View Full Version : Honda Prelude
- ecu location
- Oil pump gear, 80mm or 84mm for 1994 h22a?
- h23 oil pan
- What coolant lines are on the back of the engine block(h22a1)?
- h22 pressure switch
- Aftermarket Synchro
- 17" drag 17lb wheels, tading for 15" rota slipstreams
- Prelude F22a1 vs Accord F22b1 vs H23a1
- finding gas leak
- first time at the track...i think i need an h22 tranny
- check engine ligth flasing.
- kill switch
- advice before a purchase on 5th gen
- I just want to make sure
- JB Weld - strong enough?
- STOCK 92-96 prelude si/h23 W/O 4WS 1/4 mile?
- ECU question *searched*
- AMR Engineering Coilovers ?
- H22a swap into 5th gen
- h23 vtec question
- Omni Front and rear LCA's.....
- will a jdm h22a pass CA SMOG
- HELP ME!----1998 honda prelude help
- new valves
- external or internal coil? and why?
- what kinda motor came in the 91 thru 95 preludes..
- Problem. Speedometer not moving
- Tach bounces above 7000 rpms, drops out of vtec sometimes
- AC Removal Guys: Heater Question
- HotSHot header for hybrid swap.
- 97-up Prelude MT AEM EMS on Ebay~!
- Attempting to swap a 92 h22a and tranny into a 97 lude
- hello everyone!!!- couple of technical questions-
- replace power steering gasket
- 4th gen JDM Steering wheel (non-srs) on USDM 4th gen (srs) HELP!
- CAI thread
- Just Bought a 97 Lude. suspension questions
- H22 Manual Tensioner Conversion How Too
- best cam?
- Check enging light turns on above 35 mph??
- video/sound clip of lude w/ apexi ws/2 exhaust?
- 96 OBD1 or OBD2 ?
- removing "extra" things in the engine bay (4th gen).
- Dual valve springs...too tight?
- AC compressor won't turn on
- so I found like 12 quarts of brand new motor oil in my yard (like 10 years old). Can I still use it?
- H23 Vtec swap
- manual tensioner question
- Hood latch along with pins ?
- GC spring rates with koni shock
- H22a distributor help
- h22a4 pistons
- Passenger Door problem
- lightweight flywheels
- Hood Pins wut size ?
- Side Markers
- To those who have replaced thier main relay (4 Gen)
- F.S. FOR FIFTH GEN. PRELUDES SPOON T.B. AND CARBON BEZEL **NEW**
- Are Preludes worth it if I want a fast car?
- New seats in my 4th gen (pic request as well)
- creepy electrical problem
- mufflers
- sweet h22a pistons
- Weird noise after clutch/flywheel install *VIDEO*
- problems with h22.please help....
- Idle problem
- JDM H22a S Crank Sensor Wiring
- H22a Itbs in 99-00 civic.
- 5gen prelude turbo life
- Headers
- HOW MUCH FOR A 97 LUDE TRANNY SWAP!
- 4th Gen door dome light issue
- 5th Gen All Motor 1/4 Times...let's see em!
- H22 no vtec why??
- help me out
- questions about seats
- turbonetics & precision turbo bolt pattern
- AEM Fuel Rail and Pressure Regulator
- Idling with P13 ecu
- Light and cost effective rims
- F22a tuning info
- First step to preparing for a turbo
- F22 header question
- Accord lip kit fab
- puttin 18in by 7.5 on the 1998 honda prelude
- 5th gen alternator belt
- Anyone every heard/seen this
- Check engine light
- Jumpy Throttle
- 92 JDM h22a IDLE PROBLEM!!!!!!!
- dumb question h22 and h23 dipstick
- High Mileage Tune Up 5Gen
- 90 Prelude idling problem
- h22 with an h23 crank pulley issue
- Coolant drain plug on block
- # 8 TDC Sensor
- alternator problems
- 89 Prelude been sitting in driveway for a year
- will 01 accord speakers fit???
- H22 sensor locations (pic)
- check fuel pump
- Turbo oil feed and return
- 1990 Prelude 4WS SI Purchase Gone Wrong *main fuse*
- Right Rear Wheel Heating up!!!
- flywheel question........on the H-seris motor
- f22 or f23 into 92 prelude si?
- What engine does this header/dp fit?
- One piece headlights fitment ?'s
- fuel line clogged!
- Changing Power Steering Pump
- 5sp compatibility
- 5th gen AT/MT swap? fit perfect? costs? pictures?
- 1 peice headlights some surface
- looking for F22b info
- HID in 02 prelude
- Exhaust Questions
- Timing/TDC Question!!!!!
- comparing the RS*R Ex-mag and Apexi WS2??
- H22a JDM OBD1 ECU
- loosing coolant and overheating at idle.
- Fuel Injector Question
- Mahle Gold Pistons
- Weak door locks
- what is this part called? *pic*
- tracking down fuel leak...stock fuel pressure info needed
- how would 18 inch wheels look on a non lowered 4th gen? Will it look silly?
