PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 [234] 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Spring ratings on ground controls?
  2. Got screwed on my tires, need some help for new tires
  3. info on a prelude??
  4. Can;t adjust FPR
  5. Compression Test results
  6. Clutch problem
  7. Stock Pressure plate PSI?
  8. stupid question, did you have bearings in all the holes for the balance shafts?
  9. slamed lude
  10. cam belt slider
  11. A question for 2point6 about manual tensioner
  12. recommendatoin's on ALL SEASON tires?
  13. can't post in the other forum section so..
  14. Sway Bars... yours?
  15. Did a search could not find topic about aftermarket radiator hoses.
  16. Polishing throttle body?
  17. jackson super charger?
  18. HID ballast placement
  19. help, jack stand placement
  20. anyone know who sell aftermarket final drive for h22??
  21. Question about the Tien S-tech springs
  22. Does Prelude type-s come with atts ?
  23. Which motor?
  24. Removing A/C H22A4; Recomended Belt to use & part number
  25. 97-01 crankshaft
  26. which longblock ??
  27. on h22 oil pan does the flywheel cover/guard go on before pan goes on...or after?
  28. Timing belt Install
  29. How much would you pay for..?!
  30. will VAFC2 remove my speed limitor?
  31. ACL Bearings for 2001 Preludes
  32. pistons
  33. Help needed, master cylinder or slave cylinder?
  34. 92-95 h22 crank vs 97-01 crank
  35. Upgrading Rear Spring Rate?
  36. Hey Prelude enthusiasts. Help me out..
  37. What Can I do to a 88 lude?
  38. h22a turbo/hatchback... how much boost can it take?
  39. Do I really need this?
  40. sleeved blocks
  41. Head vs. Head - USDM & JDM
  42. GLASS Sunroof for a 4G Lude?!
  43. Vacum leak... wheres all the places to check????????
  44. need info on replacing parts in jdm distibutor
  45. Steel wheel interchangeability for Gen 3 Preludes?
  46. im lost......
  47. Sup to everyone, New to Honda-Tech
  48. sohc motor ina prelude????
  49. Magnetic trans/oil plug?
  50. tires...what brand? size?
  51. Prelude anti-theft stereo/ignition
  52. Track data analysis
  53. Carbon fiber hood fitment is way off.
  54. Under Brace??
  55. Question on Audio
  56. Helms Service manuals
  57. Ignition Switch problems......Master Techs help
  58. H22A4 bearing clearances
  59. Overheating on a track (pics)
  60. any difference between 97-00 h22 header and 93-96 h22 header???
  61. h23a vtec jdm accord
  62. what pistons can i use na?
  63. tranny, clutch, flywheel?
  64. is gettin a chip worth it?
  65. question about service light
  66. Car won't start
  67. Clutch Dampener? How does it work?
  68. Clunk on passenger side rear??? need some help!
  69. Clutch master cylinder?
  70. unorthodox pulley ?
  71. Yok. AVS ES100
  72. Someone with a 5th gen helms- please.....
  73. NEW TO THE PRELUDE !!!
  74. Where do i add trans fluid at??
  75. Which helms manual to buy?
  76. bogarts...smallest size for 92-96 vtec lude....?
  77. Prelude 0-60....
  78. Motor Mount ?'s
  79. Doh! My cams aren't crower stage 3 cams
  80. Front Clip website
  81. Cleaned the Lude's engine bay over the winter...
  82. awesome deal
  83. what ecu is recommended? hondata? or what?
  84. horrid idle
  85. Am I crazy? (97 vs 95 VTEC)
  86. What to do next? -95 Prelude H23
  87. where is the injector resistor box
  88. When is someone going to make a 4th gen mugen replica body kit?
  89. compression test results
  90. Price Check: 1992 Prelude w/ New(er) Vtec Engine installed, new(er)Power Train, etc
  91. Idle question....
  92. Turbo SH???
  93. problem with obd1 greddy header on SH motor.
  94. H22a Hondata Maps
  95. Best Cams for H22A4?!?!?!
  96. vtec motor, non vtec tranny???
  97. Diagram of H22 harness
  98. strength of frm sleeves
  99. starters
  100. Safe REV limit with Mugen chip???
  101. h23a1 crower stage 1 camshafts
  102. Where to Corner Weight my Car?
  103. b-series tranny on h-series block....more gear ratio choices
  104. Tranny and Differential assembly
  105. Aftermarket Gear Selector Lever
  106. Have you run a FMIC with the stock 4g front bumper?
  107. CROWER turbo cams on non turbo motor?
  108. secrets for you 5th gen lude
  109. Cat flanges
  110. Replacing Oil Pan, anything else while I'm at it?
  111. h22 h23 ridiaters
  112. Question about 1992 Preludes
  113. aftermarket performance calipers on stock 5th gen rotors..
  114. After clutch install question! ACT HDSS
  115. JR NGK ZFR5F 11 Spark Plugs
  116. WILL A 94 TRANSMISSION BOLT UP???
  117. edm kit
  118. H22 Swap QUESTIONS NEED HELP!!!
  119. h23 harness with JDM H22a
  120. changing pistons with block still in the car.
  121. will 35 offset work on 97...
