View Full Version : Honda Prelude
- Rotor Cap&Rotor for a Jdm H22a internal coil dizzy
- speedometer not working...speed sensor maybe?
- VAFC setup.
- WTB: Honda Prelude Red Fender OEM
- quite a few problems.. need some help
- Oil light flickering
- bought some hids from hid planet and they are different colors idk
- oil burning
- skunk2
- Ricey tail blinking on one side
- Is this a good deal?
- NRG Torque Damper.. broke on me. wtf..
- Ram air or cold air
- 89 lude problems
- 4th gen BRAKE LIGHT/ABS
- wiresize
- cant' get the prelude started! help!
- 97 lude. Cant find whats wrong
- b20a5 motors
- Going OBDI with ATTS
- Any tips on making the job easy when changing a passenger side cv joint assembly?
- hesitation, no power!!!!!!!! confused need help asap
- Help-low oil pressure and low idle
- exhaust set up
- 4th gen vs 5th gen
- code 45 system too rich or lean
- Electrical problem, 1992 Prelude, funky signal light problem, not a missing/blown bulb
- any one with aftermarket steering wheels?/no horn 4th gen
- If I rebuild by JDM H22A - what rebuild parts do I look for?
- Prelude, To buy or not to buy?
- I need help u guys....
- no torque for my lude.......
- where can i get 1/4 pnls?
- Best piping diameter for N/A
- New radiator - tell me what size!!
- rear suspension update
- should I buy jackson racing supercharger for my prelude 98?
- What Rotor Cap&Rotor for a Jdm H22a internal coil dizzy
- Haha weekend fun! (My prelude adventure)
- header with ebay cat
- backfire
- fuel pressure regulator
- Oil Pan Leak
- H23vtec Bluetop Question
- New motor startup ...coolant
- autoSUX
- need help bad
- 99 Prelude help...
- bumper got ripped off. what can i do????
- 91 lude serious questions
- confused. please help?
- Cranking but not Starting (92' lude)
- 02 sensor help?
- 5th gen ECU/taking it out???
- how to convert to manual tensioner
- Squeeky cooling fan
- turbo question regarding cams
- New "hotness" coming to an Accord near you...
- 02 sensor
- Weird Vtec problem
- B18 Greddy Headers
- vafc problem
- Which of these 2 LSD's is better???
- Disable auto lamp!
- whats next??
- h22a Turbo
- Need a picture of a 1991 Honda Prelude Speed Sensor.
- how to get CEL code from 88 lude ?
- H22A price quote please
- Prelude burn oil // Excessive Soot
- blown tail light fuse
- ecu question
- Found a smooth suspension set up!!!
- Stock header Collector size???
- not connecting the primary temp. sensor will lead to weird idle? *rare case*
- Problems after recent tire rotation / rebalance
- Wheel lug stuck!
- 5th gen Parking Lights
- Question about an adapter plate
- TRADE?????? VW GTi 1.8turbo
- Thinking about buying a 91 Prelude, but had one question
- test pipe gasket
- wrong part? need help with exedy stage 1 clutch kit
- HELP!
- crankshaft
- Threads that need to be added to the FAQ, please post links
- Transmission fluid question
- Installing Torque Dampers??????
- Rear Sway Bar (searched)
- Anyone interested in buying a 92 prelude/h22. Missing some parts
- 2 HOLES/TRANSMISSION OIL PAN/PLS HELP/99 Prelude
- VSS ABS problem
- differential
- VSS
- Help... 93 accord ex code 4 Crankshaft position sensor??
- h2b?
- BB6 Downfall - The Interior?
- timing
- thinking abuot buying a prelude....but i hear the 98+ ones havea lot of problems...
- Power steering removal
- Found this about XTD clutches
- burns oil
- H22A in a 93 Honda Prelude Si w/ H23 Transmission... What ECU do I use?
- flywheel qustion
- Car shut off and won't start
- Replacing Oil Pan Gasket
- Fueling issue
- JDM Headlight Bulb - PLEASE HELP
- clutch/flywheel combo for a bolt on turbo kit 5th gen
- fuse box diagram?
- mustang injectors?
- weird noise
- Piston Skirt Support
- oem fog light replacement
- wtb f22a1 head
- fan doesn't turn on!!!
- 0VER REViNG*SHAKiNG WHiLE SPEEDiNG UP
- valves knocking
- My Dyno Results
- Are H22A1 and H22A4 head studs the same or different?
- 1995 Prelude Climate Controls
- Open Header?
- H23 Starting Problem
- clutch question
- PLX wiring
- How can I tell them apart - SiR H22A and H22A SiR Type S?
- clutch pedal problem
- 93 Si h23 turbo help
- Trans wont line up
- f22b1 or h23a block with h22a head
- H22A4 Head on JDM H22A Block..
