View Full Version : Honda Prelude
- Euro R intake manifold Gaskets
- Mazspeed oil coooler fitment
- Serious vibration problem
- shakes hard when i brake
- Some 4th Gen questions from a new owner...
- Skunk2 Pro 2 and Type S pistons
- Idle Problems
- H23 ARP MAIN studs + F20A = OK ?
- I need some serious expertise here
- Speedo broke, but dont think its the vss
- stock piping size on 5th gen
- prebent h23 piping
- Some help on CEL Codes
- !!!- Need Tips on how to get a Greddy Evo2 Exhaust System to fit my H23a1 -!!!
- Meets?
- stock amplifier in 5th gen.
- Is this Turbokit crap?
- JDM 4th Gen Prelude steering wheel.
- low idle....engine dies when stepped on throttle in neutral!
- leaking problem...
- h22a tranny
- S2000 exaust
- How to wire resister box for h22 with dsm 450s????
- 4th Gen Projector Headlights-What's up with the high beams?
- Difference in exhausts for h23 and h22
- Fuse Box Diagram
- spraying nitrous on a h22a4 in a accord
- Jackracing Supercharger on a Prelude SH
- Taking off the butterfly plate
- Rear Channel Speaker (Amplified Subwoofer)
- Does anyone have a sales brochure for a 92?
- h22 build wish list help
- MY CAR WILL NOT START!!
- belts squeaking
- where can I get a 6X20 bolt?
- How much would a shop charge to fix a leaked rear balance shaft seal on a 97 SH?
- greddy turbokit in an sh?
- Oil for 97 Prelude
- **3rd Gen Prelude**
- new megan rear camber kit... looks good
- DGI harness bar
- Chrome and VAFC
- Not Tech: but wanted to thank you guys for all the support
- H22 head comparison 92-97 to 98-01
- what do you think of this h22 header?
- h22 tranny fd?
- H23 Vtec... IAC problem
- 98 honda prelude for sale, IT NEEDS TO GO!!!!
- Car misfires, stalling, and die. Need advices.
- adjusting 4gen hood
- High Flow cat?
- 4th gen. Aero Magic front lip. *Reloaded*
- 94-96 Console in a 92??
- i need help with my lude's idle!!!!!!!!!
- 5 Lug Conversion
- Couple questions
- Purchasing Ecu for my jdm h22a automatic for my 92 honda prelude si
- ignition sparks....need help
- idel control motor
- timing belt cover?
- looking for harness
- Who is the idiot that thought of the ATTS system?
- Rear Airbox Hose question. 91 Prelude SI
- car won't go in to gears ??????????
- 5th Gen PROBLEM PLEASE HELP!
- 1994 type s, engine blown
- help guys with this question
- f22b engine emissions.
- Cams or exhaust QUICK!!!
- 2 different throttle bodys? trying to make sense of the engine i just bought
- JDMSHIT lips
- Prelude ?
- VTEC starts choking.
- Free mods lol but will i throw a code
- timing problems
- RHD Prelude SI 4 Sale or Trade
- RSR exmag catback for Gen4
- UK 92-96 gauge cluster question
- h22 valve springs in b16 b18 heads????
- changing tranny fluid
- Code 71
- engine shipping price?
- Read the stickies cant find the answer
- service manuals
- Knocking noise
- turbo manifold for 3rg gen
- Any Luders with a JDM/EDM rear foglight??
- Service connector location 5th gen
- Question about OEM muffler, aftermarket piping......
- Cold weather I have to jump the starter solenoid to get it started, how to fix?
- Need info on Prelude
- Flywheel help!!!!!!!!
- What would you do??
- stereo says code
- a question?
- Any Prelude Clubs?
- Rear Wiper Arm
- Tuner toys any good? **Searched**
- Quick, HELP!. crower stg 3 cams
- once my car is warmed up my idle will drop to the point of almost shutting off then bounce up again
- i just found a leak but cant tell where its coming from...
- help! Power steering problem... Power Steering fuild keep overflowing, faulty value somewhere?
- h22a vtec injectors
- nasty oil leak
- Car Running At 1/4 Temp During The Winter.
- Short shifter ?
- lovefab manifolds questions
- coolant leak 4th gen
- installing 4th gen forbidden short shifter
- Chicago 5g Prelude owners..I need your help
- H22/H23 auo trans?
- bad dizzy?
- Car wont start problem, blah!
- help need harness
- stock h23 camshafts
- Help with Radio Wiring
- Life expectancy of an H22A4?
- Confused to this..help me out (ATTS and Tranny Fluid)
- Anybody running a drag radail daily?
- USDM H22A4 Vtec Solenoid vs JDM Vtec Solenoid
- found the leak!! but what is it?
- Help: clutch/ master clutch cylinder
- h23vtec questions SEARCHED
- Emission Warranty Extension? Is this offer legit?