- FS 98 Prelude Base Rims
- New clutch
- AC Not Working.
- New balljoints
- anyone know the weights of the 4th Gen 1994 Si directional rims? Are the lighter than the 7 spoke Si
- greddy evo 2 for 4gen vtec fit si non-vtec?
- auto engine in a manual car
- gear ration question
- 97 Prelude dash lights dont work, any ideas?
- exhaust problems
- Just Got me a 97 lude!! need recomendations!
- H22 valve cover with not PCV port
- Brake pads? Searched
- Fiber-Tuned H22 manifolds...(not sure if a repost.)
- Building a B20A5 with H22 Parts?????
- aem intake
- Cleaning IACV question
- Throttle Body Cleaning
- anyone use an "F1 racing" brand clutch??
- is there a market for the 95 se 5 spoke wheels?
- Finished swap, car is running, minor problems...
- under drive pulley belt
- Torque-ing down my H22a clutch assembly
- Manual swap, any tranny?
- After market steering wheel install for 4thgen WRITE UP
- Clutch
- 4th Gen VTEC Rear 6x9 Speaker Console
- Syncros
- 1998 honda prelude
- Boosted Preluders and their numbers
- H22 cam companies?
- 92 Prelude Speedo
- Leaking Water under car by tranny
- Gonna replace my tranny
- CF Trunk **SEARCHED**
- best place to but ngk blue spark plug wires(8mm)
- best way to get crank pulley bolt loose??
- Will I lose power if I install a Turbo muffler
- 4 Wheel steer code help
- Vtec Problem, VTEC doesn't start on HP4
- swap info
- need help with idle problem on h23a vtec
- which exhaust
- car dying/shaking/etc
- Brake Pad Performance?
- Knock Sensor causing a problem?
- crower II's non-stock lobes, sometimes stalls....could it be the a/f at idle or timing?
- RWD 4th gen w/ v8 conversion.
- speed shops in CT,RI,MA area
- What happened to my belts? Possible Crank pulley issue?
- what size is the oil drain plug washer and is it a regular metal crush washer or a rubber one?
- 96 antenna mast removal
- air condition problem
- 1996 headlight issue
- anti-reversion header?
- FIDANZA SHORT SHIFTER 97-01
- Where did you get your motor from?
- Another H22A Idle Problem.
- What do you think of this turbo? is it worth it?
- A C controls question
- JDMRacingMotors.com
- H22A best exhaust systems..............
- 1st gear hesitation
- engine - body grounds!
- Maxbore throttle body
- oil feed and return
- Something Feels strange
- cooling fan stays on Please Help
- cracked coolant reservoir
- 1990 accord ex withg h22
- Anyone have pics of custom intakes they have made?
- JDM P13 from a 93 model - Integrated Circuit and Fan Timer
- 93 honda prelude radio & CD problems
- Suspension Suggestions
- IAB Question
- ??? about Crower valves....
- H22a cams in h23a ?
- quick knock sensor question, yea did some searching
- boosting the lude.. any precautions that i should take?
- engine swap
- wierdish clutch noise
- Running a cone filter with stock intake piping
- 92 si prelude crankshaft pulley?
- Issues w/ HID n headlight on 1998 prelude
- Anyone running 550f/400r spring rate on their 5th gen prelude?
- Strange moaning noise comming from under the my lude.
- Aftermarket rod bolts?
- thinking of buying a lude
- My Prelude for sale, full cream leather, honda bodykit. Located in England.
- 1994 Prelude Type S (F22) - H22 Swap - new fuel pump?
- Crankshaft end play?
- Telling the Dmv
- how much refridgerant?
- Wings West RS front lip
- Belt Size for 98 Prelude with AEM Underdrive Pulleys.
- car wont go to gear when its running
- Releasing more power
- H23a1 and H23a3 wiring harness compatability
- 1988 Prelude
- turbo kit for 99 H22a4
- Install of camber kit on 4th Gen Prelude.... I have a question!!!
- Low Idle (Tried Searching)
- VAFCs, are they all the same
- Knock Sensor
- Vibrant flat black muffler-anyone using them??
- shocks and spring install guide for prelude???
- Recommendation for a stock rebuild in so-california, Orange/LA area
- 4th gen DIY front lip
- any experiences with toyo T1Rs?
- Turbo Manifolds
- Not going in gear
- rebuild my h23 cheap....starting t knock from my nos
- WTB jdm headlights
- Mahle 11:1 or type S 11:1??
- JDM headlights installed *PROBLEMS*HELP*
- h22 in 94 accord will not turn over (start)
- Suggestion on front and rear camber kits for 01 non-sh
- 89 prelude wont start, can anyone help?
- Questions about harness on H22 5spd
- PRELUDE EVERYTHING... CF HOOD, SHORT SHIFTER, CATALYTIC CONVERTER
- 95 Accord, Jdm H22a W/ Skunk2 Intake,
- Tranny fluid?
- throwing cel #9 (cyp sensor) even after dizzy swap
- car gauges.
