PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 [130] 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. FITV repair (does coolant system need to be bled afterwards?)
  2. Is my alternator going bad
  3. smoke issue
  4. ECU problem
  5. Anyone with D2 coilovers???
  6. do 5th gens have factory oil coolers?
  7. greddy header california legal?
  8. Please read and reply!
  9. How many miles on your H22s?
  10. Hondata S300?
  11. How much oil?
  12. 97-01 JDM Type-S Steering Wheel Install
  13. Apex turbo N-1 muffler
  14. Pilot Bearing?
  15. tuning with MSD SCI?
  16. JDM H22 Swap - A few problems!
  17. How to tell whether it is base or Si, 1992.
  18. a RH 5 lug wheels
  19. Universal or direct fit
  20. Honda Heat Gasket!!??
  21. sometimes car stalls out at idle.....how to fix this??
  22. I need some help please
  23. Valves ?
  24. rpm/speed related question
  25. code 7..how to fix
  26. GreddY Turbo Kit on 4th Gen
  27. Electical ISSUES! help!
  28. SH rims
  29. How can you wire your JDM fogs to come on with your headlights?
  30. cant find the plug end of the injectors wire
  31. mounting JDM fogs
  32. Climate Control..
  33. F and H series alternator
  34. For sale: '92 Lude w/ H22A swap
  35. witch type of LSD is the one of the SIR S-Spec ?
  36. Hondata S300
  37. bb6 prelude vs. dc integra Gsr? (Need your knowledge!)
  38. Clutch switch going out
  39. Knock Sensor. [I searched :( ]
  40. Opinions Please . . . (About buying a used car and some other stuff)
  41. brake fluid leaking from under lower rad hose
  42. So I custom mounted some CF aero mirrors on my 4th gen--
  43. 89 lude, runnin problems
  44. polishing rims, but w/o wetsanding...best product(s)?
  45. I'm running on 3 cylinders, why?
  46. h22 head f22 block
  47. Vtec Sound/scream dam!!!
  48. tranny problem
  49. fuel filter change
  50. wwrs front lip painting
  51. FS prelude parts
  52. accord rear lip on a 4th gen
  53. Removed AC...can i remove the fan that is on the drivers side ?
  54. Crazy electrical issues! Help please:
  55. Car wont start
  56. Problem with My Exedy Three Puck Cerametalic Stage 2 Clutch
  57. Radiator cap for Koyo
  58. hub and quick release fitment ?'s
  59. 5th gen water in trunk
  60. How hard is to remove the VSS?
  61. Honda Remanufactured Calipers for 5th Gen Preludes
  62. Pressure Regulator Cutoff Solenoid Valve ?
  63. Distributor Problem?
  64. pic request
  65. Motor Mount Problem??
  66. Oil pressure gauge readin???
  67. Euro-R Pistons
  68. 16'' rims on a 4gen pic request.
  69. dvd playa
  70. rs-r or invidia
  71. scion tc seats
  72. Help! h22 cuts out at high revs
  73. Aftermarket motor mounts?
  74. JIC Coilover owners on 5th Gen ludes ?
  75. do 98 ludes come with a resistor box ?
  76. Should i remove heat sheild ?
  77. Need some input . . . (Purchasing used 3rd Gen Prelude)
  78. 4th Gen Radio Install
  79. prelude 92
  80. jdm headlight hid conversion
  81. H22A injectors what do i need???
  82. I don't know how manyof you guys check out the appearance forum so....
  83. JUN cam gears, any markings?
  84. getting a atts tranny to work on a h22a
  85. 4x114.3 16" rota slipstreams 450 picked up
  86. Momo Hub/Wheel Install
  87. NOISE IS DRIVING ME NUTS
  88. help! with fuel rail
  89. rattle
  90. just put a h22 in my eg coupe
  91. taking off 5th gen fender
  92. Engine or tranny?
  93. Square entry bolt on the side of tranny. (searched already)
  94. Problem with low fuel pressure
  95. destroked f20a f18a f20b (destroke destroking) h22a h22 h23 whatever
  96. B series tranny on a h22
  97. map sensor question
  98. Adjustments for H22 JUN Cams
  99. 5 lug conversion/searched
  100. Spoon Sports Front upper Strut bar?? Questions
  101. Wierd rattle when start up?
  102. shift cable replacement
  103. Cleaned EGR, now eratic idle and ticking - Help!
  104. Anyone tune/swap into an '86 Lude?
  105. Main Relay Compatability
  106. timing belt change. Auto tensioner install help
  107. Splash guards
  108. voltage stabilizer
  109. a/c
  110. Q prelude running rich?
  111. overrev problem(car feels slower also)
  112. how the hell did this happen?
  113. WTF!!!!! shock tower
  114. What type of exhaust is the best for a 99 prelude non sh
  115. powersteering pump bolt **searched**
  116. what FULL coilover set do you have?
  117. GAS MILAGE...lookin for new car, curious
  118. a/c restoration problem!
  119. sudden loss of power/shut down
  120. Brake bleeding order
  121. Fuel Pressure Reg. Question...
  122. 4th gen giving me CEL
  123. cam gear
  124. CEL 20 Electric load detector (ELD) & 23 knock sensor - how to fix?
  125. just installed crowerII with skunk gears and dyno tuned - number seem too low?
