View Full Version : Honda Prelude
- very URGENT, help!!
- h22a4 weight?
- fmax install
- Your thoughts....
- dunlop sports, any good?
- Suggestions on an Exhaust?
- how bit is too big TB for N/A engine
- How fast is your prelude?
- All you JDM '92-'96 Prelude people (L.A. area especially)...look what I found for you..
- Identifying a JDM VTEC?
- Parts for sale
- TURBO question HELP!!!
- My ATTS Light came on today....help~!!!!
- Prelude Intake Manifold
- Just Got my car back still not better
- Ignition timing
- Best BRAKE SET-UP for <$1000
- valve specs on h23
- Tranny question
- spark plug gap
- FOUND out the problem why my car was shaking/bouncing haha
- what's the easiest way to reset a 92-96n/m
- ATTS Fluid Change
- Throttle rotor
- Whats a sure way of me knowing if my timing belt has been changed??
- Valve Cover Question!
- ok did my flywheel question get deleted??? well which has timing marks?
- Best Brake Fluid and Pads??
- 5th Gen crank pulley and lighting
- Prelude Oil Analysis?
- Which of these parts are worth to get?
- JDM Climate control
- Has anyone reduce the weight of there stock flywheel?
- anyone want 4th gen vtec kill & loss vids?
- Stock spring rate.
- Are we not allow to...
- i want to buy your amber bumper lenses....
- My Lude, minus the fogs...
- hand drawn prelude
- Short Ram vs. CAI
- yea this headgasket replacement looks just fun...
- b20z in a 1990 prelude 2.0 si??
- Painting Rotors???
- Need an answer about Base to SH swap
- Pics of my lude
- Where to Buy Spoon Front Lip?
- Which cam gears will fit in the stock housings without cutting?
- gasoline usage ..
- 94 H22 Tranny Question.
- should i buy?
- 94 H22 Turbo Questions
- Pic of my car....
- wtt: my 93 h22 ecu (p13) for your 94-95 gsr (p72) ecu
- H23 VTEC conversion?
- Got my block back today and got a few pics
- MAP sensor?
- Can Lude springs fit on a DC2?
- engine surging while in neutral
- Check Out My Pics!!
- Clunking front suspension
- Brake dust shields removal? anyone try this?
- JDM headlights....
- h22a1 h22a4 head gasket question
- H22 Problem
- Need help with injector cc on H23
- good upgrades for my prelude(exterior)
- Luders near and far- check this setup!
- Lamborgini Doors on a lude?!
- AEM Pullie Question
- Type S motor (does it bolt up directly to 97 SH.)
- h22a tranny code?
- need phone number to HKB
- WingsWest Kit Question??
- H23 turbo questions
- Short circuit? Fuel cut-off = bad?
- Do any body have a pic of..
- Condensation in rear turn signal.
- je piston pin
- o2 sensor check?
- Need some Nitrous help Please!
- a pipe
- Inake manifold??
- Question...about H22A Type-S and.. ?
- Spoon Caliper Special $1090 set
- where to get injectors cleaned and tested in ga?
- Got quoted for an exhaust...
- Slight hesitation at around 2500rpm
- Car's running rough, mileage went down. Ideas?
- going about spraying my wheels..?
- anyone get drag turbo kit for h22?
- anyone know good intake manifold for h22?
- need specs on prelude throttle body's
- S2K steering Wheel
- Does anyone have 18's on a 4th gen prelude
- help a ex owner
- anyone using an oil cooler?
- SH Suspension Questions????
- VAFC Gains
- "best" FPR for H22?
- fireball ignition system off of civic...
- Anyone want?
- anyone using an aftermarket TB?
- Newbie lude questions
- prelude sh shell???
- factory stereo removal question
- NOS on a stock H22??
- any people around fayetteville
- catch cans on h22's. lets see em.
- Newbie needs major help
- OT: Can anyone run a CarFax report for me please? This car sounds too good to be true...
- 84 prelude?
- Pics of the Electron Blue Pearl Preludes
- '93 lude bodykit
- Light Combo
- Aggressive cams with high comp pistons and milled head.... clearance questions
- H23 compression #'s
- Off-Topic posts...
- you guys think I should replace this thing? (pics inside)
- Can anyone vouch for iC Roger????
- mugen steering wheel
- Cam Gears
- cost to fix a door
- does automatic engine with manal transmission...
- Whats the difference in ludes?
- Clutch squeaking and drives me mad...
- In-cabin microfilter
- what brand tools?
- tire size
- converting a prelude Si to a Vtec 2.3 liter
- Upgrade S Brakes
- carbon fiber hoods for 92-96 preludes
- Turbo question, but i researched and can't find anything.
