View Full Version : Honda Prelude
- 1st gen Prelude
- honda prelude 4th gen body kits
- balance shaft
- universally accepted 'best' turbo mani?
- Looking for 98 up prelude SH stock wheel asap.
- If you have a tanabe racing madalion exhaust, read this plz...
- I know this is a prelude board but this is impressive.....
- Lightweight flywheel, worth it?
- Help me...where can i find a driver side engine mount (93-96)?
- Rear main seal replacement, h22a1?
- holy shit check this out
- Having a lil prob...
- Honda Madness
- jd h22 lsd
- alignment...
- -HELP- Idle Up & Down, A/F Up & Down
- What cams??
- Where can i buy an H22A factory LSD?
- How strong are 4th gen axles?
- Tanabe Mid-Pipe with Greddy Evo Muffler
- WTF is this?????
- What size exhaust piping to a STOCK MUFFLER is best for daily driving? and unbolted for racing?
- EXHAUSTS, EXHAUSTS, EXHAUSTS . . . . . but jesus, which one?!
- anyone want a GReddy turbo kit, intercooled??? i am selling mine at good price
- WTB: h22 Tranny
- Is there a fuel filter on a 4g lude??
- Compression and N2O good or bad?
- 16 inch light weight racing rims
- 550cc injectors and Walbro 255 high pressure fuel pump
- ball joint trouble
- tMain Bearings?
- need wiring instructions for Apexi SAFC install on 3g lude....
- jun h22a in car
- cost of replacing a fuel pump for 4th gen H22.
- Prelude electrical design question
- The search for the Spoon rear upper strut bar is over...
- 88 2.0s head gasket repair b20a3 help??
- What size....
- Anyone with jdm lights please read
- S2000 guages in a 4th Gen...
- 1991 SR Prelude Water Temp Problem
- F22A idle
- Where to get antenna
- Dash light bulbs
- can the 5th gen suspension be bolted up to the 4th gen?
- installing projector headlights on a 4th gen prelude
- Best bobykits for 4th gen prelude
- which prelude is faster 4th or 5th generation
- Wheel Size and opinion
- engine swap pretty straight forward stuff??
- 94 Si, auto tranny question . . . .
- h23 head
- What clutch...?
- Times for the f22b
- F22b swap in my new prelude
- 4th Gen Interior Sale
- h22 w/jun3
- New enginge ... broken crank shaft
- whats the diff. sh and non sh
- Camber Wear... how long will my tires last?????
- WTB h22 crank
- long block?
- looking for connectors!!!!!!!
- Maxrev turbo kits
- Fujitsubo Exhaust
- question about 90-97 accord GC coilovers?
- Need help deciding on exaust system
- need website for clearing rear signal 4th
- Going 1 layer headgasket, removing balance shaft belt, and need TQ specs. Some help please ;)
- Koni Yellows??
- 96 Ecu Pinouts??
- Bypassing my heater
- want 2 clear up what headers are available for 5th gen...
- i need EMS to buy!!
- vibrante headers
- hp and tq?
- 3rd gen help need help on taking the main fog lights out??
- fear the b21a1
- Need F20B info....Satan, others advice requested ASAP!
- Are Prelude's RWD?
- koni installation$$$???
- More N20 questions
- slight hesitation in second gear 95 H22
- Midwest Prelude Fest '03 - Aug 17th
- whats is ATTS???
- In search for low end for the H22...
- how do you tell if its an SI
- Greddy header on a 5th gen?
- who has foglights on there 5g?? i need the peices that go where the foglights would go
- 4th gen Exhaust systems.... need ur help guys.
- JDM fog lights
- Hondata??
- Prelude Type SH and turbo...
- How to remove Crank Pulley with motor sitting on garage floor?
- found it!!!
- Timing belt - dealer/shop or myself?
- 95 Prelude H23 vs. 2001 Civic SOHC....HELP!
- Preluder, What do you want?
- FS: 5th gen Prelude JDM fog lights w/ USDM fog light switch
- screeching sound?
- 5th gen SH or S2000
- how to improve handling on 5th gens
- Todd or Mike any updates?
- Seems weird, but truth
- Clevite main and rod bearings?
- soon to be without my lude =(
- NYC area need Front end of 97+ Ludes for there Brakes/spindles
- Just bought my first prelude today!!!!
- msd digi. 6 users....what did you hook up the 2 step wire too?
- H23 Manual Tensior
- ATTS Fluid Change??
- CEL? O2 Sensor? Whats goin on here?
- cel ?
- H22 turbo manifolds
- RS*R Exhaust
- Tire Question
- What are the knock-offs called.......
- Bought my Prelude Yesterday!
- advance timing how to?? is it easy to do?
- Rebuilding Bottom End: What else?
- hytech header?
- You guys seen this kitcar?
- Aem intake cleaning??
- Tanabe Racing Medallion axle back for 5th lude
- 1rst gen ludes: I WAN'T YOU (need to contact)
- Car surging rpms!@!@!@
- Apexi vtec controller or whatever...