  126. trouble installing springs
  127. Going from P13 to P28 (with H22 map)...what else is needed besides just plugging it up?
  128. 95 Prelude real JDM brake pads
  129. Help with O2 sensor! urgent!!
  130. base prelude info
  131. cams?
  132. prelude sh?
  133. quarter mile time
  134. 97 Base Boggs thru turns at wot, any ideas?
  135. H22 Intake Manifold install skunk 2???
  136. Head Gasket Question
  137. Greddy Turbo Timer help
  138. Anyone knows what these wheels are???
  139. Knock/Map sensor problems???
  140. Looped lines now check engine and ATTS lights
  141. Quick Question
  142. Anyone had the This Throttle cable Problem...5th Gens
  143. Clutch problem??
  144. ? on the converting SH suspension to base
  145. steering wheel hub
  146. 91 civic si skunk2 coilovers fit 95 lude?
  147. signal problem...help!!!
  148. fan relay switch
  149. search already need info will f22a1 head fit on f23 nonvtec block ?
  150. boosted problems
  151. BB6 Black housing headlights
  152. Koyo by surprise
  153. Sell or Rebuild????????
  154. ECU for F22b1?...
  155. EL gauge install questions
  156. Best ram air hood for 5th gen?
  157. Can i put this on a BB2 prelube
  158. relay location question
  159. Exhaust??
  160. Oil Change Gone Wrong
  161. What kind of harnesses/color should I get?
  162. Noticeable Performance Gain in Removing A/C?
  163. is it possible to...
  164. buying a 91 prelude 200k mileage X'(
  165. 92 prelude swap problem?
  166. Engine Mounts Going Bad?
  167. OBD2 P13 ECU question
  168. 4th Gen Prelude CEL Blink Code (Video)
  169. 97 Prelude AC Problem
  170. Need advise on a tranny situation with warranty
  171. 4 point harness question...
  172. h22 stock piston/ring installation
  173. tranny still ok after accident??
  174. 2nd gen swap(87)
  175. aux input installed: problem
  176. H22 pistons in H23
  177. 97 Prelude Issues
  178. H22a into F22a1 4th gen S... Questions
  179. Wiring JDM 4gen fogs?
  180. NPM06 Pix?
  181. Where i can find oil filter part #?? (searched)
  182. Does anyone know if there is a turbo kit available for my Prelude?
  183. header heat shield
  184. Oil filter for 97 Lude
  185. jdm clear corners on black housing?
  186. car shut off while cruising
  187. OEM or MOROSO oil pan which should i use
  188. clutch problem on 98 sh
  189. is there anything you have to do before put on a new headgasket
  190. diagnosing ABS on a 92 Si?
  191. Removing high pressure power steering line from rack
  192. anybody on here rocking a spoon axle back?
  193. Back from the Dyno(JDM H22)
  194. cold air sucked in water from semi deep puddle, clicking in engine now
  195. Gauge Cluster NOt bright Enough
  196. Are H22 and H23 B-Pipes the same? tell me now
  197. Will this ignition coil work for h22?
  198. Weird JDM H22A problem....Can anyone help?
  199. 4th gen goodies for sale
  200. Airbag block off tray
  201. Speaker Troubles 4th gen bass
  202. Found a 99 Prelude w/ 142k miles - too high?? Potential buyer
  203. Just bought some type s pistons for my jdm 95 closed deck h22a....help...
  204. boost, stock internals
  205. walbro 255 lph question
  206. Need to verify clearances/specs H22 closed-deck
  207. mis-shift/overrev, not valvetrain noise
  208. H22A in 98 Lude-
  209. H2B swap
  210. questions for the cognoscenti about Smog and Final Drive
  211. Why Do I Get Short Gears On H23?
  212. BB6 Ground Control Coilovers
  213. any company make aftermarket mount for 5th gen prelude?
  214. Bad Clutch or is it normal??
  215. Skunk 2 PRO Series cams
  216. Question on weight reduction (4th gen)
  217. H22A Wiring Problem...
  218. is 98-01 sus. interchanable with 5th gen prelude?
  219. Sea foam?
  220. Clunking from rear... what could it be?
  221. PRELUDE --- SHOK & SPRING --- PICTURES
  222. SRS question
  223. Whats on my pistons???
  224. H22A balance shaft removal
  225. Engine Serial Number
  226. how to take off seat knob for 5th gen
  227. h22 in civic help
  228. 87 Fuel delivery problem
  229. What would you do?
  230. Question about lighting issue on JDM 1pc
  231. AC Removal Write up ?
  232. Feedbacks on Ebay crank pulley? And are they interchangeable?
  233. Loud engine(H22a)
  234. Wiring harness
  235. DRL Removal help 5 th gen
  236. AEM pulleys
  237. Using old pads with new rotors
  238. Doing a h22swap next weekend=)
  239. Help with gasket
  240. GSR vs H22
  241. need help on msd blaster 2 coil
  242. brake pad problem
  243. atts or 4ws
  244. how to install the short shufter??
  245. Prelude Headlights Adjustment??? Easy question, Please help.
  246. Need a cLutch for H22...Insight needed
  247. swap help!!!!!!!!
  248. Saturated Injectors on Peak and hold set up
  249. Nippon pistons
  250. 92 prelude si for sale...