- I love my SMSP header - Got tuned today!
- bucket seats for 4th gen...
- Oil Pressure Switch SMOKING!
- Installing F20B DOHC in 98 prelude!! HELP
- new 4th gen headlights
- bypassing prelude immobilizer
- 97 prelude @ 3000rpm
- how to tell/identify jdm h22a injectors??
- A/C Thermostat connector?
- AEMtruPowerpulleys
- Cleaned engine bay now throwing cel 4 crank position sensor
- H22a4 Crank sensor question.
- White or Black roof?
- Will H22 motor fit trans for H23
- 4th Gen Harness Bar
- HID FogLights
- ballasts or bulb?
- 97 prelude sh vs eg ls/vtec
- JDM H22A into USDM 99 prelude base
- need help please with h22a1 swap
- shifting
- Auto to manual swap questions.
- Advance Vtec????? Post what you know about it
- Burnt Oil smell coming from sides of Prelude.
- 1997 Prelude, AC stopped working
- Just a few questions: Ignition and Racing
- JRSC install: how hard is it?
- Tranny noise LSD H Series
- after car sat for a weekend, it fired up, but stalled 3 times in a row, unless I gave it gas?
- EGR Valve... Do I need it?
- TB spacer
- vtec doesn't work
- short shifter
- crank pulley
- Dusty Headlights??
- 1992 Prelude A/C problems
- Starter cut relay pic?
- headlight disassembly question
- Mugen kit question
- 98 Pearl White Prelude 5spd
- running on 3 cylinders =X
- HAS ANYONE SWAPPED A B20 INTO A PRELUDE?
- Questions b4 purchasing 5th gen.
- Anyone messed with an inline filter ?
- 88 honda prelude
- Aftermarket Radiator
- do i have a sh???
- A/C fan level.Switched it from level 2 to level 3 and all of a sudden the engine went jerking
- JDM POWER FOLDING MIRRORS OPERATED BY ALARM
- NEED parts for a 95 VTEC.
- h22a shifter problem in hatch
- painted rims
- Does anyone know a good honda mechanic in new york?
- Front lip question
- Rear brake line picture
- Any florida guys got they're 97+ stock wheels?
- Basics
- quick sensor question <===
- help! shifter problem.
- 98 Honda Prelude
- I need to find a web site that has good JDM parts for a 4th gen
- distributor obd2-obd1 which one ?
- f23 crankshaft w/ h22a4 block
- Vent lines on MT ??
- fields VTec controller settings?
- 92 gsr running code 8 and 15
- intake manifolds...
- No Start after head swap on '91 Prelude
- need help brake lights don't work tried everything
- LED Projector headlights lifetime
- ENGINE IDEAS
- valve springs and retainers sizes???
- crank pulley instalation
- Wont Start!!!
- 5spd Reverse problems
- loose shift
- I've had problems with the balancers and various other parts...
- Dropping Gast Tank ...STUCKKK
- For the few people who had done this....
- LSD from JDM auto tranny MP1A - will it fit H23 tranny M2S4???
- si jdm turbo lude for sale, customized---New Jersey
- oil pan fitment
- Getting to 300hp+ on an H23a1
- Stupid Question 2.0: Whats the key thing on the floor?
- Will a H23A replace my H22AH as a drop in replacement
- CRANK PULLEY MADNESS!!!!!!!!!!!!!!!!!!!
- WHAT ENGINE DO I HAVE??? HELP PLEASE
- lower ball joint recall question
- h23 trany
- Trouble with f22b dohc into prelude s f22a sohc wire harness
- Picture of oil pressure switch
- Need help with ignition problem...
- Scary Noise from block!!
- jdm h22 vs usdm
- Vaccume leak/ground wire?
- Upgrading brake's. Si --> VTEC (or better)
- 99 prelude for sale!!!
- Motor delivery
- NeeD SoMe HeLp in The Tri-state area
- Power Steering Problems
- My Lude's swap is complete, JDM now baby! "PICS"
- Wierd Battery issues!?!?!?!
- Rear ended
- Motor and Tranny weight
- Help! something wrong with tranny/clutch
- NEED help I need h23 and h23 head bolt lenths
- A/C gurus I need some help again! Defrost light on /w AC light
- Help!!! WHITE SMOKE... Not blown head gasket.
- Ecu frying
- h22 vs h23 spark plug wires
- Stainless Fuel line
- Quick question....
- New 4th gen owner with questions
- Can this be bypassed?
- turbo'ing my 92si
- Best axles to use for a boosted lude?
- DOES ANY ONE MAKE HOUSE CALLS
- Sachs Clutch
- I need help with a H22a into a 92 prelude.
