View Full Version : Honda Prelude
- Qtec?
- A few questions about OEM parts
- $.02 needed for springs
- Couple of dizzy questions
- Lower Balljoint
- Reverse glow gauges
- Anyone with a 97 Accord put in the Sk2 manifold yet??????
- radiator help! 95 lude
- Drivers side door panel
- Tranny rebuild
- NO power & BAD gas mileage
- What header is this?
- oil smell :(
- will the m2ua h22 sh tranny work without using the atts??????Help???
- Registering a 95 Civic with a H22 Swap
- Turbonator bolt on supercharger any good?
- what should i do?
- removing a cai filter, is there an easier way?!
- Engine problem
- sparkplug question
- what is the difference between a h22a tranny vs the f22
- I have a question about the Prelude Type-SH's Limited Slip Differential
- Intake filters
- dc sports water pipes.
- 92 SI Broken Timing Belt---Newbie needs advice
- Radar Detectors
- ENERGY SUSPENSION MOTOR MOUNT BUSHINGS
- A/C fuse and a/c schematic
- need help with timing where the seeting go exactly
- h22a tranny question-need help
- For those of you that have had your engine on a engine stand.
- Engine Swap with 4ws
- Crower 4340 Billets vs. IB Spec Rods
- Skunk2 Mani and Hondata Gasket
- Does a defective EGR valve affect the idling of a car?
- back seats
- CAI question
- Resonator removal
- Automatic Drive Train Loss
- manifold question
- h22 head on a h23?
- h22 automatic (usdm) to h22 5 speed (j-spec) engine harness problems
- H22 Tranny Problem
- how long can a stock lude take a 75 shot of nos ?
- What happened to my post?
- Preludes love Air
- error code 12
- 4WS alignments
- H23 compression results..
- 5th gen wheel fitment
- 92 frontend match with 93???
- 1995 Prelude oil pressure problem - need advice (please?)
- whats the best way?
- Skunk2 intake manifold install pics/guide
- Question about dashboard shipping...
- For those who HAVE installed their Skunk2 Mani.........
- How can you tell if a 96 p13 ECU is JDM?
- Anyone installed a vafc 2 on a 4th gen?
- hole in my intake
- H22 Swap with H23 VTEC solniod help and oil pressure sensor
- good place to get a type s or h22 with a lsd tranny
- Best choice intake?!
- SPEEDOMETER NOT WORKING PLEASE HELP!!!!!!!!!!!
- Torque Specs ??
- vss h22a
- I am have some strange noises
- Can anyone tell me why my lude is running like it is? details inclosed...
- to those who shift past redline
- A/C Relay???
- HELP needed on headlights!!
- Manual Belt Tensioner
- torque specs for TB and Valve cover
- 97-00 brake booster size
- S2 IM & PR solid mounts installation pics
- backseat
- Need a little help.
- Does anyone know the EXACT weight of a 95 VTEC prelude?
- Performance chips?
- Whats the best way to ship a bumper and hood from CA to CO?
- Low mileage 2001 SH or Mid-mileage 2000 base
- FS: Rare 1988 Prelude Si coupe with JDM H22 185 whp! (Wisconsin)
- How does a 9260 rpm over-rev on a bone stock internal H22A sound? :-(
- Type s?
- Looking for car tips: Honda Prelude Si against Toyota Celica GT/Eclipse GST
- How Much Nos?
- replacing head gasket, should I shave the head while I'm at it??
- Running rich............
- Climate Control won't light up?
- Car will not start, it is fuel related.
- Possible Honda-Tech meet for the TN/GA/NC/SC area?--Prelude
- sticking injectors...what would be the outcome?
- Transmission? Clutch? Something else?
- Exhaust Setup
- how long do koni yellows last?
- H23 head on F22?
- Most Power for the buck
- type s performance
- Check Engine Light please help!?!?!?!
- will a fwd 3.2L accord v6 fit in a 92 prelude?
- Jasma Header fit on a 99 Prelude?
- Radias Rod Poly Bushings?
- cruise control
- Turbo people, location of Power steering cooler?
- Help Me
- MY right headlight keeps killing bulbs, help please!
- is this a jdm engine code
- Front Passenger Headlights Is Discolored (yellow)
- Transmission swap Help
- smoke/burning smell from under the car....
- VIN Info How do I tell if My 92 lude is an SI or not?
- Carb to FI Swap
- What is the ceiling on NA power?
- Prelude SH and non SH.
- Good place to buy a used or new converter for an A4 88 Prelude
- JDM H22 beat me =(
- 350 in a Prelude
- H22 Head Swap to H23
- engine is sputtering at high rpms i have a supercharger any thoughts
- can someone take a picture for me of their 92 prelude.
- Engine mounts in a S model vtec... 1992
- just got my block back
- performance parts?
- ecu question
- 91 engine swap
- egr valve question
- left coil overs squeaking
- PLEASE STOP LOCKING MY THREADS!