- Turbo!!
- JDM Digital Climate Control
- What is the cc on 92-96 Prelude injectors?
- Type S pistons in my 93 Vtec
- MY car makes noise when it is off.
- will 110 octane help....?
- Prelude seat question...
- Mugen Body Kit pics
- Technical questions for those of you running a Fmax turbo system.
- GSR ecu?
- got 97 and up headlights...?
- Where is the ecu located/How do u reset??
- going obd 1 with a 98 prelude???
- fuel pressure
- rear brake light keeps burning....
- Anyone here have a Hy-tech Header?
- Check engine light blinks TWICE need HELP ASAP
- Any Florida prelude owners on this list???
- ECU wire colours???
- H22A1 oil pump the same as H22A4?
- Getting into my garage... car to low! can I build anything that may help?
- Drove without a filter!
- Hello All.
- 1991 prelude swap
- I'm an oil burner; passed compression test, doing consumption test.
- i'm having problem with my transmission...wat do u think the problem is?
- the rarest color for the 97-01 5th generation Prelude
- JDM stock h23 vtec out of the Accord...
- All motor Webcam Billet cams for H22. link to classifieds section
- Which clutch for boostedh23
- Prelude Forum!
- Z , W rated tires?
- NA Engine
- I'm Running rich on gas what do i do?
- Suspension difference for the S and the vtec
- P13 OBD1 ECU the only way to go on a JDM H22a?
- 92-96 Si intake manifold
- ?s about h23/vtec (already searched)
- nos plate kit??
- engine swap into 91 prelude question
- My H22 is STILL eating cams!
- Why H22a4's Spin rod bearings compared to h22a1's
- Does anyone know if a 4G VTEC exhaust will fit a 4G Si?
- Car shaking/bouncing
- Need list of supplies to change from SH to a base engine
- Need initial V-AFC tuning tips for built all-motor H22A please
- Help from Friends Shall be Rewarded.
- Custom Exhaust
- Want SMSP header, Wanna know how much to $ save?
- are these motors useful?
- Would would be a good slow build up for nitrous now and eventually boost?
- prelude 101
- dont u think we should have a west east midwest canada etc forums
- check out this 4th gen i found on autotrader.
- A 13.5+ sec 5th gen prelude.... how can we do this?
- slow spedometer....
- Lightened Flywheel
- question about the SS H22
- stock exhaust
- Mugen exhaust pics
- tinkering with all motor ideas
- cam gear tuning?
- Serious turbo question.
- n/e one know about Drag Trubo Kit for 5th gen?
- Anyone change out their exhause tip???
- h22 into 92 si
- ATTS Problem Help!!!!!!
- help clutch install....
- Cam Gears
- What wheels....decisions decisions
- What's a good Car cover for a 4th gen?
- Need new tranny.....what will fit 94 vtec motor?
- update, almost turbo again!
- Sparco Bracket install on a torino..?
- New member question?
- face gauge install????
- WTB: H22A4 (97+ opendeck) head, complete.
- installing a turbo on a 97 lude
- jdm dohc vtec h23a?
- Is this a good price for this 93 prelude with a JDM swap?
- Injection Throttle Body Spacer????
- Greddy Turbo Kit!?
- Noob Question here
- H22 ECU Pins
- Milliing the head to get high compresion
- H22 Tranny ?
- exhaust flames
- headlights....
- Engine Sounds...
- Nitrous planning, but first...
- AEM or Iceman intake?
- NGK G-Power Spark Plugs...
- would would the limiting factor with this header be?
- Anyone running aftermarket performance valves?
- ANY 5th Gens in RTP , NC area?
- 4g prelude owners! you got to see this!!
- What did you pay to have your H22a in your 4th Gen???
- Resonators
- Please help!!!!
- Wheres the cheapest place to get.....
- Does anyone know when production of the h22 started?
- h22 in a 97 acura 2.2?
- just a simple question
- How to read a compressor map
- 4th gen tranny in 97SH (5th gen H22a4)
- Suspension questions?
- JDM H22a Owners - need your help
- 98 Types SH motor and tranny in my 92 Si 4WS???
- how much do you 5th gen owners pay for insurance?
- 4th gen side skirts
- I am SOOOOOOO pissed!
- where to drill for dp n2o on the h22 manifold?pics?
- Spoon strut braces - Worth the wait?
- Intake Manifold...
- yes, i know it's OT, but i found myself in a pic online
- resleeved block???
- anyone know of a good place to buy a SS H22 swap?
- question about Carbon fiber hoods
