PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 [72] 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. Shop location
  2. MSD Ignition
  3. motor in... shift linkage problems?
  4. clutch master/slave cylinder
  5. clutch?
  6. Emblems? How to remove?
  7. How do you remove the rear seat?
  8. How good of a compressor and impact wrench....
  9. HELP!!! ABS or ATTS or ECU?? type s
  10. P0A vs P0B ECU
  11. Max weight capacity
  12. WORLD SUSPENSION BALL JOINT WARNING
  13. h23 crank in a h22 compression?
  14. car won't crank....battery???
  15. Throttle body ?
  16. 5th gen 5spd swap (4th gen parts???) searched!!!!!!
  17. Tein S techs
  18. is this H22A OBD2A or B
  19. HP Gain?
  20. Brake Light
  21. Nasty Sputter at idel/searched
  22. NEED HELP!!!!
  23. misfire cylinder 1
  24. H23 Connecting Rods
  25. NRG Engine Damper
  26. H22 Prodrive Final Drive
  27. how to tell if i have had a swap done???
  28. halos and HIDs
  29. ^^Timing belt purchase^^
  30. Injector differences between OBD1 and OBD2 - do i care?
  31. Strange Alt and battery readings
  32. fuel system
  33. 97' sh wiring harness
  34. K24 into 94 vtec
  35. will a prelude steering wheel from a 5th gen fit accords?
  36. buyin new car. help!
  37. Front spindles
  38. anyone have 93 lude underdash fuse map?
  39. does 90-97 Accord shocks fit on a 97 Prelude???? Please help!!!!
  40. Posi quiet brake pad by Centric
  41. easiest way to replace timing belt?
  42. S2K antenna
  43. how do i make my car run leaner
  44. please help me with my headlights. not working?
  45. Do h22 and h23 share the same valve seals
  46. 1989 Prelude glove box question
  47. h23 is running bad.hesitates,idle sticks and low idle
  48. transmission oil
  49. need help a.s.a.p
  50. supertech valvetrain
  51. real mugen shiznit
  52. Attn: 5th Gen owners --- How many kms before you change the oil?
  53. Are there any accessory (blank) fuse slots on the 4th Gen Lude
  54. Sick Looking Prelude...what's on it?
  55. 99' prelude swap
  56. H22 Valvetrain
  57. Does a stock P14 ECU support VTEC
  58. engine miss when cold
  59. jdmtigerjapanese.com any good?
  60. F20b into 4th gen swap questions
  61. tokico white or blue?
  62. jdm and usdm p/s pumps
  63. Fuel Injector problem (will not start, fuel injectors dont fire) need a master tech for this one.
  64. 92 Head Vs 99 Head on an H22A4
  65. engine help!
  66. Any input is appreciated...
  67. how do you take off the...
  68. Spoon strut bar for 4th gen?
  69. Know how to install jdm garther's tv?
  70. ==Timing belt quote=
  71. preludes boggin out at 3000rpms on h23
  72. 3 inch exhaust on h22a stock
  73. JDM vin
  74. no spark ! not grounding? please help!
  75. Any Difference between fuel pumps?
  76. ATTS Do All Type S Preludes Come With It
  77. 5th gen passenger side mirror
  78. Vtec Controller
  79. New headlights
  80. 96 jdm prelude injectors
  81. stg 3 clutch really make car slower?
  82. sh/base exhaust
  83. how to tell if a intermediate shaft is bad?
  84. 4x6 instead of Tweeters?
  85. skunk2 valves
  86. 97 sh motor, what goes here.....
  87. VTEC problem
  88. high flow cat/battery issue plus other
  89. here is the solution to your problem
  90. is it my clutch master or slave cylinder?
  91. where can i get the aluminum wheather stripping in between the boor and roof
  92. pictures in older threads?
  93. AC Removal
  94. H22/H23/F22 IACV Deletion How To
  95. H22 Ticking/Knocking Noise
  96. 1 st gear
  97. what spark plugs are u running and why????
  98. quick question
  99. ITR spoiler
  100. oil light flickering problem...
  101. LSD Options
  102. Are these type s pistons ebay junk??
  103. Hmotors no longer carries oversize type s pistons!!!!!
  104. what would be easy
  105. headgasket question
  106. anyone back with the prelude?
  107. wheels and tire ?
  108. HP Vgen. JDM parts in Bangkok
  109. h22 swap distributor question
  110. Need help fixing prelude issues
  111. missfiring h23 after bent plug change
  112. apexi gt spec vs N1
  113. big wiring problem!!!
  114. 4th gen prelude exhuast differences
  115. ATTS light
  116. JDM headlights PROBLEMS!
  117. IACV blockoff plate??
  118. p28
  119. (((Noob question about muffler)))
  120. 97-01 Honda prelude sh or base engine differences?
  121. Cool color for control arms?
  122. 93 Vtech Electrical
  123. any difference between jdm and obd1 dizzy's?
  124. jrsc
  125. crower stroke kit son
  126. did all 97-01 preludes have h22's?
