View Full Version : Honda Prelude
- Compression Test Results, What could it Be? 2000 Prelude
- Temp Guage
- I need to know....
- Swap Installation Help/Drive Shaft/Oil Pump
- Radiator Fan switches not working
- i need these!!
- lug nut set...what size?
- Just picked up a 96 Prelude S
- '99 Prelude Power Steering Problem
- Pic Request: Tenzo DC-5 or DC-6 on Prelude
- Requesting Pics of H22a
- Where to start....auto-manual swap?
- H22a p28 ecu
- P13 OBD2? F22a1? or H22a1?
- Relocating Battery.
- HYtech HEader
- clip removal techniques ^_^
- Shifter Bushings
- need help again....
- Cylinder Head Gasket Kit
- Confused about HID installation.
- need yoour help
- Engine won't start- strange things happen- help
- heat shield for headers
- 92-96 BB4 oem hoods???
- Timing Belt Manual Tensinor conversion Look
- 5th gen projectors
- p28 ECU with s300 on IAB,s
- Cam suggestions and other suggestions.
- Excessive Carbon Output
- old school preludes.. post them up!
- Camshaft Swap
- Radiator question
- noise from tranny
- vafcII
- Installing H22 with turbo in 91 honda prelude
- Rebuiding calipers?
- Muffler expectancy?
- header installation
- upgrade my radiator??
- 01 white on black type sh
- Looking for a DD?
- Steam Coming From Oil Refill
- Custom headliner?
- Firewall questions ~ thx
- code 43, 92 prelude please help!
- KaizenSpeed BalanceShaft eliminator kit ....issues ??
- Idle Bounce with coolant line LOOP
- Auto ECU Question
- quick, easy, simple question about fuel injectors
- Suspension Question.
- low/slow oil pressure?
- Idle Problems ???"IACV"???
- checking cel
- location of oil pressure switch...
- Chipped Crank Pulley to replace Unorthodox one
- ***97 SS TRANNY ISSUES HELP ANY SUGGESTIONS***
- Installed Euro R and Innovative Mounts now Cooling/Grounding problem?
- I'm In Need of Serious H22A Help!!! Please!!!
- Defi-Link VSD Concept
- Vtec Wiring question
- throttle body question
- need help....h22a.....from wat vehicle...
- Oil Leak
- Timing Belt
- Oil after startup
- clutch or transmission problem
- skunk 2 intake manifold or euro r
- Gas brand preference, and does it matter?
- How tight should timing belt be?
- How to replace Idle Air Control Valve 1991 Honda Prelude
- butterfly valves + boost = bad? (searched)
- weird problem help????
- bb4/1 tie bar fit bb6?
- What Bolts/Studs to use when you remove butterfly plate?
- Just wanna know....
- Finally Got a Prelude
- Parts Needed in Canada
- problems with JDM foglights
- automatic Tuning
- Why does my oil light flash?
- 93 prelude
- idle problems are giving me hell (and making me broke)
- 5thgen window trim part # request
- 3rd gear grind at higher speeds???
- Tachometer Reving!
- how to check check engine light 92 lude
- My G/F just bought a BB2
- H22A Euro R miss in certain RPM Help!
- Engine bogging: need some input!!
- nsx caliper upgrade
- Buying eBAY OEM LIP or 2loww auto
- can i get your input on something?
- CrowerCams on Auto Tranny
- Improvements?
- do I need for 75 shot zex wet 2000 prelude
- transmission problem.
- clutch help!!
- 2000 Prelude Shift Knob
- Interesting info black bumper recently
- Wrench for Ground Control
- Faulty Transmission Install
- Possible problem. Please Help.
- prelude h22 auto tranny replacement question f22?????
- picture request....4gen on tein s-tech springs???
- help. honda prelude 01 no key
- Quick Question?
- Should oil come out of hole where Dizzy meets Head?
- Distinguishing Type SH from Base
- Who makes Shock absorber for SH model?
- Distributor and fuel rail conversion
- What kind of strut bars and sway bars are you guys using?
- steering wheel into bb6...
- eBoost2 - Not good for Honda?
- Transmission removal
- Wire harness off h23a1 will it fit h22a
- expletive ME!
- Evo 2 or SP 2
- larger throttle body? any TRUE dyno resluts?
- Why does my car idle so much?
- Anyone wired msd8982 start/retard box and msd8969 digital window switch to a zex wet kit
- passenger window not working
- 5gen Short shifter test
- built h22a (smokes on cold start)
- JDM-H22A Engine sputters when cold, after it's warm it's fine!
- What engines can i swap with the one in my 1991 honda prelude?
- My Cherry Picker just bent in half and my engine is half out the chaisis
- 99 pralude burning oil help
- 94 4ws lude Rare?