- Radiator fan doesnt work?
- HELP: Check Engine Light Came On!
- HELP Turbo for 93 H22A
- Oil All Over Valve Cover
- not your typical swap question!
- Door Lock problem
- TWM ITBs for a street car?
- multiple dash checklights 92 si vtec auto
- will all the motor mounts from a h23 fit a h22??
- engine build
- Need some help
- h22 vs h23 tranny
- Radiator coolant line
- turbo setup - suggestions?
- exhaust advice: (searched)
- ....Finally got my graphs up - crower3 h22 dyno
- blown motor. should i buy it?
- bad axle.. driveable?
- Scratched glass
- Swap Help
- Best Daily Use N/A H22A Setup??
- Steering column question
- new exhaust
- head bolt are killing me
- H22 wont start when it's cold... just cranks and cranks with no fire. *searched
- What The expletive!!!?? Someone help ME!!! Check Engine/ATTS Light came on...TWICE!!!
- skunk2 H22 intake manifold
- Unbalanced Tire or What?!?!
- I Can't Get The Shifter into Gear
- Having hard time starting, Rough Idle, and black spark plugs...
- Drove an 06 TSX in comparison to my 97 SH
- will h23 DISTRIBUTOR work on h22??
- i got a question there r 2 pulleys on the h22 which one is which???
- max psi on stock injectors
- Upgrade 91 prelude ecu
- Burning LOTS of Oil – Oily Film on Trunk and Rear Bumper
- dash light question
- balance and blueprinting
- H22a4 fuel pressure at fuel rail?
- i want more torque on my sh
- steering making very bad creaking noises
- need advice on turbo lude set up
- the check engine light that won't go away
- need clutch help fast!
- No Start Help
- axle installation
- hondata vtec and fuel maps
- Prelude AutoTransmission Help
- Burning LOTS of oil - Prolong Engine Treatment - Check this out...
- Clutch Damper?
- HELP H22 vtec wiring to ecu
- 98 lude. random deadness
- find a ECU
- Dealer for USDM Parts (for JDM TypeS ATTS)
- Pic Request: H22 Engine Cut-a-way
- ATTS/Check Engine Light
- 2 preludes?????????
- H22a Vtec Ecu wiring
- H22a hatch idles
- 1991 honda prelude si vs. 1997 honda accord lx
- Wierd noises after engine off and on...tap noise
- O2 sensor..will it work without cat
- headlights housing
- The right path to follow.
- Milleage gauge not moving...need help smog soon
- wtf is my cars problem
- HELP!!! 93 Si H22A Timing Issue? Won't Run Right
- H22a Cylinder head info .........check!
- Direct Port N20 + Hondata or Jacobs NM
- JDM h22 header
- o2 sensor difference in 5th gens
- After cold night car won't start in morning - no sounds at all. Starts fine in the afternoon(warmer
- Dyno today. H22a4 in BB6= 165whp.
- Oxygen sensor - switching response time for 5th gen.
- Sport Springs effects new tires and alignment?
- turbo
- Fan only turns on when car is off
- 1995 Prelude light bulbs
- Putting a new cat in my 5th prelude... any advie/tips?
- finally getting my h22a
- Need help choosing cams....
- Anybody in the Northeast region rebuild h22a4 motors?
- window problems
- Terminology
- abs light keeps turning on after i replaced my front brake pads and rotors
- Changing the Transmission Clutch and flywheel
- Check Engine Light (6 1[o2 sensor])
- Custom made intake filter box and battery holder opinions??
- chipped sohc ecu work on dohc?
- 1.8L Carb, how much WHP is possible?
- flywheel resurface question
- block damage/rebuild
- 92-96 triple gauge pillar
- 4th/5th gen shift linkage
- Megan header with 2.5 collector mod done already?
- koni suspension how many miles are too many?
- clutch pressure problem
- need some help on h23 turbo setup...
- low oil pressure at start up?
- i need help someone help me
- Codes 23 and 36,
- Help: Got a couple of problems with the car... (JDM h22 )
- Ecu Question
- New Studs
- IAC LOCATION HELP!!!
- REPSOL oil anybody?
- 4th gen shirt shifter prelude
- LSD question
- Honda Prelude SH Suspension
- dont know what model prelude i have
- more problems more money...i need help.
- Transmission/Engine Bolt Stripped
- Grinding/Rattling Sound when in gear
- Hondata On F22A1
- misfire
- Apexi World Sport 2 universal fit 89 prelude si
- Will this rub?
- Electronic Ignition Switch Question.
- H23 Rods
- Thinking of getting a new Prelude this tax season, need Recomendations.
- ???Radiator fan keeps kicking on even in -30 degree weather!!!
- 86 Prelude Q's
- prelude leaking oil need help
- Stock junkyard flexpipe or Ebay.
- Oil pressure question
- 4gen prelude headlights