- Help me troubleshoot my prelude, h22 swap won't start
- 2point6's Skunk2 manifold second go...
- injectors and resistor box / h23vtec
- Prelude Rim Weight
- fastest 5 gen. prelude on the east coast
- To those with skunk manifold
- I have this hissing sound...
- Smacked a curb, bent something, help me figure out what.....
- B-series TB on H22 manifold
- Autotensioner Bolt
- DFW,Texas shop opinions
- Computer system for 5th gen. lude
- Lost Motion thingy?
- maintenance questions
- Diff between 98 and 99?
- where is the oil press sender on a 2001 prelude?
- h23 + pauter rods = notching?
- 18 x 7.5 wheels on a 4th gen
- Quick QUestion about Turbo Parts for lude???
- Wheel Off Set Size For 00 lude
- Should i buy this prelude?
- How much should I expect to pay for this Prelude?
- biggest engine in a 92 prelude
- 4th gen climate control....recalls?
- gauges quite, car won't start! wtf?!?!
- pre 92 lude?
- new to preludes got a 2001 sh and need some info
- no tail lights or dash lights, help need fixed by sunday morning.
- Rear camber Kit or Washers?
- Exhaust installation
- Intermittent starting problems
- IAT sensor???
- Please, need some help
- atts
- Gen Battle
- h23 rods
- Looking to buy a '98 lude
- Newbie wants to know 1/4 mile times
- Suspension setup for 92 Prelude
- synthetic oil spill on timing belt ..Dangerous?
- OneFAB Prelude H22 Setup
- cant seem to get aftermarket injectors to seat properly.
- i Combined the threads, JDM h22a Swap(manual) into 92 Automatic Prelude S.
- Intake box in fender?
- Prospeed header installed *pics
- Unknown Solenoid on H22A swap. Need help!!!
- Would a 92-95 Prelude be a better daily driver than an EG hatch or DC?
- Sparco seat install Q:
- suspension pics
- Prelude Factory Stereo...anything beat it?
- Good OEM Prelude parts sites?
- Spoon Chip P13 Chip
- What size pipe ?
- blown headgasket/motor?
- i want to purchase a prelude
- i got a 96 vtec Lude!
- slave cylinder/clutch release fork question
- car is overheating at idle...fans not coming on
- Tranny noise.....noise record included
- Hitting up the strip next week, suggestions comments?
- how do you install a clutch pedel, brake pedel and gas pedel assembly??
- SH ppl
- Air/Fuel ratio question...
- NEED '98 prelude wiring diagram for the passenger door!!!!!
- new problems have arisen (clutch question)
- SUPERCHARGER!!!
- hit vtec, threw code 8
- Looking for 1998 BB6 short shifter!
- Broken timing belt damaed the engine
- just drained transmission and refilled with 3 quarts??
- H22a swap wireing ?
- JDM P13 CEL - 4ws
- help!!
- installing vtec sub in si
- Temp Gauge Not Working
- my headlights don't work on my 93
- Where can I find a stand alone fuel management system?
- DC sports H22 Header...
- anyone have pics of their interior after converting to manual.
- how hard is it to run shiftlinkage in a 92 lude.... i want to convert it.
- new auto tensioner kit
- 92 prelude, automatic.... is it hard to convert over?? i am putting a Jdm h22a engine in.
- WEIRD story
- weather stripping is coming off.
- Euro R vs. Skunk2
- Is my car an SH?
- 5th gen front plate
- I'm going to buy a turbo for my 95 Prelude, I would like advice.
- Dropping a Car
- Clutch pedal spring. How to put it back in??
- Where can I download honda manuals
- Help with H23 Vaccum lines
- 89 Prelude thermostat
- Euro R help
- need quick timing belt help ASAP!!!
- 97 honda prelude sidemarkers
- For all you guys in California who have hiflow cats...
- Lights dim when powering windows/ac/stereo.. normal?
- Brake problems!
- Swapping H22 into my 92 with the f22 motor.
- adjusting manual tensioner
- What should I do with my car?
- Automatic Preludes
- grinding in 5th, hard into and out of reverse on m2b4
- 96 h22 swap!
- JDM H22A Swap, Coil Problems! Please Help!
- H22 Skunk2 Manifold pics and inner shots! Measurements too! Hondata Gasket!
- stereo problems
- MPG, or gas mileage on an FI h22 engine
- Wheel/Tire fitment on 4th Gen VTEC Lude
- Leaking roof and trunk. Anyone find a fix??
- Number One Exhaust System...Good or crap?
- vortech supercharger opinions
- WHAT IS WRONG WITH THIS????????
- I Would Be Much Obliged: ATF Replacement
- fuel pressure guage question..
- What is the main limiting factor in a k-series swap?
- looking for crank pics...
- RWD Prelude
- 3rd Gen Prelude 4WS-Si Questions
- Removing Power Steering/AC
- is a chamber kit necessary?
- P13 Mugen Chip