- s2000's and ludes
- how to remove ps belt on a 4g lude?
- erebuni kit #179?
- Best Engine Buy ?
- People who have removed their AC system!!
- h22 skunk2 intake manifold???
- New here, need opinion on H22A parts
- OT:gumball or not gumball??
- SERIOUSLY... 5th gen "air conditioning filters" where do they go????
- will this work?
- Yay! got new bulbs and Hyper Ground System in
- 98 Prelude SH on Ebay...
- SH, location..
- Finally got the lude dyno'd
- Can the H23 injectors fit a F22B engine??
- what rotors
- I'm getting annoyed. I feel like my car is so slow
- FS: MOMO, JDM, Mugen, APEX, Recaro, 5zigen, Personal STUFFs FOR DC2, DC5, EK, EG
- prelude/integra meet in kc
- exhaust header?
- Parts for Sale, 2001 Prelude
- Legend Calipers? or NSX..the Legend has larger piston?. interesting
- 2000 injectors in a 96 prelude?
- check out this prelude
- Making a digital speedo for my prelude
- greddy header???
- 5g oem kit + mugen exhaust
- Check engine lights
- KYB AGX settings..
- JDM 4G CEL & TCS faults ?
- Relocate battery to trunk
- Tail light question?
- junkyard h23 into my ek?
- How to set timing to stock?
- Bigger turbo: 14B or T25?
- Starting a Prelude project car...
- turbo timer
- engine code question
- 97+ dashboard & console into a 4th gen
- anybody want Cruise control unit ????????
- Need Help VAFC
- will SH shocks/struts work on a Base model???
- Will a stock p72 with no modifications run h22?
- Speedometer readings on a 4th gen
- OEM Body Kits
- anyone need bumper and sides?
- 1rst gen lude need download owner's manual
- Engine Identity/ B20 for $150!!!
- check engine light?
- mycar is ....
- Back from Vegas
- which brand of muffler make noisy sound???
- brake problem????
- Any 4th Gen Prelude's with shaved door handle and the AutoLoc system?
- 97+ wheel offset?
- When talking about wheel size......
- Whats the deal with KONI shocks saing not to use Eibach springs??
- need to download 97 manul
- Oil Pan Gasket
- OMG, so OT <--- Pedal Blocks
- 92 si, how to a take out the back seats?
- nitrous help..............
- H22 and 4th Gen Prelude parts for sale.
- Any tips on painting cars
- cooling fans not operating
- dash lights
- 5th Gen Greddy Evo Catback on a 4th Gen SRV
- need help with i/c sizes for 4th gen
- can't find the ECU
- Wheels, tires for the 84
- aftermarket oil pan options
- Tranny Problems!!!
- help
- 98 Prelude with ECU Problems. Please HELP!
- 5 gear rpm speed????
- h22+87 oct. = bad?
- How much should I expect to pay for an H22 swap into my 92 Lude??
- OEM Shift Boot
- h23 or h22 tranny??
- mods for my 4th gen Si
- VAFC setting with Walbro 255lph
- intercooler sizes
- best turbo manifold?
- Since Todd is getting all the attention, I feel left out.. (pics of the FAST prelude)
- Gumball FEVER!!!
- Gauge lights? - or how do I change green to white like the new TSX?
- Prelude Meet!! Over 50 ludes and counting
- wheel selection...
- N20 Refill
- Accel thundersports wires any good??
- quick question about i/e/h
- Fusebox question
- FS: 2000 Canadian Prelude SH wheels w/ red centercaps
- 1994 jdm prelude cluster
- Spoon Lip ON A 5TH GEN!
- Which Turbo?
- Pictures Of My Lude
- hotshot 4-2-1 5th gen headers, ETA May (supposedly)
- Concerned- Blowing smoke when hitting VTEC
- Oil pump durability
- Help Help! 4th Gen Code 43
- wanted: distributor for a h23a non vtec please
- Bumper and sides for sales for a PRELUDE
- Why does the H22A Block need to be resleeve?
- Will the AEM short ram and CAI for a 97-02 prelude fit a 92-96
- Anyone with Pics of 18"on a 5th gen
- Help! 90 Prelude Si Oil Leak from Hell
- 4TH gen vafc hack
- Motor rebuild time - looking for suggestions on lots of stuff
- has anyone seen the black face Apex'i EL gauges in person?
- h22a's for sale
- electroluminescent Gauges! upgrade
- Timing Belt and Water Pump Change on an H23. Suggestions Please !!!
- how to wire woofer to deck in 4th gen?
- Need part number for tail light bulb
- 92-96 Honda Prelude VTEC Ignition Coil for sale quote:
- I have no idea... do you?
- Sun (Moon) roof 99 Prelude
- Honda Commercial
- how much retard w/80 shot?
- Test pipe question
- Prelude CEL codes
- what to do?