  122. Hi/Low beam harness
  123. Camber Problems
  124. Who bought my stock h23a rods? - Daniel Held -
  125. how to take off the halfshaft on a 1998 sh prelude?>
  126. P13 vs. Hondata
  127. 4th Gen Jet Washer : Nozzle
  128. For turbo preludes...whats your timing?
  129. For those with LSD
  130. suspension. skunk2 or neuspeed race
  131. Need 4th gear ratio, and final drive ratio for 95 H23A Prelude trans.
  132. Clutch Slippage?
  133. Cometic Head Gasket
  134. Leak down tested 90% leakage???
  135. need a good diagram on wireing vtec in a 92 si
  136. can i lower my car alot on 215/40/18's?
  137. Car problems
  138. Knock sensor question
  139. how to remove....
  140. Individual throttles for the H22
  141. still failing emissions
  142. GM synchromesh questions...ergent!
  143. Auto tranny, need help big time!
  144. 90 si gauges dont work!
  145. newbie here..need some advice/input
  146. Bicycle Racks?
  147. found real short shifters for 5th gen Preludes???
  148. Koni full coilovers
  149. '84 Prelude - swapping auto tran for manual
  150. Please help me!!
  151. 215 Azenis on stock 16" wheels
  152. gas/engine lcd gone bad?
  153. help with the aib
  154. VAFC and VAFC2 wiring the same?
  155. Anyone using the chilton repair manual?
  156. pulleys or exhaust?
  157. Code 12 and code 22
  158. Do any of you guys know if MagnaFlow mufflers must be welded?
  159. compression checks
  160. 4Bidden short shifter 5th gen
  161. Valve Specs for H22a??
  162. where can i get a tranny swap in so cali?
  163. need tire size advice
  164. Details on 5th-gen 'noise cancelling' stereo?
  165. PC9 and FRM
  166. Mid Pipe Fitment
  167. Are my KYB AGX shocks blown??
  168. crower stage 2? going to buy and looking for some input
  169. hyperground wires...
  170. electrical problem....
  171. Is a Aftermarket flywheel worth it?
  172. HELP!!!! car wont start
  173. engine check light
  174. wtf is this
  175. Running rich, do I NEED a fuel rail and FPR to fix on a dyno
  176. broken knock sensor...
  177. Engine Management?
  178. SRS light!!
  179. clutch spings?
  180. Springs
  181. Euro-R Manifold
  182. Prelude suspension question....
  183. difference between years?
  184. Interior swaps?
  185. look what on the vortex
  186. Spark Plug Recommendations for 5th Gen
  187. aftermarket LSD
  188. PVC problem, brand new engine.... help.
  189. Where can I find this part for my prelude?
  190. vtec not working all the time and no codes.
  191. Intake Pipe
  192. C & R radiators for sale for 92-96 Prelude
  193. Vafc 2 / Vtec crossover
  194. rc injector + safc
  195. Wheel sizes?
  196. What to mod first
  197. Where to find a RPS Clutch?
  198. 15.1 before VAFC 15.4 after.......WTF?
  199. h23 to jdm h22a swap
  200. H22 Oil cooler?
  201. which turbocharger on???
  202. alarm questions for 01 prelude
  203. Removing Axle from ATTS unit
  204. ..:: DIY o2 simulator install::..
  205. 90-91 Prelude Front lip addon help
  206. problem with SPC sliding balljoint camber kit for 4g...
  207. Seccondaries not engaging? (Vtec not working)
  208. JDM ECU OK?
  209. popping sound from intake
  210. H22A Wire harness
  211. IF u give it gas, it dies, please help
  212. How should i tune for TURBO!!
  213. Modest Turbo Buildup: Which is more important
  214. Need a throttle body picture
  215. Temperature Guage Gone Bad! What Are Possible Solutions?
  216. New to Preludes
  217. How many of you use a "stock" P28 with your H22???
  218. independent throttle bodies for 5th gen
  219. 5th gen sidemarker placement
  220. Clutch still slips?
  221. Idling very low.. vibrations as well
  222. Hondata s200 and 98 Prlude Q's
  223. Syncromesh w/ locked out reverse
  224. All motor question about fuel
  225. 5th gen tranny q.
  226. installed tein s springs...
  227. rear shocks replace
  228. If I were to sell my 18" Gunmetal Volk Racing GTPs...
  229. APEXi....VAFC 2.....How to use properly??
  230. What do you guys think of....
  231. wondering if a cyclone motor would fit?
  232. prelude type-s cams
  233. greddy evo exhaust
  234. High No PPM
  235. Hondata/Ecu swapping
  236. (4th gen) 5-speed swap - any firewall modification required?
  237. Switching Springs on a 86 Prelude Si
  238. Please help me identify the flow of these injectors
  239. spoon prelude??
  240. Does the type-s pistons fit directly into a 1996 not JDM H22 engine?
  241. Pictures of JDM power seats in 4 gen!!! I never seen it before...
  242. prelude ecu pinout
  243. taking belt off balancer
  244. bad knock sensor(searched)
  245. bumper lights
  246. What size bolts?
  247. Where to get a o2 sensor for cheap?!
  248. Prospeed Header installed
  249. What kind of intake?
  250. h22 to h23 tensioner question