- OMNIPOWER Adjustable Upper Control Arms for Prelude..Happening NOW!
- Thoughts on this jdm rhd plelude for sale
- knock sensor
- removing back seats (searched)
- Removing Driveshaft
- Intake Manifold Help, Please!
- F20B Throttle Body
- My 92 EG h22a jdm swap.
- Pro 1's or 2's
- honda problems );
- HELP ordering tranny parts
- sk2 Intake Manifold
- What has 8 arms and likes to turn wrenches on Sunday Afternoon?
- exhaust
- the question of h2a8 tanny!
- Starting my swap today, just going over a tool list I might need.
- Will the H22A OBD2 dizzy fit on my 96 H23
- Strut Rods
- IDoes Mahle coated pistons really works???
- Won't go into gear
- vtec wiring...
- Weird Electrical Problem!
- anyone want a "write-up" automatic > to > manual transmission conversion
- 255hp intank?
- Temperature/Muffler menz
- Catback Exhaust Installation
- does this block looked sleeved
- What do you think about Red Tops
- Need Help
- What is this part called? and how do I fix this...
- p0112 cel problem, need help
- front derfroster?
- Removing FITV routing lines?
- Koni: Moving Clip up while installed on Car
- Crower Stage 3 cams
- koni yellows on type-sh
- Help - what is this component? its leaking..
- 4th Gen Parts & 95 H22A Parts
- f23 clutch/flywheel work in an H22?
- Low compression help!
- Crank Pulley timing gear
- Cat. converter question
- cam question
- 4th gen. carbon fenders......
- 5th gen immobilizer removal?
- passwordjdm BOO!!! help me find the right ECU
- I want to know what I should do with this 4th gen? (upgrades)
- "B" type-S pistons in "A" bore h22a block
- 99 Prelude SH needs some help!!! ASAP
- Questions about a (different) Prelude swap.
- auto to maual tachometer
- Trying to find a specific Prelude....
- s2000 pedal assembly swapped into a 4th gen prelude possible?
- car cranks but doesnt fire up
- please help me fix car
- Exhaust tip sticks out too far?
- Engine overheating
- 1997 Prelude Tranny Problems/Questions
- 2000 prelude How do I remove and install spark plugs to check after nitrous run
- Shipping question
- No more Cavaliers for me, I got a 1993 Honda Prelude VTEC, but I need some help...
- 2000 Prelude 75shot zex wet kit little help
- new to ludes and have a question
- Compression test results: Still Smoking?
- Header-Prelude
- turbo mani. keeping ac and ps
- Possible Engine Damage
- 97 prelude stock with H23??
- burning an awful lot of oil...
- Question about the Canadian Prelude SE
- How many miles do you get on your prelude? whats your cost per fill up?
- Aftermarket Steering Wheel Install Guide?
- Fuel Rail diffrences in H22 and h23
- Quick! I need to find some front and rear motor mount inserts for 2001 prelude
- H23 rotating assembly in H22 block
- please help me!!!!!
- AC pulleys and power steering pulleys
- Power Steering Pump on H23a1 compatiable with h22a?
- my shifter shifts very rough
- Getting 220 LBS torque on a 150lbs torque wrench crank pulley
- tranny problem or what else?
- Engine Light On... but no engine problems! Gen 4 Prelude, Vtec Auto. Japanese import.
- Wont accelerate over 70???
- What should I do for my 100k miles tune-up????HELP~~!!`
- Lacking power?
- 98vtec's h23vtec - 215whp/178tq - 13.43@103
- auto/manual halfshaft diffrence?
- h22a4 oil pan
- KMS Engineering ?
- 2000 SH..Blown motor.. Need Help Type S engine in SH model
- 1997 JR Supercharged Prelude Swap JDM H22A In. PROBLEMS!! PLEASE HELP
- Problem- car jerks at steady RPM
- 92-95 h22 in a 98 lude??????
- Identifying Crower stg II..?
- red and black battery cable question ha. help me!
- Vibrations
- injector question
- No sound...
- crankshaft pulley spinning wiggly
- what u think?
- car vibrates when I put it into drive.
- F1 Racing Stage 3 Clutch & 8lb. Flywheel
- Civic Rad + Slim Rad Fan Question
- H22 trans problem!!
- question about h2b
- valves....size and material
- h22 rod strenght?
- knife edging
- flywheel choices
- Vibration @ Idle... I've tried many things
- Vafc II Questions
- 93' Lude Hunting Idle?
- Question on h22a1..
- heat control light
- Would the 5th gen SH system work in a 4th?
- high pitched sound
- ok i know im stupid...
- problems with el fuel temp panel
- h22a jdm engine issue?
- Engine swap
