PDA
View Full Version : Honda Prelude
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 [246] 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320
  1. JDM H22A1 Redline?
  2. jerky cruising
  3. best prices on mugen header 5th gen
  4. new greddy header for 5th gen any info on gains?
  5. momo hub for 5th gens?
  6. Please tell me all you know about stock 1999-2001 Preludes
  7. car help
  8. pros and cons
  9. Moisture in headlights... Any tips on getting rid of it?
  10. 5 speed swap for 5th gen prelude
  11. Test pipe
  12. Fastest ETA going Natural Aspiration ON A PRELUDE
  13. My turbo done and tuned
  14. aftermarket master/slave cylinder
  15. JDM headlight Vs. USDM Headlight
  16. post up pics of 92-96 w/ slipstreams !!! woo-wooo
  17. using p28 (intake runners??)
  18. pros and cons of a type s intake and a AEM CAI
  19. What did you aka. your car get for christmas?
  20. H23 Head Specs...
  21. Fuel pressure dropping off before engine start-up?
  22. 5th Gen Lude on a Balanced Diet
  23. timing belt jumping time. help plz
  24. little exhaust question for yall
  25. shock and spring install
  26. woot! i threw a cel
  27. ECU Code 61 in a 2000 Prelude? Anyone know what it means?
  28. Where to put the Oil Gauge probe??????????
  29. pix of my prelude flame away all opnions welcome
  30. V-AFC settings?
  31. 5th gen Prelude LEATHER seats
  32. cold shift prob[tranny gurus]
  33. Performance Exhaust
  34. performance ? on mufflers
  35. Massive Clutch Problems
  36. Lock Locking Adjustable Cam Gears
  37. is this the VTec model?
  38. after getting big whp how about traction
  39. I apologize if this is a dumb question
  40. Enter here, thee whos knows the ancient secret, of...
  41. best performance rims
  42. what is 4WS? edit: [ searched everywhere ]
  43. anyone with an h22 direct port?.
  44. LSD Question
  45. Car acting funny (but in a good way)
  46. Prelude Fog Light Bulb Question
  47. Can I run my H23 engine using a JDM H22 ECU??
  48. Accord lowering springs on Prelude ?
  49. EGR valve help.
  50. ..::H22 / H23 Head Work::..
  51. super charger header
  52. power steering pump prob
  53. Just stripped my car yo!!
  54. things to look for in a h22a
  55. H23 Manual tensioner conversion for H22
  56. Turbo done!
  57. VTEC>>>>>>>>>>
  58. GM SyncroMesh part #!?!?ASAP
  59. front lights on 5th gen
  60. Coolant drain plug on SH Head Location??
  61. BB1 ECU P13
  62. Are ALL F-series motors open deck?
  63. brake fluid for clutch?
  64. therd locker on fly wheel
  65. drain bolt!!?
  66. ecu mounting
  67. Tranny work and question about LSD
  68. removed atts on 97 SH
  69. oil leak problem solved
  70. Code 74 misfire in 4 cyl
  71. 4th gen steering/allignment question
  72. Need a new battery...which kind do you recommend?
  73. does anyone need a 92-96 front bumper
  74. Best mid price header, and exhaust to get for my 97 base.......
  75. stock radio output????
  76. Looking for educated guesses on my projected WHP.
  77. Stock JDM H22 Injector size?!?!
  78. For Some reason my heater does not work....
  79. problems installing ground control coilovers
  80. Cradle Installed!...and looking good! (56k Beware)
  81. BOV routing
  82. important ? on helms mani
  83. Can a 2001 H22 head fit on a 1992 H23 Block??
  84. Momo Shiftknob..
  85. upper pillow mounts?
  86. honda H badge
  87. Help me to find a blueprint/drawing of a headgasket on H22A
  88. big bore Throttle body
  89. internal coil to external coil conversion
  90. ultra-lite or lightweight?
  91. how big to go with a throttle body for turbo
  92. Which clutch for 210 whp
  93. Any body work guys here? Picked up a dent
  94. Smoke, smoke, and more smoke
  95. wtb: OBD2 cat, and 98+ manual tranny
  96. h22 on h23 tranny????
  97. finishing up the turbo, have a few Q's
  98. wheres the fuel pump fuse?!
  99. AEM power pullys and DC header
  100. Prelude Turbo Completion
  101. H22 JDM Distributor and Oil pan
  102. how many amps is the stock alternator?
  103. Clearing Corners
  104. driving w/ snapped alt. belt
  105. Turbo preludes....how long has yours lasted......mileage, years etc...post
  106. Official H22 Header Dyno Testing
  107. 4th Gen Antenna Part #
  108. Need some good advice PLEASE!
  109. are these headers the same
  110. Oil Pressure readings on your Vafc
  111. vtec controller setting
  112. Weight addition...
  113. H23 to JDM H22A SWAP PROBLEMS
  114. I need a down pipe any suggestions????
  115. alternator problem
  116. 89si lude....won't go into gear??
  117. B Pillar Harness Bar for 97+ Preludes
  118. 92-97 H22 block and 98+ H22 block differences
  119. FUEL CUTOUT??????????????
  120. 88 LUDE IDLE ADJUSTING SCREW
  121. what is recommeded to reduce understeer in the 4th gen vtec lude?
  122. Apexi exhaust gaskets
  123. anyone with WW kits on their 5th gen lude?
  124. avg. going rate on the 5th gen timing belt change...@ dealer?
