
- Euro R intake manifold Install
- Head Re-Build
- Trunk lid does not stay open...
- h23 helms manual
- Trip odometer problem 4th gen odometer
- pittsburgh shops
- prelude wit a k24 drop
- Timing belt installation
- Help my speedometer, mileage, and trip meter do not work, only the tachometer works
- Wheels / tires
- Mobil discontinues 7500 synthetic blend
- H22 Axles on F22 Tranny?
- where can i find motor mounts
- Will this work i doubt it
- b20a5 question
- my axles...
- Car boggs after reinstallation of exhaust
- I need a baffled oil pan for my 97 SH..who makes one?
- FS: 1992-1996 jdm fog lights (white)
- turbo manifold
- Is This a Good Deal
- anyone know what this is
- Check Engine light aftre headers installed?
- Just got my hands on a half-mast antenna switch.
- Alternator Belt
- Looking for dash wiring diagram for 94+ EL gauge problem
- NOS the H22a4 5th gen
- 99 prelude sh flashing check engine light and atts light
- suspension
- Oil pan
- CEL 45 honda prelude
- Why does all auto parts store mistaken H22 parts as h23?
- need some help.92 honda prelude s f22
- How to install heated mirrors...?
- Pistons
- Prelude Losing Power and Randomly dies.
- knock sensor hack?
- wire diagram for a 2000 lude
- 1989 4ws prelude b20a5 advice needed
- xtd flywheel timing marks
- Coolant in exhaust?
- Coolant bypass idle issue (searched)
- Motor Setup and Losin Weight on Car
- stupid question about bulbs for a lude
- Blown engine fix
- h22 engine bracket....
- Axle problem
- My Turbo Plan so far...
- how do i hook up a cobalt air/ fuel guage
- h22 cam id
- Skunk2 Stage II camshafts!???
- Front bumper
- Blown H22 yay! Time for a Turbo H22 build
- f22(20) - g22 help
- Balance shaft removal made very cheap!
- 4th gen climate control not working!!!!
- weird power problem
- code 9 wont go away
- What ecu?
- Air condition problem (sometime no cold air, sometime cold air....) Expert Help Please?
- The right or wrong ECU with the H22
- honda being sued
- For Sale: Alpine, Accelevision, NOS, 4th gen..
- Anyone know where to get dual dash gauge pods??
- Bad Thermostat
- For sale: Alpine, NOS, Accelevision, 4th gen...
- JDM ITR conversion headlights
- M2B4
- 1996 Prelude with Quarter Panel Rust
- H23 with H22 type-S pistons
- shifter bushings
- good shift boot?
- Anyone have an idea where this oil/grease is coming from, with PICS
- Race Batteries: Which one is a good one?
- look what header I just got :)
- Help.... how to make 5 studs my Prelude 93 H22
- Best High Flow Cat? (not for the price, just plan best)
- best tuner in the midwest
- my speedometer is not working. where on the tranny 92si is the vehicle speed sensor?
- speedometer noisy/makes sound
- which exhaust is best for a 97-01 bb6
- h22a v tec cam gears
- ecu/vtec problems
- p13 question
- doing rear pads. i'm stuck.
- '97 Prelude and '97 Prelude Type-SH differences...
- Changing rear pads on 97, dont have piston tool. What to do?
- Blue Dash Light Conversion for JDM Climate Control
- Fitment H22 header and exhaust on H23
- H22 Vs K20
- My "new" car
- Problem with steering wheel!
- lose 300 to 400 lbs?
- Energy Suspension Inserts?
- Upgraded Axels ?
- Crappy shaky rough idle when car is warmed up
- Vtec solenoid and Starter part numbers ?
- Removing crank pulley
- balancer shafts
- Sway Bar
- Lookn 4 shops that specializes on H22's
- clutch pedal wires
- I need to clean my fuel system...but how?
- h23 head swap on f22b2 block
- ATTS Fluid?
- How do you remove the e brake handle?
- Searched Already H-T:: Perfect Swap from H23a to JDM H22a
- Problem with a 1991 Honda Prelude
- Blacktrax manifold vs Euro R?
- sh?
- Ripped boot..axles
- Engine Swap
- progress springs anyone?
- misfires after a headswap
- what octane should i be running
- ignition coil test
- where and what to get catalytic converter?
- clutch will not engage (searched)
- p13 ecu pin
- brake problems
- Honda's new MTF fluid