  127. want to know if any accord axle is ok to use?
  128. wiring harness
  129. How much faster is a jdm h22 than a usdm h22?
  130. What size air filter for an H22?
  131. h22a4 turbo vs. supercharger
  132. Quick M2A4 Tranny Question
  133. every place wants...
  134. Tein Basic damper
  135. H23 Manual Tensioner on H22A
  136. need help on coilovers
  137. Car Stereo Devise Powering Question
  138. need answe for dumb B20 question
  139. catch can hose
  140. for the 5th gen exhaust....
  141. h22 rod bearing question
  142. From 43 to 41
  143. stripped 12pt headbolt
  144. part identification
  145. clutch hydrolic problem plz help
  146. Oil leak please help
  147. crosshatch?
  148. cf trunk
  149. quick suspension question
  150. Coolant leak, engine bay steam
  151. Radiator Fans and A/C fans
  152. reading consumerguide.......
  153. H2B in a BB6 prelude
  154. Megan Header
  155. Lots of smoke coming from exhaust and black buildup on bumper...
  156. funky smell
  157. Help With My 97 Honda Prelude Sh!!!!!
  158. Need Major Help
  159. Injector Choices
  160. 5th Gen short throw shifters/adapters...what's the best?
  161. Camp1320 Header 5th Gen
  162. Is this true? Do all Preludes have...
  163. Need Help With Distiributor....
  164. oem front lip off of ebay?
  165. adjustible fuel pressure regulator help!!
  166. Rebuild parts. Have I covered everything?
  167. help...asap....please...
  168. what's causing this???????
  169. F23A into 4th gen Prelude, anyone have experience with this?
  170. Intake Manifold/Purge Flow fault, need some advice
  171. What is the gasket behind the oil filter "adapter" called
  172. Couple questions: Engine ticking after valve adjust. and Swaybar comfort
  173. 4th gen. driver's seat
  174. h23 vtec + type s pistons
  175. Cyp sensor in 95 integra ls
  176. instrument panel
  177. just done 5th gen auto to manual swap
  178. Vibrant Flat-Black Muffler a little too Loud!!..
  179. NEW oem parts through honda?
  180. post your broken axles hp. level
  181. Grilles: 97-98 vs. 99-01/ does Honda even sell the 99-01?
  182. vafc2 vs. safc neo
  183. installing a timing belt, tentioner question
  184. turbo kits for sale???
  185. hood question
  186. need some help plz
  187. idle lope question
  188. need h22 service mannual
  189. Are front seats interchangeable between 3rd gen. and 4th gen. Preludes?
  190. Tire Size?
  191. could a cold air intake have anything to do with a bad ilde surge
  192. Was tearing down an engine i bought when i find
  193. h22 cam install question..help please
  194. H22 Head: Euro or USDM?
  195. Front end vibration after replacing CV Boot on 99 Prelude
  196. ebay's MEGEN strut bars/ignalls dampener
  197. Prelude quarter panel rust repair
  198. can someone please tell me plug wire sequence
  199. Can someone tell me what bodykit this is?
  200. Need help with my 98 prelude auto transmission
  201. exhaust
  202. Batter Question
  203. wet back seat
  204. got a problem wiring vtec...
  205. Should i trade for a 5th gen prelude
  206. prelude exhaust
  207. just a question about Aftermarket underdrive pulleys
  208. CF hood
  209. IACV Problem
  210. weird spark plug problem.
  211. piston sticks out
  212. can i put a h2.2vtec haed on my 2.3
  213. 1989 20si problem
  214. oil on 2 sparkplugs?
  215. Brake Lamp and Trunk Light on after CF swap
  216. weird (flat tire) sound when acclerating
  217. map sensors differences across prelude models
  218. radio code
  219. spark plug gap prelude
  220. how my weekend went....
  221. Oil in radiator...
  222. Idle air control valve
  223. 5th Gen Prelude Immobiliser Query
  224. Bad Differential?? Mystery Problem, Throw an Idea!
  225. Making room for subs
  226. JDM swap help!
  227. Voilently noisy start up!
  228. custom turbo kit?
  229. transmission identification
  230. Rebuild or Replace h22a4 longblock <-----------
  231. oem lip kit
  232. is my h22a block from a prelude or an accord sir?
  233. replace windshield weather stripping?
  234. dented door
  235. Changing Intake Manifold Gasket
  236. Replacing Factory Stereo
  237. My girlfriend lost my keys....#@#*
  238. Major oil leak!!!! Oil pressure switch??
  239. Huge oil leak??????Please help!!!!!!
  240. transmission help
  241. Dashboard Conversions ?????
  242. quick b20a prelude questions
  243. I want to covert my bb6 to OBD1 completely
  244. radio code ?
  245. alternator on 2000 prelude
  246. Question on ebay suspension tenrai Sr
  247. timing belt ?
  248. Electrical Troubleshooting Question: Battery power source???
  249. Will 4th gen Rack&Pinion fit 5th gen PRelude?
  250. 5th Generation Prelude Carputer