  125. Best headlight bulb to buy for my 97 Prelude?
  126. Engine light on and stays on til I turn car off and back on - 93 JDM Lude
  127. H23 with H22 VTEC head - how to and expected power rating?
  128. H22A in teg ?'s
  129. Ticking noise from the cams,sprocket, or timing belt area
  130. coil-overs
  131. need help! running wires/switches from engine bay to drivers side comapartment! help!
  132. Another hard question for the Honda tech gods.
  133. H23 main caps??? someone had some for sale
  134. 92-96 Prelude Best exhaust
  135. limits of 450cc injector for boost
  136. car idles rough in the morning
  137. Help with shops that can build motors
  138. H22 into a 1992 Prelude SI
  139. vss question?
  140. Why do you like your preludes, what made you get one.
  141. type s connecting rods ARE different than USDM, right?
  142. What to do with installing a IAC valve
  143. Good place to buy a 5 speed?
  144. Recaro SRD seats for the Preludes
  145. 97+ lude with a greddy front lip
  146. Greddy SP exhaust for $352 a good deal? (92-96)
  147. roof scoop
  148. prelude seats?
  149. h23 w/ 60 shot of n2o dyno graph
  150. $400 oxygen sensor? $1200 clutch? Help!!
  151. 5 speed tranny question
  152. IMmobilizer removal? any one got a 96 prelude h22a ECU>?
  153. Resleeving: H23, price?
  154. modding question
  155. what coils for an 89 lude?
  156. Any other Prelude sites with good information?
  157. Camshaft rubber seal..camshaft needs to be removed?
  158. Scatter Sheild?
  159. Good crossed drilled rotors for not too much$ ?
  160. Definitive JDM folding mirrors wiring / install guide into 4gen prelude
  161. 3 gauges. Where?
  162. bogging/stalling problem
  163. oil leaking
  164. Distributor. aftermarket ignition w/coil
  165. Need help for all motor.
  166. AEM c/a/i cleaning?
  167. I've searched and searched on various sites for this answer
  168. Getting my JDM H22 rebuilt. Should I have any work done to the valves??
  169. loss in top end power
  170. V8 Sounding Exhaust...
  171. How do i get my stock cd player out of my 97 Prelude?!?!?!
  172. Jun Racing built motor
  173. Any one know the cc's on a 96 h23 fuel injectors??
  174. Rim offset on a 97 lude?
  175. what type of supplies for swap???
  176. Any one tell me where the map sensor is on a 4th gen h22?
  177. Front bumper removal? problems....need help quick! thanks!
  178. lumpy idle with lights on.
  179. Where to chip?
  180. WTB: junk parts, blown blocks, tranny casings etc - mod approved
  181. WTB - Prelude H22a Specific
  182. What size bolts are used on DC Sport SS Headers?
  183. sny one have battery relocation tips?
  184. Need a 4gen jdm folding mirrors wiring diagram!!!
  185. what size are h22/h23 fuel injectors
  186. What models have...
  187. Heater Hose Size? Can it be capped off at the block?
  188. Skunk 2 im released????
  189. Pics of N1 and sounds?
  190. is PO.com down right now??
  191. mitsubishi turbo on lude
  192. triple guage pillar
  193. DIY: Tranny Install?!?!?!
  194. National Prelude Meet
  195. what color is this?
  196. what transmision do i have?
  197. searched...base 97 prelude times?
  198. NEED HELP!
  199. Steering Problem
  200. Stuttering
  201. Anyone use a Jay's Intake on a H22?
  202. 92+ goodridge brake line......opinions/others
  203. question about short shifters??
  204. difference between JDM and USDM engines/what motor can I put into 90Si
  205. SOme needs to make a prelude to accord swap guide....Like a 5th g swap etc
  206. Size of stock ignition wires ???
  207. I need some opinions on why my motor locked up.
  208. New to forums - '88 Prelude Motor swap?
  209. Engine Code 71 help
  210. Cooling shroud 2
  211. what series is the second gen lude motor.
  212. What should i do next??
  213. 4th gen lude gas door wont open
  214. SH owners with GC/Koni setup! a few Qs, lease read.
  215. Just got 5th gen? what problesm to look for?
  216. difference between ECU's
  217. Well since I have the flu.... here's some pics (56K NO WAY)
  218. VITEK LSD
  219. H23A Vtec (from 99 Accord SiR-T) NOT hybrid..
  220. 98' Prelude Automatic Owner Needs Help...
  221. how can i tell the difference btwn type S and h22?
  222. Help me decide Go Supercharge or Stay NA
  223. How to set balancing shafts? Which wires to add for VTEC...
  224. Tensioner help
  225. 00 Prelude on the bottle
  226. Part number for H22 alternator?
  227. Gas Mileage..
  228. Prelude Spoilerless Pic Request
  229. Can adjusting valves make u burn oil?
  230. Fog light part number
  231. idle is terrible what is wrong
  232. BAD IDLING HELP
  233. Quick question on ES mount inserts
  234. What are the benefits of putting Type S pistons in a JDM H22??
  235. Valve float?
  236. wierd idle/stalling
  237. Silencer For Exhaust *Searched*
  238. Base map for haltech E6K or E6X
  239. is it worth it removing the balancer shaft on 4th gen ?
  240. axles and tranny problems on 4th gen? help
  241. how do you make all your mounts solid?
  242. New 4th gen tranny...
  243. bearnings spun or spung
  244. 4th Gens at Spa Francorchamps F1 circuit (Belgium)
  245. Air Conditioning Filter ???
  246. What would cause an engine to stop idling?
  247. Coilovers for a decent price
  248. buy my wheels..anyone??
  249. Can i swap heads
  250. TURBO PRELUDES
